[Liblas-commits] libpc: unit test work
liblas-commits at liblas.org liblas-commits at liblas.org
Thu Feb 17 15:35:50 EST 2011
details:   http://hg.liblas.orglibpc/rev/099c9b50efc1
changeset: 69:099c9b50efc1
user:      Michael P. Gerlek <mpg at flaxen.com>
date:      Thu Feb 17 12:35:44 2011 -0800
description:
unit test work
diffstat:
 test/unit/Suite1.cpp                   |    2 +
 test/unit/Suite2.cpp                   |   18 +-
 test/unit/main.cpp                     |   15 +
 test/unit/tut/README                   |  514 -----------------------------
 test/unit/tut/tut.hpp                  |  572 ---------------------------------
 test/unit/tut/tut_assert.hpp           |  306 -----------------
 test/unit/tut/tut_config.hpp           |    6 -
 test/unit/tut/tut_console_reporter.hpp |  274 ---------------
 test/unit/tut/tut_exception.hpp        |  237 -------------
 test/unit/tut/tut_posix.hpp            |  485 ---------------------------
 test/unit/tut/tut_reporter.hpp         |   11 -
 test/unit/tut/tut_restartable.hpp      |  410 -----------------------
 test/unit/tut/tut_result.hpp           |  174 ----------
 test/unit/tut/tut_runner.hpp           |  388 ----------------------
 14 files changed, 32 insertions(+), 3380 deletions(-)
diffs (truncated from 3491 to 300 lines):
diff -r 65261b9e5a03 -r 099c9b50efc1 test/unit/Suite1.cpp
--- a/test/unit/Suite1.cpp	Thu Feb 17 12:00:55 2011 -0800
+++ b/test/unit/Suite1.cpp	Thu Feb 17 12:35:44 2011 -0800
@@ -6,6 +6,8 @@
 BOOST_AUTO_TEST_CASE(Suite_1_Test_1)
+    BOOST_TEST_MESSAGE("(hello from Suite_1_Test_1)");
     BOOST_CHECK(true);
diff -r 65261b9e5a03 -r 099c9b50efc1 test/unit/Suite2.cpp
--- a/test/unit/Suite2.cpp	Thu Feb 17 12:00:55 2011 -0800
+++ b/test/unit/Suite2.cpp	Thu Feb 17 12:35:44 2011 -0800
@@ -4,14 +4,26 @@
 BOOST_AUTO_TEST_SUITE(Suite2)
-BOOST_AUTO_TEST_CASE(Suite_2_Test_1)
+char* p;
+BOOST_AUTO_TEST_CASE(Suite_2_Test_1_memleak)
-    BOOST_CHECK(true);
+    p = new char[1000];
+    //delete[] p;
-BOOST_AUTO_TEST_CASE(Suite_2_Test_2)
+BOOST_AUTO_TEST_CASE(Suite_2_Test_2_assertfalse)
     BOOST_CHECK(false);
+BOOST_AUTO_TEST_CASE(Suite_2_Test_3_uncaughtthrow)
+    throw 9;
 BOOST_AUTO_TEST_SUITE_END()
\ No newline at end of file
diff -r 65261b9e5a03 -r 099c9b50efc1 test/unit/main.cpp
--- a/test/unit/main.cpp	Thu Feb 17 12:00:55 2011 -0800
+++ b/test/unit/main.cpp	Thu Feb 17 12:35:44 2011 -0800
@@ -7,3 +7,18 @@
 #include <boost/test/unit_test.hpp>
 /* actually no code in here, this is just the main file */
+// you can run the unit tests as "bin/../libpc_test" with these interesting options:
+//     --log_format=X (-f X)     # where X is xml|hrf
+//     --log_level=X (-l X)      # where X is error|message|all|...    (default is error)
+//     --log_sink=X (-k X)       # where X is filename
+//     --report_format=X (-o X)
+//     --report_level=X (-r X)
+//     --report_sink=X (-e X)
+//     --detect_memory_leaks=X    # where X is 0|1  (default is 1)
diff -r 65261b9e5a03 -r 099c9b50efc1 test/unit/tut/README
--- a/test/unit/tut/README	Thu Feb 17 12:00:55 2011 -0800
+++ /dev/null	Thu Jan 01 00:00:00 1970 +0000
@@ -1,516 +0,0 @@
-TUT: C++ Template Unit Test Framework
-Version:  TUT (SVN Revision 190)
-Homepage: http://tut-framework.sourceforge.net/
-Documentation TUT How-To minimum steps to make TUT work for you
-What is TUT
-TUT is a pure C++ unit test framework. Its name - TUT - stands for
-Template Unit Tests.
-Features
-TUT provides all features required for unit testing:
-    * Similar tests can be grouped together into test groups. Each
-      test group has its unique name and is located in a separate
-      compilation unit. One group can contain almost unlimited number
-      of tests (actually, the limit is the compiler template
-      recursion depth).
-    * User can run all the tests (regression), or just some selected
-      groups or even some tests in these groups.
-    * TUT provides special template functions to check the condition
-      validity at run-time and to force test failure if required.
-      Since C++ doesn't provide a facility for obtaining stack trace
-      of the throwed exception and TUT avoids macros, those functions
-      accept string marker to allow users easely determine the source
-      of exception.
-    * TUT contains callback that can be implemented by the calling code
-      to integrate with an IDE, for example. Callbacks tell listener
-      when a new test run started, when test runner switches to the
-      next tests group, when a test was completed (and what result it
-      has), and when test run was finished. The callbacks allow users
-      to produce their own visualization format for test process and results.
-    * Being a template library, it doesn't need compilation; just
-      include the <tut.h> header into the test modules.
-TUT tests organization
-Test application
-C++ produces executable code, so tests have to be compiled into a single
-binary called test application. The application can be built in automated
-mode to perform nightly tests. They also can be built manually when a
-developer hunts for bugs.
-The test application contains tests, organized into test groups.
-Test groups
-The functionality of a tested application can be divided into a few separate
-function blocks (e.g. User Rights, Export, Processing, ...). It is natural
-to group together tests for each block. TUT invokes this test group. Each
-test group has a unique human-readable name and normally is located in a
-separate file.
-Tests
-Each single test usually checks only one specific element of functionality.
-For example, for a container a test could check whether size() call
-returns zero after the successful call to the clear() method.
-Writing simple test
-Preamble
-You are going to create a new class for your application. You decided to
-write tests for the class to be sure it works while you are developing or,
-possibly, enhancing it. Let's consider your class is shared pointer:
-std::auto_ptr-alike type that shares the same object among instances.
-Prior to test writing, you should decide what to test. Maximalist's
-approach requires to write so many tests that altering any single
-line of your production code will break at least one of them.
-Minimalist's approach allows one to write tests only for the most
-general or the most complex use cases. The truth lies somewhere in
-between, but only you, developer, know where. You should prepare
-common successful and unsuccessful scenarios, and the scenarios for
-testing any other functionality you believe might be broken in some way.
-For our shared_ptr we obviosly should test constructors, assignment operators, referencing and passing ownership.
-Skeleton
-If you don't have any implemented class to test yet, it would be good to
-implement it as a set of stubs for a first time. Thus you'll get an
-interface, and be able to write your tests. Yes, that's correct: you
-should write your tests before writing code! First of all, writing tests
-often helps to understand oddities in the current interface, and fix it.
-Secondly, with the stubs all your tests will fail, so you'll be sure
-they do their job.
-Creating Test Group
-Since we're writing unit tests, it would be a good idea to group the
-tests for our class in one place to be able to run them separately.
-It's also natural in C++ to place all the grouped tests into one
-compilation unit (i.e. source file). So, to begin, we should create
-a new file. Let's call it test_shared_ptr.cpp. (Final variant of the
-test group can be found in examples/shared_ptr subdirectory of the
-distribution package)
-// test_shared_ptr.cpp
-#include <tut.h>
-namespace tut
-As you see, you need to include TUT header file (as expected) and
-use namespace tut for tests. You may also use anonymous namespace if
-your compiler allows it (you will need to instantiate methods from
-tut namespace and some compilers refuse to place such instantiations
-into the anonymous namespace).
-A test group in TUT framework is described by the special template
-test_group<T>. The template parameter T is a type that will hold all
-test-specific data during the test execution. Actually, the data
-stored in T are member data of the test. Test object is inherited
-from T, so any test can refer to the data in T as its member data.
-For simple test groups (where all data are stored in test local
-variables) type T is an empty struct.
-#include <tut.h>
-namespace tut
-  struct shared_ptr_data
-But when tests have complex or repeating creation phase, you may put
-data members into the T and provide constructor (and, if required,
-destructor) for it. For each test, a new instance of T will be
-created. To prepare your test for execution TUT will use default
-constructor. Similarly, after the test has been finished, TUT
-calls the destructor to clean up T. I.e.:
-#include <tut.h>
-namespace tut
-  struct complex_data
-    connection* con;
-    complex_data(){ con = db_pool.get_connection(); }
-    ~complex_data(){ db_pool.release_connection(con); }
-  // each test from now will have con data member initialized
-  // by constructor:
-  con->commit();
-What will happen if the constructor throws an exception? TUT will treat
-it as if test itself failed with exception, so this test will
-not be executed. You'll see an exception mark near the test, and
-if the constructor throwed something printable, a certain message will appear.
-Exception in destructor is threated a bit different. Reaching destruction
-phase means that the test is passed, so TUT marks test with warning
-status meaning that test itself was OK, but something bad has happend
-after the test.
-Well, all we have written so far is just a type declaration. To work
-with a group we have to have an object, so we must create the test group
-object. Since we need only one test group object for each unit, we can
-(and should, actually) make this object static. To prevent name clash with
-other test group objects in the namespace tut, we should provide a
-descriptive name, or, alternatively, we may put it into the anonymous
-namespace. The former is more correct, but a descriptive name usually works
-well too, unless you're too terse in giving names to objects.
-#include <tut.h>
-namespace tut
-    typedef test_group<shared_ptr_data> tg;
-    tg shared_ptr_group("shared_ptr");
-As you see, any test group accepts a single parameter - its human-readable
-name. This name is used to identify the group when a programmer wants to
-execute all tests or a single test within the group. So this name shall
-also be descriptive enough to avoid clashes. Since we're writing tests
-for a specific unit, it's enough to name it after the unit name.
-Test group constructor will be called at unspecified moment at the test
-application startup. The constructor performs self-registration; it calls
-tut::runner and asks it to store the test group object name and location.
-Any other test group in the system undergoes the same processing, i.e.
-each test group object registers itself. Thus, test runner can iterate
-all test groups or execute any test group by its name.
-Newly created group has no tests associated with it. To be more precise,
-it has predefined set of dummy tests. By default, there are 50 tests in a
-group, including dummy ones. To create a test group with higher volume
-(e.g. when tests are generated by a script and their number is higher)
-we must provide a higher border of test group size when it is instantiated:
-#include <tut.h>
-namespace tut
-    struct huge_test_data
-    // test group with maximum 500 tests
-    typedef test_group<huge_test_data,500> testgroup;
-    testgroup huge_test_testgroup("huge group");
-Note also, that your compiler will possibly need a command-line switch
More information about the Liblas-commits mailing list
