[Liblas-commits] libpc: added Color (from liblas)
liblas-commits at liblas.org liblas-commits at liblas.org
Fri Feb 11 17:00:46 EST 2011
details:   http://hg.liblas.orglibpc/rev/f1c9ab596938
changeset: 42:f1c9ab596938
user:      Michael P. Gerlek <mpg at flaxen.com>
date:      Fri Feb 11 13:45:24 2011 -0800
description:
Subject: libpc: moved in some utility funcs
details:   http://hg.liblas.orglibpc/rev/0083f658832d
changeset: 43:0083f658832d
date:      Fri Feb 11 14:00:41 2011 -0800
description:
diffstat:
 apps/pc2pc.cpp          |    3 +
 include/libpc/Color.hpp |  156 ++++++++++++++++++++++++++++++++++++++++++++++++
 include/libpc/Utils.hpp |   23 ++----
 src/CMakeLists.txt      |    2 +
 src/Color.cpp           |  101 +++++++++++++++++++++++++++++++
 src/Utils.cpp           |   70 +++++++++++++++++++++-
 6 files changed, 340 insertions(+), 15 deletions(-)
diffs (truncated from 431 to 300 lines):
diff -r 9bce9c5cf461 -r 0083f658832d apps/pc2pc.cpp
--- a/apps/pc2pc.cpp	Fri Feb 11 13:35:19 2011 -0800
+++ b/apps/pc2pc.cpp	Fri Feb 11 14:00:41 2011 -0800
@@ -14,6 +14,7 @@
 #include "libpc/version.hpp"
 #include "libpc/Bounds.hpp"
+#include "libpc/Color.hpp"
 #include "libpc/Dimension.hpp"
 #include "libpc/Schema.hpp"
@@ -48,6 +49,8 @@
         std::cout << schema;
+    Color c;
     return 0;
 #if 0
diff -r 9bce9c5cf461 -r 0083f658832d include/libpc/Color.hpp
--- /dev/null	Thu Jan 01 00:00:00 1970 +0000
+++ b/include/libpc/Color.hpp	Fri Feb 11 14:00:41 2011 -0800
@@ -0,0 +1,156 @@
+ * $Id$
+ * Project:  libLAS - http://liblas.org - A BSD library for LAS format data.
+ * Purpose:  LAS color class
+ * Author:   Howard Butler, hobu.inc at gmail.com
+ * Copyright (c) 2008, Howard Butler
+ * All rights reserved.
+ * Redistribution and use in source and binary forms, with or without
+ * modification, are permitted provided that the following
+ * conditions are met:
+ *     * Redistributions of source code must rede following disclaimer.
+ *     * Redistributions in binary form must reproduce the above copyright
+ *       notice, this list of conditions and the following disclaimer in
+ *       the documentation and/or other materials provided
+ *       with the distribution.
+ *     * Neither the name of the Martin Isenburg or Iowa Department
+ *       of Natural Resources nor the names of its contributors may be
+ *       used to endorse or promote products derived from this software
+ *       without specific prior written permission.
+ * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
+ * "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
+ * LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS
+ * FOR A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE
+ * COPYRIGHT OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT,
+ * INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING,
+ * BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS
+ * OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED
+ * AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY,
+ * OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT
+ * OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY
+ * OF SUCH DAMAGE.
+#ifndef LIBPC_COLOR_HPP_INCLUDED
+#define LIBPC_COLOR_HPP_INCLUDED
+#include <libpc/export.hpp>
+// boost
+#include <boost/array.hpp>
+#include <boost/cstdint.hpp>
+// std
+//#include <cstdlib> // std::size_t
+namespace libpc
+/// RGB color container
+class LIBPC_DLL Color
+public:
+    typedef boost::uint16_t value_type;
+    /// Default constructor.
+    /// Initializes with black color using RGB {0, 0, 0}.
+    Color();
+    /// User-defined constructor.
+    /// Initializes object with given RGB values.
+    /// \exception std::invalid_argument if color component value is out of range of unsigned 8-bit integer.
+    Color(boost::uint32_t red, boost::uint32_t green, boost::uint32_t blue);
+    /// Initializes colour components based on values of 3-element array.
+    Color(boost::array<value_type, 3> const& color);
+    /// Copy constructor.
+    Color(Color const& other);
+    /// Assignment operator.
+    Color& operator=(Color const& rhs);
+    /// Fetch value of the red image channel
+    value_type GetRed() const
+        return m_color[0];
+    /// Set value of the red image channel
+    void SetRed(value_type const& value)
+        m_color[0] = value;
+    /// Fetch value of the green image channel
+    value_type GetGreen() const
+        return m_color[1];
+    void SetGreen(value_type const& value)
+        m_color[1] = value;
+    /// Fetch value of the blue image channel
+    value_type GetBlue() const
+        return m_color[2];
+    /// Set value of the blue image channel
+    void SetBlue(value_type const& value)
+        m_color[2] = value;
+    /// Index operator providing access to RGB values.
+    /// Valid index values are 0, 1 or 2.
+    /// \exception std::out_of_range if requested index is out of range (> 2).
+    value_type& operator[](std::size_t const& index)
+        return m_color[index];
+    /// Const version of index operator providing access to RGB values.
+    value_type const& operator[](std::size_t const& index) const
+private:
+    typedef boost::array<value_type, 3> base_type;
+    base_type m_color;
+    void throw_index_out_of_range() const;
+    void throw_invalid_color_component() const;
+LIBPC_DLL inline bool operator==(Color const& lhs, Color const& rhs)
+    return lhs[0] == rhs[0] && lhs[1] == rhs[1] && lhs[2] == rhs[2];
+LIBPC_DLL inline bool operator!=(Color const& lhs, Color const& rhs)
+    return !(lhs == rhs);
+} // namespace libpc
+#endif // LIBPC_COLOR_HPP_INCLUDED
diff -r 9bce9c5cf461 -r 0083f658832d include/libpc/Utils.hpp
--- a/include/libpc/Utils.hpp	Fri Feb 11 13:35:19 2011 -0800
+++ b/include/libpc/Utils.hpp	Fri Feb 11 14:00:41 2011 -0800
@@ -35,8 +35,9 @@
 #ifndef INCLUDED_UTILS_HPP
 #define INCLUDED_UTILS_HPP
-#include <cassert>
-#include <limits>
+#include <iosfwd>
+#include <string>
 #include "libpc/export.hpp"
 namespace libpc
@@ -45,18 +46,7 @@
 class LIBPC_DLL Utils
 public:
-    static double random(double min, double max)
-        double r = (double)rand();  // [0..32767]
-        double v = (max - min) / (double)RAND_MAX;
-        double s = r * v; // [0..(max-min)]
-        double t = min + s; // [min..max]
-        assert(t >= min);
-        assert(t <= max);
-        return t;
+    static double random(double minimum, double maximum);
     template<class T>
     static bool compare_distance(const T& actual, const T& expected)
@@ -71,6 +61,11 @@
         return true;
+    static std::istream* Open(std::string const& filename, std::ios::openmode mode=std::ios::in | std::ios::binary);
+    static std::ostream* Create(std::string const& filename, std::ios::openmode mode=std::ios::in | std::ios::binary);
+    static void Cleanup(std::ostream* ofs);
+    static void Cleanup(std::istream* ifs);
diff -r 9bce9c5cf461 -r 0083f658832d src/CMakeLists.txt
--- a/src/CMakeLists.txt	Fri Feb 11 13:35:19 2011 -0800
+++ b/src/CMakeLists.txt	Fri Feb 11 14:00:41 2011 -0800
@@ -24,6 +24,7 @@
   ${LIBPC_HEADERS_DIR}/export.hpp
   ${LIBPC_HEADERS_DIR}/version.hpp
   ${LIBPC_HEADERS_DIR}/Bounds.hpp
+  ${LIBPC_HEADERS_DIR}/Color.hpp
   ${LIBPC_HEADERS_DIR}/ColorFilter.hpp
   ${LIBPC_HEADERS_DIR}/CropFilter.hpp
   ${LIBPC_HEADERS_DIR}/Dimension.hpp
@@ -45,6 +46,7 @@
 set(LIBPC_CPP
   version.cpp
   Bounds.cpp
+  Color.cpp
   ColorFilter.cpp
   Dimension.cpp
   FauxReader.cpp
diff -r 9bce9c5cf461 -r 0083f658832d src/Color.cpp
+++ b/src/Color.cpp	Fri Feb 11 14:00:41 2011 -0800
@@ -0,0 +1,101 @@
+ * $Id$
+ *     * Redistributions of source code must retain the above copyright
+ *       notice, this list of conditions and the following disclaimer.
+ * OF SUCH DAMAGE.
+#include <libpc/Color.hpp>
+// boost
+//#include <boost/cstdint.hpp>
+// std
+//#include <stdexcept>
+//#include <limits>
+namespace libpc
More information about the Liblas-commits mailing list
