[Liblas-commits] laszip: mpg: the LAS_ZIP_DLL does not work with my code. can you...
liblas-commits at liblas.org liblas-commits at liblas.org
Tue Jan 4 18:58:09 EST 2011
details:   http://hg.liblas.orglaszip/rev/a8aa0185aa63
changeset: 114:a8aa0185aa63
user:      isenburg
date:      Tue Jan 04 15:52:11 2011 -0800
description:
mpg: the LAS_ZIP_DLL does not work with my code. can you ifdef it?
Subject: laszip: improved endianness again, renamed compression to algorithm, improved wavepacket13 compressor
details:   http://hg.liblas.orglaszip/rev/dcd14845f9ed
changeset: 115:dcd14845f9ed
user:      isenburg
date:      Tue Jan 04 15:57:54 2011 -0800
description:
diffstat:
 include/laszip/lasunzipper.hpp    |    6 +-
 include/laszip/laszip.hpp         |   90 +++++-----
 include/laszip/laszipper.hpp      |    6 +-
 src/bytestreamin.hpp              |   18 +-
 src/bytestreamin_file.hpp         |  148 ++++++++++++++----
 src/bytestreamin_istream.hpp      |  148 ++++++++++++++----
 src/bytestreamout.hpp             |   18 +-
 src/bytestreamout_file.hpp        |  134 +++++++++++++----
 src/bytestreamout_ostream.hpp     |  134 +++++++++++++----
 src/lasreaditemcompressed_v1.cpp  |   28 +++-
 src/lasreaditemcompressed_v1.hpp  |    3 +-
 src/lasreaditemraw.hpp            |   40 ++--
 src/lasreadpoint.cpp              |   12 +-
 src/lasreadpoint.hpp              |    2 +-
 src/lasunzipper.cpp               |   18 +-
 src/laswriteitemcompressed_v1.cpp |   39 ++++-
 src/laswriteitemcompressed_v1.hpp |    3 +-
 src/laswriteitemraw.hpp           |   40 ++--
 src/laswritepoint.cpp             |   11 +-
 src/laswritepoint.hpp             |    2 +-
 src/laszip.cpp                    |  292 ++++++++++++++++++-------------------
 src/laszipper.cpp                 |   18 +-
 src/rangemodel.cpp                |   10 +-
 23 files changed, 793 insertions(+), 427 deletions(-)
diffs (truncated from 1859 to 300 lines):
diff -r 473e998d2955 -r dcd14845f9ed include/laszip/lasunzipper.hpp
--- a/include/laszip/lasunzipper.hpp	Tue Jan 04 12:02:44 2011 -0600
+++ b/include/laszip/lasunzipper.hpp	Tue Jan 04 15:57:54 2011 -0800
@@ -61,11 +61,11 @@
 class ByteStreamIn;
 class LASreadPoint;
-class LASZIP_DLL LASunzipper
+class LASunzipper
 public:
-  unsigned int open(FILE* file, unsigned int num_items, const LASitem items[], LASzip::CompressionType compression_type);
-  unsigned int open(istream& stream, unsigned int num_items, const LASitem items[], LASzip::CompressionType compression_type);
+  unsigned int open(FILE* file, unsigned int num_items, const LASitem items[], LASzip::Algorithm algorithm);
+  unsigned int open(istream& stream, unsigned int num_items, const LASitem items[], LASzip::Algorithm algorithm);
   bool read(unsigned char * const * point);
   unsigned int close();
diff -r 473e998d2955 -r dcd14845f9ed include/laszip/laszip.hpp
--- a/include/laszip/laszip.hpp	Tue Jan 04 12:02:44 2011 -0600
+++ b/include/laszip/laszip.hpp	Tue Jan 04 15:57:54 2011 -0800
@@ -16,36 +16,36 @@
-  FILE:  laszip.hpp
-  CONTENTS:
+  FILE:  laszip.hpp
+  CONTENTS:
     Contains LASitem and LASchunk structs as well as the IDs of the currently
-    supported entropy coding scheme
-  PROGRAMMERS:
-    martin isenburg at cs.unc.edu
-  COPYRIGHT:
-    copyright (C) 2007  martin isenburg at cs.unc.edu
-    This software is distributed in the hope that it will be useful,
-    but WITHOUT ANY WARRANTY; without even the implied warranty of
-    MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
-  CHANGE HISTORY:
+    supported entropy coding scheme
+  PROGRAMMERS:
+    martin isenburg at cs.unc.edu
+  COPYRIGHT:
+    copyright (C) 2007  martin isenburg at cs.unc.edu
+    This software is distributed in the hope that it will be useful,
+    but WITHOUT ANY WARRANTY; without even the implied warranty of
+    MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
+  CHANGE HISTORY:
     12 December 2010 -- refactored from lasdefinitions after movies with silke
-#ifndef LASZIP_H
-#define LASZIP_H
+#ifndef LASZIP_H
+#define LASZIP_H
 #if defined(_MSC_VER) && (_MSC_VER < 1300)
 #define LZ_WIN32_VC6
@@ -58,10 +58,10 @@
 #define LASZIP_VERSION_MINOR    0
 #define LASZIP_VERSION_REVISION 0
-#include "export.hpp"
+//#include "export.hpp"
+#define LAS_ZIP_DLL
-class LASZIP_DLL LASitem
+class LAS_ZIP_DLL LASitem
 public:
   enum Type { BYTE = 0, SHORT, INT, LONG, FLOAT, DOUBLE, POINT10, GPSTIME11, RGB12, WAVEPACKET13 } type;
@@ -80,23 +80,23 @@
   unsigned short version;
-class LASZIP_DLL LASzip
+class LAS_ZIP_DLL LASzip
 public:
-    enum CompressionType
-        COMPRESSION_NONE       = 0,
-        COMPRESSION_ARITHMETIC = 1,
-        COMPRESSION_RANGE      = 2,
-        COMPRESSION_DEFAULT    = COMPRESSION_ARITHMETIC
-public:
-    LASzip();
-    ~LASzip();
+  enum Algorithm
+    POINT_BY_POINT_RAW        = 0,
+    POINT_BY_POINT_ARITHMETIC = 1,
+    POINT_BY_POINT_RANGE      = 2,
+    DEFAULT_COMPRESSION       = POINT_BY_POINT_ARITHMETIC,
+    DEFAULT_RAW               = POINT_BY_POINT_RAW
-public:
-  unsigned int compression;
+  LASzip();
+  ~LASzip();
+  Algorithm algorithm;
   unsigned char version_major;
   unsigned char version_minor;
   unsigned short version_revision;
@@ -116,4 +116,4 @@
-#endif
+#endif
diff -r 473e998d2955 -r dcd14845f9ed include/laszip/laszipper.hpp
--- a/include/laszip/laszipper.hpp	Tue Jan 04 12:02:44 2011 -0600
+++ b/include/laszip/laszipper.hpp	Tue Jan 04 15:57:54 2011 -0800
@@ -61,11 +61,11 @@
 class ByteStreamOut;
 class LASwritePoint;
-class LASZIP_DLL LASzipper
+class LASzipper
 public:
-  unsigned int open(FILE* outfile, unsigned int num_items, LASitem items[], LASzip::CompressionType compression_type);
-  unsigned int open(ostream& outstream, unsigned int num_items, LASitem items[], LASzip::CompressionType compression_type);
+  unsigned int open(FILE* outfile, unsigned int num_items, LASitem items[], LASzip::Algorithm algorithm);
+  unsigned int open(ostream& outstream, unsigned int num_items, LASitem items[], LASzip::Algorithm algorithm);
   bool write(const unsigned char* const * point);
diff -r 473e998d2955 -r dcd14845f9ed src/bytestreamin.hpp
--- a/src/bytestreamin.hpp	Tue Jan 04 12:02:44 2011 -0600
+++ b/src/bytestreamin.hpp	Tue Jan 04 15:57:54 2011 -0800
@@ -51,12 +51,18 @@
   virtual unsigned int getByte() = 0;
 /* read an array of bytes                                    */
   virtual bool getBytes(unsigned char* bytes, unsigned int num_bytes) = 0;
-/* read 16 bit field (for implementing endian swap)         */
-  virtual bool get16bits(unsigned char* bytes) = 0;
-/* read 32 bit field (for implementing endian swap)         */
-  virtual bool get32bits(unsigned char* bytes) = 0;
-/* read 64 bit field (for implementing endian swap)         */
-  virtual bool get64bits(unsigned char* bytes) = 0;
+/* read 16 bit low-endian field                              */
+  virtual bool get16bitsLE(unsigned char* bytes) = 0;
+/* read 32 bit low-endian field                              */
+  virtual bool get32bitsLE(unsigned char* bytes) = 0;
+/* read 64 bit low-endian field                              */
+  virtual bool get64bitsLE(unsigned char* bytes) = 0;
+/* read 16 bit big-endian field                              */
+  virtual bool get16bitsBE(unsigned char* bytes) = 0;
+/* read 32 bit big-endian field                              */
+  virtual bool get32bitsBE(unsigned char* bytes) = 0;
+/* read 64 bit big-endian field                              */
+  virtual bool get64bitsBE(unsigned char* bytes) = 0;
 /* is the stream seekable (e.g. standard in is not)          */
   virtual bool isSeekable() const = 0;
 /* returns how many bytes were read since last reset         */
diff -r 473e998d2955 -r dcd14845f9ed src/bytestreamin_file.hpp
--- a/src/bytestreamin_file.hpp	Tue Jan 04 12:02:44 2011 -0600
+++ b/src/bytestreamin_file.hpp	Tue Jan 04 15:57:54 2011 -0800
@@ -56,12 +56,6 @@
   unsigned int getByte();
   bool getBytes(unsigned char* bytes, unsigned int num_bytes);
-  virtual bool get16bits(unsigned char* bytes);
-  virtual bool get32bits(unsigned char* bytes);
-  virtual bool get64bits(unsigned char* bytes);
   bool isSeekable() const;
 /* save position in the stream for (forward) seeking later   */
@@ -83,16 +77,42 @@
   long seek_position;
-class ByteStreamInFileEndianSwapped : public ByteStreamInFile
+class ByteStreamInFileLE : public ByteStreamInFile
 public:
-  ByteStreamInFileEndianSwapped(FILE* file);
-  bool get16bits(unsigned char* bytes);
-  bool get32bits(unsigned char* bytes);
-  bool get64bits(unsigned char* bytes);
+  ByteStreamInFileLE(FILE* file);
+  bool get16bitsLE(unsigned char* bytes);
+  bool get32bitsLE(unsigned char* bytes);
+  bool get64bitsLE(unsigned char* bytes);
+  bool get16bitsBE(unsigned char* bytes);
+  bool get32bitsBE(unsigned char* bytes);
+  bool get64bitsBE(unsigned char* bytes);
+private:
+  unsigned char swapped[8];
+class ByteStreamInFileBE : public ByteStreamInFile
+public:
+  ByteStreamInFileBE(FILE* file);
 private:
@@ -109,7 +129,7 @@
   int byte = getc(file);
   if (byte == EOF)
-    //fprintf(stderr, "reading EOF\n");
+//    fprintf(stderr, "reading EOF\n");
     byte = 0;
   return (unsigned int)byte;
@@ -120,21 +140,6 @@
   return (fread(bytes, 1, num_bytes, file) == num_bytes);
-inline bool ByteStreamInFile::get16bits(unsigned char* bytes)
-  return getBytes(bytes, 2);
-inline bool ByteStreamInFile::get32bits(unsigned char* bytes)
-  return getBytes(bytes, 4);
-inline bool ByteStreamInFile::get64bits(unsigned char* bytes)
-  return getBytes(bytes, 8);
 inline bool ByteStreamInFile::isSeekable() const
   return (file != stdin);
@@ -161,11 +166,26 @@
   start = ftell(file);
-inline ByteStreamInFileEndianSwapped::ByteStreamInFileEndianSwapped(FILE* file) : ByteStreamInFile(file)
+inline ByteStreamInFileLE::ByteStreamInFileLE(FILE* file) : ByteStreamInFile(file)
-inline bool ByteStreamInFileEndianSwapped::get16bits(unsigned char* bytes)
+inline bool ByteStreamInFileLE::get16bitsLE(unsigned char* bytes)
+  return getBytes(bytes, 2);
More information about the Liblas-commits mailing list
