[Liblas-commits] libpc: move << to .cpp
liblas-commits at liblas.org liblas-commits at liblas.org
Fri Feb 11 16:35:26 EST 2011
details:   http://hg.liblas.orglibpc/rev/7cf817acffe3
changeset: 40:7cf817acffe3
user:      Michael P. Gerlek <mpg at flaxen.com>
date:      Fri Feb 11 12:20:09 2011 -0800
description:
move << to .cpp
Subject: libpc: added Schema (from liblas)
details:   http://hg.liblas.orglibpc/rev/9bce9c5cf461
changeset: 41:9bce9c5cf461
date:      Fri Feb 11 13:35:19 2011 -0800
description:
diffstat:
 apps/pc2pc.cpp              |    6 +
 include/libpc/Dimension.hpp |   26 +-
 include/libpc/Schema.hpp    |  187 ++++++++++
 src/CMakeLists.txt          |    2 +
 src/Dimension.cpp           |   26 +
 src/Schema.cpp              |  796 ++++++++++++++++++++++++++++++++++++++++++++
 6 files changed, 1018 insertions(+), 25 deletions(-)
diffs (truncated from 1103 to 300 lines):
diff -r ab124c3d43e2 -r 9bce9c5cf461 apps/pc2pc.cpp
--- a/apps/pc2pc.cpp	Fri Feb 11 12:11:37 2011 -0800
+++ b/apps/pc2pc.cpp	Fri Feb 11 13:35:19 2011 -0800
@@ -15,6 +15,7 @@
 #include "libpc/version.hpp"
 #include "libpc/Bounds.hpp"
 #include "libpc/Dimension.hpp"
+#include "libpc/Schema.hpp"
 using namespace libpc;
@@ -42,6 +43,11 @@
         std::cout << dim << std::endl;
+        Schema schema(ePointFormat0);
+        std::cout << schema;
     return 0;
 #if 0
diff -r ab124c3d43e2 -r 9bce9c5cf461 include/libpc/Dimension.hpp
--- a/include/libpc/Dimension.hpp	Fri Feb 11 12:11:37 2011 -0800
+++ b/include/libpc/Dimension.hpp	Fri Feb 11 13:35:19 2011 -0800
@@ -298,31 +298,7 @@
-// BUG: move this implementation into .cpp file
-std::ostream& operator<<(std::ostream& os, libpc::Dimension const& d)
-    using boost::property_tree::ptree;
-    ptree tree = d.GetPTree();
-    std::string const name = tree.get<std::string>("name");
-    std::ostringstream quoted_name;
-    quoted_name << "'" << name << "'";
-    std::ostringstream pad;
-    std::string const& cur = quoted_name.str();
-    std::string::size_type size = cur.size();
-    std::string::size_type pad_size = 30 - size;
-    for (std::string::size_type i=0; i != pad_size; i++ )
-        pad << " ";
-    os << quoted_name.str() << pad.str() <<" -- "<< " size: " << tree.get<boost::uint32_t>("size");
-    os << " offset: " << tree.get<boost::uint32_t>("byteoffset");
-    os << std::endl;
-    return os;
+LIBPC_DLL std::ostream& operator<<(std::ostream& os, libpc::Dimension const& d);
 } // namespace libpc
diff -r ab124c3d43e2 -r 9bce9c5cf461 include/libpc/Schema.hpp
--- /dev/null	Thu Jan 01 00:00:00 1970 +0000
+++ b/include/libpc/Schema.hpp	Fri Feb 11 13:35:19 2011 -0800
@@ -0,0 +1,187 @@
+ * $Id$
+ * Project:  libLAS - http://liblas.org - A BSD library for LAS format data.
+ * Purpose:  LAS Schema implementation for C++ libLAS
+ * Author:   Howard Butler, hobu.inc at gmail.com
+ * Copyright (c) 2010, Howard Butler
+ * All rights reserved.
+ * Redistribution and use in source and binary forms, with or without
+ * modification, are permitted provided that the following
+ * conditions are met:
+ *     * Redistributions of source code must retain the above copyright
+ *       notice, this list of conditions and the following disclaimer.
+ *     * Redistributions in binary form must reproduce the above copyright
+ *       notice, this list of conditions and the following disclaimer in
+ *       the documentation and/or other materials provided
+ *       with the distribution.
+ *     * Neither the name of the Martin Isenburg or Iowa Department
+ *       of Natural Resources nor the names of its contributors may be
+ *       used to endorse or promote products derived from this software
+ *       without specific prior written permission.
+ * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
+ * "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
+ * LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS
+ * FOR A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE
+ * COPYRIGHT OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT,
+ * INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING,
+ * BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS
+ * OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED
+ * AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY,
+ * OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT
+ * OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY
+ * OF SUCH DAMAGE.
+#ifndef LIBPC_SCHEMA_HPP_INCLUDED
+#define LIBPC_SCHEMA_HPP_INCLUDED
+// std
+#include <vector>
+// boost
+#include <boost/multi_index_container.hpp>
+#include <boost/multi_index/hashed_index.hpp>
+#include <boost/multi_index/mem_fun.hpp>
+#include <boost/multi_index/random_access_index.hpp>
+#include "libpc/export.hpp"
+#include "libpc/Dimension.hpp"
+namespace libpc
+typedef std::vector<Dimension> DimensionArray;
+struct name{};
+struct position{};
+struct index{};
+typedef boost::multi_index::multi_index_container<
+    Dimension,
+    boost::multi_index::indexed_by<
+    // sort by Dimension::operator<
+    boost::multi_index::ordered_unique<boost::multi_index::tag<position>, boost::multi_index::identity<Dimension> >,
+    // Random access
+    boost::multi_index::random_access<boost::multi_index::tag<index> >,
+    // sort by less<string> on GetName
+    boost::multi_index::hashed_unique<boost::multi_index::tag<name>, boost::multi_index::const_mem_fun<Dimension,std::string const&,&Dimension::GetName> >
+> IndexMap;
+typedef IndexMap::index<name>::type index_by_name;
+typedef IndexMap::index<position>::type index_by_position;
+typedef IndexMap::index<index>::type index_by_index;
+// BUG: move elsewhere, this is only here temporarily
+/// Versions of point record format.
+enum PointFormatName
+    ePointFormat0 = 0,  ///< Point Data Format \e 0
+    ePointFormat1 = 1,  ///< Point Data Format \e 1
+    ePointFormat2 = 2,  ///< Point Data Format \e 2
+    ePointFormat3 = 3,  ///< Point Data Format \e 3
+    ePointFormat4 = 4,  ///< Point Data Format \e 3
+    ePointFormat5 = 5,  ///< Point Data Format \e 3
+    ePointFormatUnknown = -99 ///< Point Data Format is unknown
+/// Schema definition
+class LIBPC_DLL Schema
+public:
+    // Schema();
+    Schema(PointFormatName data_format_id);
+////    Schema(std::vector<VariableRecord> const& vlrs);
+    Schema& operator=(Schema const& rhs);
+    Schema(Schema const& other);
+    ~Schema() {}
+    /// Fetch byte size
+    std::size_t GetByteSize() const;
+    std::size_t GetBitSize() const;
+    void CalculateSizes();
+    /// Get the base size (only accounting for Time, Color, etc )
+    std::size_t GetBaseByteSize() const;
+    PointFormatName GetDataFormatId() const
+        return m_data_format_id;
+    void SetDataFormatId(PointFormatName const& value);
+    void AddDimension(Dimension const& dim);
+    boost::optional< Dimension const& > GetDimension(std::string const& n) const;
+    boost::optional< Dimension const& > GetDimension(index_by_index::size_type t) const;
+    // DimensionPtr GetDimension(std::size_t index) const;
+    void RemoveDimension(Dimension const& dim);
+    void SetDimension(Dimension const& dim);
+    std::vector<std::string> GetDimensionNames() const;
+    IndexMap const& GetDimensions() const
+        return m_index;
+    boost::property_tree::ptree GetPTree() const;
+    boost::uint16_t GetSchemaVersion() const
+        return m_schemaversion;
+    void SetSchemaVersion(boost::uint16_t v)
+        m_schemaversion = v;
+    bool IsCustom() const;
+////    VariableRecord GetVLR() const;
+protected:
+    PointFormatName m_data_format_id;
+    boost::uint32_t m_nextpos;
+    std::size_t m_bit_size;
+    std::size_t m_base_bit_size;
+    boost::uint16_t m_schemaversion;
+private:
+    IndexMap m_index;
+    void add_record0_dimensions();
+    void add_time();
+    void add_color();
+    void update_required_dimensions(PointFormatName data_format_id);
+////    bool IsSchemaVLR(VariableRecord const& vlr);
+////    boost::property_tree::ptree LoadPTree(VariableRecord const& v);
+    IndexMap LoadDimensions(boost::property_tree::ptree tree);
+bool inline sort_dimensions(Dimension i, Dimension j)
+    return i < j;
+LIBPC_DLL std::ostream& operator<<(std::ostream& os, Schema const&);
+} // namespace liblas
+#endif // LIBPC_SCHEMA_HPP_INCLUDED
diff -r ab124c3d43e2 -r 9bce9c5cf461 src/CMakeLists.txt
--- a/src/CMakeLists.txt	Fri Feb 11 12:11:37 2011 -0800
+++ b/src/CMakeLists.txt	Fri Feb 11 13:35:19 2011 -0800
@@ -37,6 +37,7 @@
   ${LIBPC_HEADERS_DIR}/PointLayout.hpp
   ${LIBPC_HEADERS_DIR}/Range.hpp
   ${LIBPC_HEADERS_DIR}/Reader.hpp
+  ${LIBPC_HEADERS_DIR}/Schema.hpp
   ${LIBPC_HEADERS_DIR}/Stage.hpp
   ${LIBPC_HEADERS_DIR}/Utils.hpp
   ${LIBPC_HEADERS_DIR}/Writer.hpp)
@@ -55,6 +56,7 @@
   PointData.cpp
   PointLayout.cpp
   Reader.cpp
+  Schema.cpp
   Stage.cpp
   Utils.cpp
   Writer.cpp)
diff -r ab124c3d43e2 -r 9bce9c5cf461 src/Dimension.cpp
--- a/src/Dimension.cpp	Fri Feb 11 12:11:37 2011 -0800
+++ b/src/Dimension.cpp	Fri Feb 11 13:35:19 2011 -0800
@@ -163,4 +163,30 @@
     return dim;
+std::ostream& operator<<(std::ostream& os, libpc::Dimension const& d)
+    using boost::property_tree::ptree;
+    ptree tree = d.GetPTree();
+    std::string const name = tree.get<std::string>("name");
+    std::ostringstream quoted_name;
+    quoted_name << "'" << name << "'";
+    std::ostringstream pad;
+    std::string const& cur = quoted_name.str();
+    std::string::size_type size = cur.size();
+    std::string::size_type pad_size = 30 - size;
+    for (std::string::size_type i=0; i != pad_size; i++ )
+        pad << " ";
+    os << quoted_name.str() << pad.str() <<" -- "<< " size: " << tree.get<boost::uint32_t>("size");
+    os << " offset: " << tree.get<boost::uint32_t>("byteoffset");
+    os << std::endl;
+    return os;
More information about the Liblas-commits mailing list
