[Liblas-commits] libpc: "using namspace libpc;
" -> "namespace libpc {..."
liblas-commits at liblas.org
Fri Feb 11 15:11:41 EST 2011
details: http://hg.liblas.orglibpc/rev/ab124c3d43e2
changeset: 39:ab124c3d43e2
user: Michael P. Gerlek <mpg at flaxen.com>
date: Fri Feb 11 12:11:37 2011 -0800
description:
"using namspace libpc;" -> "namespace libpc {..."
diffstat:
src/ColorFilter.cpp | 5 ++++-
src/Dimension.cpp | 5 ++++-
src/FauxReader.cpp | 6 +++++-
src/FauxWriter.cpp | 6 +++++-
src/Field.cpp | 6 +++++-
src/Filter.cpp | 6 +++++-
src/Header.cpp | 6 +++++-
src/MosaicFilter.cpp | 6 +++++-
src/PointData.cpp | 6 +++++-
src/PointLayout.cpp | 5 ++++-
src/Reader.cpp | 5 ++++-
src/Stage.cpp | 6 +++++-
src/Writer.cpp | 5 ++++-
13 files changed, 60 insertions(+), 13 deletions(-)
diffs (255 lines):
diff -r c61d04bc7d5b -r ab124c3d43e2 src/ColorFilter.cpp
--- a/src/ColorFilter.cpp Fri Feb 11 11:51:31 2011 -0800
+++ b/src/ColorFilter.cpp Fri Feb 11 12:11:37 2011 -0800
@@ -35,7 +35,8 @@
#include <cassert>
#include "libpc/ColorFilter.hpp"
-using namespace libpc;
+namespace libpc
ColorFilter::ColorFilter(Stage& prevStage)
: Filter(prevStage)
@@ -141,3 +142,5 @@
return;
+} // namespace libpc
diff -r c61d04bc7d5b -r ab124c3d43e2 src/Dimension.cpp
--- a/src/Dimension.cpp Fri Feb 11 11:51:31 2011 -0800
+++ b/src/Dimension.cpp Fri Feb 11 12:11:37 2011 -0800
@@ -45,7 +45,9 @@
#include <iostream>
using namespace boost;
+namespace libpc
Dimension::Dimension(std::string const& name, std::size_t size_in_bits) :
@@ -161,3 +163,4 @@
return dim;
diff -r c61d04bc7d5b -r ab124c3d43e2 src/FauxReader.cpp
--- a/src/FauxReader.cpp Fri Feb 11 11:51:31 2011 -0800
+++ b/src/FauxReader.cpp Fri Feb 11 12:11:37 2011 -0800
@@ -40,7 +40,8 @@
using std::vector;
using std::string;
+namespace libpc
FauxReader::FauxReader(const Bounds<double>& bounds, int numPoints)
: Reader()
@@ -106,3 +107,6 @@
return;
diff -r c61d04bc7d5b -r ab124c3d43e2 src/FauxWriter.cpp
--- a/src/FauxWriter.cpp Fri Feb 11 11:51:31 2011 -0800
+++ b/src/FauxWriter.cpp Fri Feb 11 12:11:37 2011 -0800
@@ -40,7 +40,8 @@
using std::cout;
using std::endl;
+namespace libpc
FauxWriter::FauxWriter(Stage& prevStage) :
Writer(prevStage)
@@ -95,3 +96,6 @@
return;
diff -r c61d04bc7d5b -r ab124c3d43e2 src/Field.cpp
--- a/src/Field.cpp Fri Feb 11 11:51:31 2011 -0800
+++ b/src/Field.cpp Fri Feb 11 12:11:37 2011 -0800
@@ -41,7 +41,8 @@
using std::cout;
using std::endl;
+namespace libpc
Field::Field() :
@@ -186,3 +187,6 @@
return 0; // BUG: notreached
diff -r c61d04bc7d5b -r ab124c3d43e2 src/Filter.cpp
--- a/src/Filter.cpp Fri Feb 11 11:51:31 2011 -0800
+++ b/src/Filter.cpp Fri Feb 11 12:11:37 2011 -0800
@@ -34,7 +34,8 @@
#include "libpc/Filter.hpp"
+namespace libpc
Filter::Filter(Stage& prevStage) :
@@ -44,3 +45,6 @@
header = m_prevStage.getHeader();
return;
diff -r c61d04bc7d5b -r ab124c3d43e2 src/Header.cpp
--- a/src/Header.cpp Fri Feb 11 11:51:31 2011 -0800
+++ b/src/Header.cpp Fri Feb 11 12:11:37 2011 -0800
@@ -39,7 +39,8 @@
using std::cout;
using std::endl;
+namespace libpc
Header::Header() :
@@ -128,3 +129,6 @@
return;
diff -r c61d04bc7d5b -r ab124c3d43e2 src/MosaicFilter.cpp
--- a/src/MosaicFilter.cpp Fri Feb 11 11:51:31 2011 -0800
+++ b/src/MosaicFilter.cpp Fri Feb 11 12:11:37 2011 -0800
@@ -35,7 +35,8 @@
#include <cassert>
#include "libpc/MosaicFilter.hpp"
+namespace libpc
// BUG: will generalize to more than 2 inputs
MosaicFilter::MosaicFilter(Stage& prevStage, Stage& prevStage2)
@@ -112,3 +113,6 @@
return;
diff -r c61d04bc7d5b -r ab124c3d43e2 src/PointData.cpp
--- a/src/PointData.cpp Fri Feb 11 11:51:31 2011 -0800
+++ b/src/PointData.cpp Fri Feb 11 12:11:37 2011 -0800
@@ -41,7 +41,8 @@
using std::endl;
using std::string;
+namespace libpc
PointData::PointData(const PointLayout& layout, int numPoints) :
@@ -258,3 +259,6 @@
return;
diff -r c61d04bc7d5b -r ab124c3d43e2 src/PointLayout.cpp
--- a/src/PointLayout.cpp Fri Feb 11 11:51:31 2011 -0800
+++ b/src/PointLayout.cpp Fri Feb 11 12:11:37 2011 -0800
@@ -41,7 +41,8 @@
using std::endl;
using std::string;
+namespace libpc
PointLayout::PointLayout()
@@ -179,3 +180,5 @@
cout << endl;
diff -r c61d04bc7d5b -r ab124c3d43e2 src/Reader.cpp
--- a/src/Reader.cpp Fri Feb 11 11:51:31 2011 -0800
+++ b/src/Reader.cpp Fri Feb 11 12:11:37 2011 -0800
@@ -34,7 +34,8 @@
#include "libpc/Reader.hpp"
+namespace libpc
Reader::Reader() :
@@ -42,3 +43,5 @@
return;
diff -r c61d04bc7d5b -r ab124c3d43e2 src/Stage.cpp
--- a/src/Stage.cpp Fri Feb 11 11:51:31 2011 -0800
+++ b/src/Stage.cpp Fri Feb 11 12:11:37 2011 -0800
@@ -34,7 +34,8 @@
#include "libpc/Stage.hpp"
+namespace libpc
Stage::Stage()
@@ -53,3 +54,6 @@
return m_header;
diff -r c61d04bc7d5b -r ab124c3d43e2 src/Writer.cpp
--- a/src/Writer.cpp Fri Feb 11 11:51:31 2011 -0800
+++ b/src/Writer.cpp Fri Feb 11 12:11:37 2011 -0800
@@ -36,7 +36,8 @@
#include "libpc/Writer.hpp"
+namespace libpc
Writer::Writer(Stage& prevStage) :
@@ -67,3 +68,5 @@
return;
More information about the Liblas-commits
