[Liblas-commits] hg: use bits 7 and 6 for laszip flags (as per
Martin)
liblas-commits at liblas.org
Mon Jan 3 13:59:34 EST 2011
details: http://hg.liblas.orghg/rev/e2cf1be6b142
changeset: 2673:e2cf1be6b142
user: Michael P. Gerlek <mpg at flaxen.com>
date: Mon Jan 03 10:59:15 2011 -0800
description:
use bits 7 and 6 for laszip flags (as per Martin)
diffstat:
src/detail/reader/header.cpp | 15 +++++++++++++--
src/detail/writer/header.cpp | 2 +-
2 files changed, 14 insertions(+), 3 deletions(-)
diffs (41 lines):
diff -r 5fae42ddbc14 -r e2cf1be6b142 src/detail/reader/header.cpp
--- a/src/detail/reader/header.cpp Mon Jan 03 10:35:29 2011 -0800
+++ b/src/detail/reader/header.cpp Mon Jan 03 10:59:15 2011 -0800
@@ -161,12 +161,23 @@
// 17. Point Data Format ID
read_n(n1, m_ifs, sizeof(n1));
- if (n1 >> 7)
+ // the high two bits are reserved for laszip compression type
+ uint8_t compression_bits = (n1 & 0xC0) >> 6;
+ if (compression_bits == 0)
+ m_header->SetCompressed(false);
+ else if (compression_bits == 2)
m_header->SetCompressed(true);
- n1 &= 0x7f;
+ else
+ throw std::domain_error("invalid point compression format");
+ // strip the hgih bits, to determine point type
+ n1 &= 0x3f;
if (n1 == liblas::ePointFormat0)
m_header->SetDataFormatId(liblas::ePointFormat0);
diff -r 5fae42ddbc14 -r e2cf1be6b142 src/detail/writer/header.cpp
--- a/src/detail/writer/header.cpp Mon Jan 03 10:35:29 2011 -0800
+++ b/src/detail/writer/header.cpp Mon Jan 03 10:59:15 2011 -0800
@@ -237,7 +237,7 @@
// 16. Point Data Format ID
n1 = static_cast<uint8_t>(m_header.GetDataFormatId());
uint8_t n1tmp = n1;
- if (m_header.Compressed())
+ if (m_header.Compressed()) // high bit set indicates laszip compression
n1tmp |= 0x80;
detail::write_n(m_ofs, n1tmp, sizeof(n1tmp));
More information about the Liblas-commits
