[Liblas-commits] libpc: turned on liblas writer for point types
liblas-commits at liblas.org liblas-commits at liblas.org
Mon Feb 28 18:34:25 EST 2011
details:   http://hg.liblas.orglibpc/rev/4e5167bc4720
changeset: 119:4e5167bc4720
user:      Michael P. Gerlek <mpg at flaxen.com>
date:      Mon Feb 28 15:32:03 2011 -0800
description:
Subject: libpc: moved note on custom fields NYI
details:   http://hg.liblas.orglibpc/rev/c77eb9547b3b
changeset: 120:c77eb9547b3b
date:      Mon Feb 28 15:34:03 2011 -0800
description:
Subject: libpc: updated liblas ref file
details:   http://hg.liblas.orglibpc/rev/d9188caa4f11
changeset: 121:d9188caa4f11
date:      Mon Feb 28 15:34:21 2011 -0800
description:
diffstat:
 src/FauxReader.cpp             |    4 +-
 src/drivers/liblas/writer.cpp  |  154 ++++++++++++++++++++++++++++++++++------
 src/drivers/liblas/writer.hpp  |   10 ++-
 test/data/simple.las           |    0
 test/unit/LiblasWriterTest.cpp |   24 ++++-
 5 files changed, 159 insertions(+), 33 deletions(-)
diffs (truncated from 328 to 300 lines):
diff -r a4f68c513443 -r d9188caa4f11 src/FauxReader.cpp
--- a/src/FauxReader.cpp	Mon Feb 28 15:31:29 2011 -0800
+++ b/src/FauxReader.cpp	Mon Feb 28 15:34:21 2011 -0800
@@ -78,7 +78,6 @@
         throw; // BUG
     schema.addDimensions(dimensions);
-    throw not_yet_implemented("need to add ability to read from arbitrary fields");
     header->setNumPoints(numPoints);
     header->setBounds(bounds);
@@ -91,6 +90,9 @@
 boost::uint32_t FauxReader::readPoints(PointData& data)
+    if (data.getSchemaLayout().getSchema().getDimensions().size() != 4)
+        throw not_yet_implemented("need to add ability to read from arbitrary fields");
     // make up some data and put it into the buffer
     const boost::uint32_t numPoints = data.getNumPoints();
diff -r a4f68c513443 -r d9188caa4f11 src/drivers/liblas/writer.cpp
--- a/src/drivers/liblas/writer.cpp	Mon Feb 28 15:31:29 2011 -0800
+++ b/src/drivers/liblas/writer.cpp	Mon Feb 28 15:34:21 2011 -0800
@@ -39,6 +39,8 @@
 #include "header.hpp"
 #include <liblas/Writer.hpp>
+#include <libpc/exceptions.hpp>
 namespace libpc
@@ -47,19 +49,17 @@
 LiblasWriter::LiblasWriter(Stage& prevStage, std::ostream& ostream)
     : Writer(prevStage)
     , m_ostream(ostream)
-    , m_writer(NULL)
+    , m_externalWriter(NULL)
-    liblas::Header extHeader;
-    extHeader.SetCompressed(false);
+    m_externalHeader = new liblas::Header;
+    m_externalHeader->SetCompressed(false);
-    extHeader.SetCreationDOY(55);
-    extHeader.SetCreationYear(2011);
-    m_writer = new liblas::Writer(m_ostream, extHeader);
+    setFormatVersion(1,2);
+    setPointFormat(0);
     // make our own header
-    LiblasHeader* myHeader = new LiblasHeader;
-    setHeader(myHeader);
+    LiblasHeader* internalHeader = new LiblasHeader;
+    setHeader(internalHeader);
     //myHeader->setNumPoints( extHeader.GetPointRecordsCount() );
@@ -67,29 +67,49 @@
     //const Bounds<double> bounds(extBounds.minx(), extBounds.miny(), extBounds.minz(), extBounds.maxx(), extBounds.maxy(), extBounds.maxz());
     //myHeader->setBounds(bounds);
-    //Schema& schema = myHeader->getSchema();
-    //schema.addDimension(Dimension(Dimension::Field_X, Dimension::Double));
-    //schema.addDimension(Dimension(Dimension::Field_Y, Dimension::Double));
-    //schema.addDimension(Dimension(Dimension::Field_Z, Dimension::Double));
     return;
 LiblasWriter::~LiblasWriter()
-    delete m_writer;
+    delete m_externalHeader;
+    return;
+void LiblasWriter::setFormatVersion(boost::uint8_t majorVersion, boost::uint8_t minorVersion)
+    m_externalHeader->SetVersionMajor(majorVersion);
+    m_externalHeader->SetVersionMinor(minorVersion);
+void LiblasWriter::setPointFormat(boost::int8_t pointFormat)
+    m_externalHeader->SetDataFormatId((liblas::PointFormatName)pointFormat);
+void LiblasWriter::setDate(boost::uint16_t dayOfYear, boost::uint16_t year)
+    m_externalHeader->SetCreationDOY(dayOfYear);
+    m_externalHeader->SetCreationYear(year);
 void LiblasWriter::writeBegin()
+    m_externalHeader->SetPointRecordsCount(99);
+    m_externalWriter = new liblas::Writer(m_ostream, *m_externalHeader);
     return;
 void LiblasWriter::writeEnd()
+    delete m_externalWriter;
+    m_externalWriter = NULL;
     return;
@@ -99,25 +119,111 @@
     boost::uint32_t numPoints = pointData.getNumPoints();
     boost::uint32_t i = 0;
+    bool hasTimeData = false;
+    bool hasColorData = false;
+    bool hasWaveData = false;
+    const liblas::PointFormatName pointFormat = m_externalHeader->GetDataFormatId();
+    switch (pointFormat)
+    case liblas::ePointFormat0:
+        break;
+    case liblas::ePointFormat1:
+        hasTimeData = true;
+        break;
+    case liblas::ePointFormat2:
+        hasColorData = true;
+        break;
+    case liblas::ePointFormat3:
+        break;
+    case liblas::ePointFormat4:
+        hasWaveData = true;
+        break;
+    case liblas::ePointFormat5:
+        break;
+    if (hasWaveData)
+        throw not_yet_implemented("Waveform data (types 4 and 5) not supported");
     const std::size_t indexX = pointData.getDimensionIndex(Dimension::Field_X);
     const std::size_t indexY = pointData.getDimensionIndex(Dimension::Field_Y);
     const std::size_t indexZ = pointData.getDimensionIndex(Dimension::Field_Z);
-    const std::size_t indexT = pointData.getDimensionIndex(Dimension::Field_GpsTime);
+    const std::size_t indexIntensity = pointData.getDimensionIndex(Dimension::Field_Intensity);
+    const std::size_t indexReturnNumber = pointData.getDimensionIndex(Dimension::Field_ReturnNumber);
+    const std::size_t indexNumberOfReturns = pointData.getDimensionIndex(Dimension::Field_NumberOfReturns);
+    const std::size_t indexScanDirectionFlag = pointData.getDimensionIndex(Dimension::Field_ScanDirectionFlag);
+    const std::size_t indexEdgeOfFlightLine = pointData.getDimensionIndex(Dimension::Field_EdgeOfFlightLine);
+    const std::size_t indexClassification = pointData.getDimensionIndex(Dimension::Field_Classification);
+    const std::size_t indexScanAngleRank = pointData.getDimensionIndex(Dimension::Field_ScanAngleRank);
+    const std::size_t indexUserData = pointData.getDimensionIndex(Dimension::Field_UserData);
+    const std::size_t indexPointSourceId = pointData.getDimensionIndex(Dimension::Field_PointSourceId);
+    const std::size_t indexGpsTime = (hasTimeData ? pointData.getDimensionIndex(Dimension::Field_GpsTime) : 0);
+    const std::size_t indexRed = (hasColorData ? pointData.getDimensionIndex(Dimension::Field_Red) : 0);
+    const std::size_t indexGreen = (hasColorData ? pointData.getDimensionIndex(Dimension::Field_Green) : 0);
+    const std::size_t indexBlue = (hasColorData ? pointData.getDimensionIndex(Dimension::Field_Blue) : 0);
+    //const std::size_t indexWavePacketDescriptorIndex = (hasWaveData ? pointData.getDimensionIndex(Dimension::Field_WavePacketDescriptorIndex) : 0);
+    //const std::size_t indexWaveformDataOffset = (hasWaveData ? pointData.getDimensionIndex(Dimension::Field_WaveformDataOffset) : 0);
+    //const std::size_t indexReturnPointWaveformLocation = (hasWaveData ? pointData.getDimensionIndex(Dimension::Field_ReturnPointWaveformLocation) : 0);
+    //const std::size_t indexWaveformXt = (hasWaveData ? pointData.getDimensionIndex(Dimension::Field_WaveformXt) : 0);
+    //const std::size_t indexWaveformYt = (hasWaveData ? pointData.getDimensionIndex(Dimension::Field_WaveformYt) : 0);
+    //const std::size_t indexWaveformZt = (hasWaveData ? pointData.getDimensionIndex(Dimension::Field_WaveformZt) : 0);
     liblas::Point pt;
     for (i=0; i<numPoints; i++)
-        const double x = pointData.getField<float>(i, indexX);
-        const double y = pointData.getField<float>(i, indexY);
-        const double z = pointData.getField<float>(i, indexZ);
-        const boost::uint64_t t = pointData.getField<boost::uint64_t>(i, indexT);
+        const boost::int32_t x = pointData.getField<boost::int32_t>(i, indexX);
+        const boost::int32_t y = pointData.getField<boost::int32_t>(i, indexY);
+        const boost::int32_t z = pointData.getField<boost::int32_t>(i, indexZ);
+        pt.SetRawX(x);
+        pt.SetRawY(y);
+        pt.SetRawZ(z);
-        pt.SetCoordinates(x,y,z);
-        pt.SetTime((double)t);
+        const boost::uint16_t intensity = pointData.getField<boost::uint16_t>(i, indexIntensity);
+        const boost::int8_t returnNumber = pointData.getField<boost::int8_t>(i, indexReturnNumber);
+        const boost::int8_t numberOfReturns = pointData.getField<boost::int8_t>(i, indexNumberOfReturns);
+        const boost::int8_t scanDirFlag = pointData.getField<boost::int8_t>(i, indexScanDirectionFlag);
+        const boost::int8_t edgeOfFlightLine = pointData.getField<boost::int8_t>(i, indexEdgeOfFlightLine);
+        const boost::uint8_t classification = pointData.getField<boost::uint8_t>(i, indexClassification);
+        const boost::uint8_t scanAngleRank = pointData.getField<boost::uint8_t>(i, indexScanAngleRank);
+        const boost::uint8_t userData = pointData.getField<boost::uint8_t>(i, indexUserData);
+        const boost::uint16_t pointSourceId = pointData.getField<boost::uint16_t>(i, indexPointSourceId);
-        bool ok = m_writer->WritePoint(pt);
-        assert(ok);
+        if (hasTimeData)
+            const double gpsTime = pointData.getField<double>(i, indexGpsTime);
+            pt.SetTime(gpsTime);
+        if (hasColorData)
+            const boost::uint16_t red = pointData.getField<boost::uint16_t>(i, indexRed);
+            const boost::uint16_t green = pointData.getField<boost::uint16_t>(i, indexGreen);
+            const boost::uint16_t blue = pointData.getField<boost::uint16_t>(i, indexBlue);
+            liblas::Color color(red, green, blue);
+            pt.SetColor(color);
+        if (hasWaveData)
+            assert(false);
+        bool ok = m_externalWriter->WritePoint(pt);
+        assert(ok); // BUG
     return numPoints;
diff -r a4f68c513443 -r d9188caa4f11 src/drivers/liblas/writer.hpp
--- a/src/drivers/liblas/writer.hpp	Mon Feb 28 15:31:29 2011 -0800
+++ b/src/drivers/liblas/writer.hpp	Mon Feb 28 15:34:21 2011 -0800
@@ -40,18 +40,23 @@
 namespace liblas
     class Writer;
+    class Header;
 namespace libpc
+// we default to LAS 1.2, point format 0
 class LIBPC_DLL LiblasWriter : public Writer
 public:
     LiblasWriter(Stage& prevStage, std::ostream&);
     ~LiblasWriter();
+    void setFormatVersion(boost::uint8_t majorVersion, boost::uint8_t minorVersion);
+    void setPointFormat(boost::int8_t pointFormat);
+    void setDate(boost::uint16_t dayOfYear, boost::uint16_t year);
 protected:
     // this is called once before the loop with the writeBuffer calls
@@ -65,7 +70,8 @@
 private:
     std::ostream& m_ostream;
-    liblas::Writer* m_writer;
+    liblas::Writer* m_externalWriter;
+    liblas::Header* m_externalHeader;
     LiblasWriter& operator=(const LiblasWriter&); // not implemented
     LiblasWriter(const LiblasWriter&); // not implemented
diff -r a4f68c513443 -r d9188caa4f11 test/data/simple.las
Binary file test/data/simple.las has changed
diff -r a4f68c513443 -r d9188caa4f11 test/unit/LiblasWriterTest.cpp
--- a/test/unit/LiblasWriterTest.cpp	Mon Feb 28 15:31:29 2011 -0800
+++ b/test/unit/LiblasWriterTest.cpp	Mon Feb 28 15:34:21 2011 -0800
@@ -37,6 +37,7 @@
 #include "libpc/FauxReader.hpp"
 #include "libpc/../../src/drivers/liblas/writer.hpp"
+#include "libpc/../../src/drivers/liblas/reader.hpp"
 #include "support.hpp"
@@ -49,22 +50,33 @@
     // remove file from earlier run, if needed
     Utils::deleteFile("temp.las");
-    Bounds<double> bounds(1.0, 2.0, 3.0, 101.0, 102.0, 103.0);
-    FauxReader reader(bounds, 1000, FauxReader::Constant);
+    std::istream* ifs = Utils::openFile("../../test/data/1.2-with-color.las");
+    LiblasReader reader(*ifs);
     std::ostream* ofs = Utils::createFile("temp.las");
More information about the Liblas-commits mailing list
