[Liblas-commits] libpc: stub for using boost unit tests
liblas-commits at liblas.org
Thu Feb 17 15:01:02 EST 2011
details: http://hg.liblas.orglibpc/rev/65261b9e5a03
changeset: 68:65261b9e5a03
user: Michael P. Gerlek <mpg at flaxen.com>
date: Thu Feb 17 12:00:55 2011 -0800
description:
diffstat:
test/unit/CMakeLists.txt | 5 ++-
test/unit/Suite1.cpp | 17 +++++++++++++
test/unit/Suite2.cpp | 17 +++++++++++++
test/unit/libpc_test.hpp | 18 --------------
test/unit/libpc_test_suite.cpp | 53 ------------------------------------------
test/unit/main.cpp | 9 +++++++
test/unit/zipreader_test.cpp | 38 ------------------------------
7 files changed, 46 insertions(+), 111 deletions(-)
diffs (191 lines):
diff -r b899ec533e10 -r 65261b9e5a03 test/unit/CMakeLists.txt
--- a/test/unit/CMakeLists.txt Thu Feb 17 10:23:40 2011 -0800
+++ b/test/unit/CMakeLists.txt Thu Feb 17 12:00:55 2011 -0800
@@ -8,8 +8,9 @@
SET(LIBPC_UNIT_TEST libpc_test)
SET(LIBPC_UNIT_TEST_SRC
- zipreader_test.cpp
- libpc_test_suite.cpp)
+ Suite1.cpp
+ Suite2.cpp
+ main.cpp)
INCLUDE_DIRECTORIES(
diff -r b899ec533e10 -r 65261b9e5a03 test/unit/Suite1.cpp
--- /dev/null Thu Jan 01 00:00:00 1970 +0000
+++ b/test/unit/Suite1.cpp Thu Feb 17 12:00:55 2011 -0800
@@ -0,0 +1,17 @@
+#define BOOST_TEST_DYN_LINK
+#include <boost/test/unit_test.hpp>
+BOOST_AUTO_TEST_SUITE(Suite1)
+BOOST_AUTO_TEST_CASE(Suite_1_Test_1)
+ BOOST_CHECK(true);
+BOOST_AUTO_TEST_CASE(Suite_1_Test_2)
+BOOST_AUTO_TEST_SUITE_END()
diff -r b899ec533e10 -r 65261b9e5a03 test/unit/Suite2.cpp
+++ b/test/unit/Suite2.cpp Thu Feb 17 12:00:55 2011 -0800
@@ -0,0 +1,17 @@
+BOOST_AUTO_TEST_SUITE(Suite2)
+BOOST_AUTO_TEST_CASE(Suite_2_Test_1)
+BOOST_AUTO_TEST_CASE(Suite_2_Test_2)
+ BOOST_CHECK(false);
diff -r b899ec533e10 -r 65261b9e5a03 test/unit/libpc_test.hpp
--- a/test/unit/libpc_test.hpp Thu Feb 17 10:23:40 2011 -0800
+++ /dev/null Thu Jan 01 00:00:00 1970 +0000
@@ -1,18 +0,0 @@
-// $Id$
-// (C) Copyright Mateusz Loskot 2008, mateusz at loskot.net
-// Distributed under the BSD License
-// (See accompanying file LICENSE.txt or copy at
-// http://www.opensource.org/licenses/bsd-license.php)
-#ifndef LIBLAS_TEST_HPP_INCLUDED
-#define LIBLAS_TEST_HPP_INCLUDED
-namespace tut
- // full path to trunk/test/data
- extern std::string g_test_data_path;
-#endif // LIBLAS_TEST_HPP_INCLUDED
diff -r b899ec533e10 -r 65261b9e5a03 test/unit/libpc_test_suite.cpp
--- a/test/unit/libpc_test_suite.cpp Thu Feb 17 10:23:40 2011 -0800
@@ -1,53 +0,0 @@
-// $Id$
-#include <tut/tut.hpp>
-#include <tut/tut_reporter.hpp>
-#include <iostream>
-#include <string>
-namespace tut
- test_runner_singleton runner;
- std::string g_test_data_path;
-int main(int argc, char* argv[])
- if (1 == argc)
- tut::g_test_data_path = "../data"; // default path
- else if (2 == argc)
- tut::g_test_data_path = argv[1];
- else
- std::cout << "Usage: liblas_test <test data path>\n";
- return 1;
- std::cout << "libLAS Test Suite:\n==================";
- tut::reporter reporter;
- tut::runner.get().set_callback(&reporter);
- try
- tut::runner.get().run_tests();
- catch (std::exception const& e)
- std::cerr << "TUT raised exception: " << e.what() << std::endl;
- return (reporter.all_ok() ? 0 : 1);
diff -r b899ec533e10 -r 65261b9e5a03 test/unit/main.cpp
+++ b/test/unit/main.cpp Thu Feb 17 12:00:55 2011 -0800
@@ -0,0 +1,9 @@
+#define BOOST_TEST_MODULE Main
+/* actually no code in here, this is just the main file */
diff -r b899ec533e10 -r 65261b9e5a03 test/unit/zipreader_test.cpp
--- a/test/unit/zipreader_test.cpp Thu Feb 17 10:23:40 2011 -0800
@@ -1,38 +0,0 @@
-// (C) Copyright 2010 Michael P. Gerlek (mpg at flaxen.com)
-#include <string>
-#include "libpc_test.hpp"
-namespace tut
- struct zipreader_data
- std::string file_las;
- std::string file_laz;
- zipreader_data() :
- file_las(g_test_data_path + "//1.2-with-color.las"),
- file_laz(g_test_data_path + "//1.2-with-color.laz")
- typedef test_group<zipreader_data> tg;
- typedef tg::object to;
- tg test_group_zipreader("liblas::ZipReader");
- // Test the factory does the right thing and the header is marked as compressed
- template<>
- template<>
- void to::test<1>()
- std::cout << "yow\n";
More information about the Liblas-commits
