[Liblas-commits] laszip: fix osgeo4w dependency and add
OSGEO4W_UPSTREAM_RELEASE ...
liblas-commits at liblas.org
Mon Jan 3 15:47:24 EST 2011
details: http://hg.liblas.orglaszip/rev/6cfec438cea3
changeset: 111:6cfec438cea3
user: Howard Butler <hobu.inc at gmail.com>
date: Mon Jan 03 14:47:10 2011 -0600
description:
fix osgeo4w dependency and add OSGEO4W_UPSTREAM_RELEASE usage
diffstat:
CMakeLists.txt | 2 +-
cmake/modules/BuildOSGeo4W.cmake | 9 +++------
2 files changed, 4 insertions(+), 7 deletions(-)
diffs (38 lines):
diff -r bb381252df0d -r 6cfec438cea3 CMakeLists.txt
--- a/CMakeLists.txt Mon Jan 03 12:31:23 2011 -0600
+++ b/CMakeLists.txt Mon Jan 03 14:47:10 2011 -0600
@@ -125,7 +125,7 @@
SET(CPACK_PACKAGE_VERSION_MAJOR ${LASZIP_VERSION_MAJOR})
SET(CPACK_PACKAGE_VERSION_MINOR ${LASZIP_VERSION_MINOR})
SET(CPACK_PACKAGE_VERSION_PATCH ${LASZIP_VERSION_MINOR})
-SET(OSGEO4W_UPSTREAM_RELEASE "2")
+SET(OSGEO4W_UPSTREAM_RELEASE "1")
SET(CPACK_SOURCE_GENERATOR "TGZ;ZIP;TBZ2")
SET(CPACK_CMAKE_GENERATOR "Unix Makefiles")
diff -r bb381252df0d -r 6cfec438cea3 cmake/modules/BuildOSGeo4W.cmake
--- a/cmake/modules/BuildOSGeo4W.cmake Mon Jan 03 12:31:23 2011 -0600
+++ b/cmake/modules/BuildOSGeo4W.cmake Mon Jan 03 14:47:10 2011 -0600
@@ -38,10 +38,7 @@
add_custom_target(make_osgeo4w_directories
COMMAND ${CMAKE_COMMAND} -E echo "Building OSGeo4W install directories")
-foreach(utility ${LASZIP_UTILITIES})
- add_dependencies( make_osgeo4w_directories ${utility} )
-endforeach()
+add_dependencies( make_osgeo4w_directories ${LASZIP_LIB_NAME} )
macro (make_directories)
@@ -109,8 +106,8 @@
copy_files(${LASZIP_BUILD_OUTPUT_DIRECTORY}/laszip.lib ${OSGEO4W_DEVEL_LIB_DIR}/ )
copy_files(./include/laszip/*.hpp ${OSGEO4W_DEVEL_INCLUDE_LASZIP_DIR}/ )
-tar_directories(${OSGEO4W_DIR} ${laszip_SOURCE_DIR}/${OSGEO4W_PACKAGES}/laszip-${VERSION}.tar.bz2 "bin/")
-tar_directories(${OSGEO4W_DIR}/devel ${laszip_SOURCE_DIR}/${OSGEO4W_PACKAGES}/laszip-devel-${VERSION}.tar.bz2 "lib/;include")
+tar_directories(${OSGEO4W_DIR} ${laszip_SOURCE_DIR}/${OSGEO4W_PACKAGES}/laszip-${VERSION}-${OSGEO4W_UPSTREAM_RELEASE}.tar.bz2 "bin/")
+tar_directories(${OSGEO4W_DIR}/devel ${laszip_SOURCE_DIR}/${OSGEO4W_PACKAGES}/laszip-devel-${VERSION}-${OSGEO4W_UPSTREAM_RELEASE}.tar.bz2 "lib/;include")
add_custom_target(osgeo4w
More information about the Liblas-commits
