[Liblas-commits] hg: restore the point count setter; be suyre and restore the ori...
liblas-commits at liblas.org liblas-commits at liblas.org
Tue Jan 4 15:42:23 EST 2011
details:   http://hg.liblas.orghg/rev/eae4c3cfb963
changeset: 2682:eae4c3cfb963
user:      Michael P. Gerlek <mpg at flaxen.com>
date:      Tue Jan 04 12:17:12 2011 -0800
description:
restore the point count setter; be suyre and restore the orig pos after updating, although I still don't know why
Subject: hg: turn on the tests
details:   http://hg.liblas.orghg/rev/97a8e4b6e3bb
changeset: 2683:97a8e4b6e3bb
date:      Tue Jan 04 12:18:16 2011 -0800
description:
turn on the tests
Subject: hg: we can't determine the point count manually if we're a compressed file, so as a fallback we'll use the point count we already have -- not clear if this is sufficient, though
details:   http://hg.liblas.orghg/rev/20f07b581c9c
changeset: 2684:20f07b581c9c
date:      Tue Jan 04 12:42:06 2011 -0800
description:
diffstat:
 src/detail/writer/header.cpp    |  29 ++++++++++++++++++-----------
 src/detail/writer/zipwriter.cpp |  10 +++++++---
 test/unit/zipreader_test.cpp    |   2 +-
 test/unit/zipwriter_test.cpp    |   2 +-
 4 files changed, 27 insertions(+), 16 deletions(-)
diffs (113 lines):
diff -r b2b4ee72c615 -r 20f07b581c9c src/detail/writer/header.cpp
--- a/src/detail/writer/header.cpp	Tue Jan 04 11:54:33 2011 -0800
+++ b/src/detail/writer/header.cpp	Tue Jan 04 12:42:06 2011 -0800
@@ -101,20 +101,27 @@
         // We're opened in append mode
-        ios::off_type points = end - static_cast<ios::off_type>(m_header.GetDataOffset());
-        ios::off_type count = points / static_cast<ios::off_type>(m_header.GetDataRecordLength());
+        if (m_header.Compressed())
+            m_pointCount = m_header.GetPointRecordsCount();
+        else
+            ios::off_type points = end - static_cast<ios::off_type>(m_header.GetDataOffset());
+            ios::off_type count = points / static_cast<ios::off_type>(m_header.GetDataRecordLength());
-        if (points < 0) {
-            std::ostringstream oss;
-            oss << "The header's data offset, " << m_header.GetDataOffset()
-                <<", is much larger than the size of the file, " << end
-                <<", and something is amiss.  Did you use the right header"
-                <<" offset value?";
-            throw std::runtime_error(oss.str());
+            if (points < 0) {
+                std::ostringstream oss;
+                oss << "The header's data offset, " << m_header.GetDataOffset()
+                    <<", is much larger than the size of the file, " << end
+                    <<", and something is amiss.  Did you use the right header"
+                    <<" offset value?";
+                throw std::runtime_error(oss.str());
+            m_pointCount = static_cast<uint32_t>(count);
-        m_pointCount = static_cast<uint32_t>(count);
         // Position to the beginning of the file to start writing the header
         m_ofs.seekp(0, ios::beg);
diff -r b2b4ee72c615 -r 20f07b581c9c src/detail/writer/zipwriter.cpp
--- a/src/detail/writer/zipwriter.cpp	Tue Jan 04 11:54:33 2011 -0800
+++ b/src/detail/writer/zipwriter.cpp	Tue Jan 04 12:42:06 2011 -0800
@@ -81,6 +81,8 @@
 void ZipWriterImpl::UpdatePointCount(boost::uint32_t count)
+    std::streamoff orig_pos = m_ofs.tellp();
     boost::uint32_t out = m_pointCount;
     if ( count != 0 ) { out = count; }
@@ -90,6 +92,8 @@
     std::streamsize const dataPos = 107;
     m_ofs.seekp(dataPos, std::ios::beg);
     detail::write_n(m_ofs, out , sizeof(out));
+    m_ofs.seekp(orig_pos, std::ios::beg);
@@ -123,7 +127,7 @@
     if (!ok)
         throw liblas_error("Error writing compressed point data");
-    /*++m_pointCount;*/
+    ++m_pointCount;
     return;
@@ -132,14 +136,14 @@
     // Try to update the point count on our way out, but we don't really
     // care if we weren't able to write it.
-    /*try
+    try
         UpdatePointCount(0);
     } catch (std::runtime_error const&)
     delete m_zipper;
     delete m_zipPoint;
diff -r b2b4ee72c615 -r 20f07b581c9c test/unit/zipreader_test.cpp
--- a/test/unit/zipreader_test.cpp	Tue Jan 04 11:54:33 2011 -0800
+++ b/test/unit/zipreader_test.cpp	Tue Jan 04 12:42:06 2011 -0800
@@ -5,7 +5,7 @@
 // http://www.opensource.org/licenses/bsd-license.php)
-#ifdef HAVE_LASZIPxxx
+#ifdef HAVE_LASZIP
 #include <liblas/liblas.hpp>
 #include <liblas/variablerecord.hpp>
diff -r b2b4ee72c615 -r 20f07b581c9c test/unit/zipwriter_test.cpp
--- a/test/unit/zipwriter_test.cpp	Tue Jan 04 11:54:33 2011 -0800
+++ b/test/unit/zipwriter_test.cpp	Tue Jan 04 12:42:06 2011 -0800
@@ -5,7 +5,7 @@
+#ifdef HAVE_LASZIP
 #include <tut/tut.hpp>
More information about the Liblas-commits mailing list
