[Liblas-commits] hg: add OSGeo4W install doc
    liblas-commits at liblas.org
    Thu Feb 17 10:02:44 EST 2011
details:   http://hg.liblas.orghg/rev/8cbdf640ffc9
changeset: 2863:8cbdf640ffc9
user:      Howard Butler <hobu.inc at gmail.com>
date:      Thu Feb 17 09:02:45 2011 -0600
description:
diffstat:
 doc/osgeo4w.txt |  52 +++++++++++++++++++++++++++++++++++++++++++++++-----
 1 files changed, 47 insertions(+), 5 deletions(-)
diffs (68 lines):
diff -r 2aa0f7838c0a -r 8cbdf640ffc9 doc/osgeo4w.txt
--- a/doc/osgeo4w.txt	Wed Feb 16 13:20:44 2011 -0800
+++ b/doc/osgeo4w.txt	Thu Feb 17 09:02:45 2011 -0600
@@ -7,16 +7,58 @@
 :Author: Howard Butler
 :Contact: hobu.inc at gmail dot com
+:Date: 2/17/2011
 This document describes how to install libLAS and its related :ref:`utilities <utilities>`
 using `OSGeo4W`_.  `OSGeo4W`_ is a collection of Windows packages that uses the `Cygwin`_
 installer to manage package dependencies.  libLAS in its fully-featured form
-requires a number of dependencies
+requires a number of dependencies, and these are all available via the OSGeo4W installer.
-.. seealso::
-    :ref:`Prerequisites` contains a detailed listing of the
-    prerequisites that libLAS needs to provide a full feature set.
+1) Obtain the `OSGeo4W Installer`_.  It is an executable that will run and
+   automatically download and install selected packages.
+    .. note::
+        OSGeo4W does not currently provide any options to install in any other
+        locations besides ``C:\osgeo4w``.
+.. `OSGeo4W Installer`: http://download.osgeo.org/osgeo4w/osgeo4w-setup.exe
+2) Choose "Advanced Install".
+    .. note::
+        libLAS is not part of any default package grouping, and it must be
+        installed individually.
+.. figure:: ./images/osgeo4w-advanced-install.png
+    :alt: Choosing the "Advanced" OSGeo4W install
+3) Select liblas from the "Commandline_Utilities" dropdown
+.. figure:: ./images/osgeo4w-select-liblas.png
+    :alt: Selecting libLAS to install from the "Advanced" list tree
+4) *Optional*: Select liblas-python from the "Libs" dropdown
+5) Run the ``OSGeo4W Shell`` from Start-Programs-OSGeo4W
+6) Execute the ``liblas`` command to set environment variables necessary to
+   support full libLAS operations.
+    .. note::
+        libLAS needs a number of environment variables set to do its business,
+        most notably the ones related to `GDAL`_ and `Proj.4`_ for
+        reprojection and coordinate system description.
+.. figure:: ./images/osgeo4w-run-liblas-shell.png
+    :alt: Running the libLAS subshell from OSGeo4W
+7) Test ``lasinfo`` with your own data
+.. figure:: ./images/osgeo4w-lasinfo-output.png
+    :alt: Running lasinfo
+.. _`OSGeo4W Installer`: http://download.osgeo.org/osgeo4w/osgeo4w-setup.exe
 .. _`OSGeo4W`: http://trac.osgeo.org/osgeo4w/
 .. _`Cygwin`: http://www.cygwin.com/
+.. _`GDAL`: http://www.gdal.org
+.. _`Proj.4`: http://trac.osgeo.org/proj/
\ No newline at end of file
More information about the Liblas-commits
