[Liblas-commits] libpc: improve liblaswriter
liblas-commits at liblas.org liblas-commits at liblas.org
Mon Feb 28 19:15:19 EST 2011
details:   http://hg.liblas.orglibpc/rev/17fff2474d04
changeset: 122:17fff2474d04
user:      Michael P. Gerlek <mpg at flaxen.com>
date:      Mon Feb 28 16:15:15 2011 -0800
description:
diffstat:
 src/drivers/liblas/writer.cpp  |   51 ++++++++++++++++++++++++++++++++++++----
 src/drivers/liblas/writer.hpp  |    8 ++++++
 test/data/simple.las           |    0
 test/unit/LiblasWriterTest.cpp |    2 +
 4 files changed, 56 insertions(+), 5 deletions(-)
diffs (135 lines):
diff -r d9188caa4f11 -r 17fff2474d04 src/drivers/liblas/writer.cpp
--- a/src/drivers/liblas/writer.cpp	Mon Feb 28 15:34:21 2011 -0800
+++ b/src/drivers/liblas/writer.cpp	Mon Feb 28 16:15:15 2011 -0800
@@ -40,6 +40,7 @@
 #include <liblas/Writer.hpp>
 #include <libpc/exceptions.hpp>
+#include <libpc/libpc_config.hpp>
 namespace libpc
@@ -54,15 +55,12 @@
     m_externalHeader = new liblas::Header;
     m_externalHeader->SetCompressed(false);
-    setFormatVersion(1,2);
-    setPointFormat(0);
+    setupExternalHeader();
     // make our own header
     LiblasHeader* internalHeader = new LiblasHeader;
     setHeader(internalHeader);
-    //myHeader->setNumPoints( extHeader.GetPointRecordsCount() );
     //const liblas::Bounds<double>& extBounds = extHeader.GetExtent();
     //const Bounds<double> bounds(extBounds.minx(), extBounds.miny(), extBounds.minz(), extBounds.maxx(), extBounds.maxy(), extBounds.maxz());
     //myHeader->setBounds(bounds);
@@ -78,6 +76,27 @@
+void LiblasWriter::setupExternalHeader()
+    setFormatVersion(1,2);
+    setPointFormat(0);
+    setSystemIdentifier("libPC");
+    setGeneratingSoftware(GetVersionString());
+    std::size_t indexX = getHeader().getSchema().getDimensionIndex(Dimension::Field_X);
+    std::size_t indexY = getHeader().getSchema().getDimensionIndex(Dimension::Field_Y);
+    std::size_t indexZ = getHeader().getSchema().getDimensionIndex(Dimension::Field_Z);
+    const Dimension& dimX = getHeader().getSchema().getDimension(indexX);
+    const Dimension& dimY = getHeader().getSchema().getDimension(indexY);
+    const Dimension& dimZ = getHeader().getSchema().getDimension(indexZ);
+    m_externalHeader->SetScale(dimX.getNumericScale(), dimY.getNumericScale(), dimZ.getNumericScale());
+    m_externalHeader->SetOffset(dimX.getNumericOffset(), dimY.getNumericOffset(), dimZ.getNumericOffset());
+    return;
 void LiblasWriter::setFormatVersion(boost::uint8_t majorVersion, boost::uint8_t minorVersion)
     m_externalHeader->SetVersionMajor(majorVersion);
@@ -98,9 +117,22 @@
+void LiblasWriter::setSystemIdentifier(const std::string& systemId)
+    m_externalHeader->SetSystemId(systemId);
+void LiblasWriter::setGeneratingSoftware(const std::string& softwareId)
+    m_externalHeader->SetSoftwareId(softwareId);
 void LiblasWriter::writeBegin()
-    m_externalHeader->SetPointRecordsCount(99);
+    m_externalHeader->SetPointRecordsCount(99); // BUG
     m_externalWriter = new liblas::Writer(m_ostream, *m_externalHeader);
     return;
@@ -201,6 +233,15 @@
         const boost::uint8_t scanAngleRank = pointData.getField<boost::uint8_t>(i, indexScanAngleRank);
         const boost::uint8_t userData = pointData.getField<boost::uint8_t>(i, indexUserData);
         const boost::uint16_t pointSourceId = pointData.getField<boost::uint16_t>(i, indexPointSourceId);
+        pt.SetIntensity(intensity);
+        pt.SetReturnNumber(returnNumber);
+        pt.SetNumberOfReturns(numberOfReturns);
+        pt.SetScanDirection(scanDirFlag);
+        pt.SetFlightLineEdge(edgeOfFlightLine);
+        pt.SetClassification(classification);
+        pt.SetScanAngleRank(scanAngleRank);
+        pt.SetUserData(userData);
+        pt.SetPointSourceID(pointSourceId);
         if (hasTimeData)
diff -r d9188caa4f11 -r 17fff2474d04 src/drivers/liblas/writer.hpp
--- a/src/drivers/liblas/writer.hpp	Mon Feb 28 15:34:21 2011 -0800
+++ b/src/drivers/liblas/writer.hpp	Mon Feb 28 16:15:15 2011 -0800
@@ -57,6 +57,12 @@
     void setFormatVersion(boost::uint8_t majorVersion, boost::uint8_t minorVersion);
     void setPointFormat(boost::int8_t pointFormat);
     void setDate(boost::uint16_t dayOfYear, boost::uint16_t year);
+    // up to 32 chars (default is "libPC")
+    void setSystemIdentifier(const std::string& systemId);
+    // up to 32 chars (default is "libPC x.y.z")
+    void setGeneratingSoftware(const std::string& softwareId);
 protected:
     // this is called once before the loop with the writeBuffer calls
@@ -69,6 +75,8 @@
     virtual void writeEnd();
 private:
+    void setupExternalHeader();
     std::ostream& m_ostream;
     liblas::Writer* m_externalWriter;
     liblas::Header* m_externalHeader;
diff -r d9188caa4f11 -r 17fff2474d04 test/data/simple.las
Binary file test/data/simple.las has changed
diff -r d9188caa4f11 -r 17fff2474d04 test/unit/LiblasWriterTest.cpp
--- a/test/unit/LiblasWriterTest.cpp	Mon Feb 28 15:34:21 2011 -0800
+++ b/test/unit/LiblasWriterTest.cpp	Mon Feb 28 16:15:15 2011 -0800
@@ -63,6 +63,8 @@
         writer.setDate(0, 0);
         writer.setPointFormat(3);
+        writer.setSystemIdentifier("");
+        writer.setGeneratingSoftware("TerraScan");
         writer.write(numPoints);
More information about the Liblas-commits mailing list
