[Liblas-commits] libpc: boost I/O fix
liblas-commits at liblas.org liblas-commits at liblas.org
Wed Feb 16 17:23:04 EST 2011
details:   http://hg.liblas.orglibpc/rev/ea5f8fd7eb39
changeset: 63:ea5f8fd7eb39
user:      Michael P. Gerlek <mpg at flaxen.com>
date:      Wed Feb 16 13:38:01 2011 -0800
description:
boost I/O fix
Subject: libpc: debugging
details:   http://hg.liblas.orglibpc/rev/68f9d8765824
changeset: 64:68f9d8765824
date:      Wed Feb 16 13:38:24 2011 -0800
description:
debugging
Subject: libpc: checkpoint - las writing
details:   http://hg.liblas.orglibpc/rev/3f400151fa35
changeset: 65:3f400151fa35
date:      Wed Feb 16 14:22:44 2011 -0800
description:
diffstat:
 apps/pc2pc.cpp                    |   16 +-
 include/libpc/LasHeader.hpp       |   24 +-
 include/libpc/LasHeaderReader.hpp |   76 +++
 include/libpc/LasHeaderWriter.hpp |   74 +++
 include/libpc/LasWriter.hpp       |    6 +-
 include/libpc/Utils.hpp           |    3 +-
 include/libpc/Vector.hpp          |    6 +-
 src/CMakeLists.txt                |    4 +
 src/LasHeader.cpp                 |  733 +-------------------------------------
 src/LasHeaderReader.cpp           |  454 +++++++++++++++++++++++
 src/LasHeaderWriter.cpp           |  398 ++++++++++++++++++++
 src/LasReader.cpp                 |    7 +-
 src/LasWriter.cpp                 |  133 ++++++-
 src/Utils.cpp                     |   12 +-
 src/Writer.cpp                    |   24 +-
 15 files changed, 1189 insertions(+), 781 deletions(-)
diffs (truncated from 2235 to 300 lines):
diff -r 9ec62d76b00f -r 3f400151fa35 apps/pc2pc.cpp
--- a/apps/pc2pc.cpp	Tue Feb 15 17:25:48 2011 -0800
+++ b/apps/pc2pc.cpp	Wed Feb 16 14:22:44 2011 -0800
@@ -24,6 +24,7 @@
 #include "libpc/FauxWriter.hpp"
 #include "libpc/LasReader.hpp"
 #include "libpc/LasHeader.hpp"
+#include "libpc/LasWriter.hpp"
 using namespace libpc;
@@ -77,21 +78,20 @@
   std::cout << (const LasHeader&)header;
-  boost::uint32_t numPoints = (boost::uint32_t)header.getNumPoints();
-  PointData pointData(header.getSchema(), numPoints);
-  reader.readPoints(pointData);
+  //boost::uint32_t numPoints = (boost::uint32_t)header.getNumPoints();
+  //PointData pointData(header.getSchema(), numPoints);
+  //reader.readPoints(pointData);
 //  std::cout << pointData;
   std::ostream* ofs = Utils::Create("temp.las");
-  ((LasHeader&)header).write(*ofs);
+  LasWriter lasWriter(reader, *ofs);
+  lasWriter.write();
-  ofs->flush();
-  delete ofs;
+  Utils::Cleanup(ofs);
-//  Utils::Cleanup(ifs);
-//  Utils::Cleanup(ofs);
+  Utils::Cleanup(ifs);
   return;
diff -r 9ec62d76b00f -r 3f400151fa35 include/libpc/LasHeader.hpp
--- a/include/libpc/LasHeader.hpp	Tue Feb 15 17:25:48 2011 -0800
+++ b/include/libpc/LasHeader.hpp	Wed Feb 16 14:22:44 2011 -0800
@@ -57,8 +57,6 @@
 class LIBPC_DLL LasHeader : public Header
 public:
-    typedef boost::uuids::uuid uuid;
     /// Versions of point record format.
     enum PointFormatId
@@ -155,10 +153,10 @@
     /// Get project identifier.
     /// \return Global Unique Identifier as an instance of liblas::guid class.
-    uuid GetProjectId() const;
+    boost::uuids::uuid GetProjectId() const;
     /// Set project identifier.
-    void SetProjectId(uuid const& v);
+    void SetProjectId(boost::uuids::uuid const& v);
     /// Get major component of version of LAS format.
     /// \return Always 1 is returned as the only valid value.
@@ -352,11 +350,10 @@
     //void to_rst(std::ostream& os) const;
     //void to_xml(std::ostream& os) const;
     //void to_json(std::ostream& os) const;
+    // used by LasHeaderReader
+    static void update_required_dimensions(PointFormatId data_format_id, Schema&);
-    void read(std::istream&);
-    void write(std::ostream&);
 private:
     typedef Vector<double> PointScales;
     typedef Vector<double> PointOffsets;
@@ -378,26 +375,17 @@
     // TODO (low-priority): replace static-size char arrays
     // with std::string and return const-reference to string object.
-    bool HasLAS10PadSignature(std::istream& ifs);
-    void ReadVLRs(std::istream& ifs);
-    void Validate(std::istream& ifs);
-    static void update_required_dimensions(PointFormatId data_format_id, Schema&);
     static void add_record0_dimensions(Schema& schema);
     static void add_time(Schema& schema);
     static void add_color(Schema& schema);
-    void WriteLAS10PadSignature(std::ostream& ostream);
-    boost::int32_t GetRequiredHeaderSize(std::ostream& ostream) const;
-    void WriteVLRs(std::ostream& ostream);
     // Private data members
     char m_signature[eFileSignatureSize]; // TODO: replace with boost::array --mloskot
     boost::uint16_t m_sourceId;
     boost::uint16_t m_reserved;
-    uuid m_projectGuid;
+    boost::uuids::uuid m_projectGuid;
     boost::uint8_t m_versionMajor;
     boost::uint8_t m_versionMinor;
     char m_systemId[eSystemIdSize]; // TODO: replace with boost::array --mloskot
diff -r 9ec62d76b00f -r 3f400151fa35 include/libpc/LasHeaderReader.hpp
--- /dev/null	Thu Jan 01 00:00:00 1970 +0000
+++ b/include/libpc/LasHeaderReader.hpp	Wed Feb 16 14:22:44 2011 -0800
@@ -0,0 +1,76 @@
+ * $Id$
+ * Project:  libLAS - http://liblas.org - A BSD library for LAS format data.
+ * Purpose:  LAS header class
+ * Author:   Mateusz Loskot, mateusz at loskot.net
+ * Copyright (c) 2008, Mateusz Loskot
+ * Copyright (c) 2008, Phil Vachon
+ * All rights reserved.
+ * Redistribution and use in source and binary forms, with or without
+ * modification, are permitted provided that the following
+ * conditions are met:
+ *     * Redistributions of source code must retain the above copyright
+ *       notice, this list of conditions and the following disclaimer.
+ *     * Redistributions in binary form must reproduce the above copyright
+ *       notice, this list of conditions and the following disclaimer in
+ *       the documentation and/or other materials provided
+ *       with the distribution.
+ *     * Neither the name of the Martin Isenburg or Iowa Department
+ *       of Natural Resources nor the names of its contributors may be
+ *       used to endorse or promote products derived from this software
+ *       without specific prior written permission.
+ * THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
+ * "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
+ * LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS
+ * FOR A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE
+ * COPYRIGHT OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT,
+ * INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING,
+ * BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS
+ * OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED
+ * AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY,
+ * OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT
+ * OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY
+ * OF SUCH DAMAGE.
+#ifndef INCLUDED_LASHEADERREADER_HPP
+#define INCLUDED_LASHEADERREADER_HPP
+#include <iostream>
+#include "libpc/LasHeader.hpp"
+namespace libpc
+class LIBPC_DLL LasHeaderReader
+public:
+    LasHeaderReader(LasHeader& header, std::istream& istream);
+    void read();
+private:
+    LasHeader& m_header;
+    std::istream& m_istream;
+    bool HasLAS10PadSignature();
+    void ReadVLRs();
+    void Validate();
+    LasHeaderReader& operator=(const LasHeaderReader&); // nope
+    LasHeaderReader(const LasHeaderReader&); // nope
+} // namespace libpc
+#endif
diff -r 9ec62d76b00f -r 3f400151fa35 include/libpc/LasHeaderWriter.hpp
+++ b/include/libpc/LasHeaderWriter.hpp	Wed Feb 16 14:22:44 2011 -0800
@@ -0,0 +1,74 @@
+ * $Id$
+ * OF SUCH DAMAGE.
+#ifndef INCLUDED_LASHEADERWRITER_HPP
+#define INCLUDED_LASHEADERWRITER_HPP
+namespace libpc
+class LIBPC_DLL LasHeaderWriter
+public:
+    LasHeaderWriter(LasHeader& header, std::ostream&);
+    void write();
+private:
+    void WriteLAS10PadSignature();
+    std::size_t GetRequiredHeaderSize() const;
+    void WriteVLRs();
+    LasHeader& m_header; // BUG: I want this to be const
+    std::ostream& m_ostream;
+    LasHeaderWriter& operator=(const LasHeaderWriter&); // nope
+    LasHeaderWriter(const LasHeaderWriter&); // nope
+#endif
diff -r 9ec62d76b00f -r 3f400151fa35 include/libpc/LasWriter.hpp
--- a/include/libpc/LasWriter.hpp	Tue Feb 15 17:25:48 2011 -0800
+++ b/include/libpc/LasWriter.hpp	Wed Feb 16 14:22:44 2011 -0800
@@ -43,9 +43,9 @@
 class LIBPC_DLL LasWriter : public Writer
 public:
-    LasWriter(Stage& prevStage);
+    LasWriter(Stage& prevStage, std::ostream&);
-    void write();
+    //void write();
 protected:
     // this is called once before the loop with the writeBuffer calls
@@ -64,6 +64,8 @@
         throw;
     LasWriter& operator=(const LasWriter&); // not implemented
     LasWriter(const LasWriter&); // not implemented
diff -r 9ec62d76b00f -r 3f400151fa35 include/libpc/Utils.hpp
--- a/include/libpc/Utils.hpp	Tue Feb 15 17:25:48 2011 -0800
+++ b/include/libpc/Utils.hpp	Wed Feb 16 14:22:44 2011 -0800
@@ -94,7 +94,8 @@
         T& tmp = const_cast<T&>(src);
         //LIBLAS_SWAP_BYTES_N(tmp, num);
-        dest.write(as_bytes(tmp), num);
+        char const* p = as_bytes(tmp);
+        dest.write(p, num);
More information about the Liblas-commits mailing list
