[Liblas-commits] hg: fix for closing files under USE_BOOST_IO (for
Maury)
liblas-commits at liblas.org
Wed Feb 16 16:20:51 EST 2011
details: http://hg.liblas.orghg/rev/6511163e5ba1
changeset: 2861:6511163e5ba1
user: Michael P. Gerlek <mpg at flaxen.com>
date: Wed Feb 16 13:20:16 2011 -0800
description:
fix for closing files under USE_BOOST_IO (for Maury)
Subject: hg: merge
details: http://hg.liblas.orghg/rev/2aa0f7838c0a
changeset: 2862:2aa0f7838c0a
date: Wed Feb 16 13:20:44 2011 -0800
description:
merge
diffstat:
apps/lasinfo.cpp | 2 +-
doc/development/index.txt | 1 +
doc/development/wkt.txt | 99 ++++++++++++++++++++++++++++++++++++++++++++
include/liblas/liblas.hpp | 18 ++++++++
src/detail/reader/reader.cpp | 3 +-
5 files changed, 121 insertions(+), 2 deletions(-)
diffs (184 lines):
diff -r ac359ef58925 -r 2aa0f7838c0a apps/lasinfo.cpp
--- a/apps/lasinfo.cpp Mon Feb 14 09:11:00 2011 -0800
+++ b/apps/lasinfo.cpp Wed Feb 16 13:20:44 2011 -0800
@@ -236,7 +236,7 @@
verbose
- liblas::Header const& header = reader.GetHeader();
+ header = reader.GetHeader();
// Add the header to the summary so we can get more detailed
// info
diff -r ac359ef58925 -r 2aa0f7838c0a doc/development/index.txt
--- a/doc/development/index.txt Mon Feb 14 09:11:00 2011 -0800
+++ b/doc/development/index.txt Wed Feb 16 13:20:44 2011 -0800
@@ -18,6 +18,7 @@
Motivation <http://www.youtube.com/watch?v=u6XAPnuFjJc>
2010 Annual Report <annual_report_2010>
RFCs <rfc/index>
+ LAS 1.4 WKT Proposal <wkt>
Authors
diff -r ac359ef58925 -r 2aa0f7838c0a doc/development/wkt.txt
--- /dev/null Thu Jan 01 00:00:00 1970 +0000
+++ b/doc/development/wkt.txt Wed Feb 16 13:20:44 2011 -0800
@@ -0,0 +1,99 @@
+.. _srs_wkt:
+Georeferencing LAS files with LAS 1.4
+:Author: Howard Butler
+:Contact: hobu.inc at gmail dot com
+:Date: 2/16/2011
+Summary
+This document proposes how to handle describing spatial reference systems
+in `ASPRS LAS`_ 1.4. LAS 1.4 prescribes that software developers add and
+prefer to use OGC WKT coordinate system description in the form of VLR
+records in LAS files. Softwares can choose to continue to write GeoTIFF keys
+to support older applications, but they should prefer the OGC WKT if it is
+found in the file.
+Rationale
+LAS 1.3 and below have used `GeoTIFF`_ keys as described by the `GeoTIFF
+specification`_, but use of the GeoTIFF keys within LAS has a number of
+deficiencies:
+* GeoTIFF is typically tied to the `EPSG database`_ and does not provide
+ simple mechanisms for extended definitions.
+* Only a few softwares provide support for working with GeoTIFF keys directly.
+* The GeoTIFF specification has no organization backing its continued
+ development.
+* GeoTIFF does not offer a mechanism to represent transformations between
+ datums, while OGC WKT offers the TOWGS84[] mechanism
+OGC WKT
+The `OGC Simple Feature Access`_ specification provides the "Well-known Text
+Representation of Spatial Reference Systems" (WKT) language in section nine.
+WKT is much more expressive than GeoTIFF keys, has an organization providing
+institutional heft and progress behind it, and a number of open source and
+commercial softwares are available to support parsing and interpreting WKT
+output.
+There are a few dialects of WKT of which to be aware. The most common dialect
+is the "ESRI WKT" dialect, which does not include TOWGS84 and authority nodes,
+but there are others including "GDAL", "CSMap", "Oracle 9", "Oracle 10", and
+"GeoTools." It should be assumed that all WKT provided in LAS files should be
+of a dialect that is not the "ESRI WKT" dialect, which lacks some important
+features -- notably TOWGS84 and AUTHORITY nodes. If you have questions about
+how to produce WKT, please participate on the `MetaCRS`_ mailing list.
+Examples of WKT may also be found on the http://spatialreference.org website.
+.. _`OGC Simple Feature Access`: http://www.opengeospatial.org/standards/sfa
+.. _`MetaCRS`: http://trac.osgeo.org/metacrs/
+Transition
+Older softwares may want to continue to use GeoTIFF keys, and it is not
+desirable to have an abrupt discontinuity in the description of coordinate
+systems for LAS data. Additionally, while many softwares may not need the
+features of OGC WKT, its usage represents the strongest case for
+interoperability with other software -- especially software in the GIS and CAD
+domains that take advantage of the OGC WKT specification.
+Softwares that currently write GeoTIFF VLR records into LAS files can continue
+to do so in LAS 1.4. It is acceptable to write *only* GeoTIFF VLR records into
+an LAS file, while softwares that choose to write OGC WKT VLRs should also
+write GeoTIFF VLRs to promote backward compatibility. If a file is found to
+have both OGC WKT and GeoTIFF VLRs, the OGC WKT description, which is more
+expressive, should be preferred if possible.
+Implementation
+OGC WKT strings shall be provided in a VLR with the following attributes:
+* User ID: LASF_Projection
+* Record ID: 2112
+The following conditions should also apply:
+* Because VLRs can only be 65536 bytes size, an OGC WKT string in a VLR data block
+ is functionally limited to 64K in size.
+* The OGC WKT VLR data shall be a null-terminated string.
+* The OGC WKT VLR data shall be considered UTF-8.
+* The OGC WKT VLR data shall be considered ``C`` locale-based, and no
+ localization of the numeric strings within the WKT should be performed.
+.. _`ASPRS LAS`: http://www.asprs.org/society/committees/standards/lidar_exchange_format.html
+.. _`GeoTIFF specification`: ftp://ftp.remotesensing.org/pub/geotiff/spec/geotiff.rtf
+.. _`GeoTIFF`: http://trac.osgeo.org/geotiff/
+.. _`EPSG database`: http://www.epsg-registry.org/
diff -r ac359ef58925 -r 2aa0f7838c0a include/liblas/liblas.hpp
--- a/include/liblas/liblas.hpp Mon Feb 14 09:11:00 2011 -0800
+++ b/include/liblas/liblas.hpp Wed Feb 16 13:20:44 2011 -0800
@@ -166,11 +166,20 @@
// An ofstream is closeable and deletable, but
// an ostream like &std::cout isn't.
if (!ofs) return;
+#ifdef USE_BOOST_IO
+ namespace io = boost::iostreams;
+ if (static_cast<io::stream<io::file_sink>&>(*ofs))
+ static_cast<io::stream<io::file_sink>&>(*ofs).close();
+ delete ofs;
+#else
if (static_cast<std::ofstream&>(*ofs))
static_cast<std::ofstream&>(*ofs).close();
delete ofs;
+#endif
inline void Cleanup(std::istream* ifs)
@@ -178,11 +187,20 @@
// An ifstream is closeable and deletable, but
// an istream like &std::cin isn't.
if (!ifs) return;
+ if (static_cast<io::stream<io::file_source>&>(*ifs))
+ static_cast<io::stream<io::file_source>&>(*ifs).close();
+ delete ifs;
+#else
if (static_cast<std::ifstream&>(*ifs))
static_cast<std::ifstream&>(*ifs).close();
delete ifs;
+#endif
class ReaderI
diff -r ac359ef58925 -r 2aa0f7838c0a src/detail/reader/reader.cpp
--- a/src/detail/reader/reader.cpp Mon Feb 14 09:11:00 2011 -0800
+++ b/src/detail/reader/reader.cpp Wed Feb 16 13:20:44 2011 -0800
@@ -172,7 +172,8 @@
} catch (std::runtime_error&)
// If the stream is no good anymore, we're done reading points
- return;
+ throw std::out_of_range("ReadNextPoint: file has no more points to read, end of file reached");
// Filter the points and continue reading until we either find
More information about the Liblas-commits
