[Liblas-commits] hg: add some try/catch blocks, just in case
liblas-commits at liblas.org
Tue Jan 4 18:39:46 EST 2011
details: http://hg.liblas.orghg/rev/86ba5e9da0dd
changeset: 2685:86ba5e9da0dd
user: Michael P. Gerlek <mpg at flaxen.com>
date: Tue Jan 04 15:39:40 2011 -0800
description:
diffstat:
src/detail/reader/zipreader.cpp | 37 ++++++++++++++++++++++++++++++++-----
src/detail/writer/zipwriter.cpp | 40 +++++++++++++++++++++++++++++++++-------
2 files changed, 65 insertions(+), 12 deletions(-)
diffs (132 lines):
diff -r 20f07b581c9c -r 86ba5e9da0dd src/detail/reader/zipreader.cpp
--- a/src/detail/reader/zipreader.cpp Tue Jan 04 12:42:06 2011 -0800
+++ b/src/detail/reader/zipreader.cpp Tue Jan 04 15:39:40 2011 -0800
@@ -106,14 +106,31 @@
// we'll create a point reader at this point.
if (!m_unzipper)
- m_unzipper = new LASunzipper();
+ try
+ m_unzipper = new LASunzipper();
+ catch(...)
+ throw liblas_error("Failed to open laszip decompression engine (1)");
PointFormatName format = m_header->GetDataFormatId();
m_zipPoint = new ZipPoint(format);
- unsigned int stat = m_unzipper->open(m_ifs, m_zipPoint->m_num_items, m_zipPoint->m_items, LASzip::COMPRESSION_DEFAULT);
+ unsigned int stat = 1;
+ try
+ stat = m_unzipper->open(m_ifs, m_zipPoint->m_num_items, m_zipPoint->m_items, LASzip::COMPRESSION_DEFAULT);
+ catch(...)
+ throw liblas_error("Failed to open laszip decompression engine (2)");
if (stat != 0)
- throw liblas_error("Failed to open laszip decompression engine");
+ throw liblas_error("Failed to open laszip decompression engine (3)");
return;
@@ -183,9 +200,19 @@
//////++m_current;
//////*m_point = m_point_reader->GetPoint();
- bool ok = m_unzipper->read(m_zipPoint->m_lz_point);
+ bool ok = false;
+ try
+ ok = m_unzipper->read(m_zipPoint->m_lz_point);
+ catch(...)
+ throw liblas_error("Error reading compressed point data (1)");
if (!ok)
- throw liblas_error("Error reading compressed point data");
+ throw liblas_error("Error reading compressed point data (2)");
std::vector<boost::uint8_t> v(m_zipPoint->m_lz_point_size);
for (unsigned int i=0; i<m_zipPoint->m_lz_point_size; i++)
diff -r 20f07b581c9c -r 86ba5e9da0dd src/detail/writer/zipwriter.cpp
--- a/src/detail/writer/zipwriter.cpp Tue Jan 04 12:42:06 2011 -0800
+++ b/src/detail/writer/zipwriter.cpp Tue Jan 04 15:39:40 2011 -0800
if (m_zipper==NULL)
- m_zipper = new LASzipper();
+ try
+ m_zipper = new LASzipper();
+ catch(...)
+ throw liblas_error("Error opening compression engine (1)");
- unsigned int stat = m_zipper->open(m_ofs, m_zipPoint->m_num_items, m_zipPoint->m_items, LASzip::COMPRESSION_DEFAULT);
+ try
+ stat = m_zipper->open(m_ofs, m_zipPoint->m_num_items, m_zipPoint->m_items, LASzip::COMPRESSION_DEFAULT);
+ catch(...)
+ throw liblas_error("Error opening compression engine (3)");
if (stat != 0)
- throw liblas_error("Error opening compression engine");
+ throw liblas_error("Error opening compression engine (2)");
const std::vector<boost::uint8_t>& v = point.GetData();
@@ -123,9 +140,19 @@
//printf("%d %d\n", v[i], i);
- bool ok = m_zipper->write(m_zipPoint->m_lz_point);
+ bool ok = false;
+ try
+ ok = m_zipper->write(m_zipPoint->m_lz_point);
+ catch(...)
+ throw liblas_error("Error writing compressed point data (1)");
if (!ok)
- throw liblas_error("Error writing compressed point data");
+ throw liblas_error("Error writing compressed point data (2)");
++m_pointCount;
@@ -139,10 +166,9 @@
try
UpdatePointCount(0);
} catch (std::runtime_error const&)
+ // ignore?
delete m_zipper;
More information about the Liblas-commits
