[Liblas-commits] hg: more typos
liblas-commits at liblas.org liblas-commits at liblas.org
Wed Feb 16 14:24:18 EST 2011
details:   http://hg.liblas.orghg/rev/2a55e231c75a
changeset: 2860:2a55e231c75a
user:      Howard Butler <hobu.inc at gmail.com>
date:      Wed Feb 16 13:24:15 2011 -0600
description:
more typos
diffstat:
 doc/development/wkt.txt |  4 ++--
 1 files changed, 2 insertions(+), 2 deletions(-)
diffs (21 lines):
diff -r e26029373da6 -r 2a55e231c75a doc/development/wkt.txt
--- a/doc/development/wkt.txt	Wed Feb 16 13:11:24 2011 -0600
+++ b/doc/development/wkt.txt	Wed Feb 16 13:24:15 2011 -0600
@@ -69,7 +69,7 @@
 Softwares that currently write GeoTIFF VLR records into LAS files can continue
 to do so in LAS 1.4. It is acceptable to write *only* GeoTIFF VLR records into
 an LAS file, while softwares that choose to write OGC WKT VLRs should also
-write GeoTIFF VLRs to promote backward compatibility If a file is found to
+write GeoTIFF VLRs to promote backward compatibility. If a file is found to
 have both OGC WKT and GeoTIFF VLRs, the OGC WKT description, which is more
 expressive, should be preferred if possible.
@@ -83,7 +83,7 @@
 The following conditions should also apply:
-* Because VLRs can only be 65536 size, an OGC WKT string in a VLR data block
+* Because VLRs can only be 65536 bytes size, an OGC WKT string in a VLR data block
   is functionally limited to 64K in size.
 * The OGC WKT VLR data shall be a null-terminated string.
 * The OGC WKT VLR data shall be considered UTF-8.
More information about the Liblas-commits mailing list
