[Liblas-commits] hg: fix up calls of std::min and std::max to satisfy windows mac...
liblas-commits at liblas.org liblas-commits at liblas.org
Tue Jan 11 10:08:36 EST 2011
details:   http://hg.liblas.orghg/rev/3b90c0b0382e
changeset: 2720:3b90c0b0382e
user:      Howard Butler <hobu.inc at gmail.com>
date:      Tue Jan 11 09:08:12 2011 -0600
description:
fix up calls of std::min and std::max to satisfy windows macros hell.
diffstat:
 apps/kdx_util.cpp                  |  16 ++++++++--------
 apps/las2ogr.cpp                   |   2 +-
 apps/laskernel.cpp                 |   4 ++--
 include/liblas/bounds.hpp          |   4 ++--
 src/color.cpp                      |   6 +++---
 src/detail/index/indexcell.cpp     |  20 ++++++++++----------
 src/detail/index/indexoutput.cpp   |  22 +++++++++++-----------
 src/detail/reader/cachedreader.cpp |   6 +++---
 src/schema.cpp                     |   4 ++--
 src/spatialreference.cpp           |   4 ++--
 src/transform.cpp                  |  38 +++++++++++++++++++-------------------
 src/utility.cpp                    |   4 ++--
 12 files changed, 65 insertions(+), 65 deletions(-)
diffs (truncated from 400 to 300 lines):
diff -r 97ca1d940f20 -r 3b90c0b0382e apps/kdx_util.cpp
--- a/apps/kdx_util.cpp	Mon Jan 10 14:08:20 2011 -0600
+++ b/apps/kdx_util.cpp	Tue Jan 11 09:08:12 2011 -0600
@@ -30,11 +30,11 @@
            first = false;
-       mins[0] = std::min(mins[0], bnd.min(0));
-       mins[1] = std::min(mins[1], bnd.min(1));
+       mins[0] = (std::min)(mins[0], bnd.min(0));
+       mins[1] = (std::min)(mins[1], bnd.min(1));
-       maxs[0] = std::max(maxs[0], bnd.max(0));
-       maxs[1] = std::max(maxs[1], bnd.max(1));
+       maxs[0] = (std::max)(maxs[0], bnd.max(0));
+       maxs[1] = (std::max)(maxs[1], bnd.max(1));
        IndexResult result(static_cast<boost::uint32_t>(i));
        result.SetIDs(ids);
@@ -73,11 +73,11 @@
             first = false;
-        mins[0] = std::min(mins[0], low[0]);
-        mins[1] = std::min(mins[1], low[1]);
+        mins[0] = (std::min)(mins[0], low[0]);
+        mins[1] = (std::min)(mins[1], low[1]);
-        maxs[0] = std::max(maxs[0], high[0]);
-        maxs[1] = std::max(maxs[1], high[1]);
+        maxs[0] = (std::max)(maxs[0], high[0]);
+        maxs[1] = (std::max)(maxs[1], high[1]);
         // if (!input.good()) continue;
         IDVector ids;
diff -r 97ca1d940f20 -r 3b90c0b0382e apps/las2ogr.cpp
--- a/apps/las2ogr.cpp	Mon Jan 10 14:08:20 2011 -0600
+++ b/apps/las2ogr.cpp	Tue Jan 11 09:08:12 2011 -0600
@@ -94,7 +94,7 @@
     static int lastTick = -1;
     int tick = static_cast<int>(complete * 40.0);
-    tick = std::min(40, std::max(0, tick));
+    tick = (std::min)(40, std::max(0, tick));
     // Have we started a new progress run?
     if (tick < lastTick && lastTick >= 39)
diff -r 97ca1d940f20 -r 3b90c0b0382e apps/laskernel.cpp
--- a/apps/laskernel.cpp	Mon Jan 10 14:08:20 2011 -0600
+++ b/apps/laskernel.cpp	Tue Jan 11 09:08:12 2011 -0600
@@ -677,8 +677,8 @@
             for(tokenizer::iterator c = rgbs.begin(); c != rgbs.end(); ++c)
                 int color_val = atoi((*c).c_str());
-                if (color_val < std::numeric_limits<boost::uint16_t>::min() ||
-                    color_val > std::numeric_limits<boost::uint16_t>::max())
+                if (color_val < (std::numeric_limits<boost::uint16_t>::min()) ||
+                    color_val > (std::numeric_limits<boost::uint16_t>::max()))
                     ostringstream oss;
                     oss << "Color value must be between 0-65536, not " << color_val;
diff -r 97ca1d940f20 -r 3b90c0b0382e include/liblas/bounds.hpp
--- a/include/liblas/bounds.hpp	Mon Jan 10 14:08:20 2011 -0600
+++ b/include/liblas/bounds.hpp	Tue Jan 11 09:08:12 2011 -0600
@@ -70,7 +70,7 @@
 	typedef T value_type;
-    Range(T mmin=std::numeric_limits<T>::max(), T mmax=std::numeric_limits<T>::min())
+    Range(T mmin=(std::numeric_limits<T>::max()), T mmax=(std::numeric_limits<T>::min()))
         : minimum(mmin), maximum(mmax) {}
@@ -129,7 +129,7 @@
     bool empty(void) const
-        return detail::compare_distance(minimum, std::numeric_limits<T>::max()) && detail::compare_distance(maximum, std::numeric_limits<T>::min());
+        return detail::compare_distance(minimum, (std::numeric_limits<T>::max())) && detail::compare_distance(maximum, (std::numeric_limits<T>::min()));
     void shift(T v)
diff -r 97ca1d940f20 -r 3b90c0b0382e src/color.cpp
--- a/src/color.cpp	Mon Jan 10 14:08:20 2011 -0600
+++ b/src/color.cpp	Tue Jan 11 09:08:12 2011 -0600
@@ -55,9 +55,9 @@
 Color::Color(boost::uint32_t red, boost::uint32_t green, boost::uint32_t blue)
-    if (red > std::numeric_limits<boost::uint16_t>::max() ||
-        green > std::numeric_limits<boost::uint16_t>::max() ||
-        blue > std::numeric_limits<boost::uint16_t>::max())
+    if (red > (std::numeric_limits<boost::uint16_t>::max()) ||
+        green > (std::numeric_limits<boost::uint16_t>::max()) ||
+        blue > (std::numeric_limits<boost::uint16_t>::max()))
         throw_invalid_color_component();
     using boost::uint16_t;
diff -r 97ca1d940f20 -r 3b90c0b0382e src/detail/index/indexcell.cpp
--- a/src/detail/index/indexcell.cpp	Mon Jan 10 14:08:20 2011 -0600
+++ b/src/detail/index/indexcell.cpp	Tue Jan 11 09:08:12 2011 -0600
@@ -51,8 +51,8 @@
 IndexCell::IndexCell() :
 	m_FileOffset(0),
 	m_NumPoints(0),
-	m_MinZ(numeric_limits<ElevExtrema>::max()),
-	m_MaxZ(numeric_limits<ElevExtrema>::min())
+	m_MinZ((std::numeric_limits<ElevExtrema>::max())),
+	m_MaxZ((std::numeric_limits<ElevExtrema>::min()))
 } // IndexCell::IndexCell
@@ -94,7 +94,7 @@
 bool IndexCell::RoomToAdd(boost::uint32_t a)
-	return (m_PtRecords[a] < numeric_limits<ConsecPtAccumulator>::max());
+	return (m_PtRecords[a] < (std::numeric_limits<ConsecPtAccumulator>::max()));
 } // IndexCell::RoomToAdd
 void IndexCell::AddPointRecord(boost::uint32_t a)
@@ -115,7 +115,7 @@
 	if ((MyIT = m_PtRecords.find(a)) != m_PtRecords.end())
-		if (MyIT->second < numeric_limits<ConsecPtAccumulator>::max())
+		if (MyIT->second < (std::numeric_limits<ConsecPtAccumulator>::max()))
 			++MyIT->second;
 			++m_NumPoints;
@@ -148,10 +148,10 @@
 void IndexCell::UpdateZBounds(double TestZ)
-	if (TestZ > numeric_limits<ElevExtrema>::max())
-		m_MaxZ = numeric_limits<ElevExtrema>::max();
-	else if (TestZ < numeric_limits<ElevExtrema>::min())
-		m_MinZ = numeric_limits<ElevExtrema>::min();
+	if (TestZ > (std::numeric_limits<ElevExtrema>::max()))
+		m_MaxZ = (std::numeric_limits<ElevExtrema>::max());
+	else if (TestZ < (std::numeric_limits<ElevExtrema>::min()))
+		m_MinZ = (std::numeric_limits<ElevExtrema>::min());
 	else
 		if (TestZ > m_MaxZ)
@@ -191,7 +191,7 @@
 		if ((YourIT = MyIT->second.find(b)) != MyIT->second.end())
-			if (YourIT->second < numeric_limits<ConsecPtAccumulator>::max())
+			if (YourIT->second < (std::numeric_limits<ConsecPtAccumulator>::max()))
 				++YourIT->second;
 				return true;
@@ -227,7 +227,7 @@
 				++YourIT->second;
 				return true;
diff -r 97ca1d940f20 -r 3b90c0b0382e src/detail/index/indexoutput.cpp
--- a/src/detail/index/indexoutput.cpp	Mon Jan 10 14:08:20 2011 -0600
+++ b/src/detail/index/indexoutput.cpp	Tue Jan 11 09:08:12 2011 -0600
@@ -127,7 +127,7 @@
 		WriteVLRData_n(m_indexVLRHeaderData, TempLong, WritePos);
 		// record length
-		assert(WritePos <= std::numeric_limits<boost::uint16_t>::max());
+		assert(WritePos <= (std::numeric_limits<boost::uint16_t>::max()));
 		m_indexVLRHeaderRecord.SetRecordLength(static_cast<boost::uint16_t>(WritePos));
 		m_indexVLRHeaderData.resize(WritePos);
 		m_indexVLRHeaderRecord.SetData(m_indexVLRHeaderData);
@@ -158,7 +158,7 @@
 			if (! InitializeVLRData(x, y))
 				return false;
-			m_indexVLRTempData.resize(numeric_limits<unsigned short>::max());
+			m_indexVLRTempData.resize((std::numeric_limits<unsigned short>::max()));
 			m_TempWritePos = 0;
 		} // if
@@ -256,7 +256,7 @@
 			// copy data to VLR
 			// if new cell data causes VLR data to exceed limit add VLR to header VLR list and start new VLR
-			if (m_SomeDataReadyToWrite && (m_TempWritePos + m_DataRecordSize > numeric_limits<unsigned short>::max()))
+			if (m_SomeDataReadyToWrite && (m_TempWritePos + m_DataRecordSize > (std::numeric_limits<unsigned short>::max())))
 				m_indexVLRCellPointData.resize(m_DataRecordSize);
 				m_indexVLRCellRecord.SetRecordLength(static_cast<boost::uint16_t>(m_DataRecordSize));
@@ -268,7 +268,7 @@
 				m_DataPointsThisVLR = NumPts;
 			} // if
 			// if size allows, add to VLR cell record data
-			if (m_TempWritePos + m_DataRecordSize <= numeric_limits<unsigned short>::max())
+			if (m_TempWritePos + m_DataRecordSize <= (std::numeric_limits<unsigned short>::max()))
 				boost::uint32_t WritePos = m_DataRecordSize;
 				// update last cell in VLR, x, y
@@ -300,17 +300,17 @@
 				m_DataRecordSize += m_TempWritePos;
 				// write the total size in the common data section
 				// resizing shouldn't be necessary
-				if (m_indexVLRCellPointData.size() != numeric_limits<unsigned short>::max())
-					m_indexVLRCellPointData.resize(numeric_limits<unsigned short>::max());
+				if (m_indexVLRCellPointData.size() != (std::numeric_limits<unsigned short>::max()))
+					m_indexVLRCellPointData.resize((std::numeric_limits<unsigned short>::max()));
 				WriteVLRDataNoInc_n(m_indexVLRCellPointData, m_DataRecordSize, m_VLRDataSizeLocation);
 				// number of points in this VLR - added in Index version 1.1
 				WriteVLRDataNoInc_n(m_indexVLRCellPointData, m_DataPointsThisVLR, m_VLRPointCountLocation);
 				// write out the part that fits in this VLR (excluding the common data)
-				boost::uint32_t WrittenBytes = numeric_limits<unsigned short>::max() - WritePos;
+				boost::uint32_t WrittenBytes = (std::numeric_limits<unsigned short>::max()) - WritePos;
 				WriteVLRDataNoInc_str(m_indexVLRCellPointData, (char * const)&m_indexVLRTempData[0], WrittenBytes, WritePos);
 				// add this VLR
-				m_indexVLRCellRecord.SetRecordLength(static_cast<boost::uint16_t>(numeric_limits<unsigned short>::max()));
+				m_indexVLRCellRecord.SetRecordLength(static_cast<boost::uint16_t>((std::numeric_limits<unsigned short>::max())));
 				m_indexVLRCellRecord.SetData(m_indexVLRCellPointData);
 				m_index->GetIndexHeader()->AddVLR(m_indexVLRCellRecord);
@@ -319,7 +319,7 @@
 				while (UnwrittenBytes > 0)
-					boost::uint32_t NewWrittenBytes = (UnwrittenBytes < numeric_limits<unsigned short>::max() ? UnwrittenBytes: numeric_limits<unsigned short>::max());
+					boost::uint32_t NewWrittenBytes = (UnwrittenBytes < (std::numeric_limits<unsigned short>::max()) ? UnwrittenBytes: (std::numeric_limits<unsigned short>::max()));
 					WriteVLRDataNoInc_str(m_indexVLRCellPointData, (char * const)&m_indexVLRTempData[WrittenBytes], NewWrittenBytes, 0);
 					WrittenBytes += NewWrittenBytes;
 					UnwrittenBytes -= NewWrittenBytes;
@@ -348,7 +348,7 @@
 	try {
 		m_DataRecordSize = m_VLRCommonDataSize;
 		m_DataPointsThisVLR = 0;
@@ -385,7 +385,7 @@
 		#ifdef LIBLAS_INDEX_PADLASTVLR
 			boost::uint32_t PadBytes = m_DataRecordSize % 4;
-			if (PadBytes && (m_DataRecordSize + PadBytes <= numeric_limits<unsigned short>::max()))
+			if (PadBytes && (m_DataRecordSize + PadBytes <= (std::numeric_limits<unsigned short>::max())))
 				m_DataRecordSize += PadBytes;
 				for (boost::uint32_t i = 0; i < PadBytes; ++i)
diff -r 97ca1d940f20 -r 3b90c0b0382e src/detail/reader/cachedreader.cpp
--- a/src/detail/reader/cachedreader.cpp	Mon Jan 10 14:08:20 2011 -0600
+++ b/src/detail/reader/cachedreader.cpp	Tue Jan 11 09:08:12 2011 -0600
@@ -98,9 +98,9 @@
     m_cache_start_position = position;
     cache_mask_type::size_type header_size = static_cast<cache_mask_type::size_type>(m_header->GetPointRecordsCount());
-    cache_mask_type::size_type left_to_cache = std::min(m_cache_size, header_size - m_cache_start_position);
+    cache_mask_type::size_type left_to_cache = (std::min)(m_cache_size, header_size - m_cache_start_position);
-    cache_mask_type::size_type to_mark = std::min(m_cache_size, header_size - old_cache_start_position);
+    cache_mask_type::size_type to_mark = (std::min)(m_cache_size, header_size - old_cache_start_position);
     for (uint32_t i = 0; i < to_mark; ++i)
@@ -290,7 +290,7 @@
     typedef cache_mask_type::size_type size_type;
     size_type old_cache_start_position = m_cache_start_position;
     size_type header_size = static_cast<size_type>(m_header->GetPointRecordsCount());
-    size_type to_mark = std::min(m_cache_size, header_size - old_cache_start_position);
+    size_type to_mark = (std::min)(m_cache_size, header_size - old_cache_start_position);
     for (uint32_t i = 0; i < to_mark; ++i) {
diff -r 97ca1d940f20 -r 3b90c0b0382e src/schema.cpp
--- a/src/schema.cpp	Mon Jan 10 14:08:20 2011 -0600
+++ b/src/schema.cpp	Tue Jan 11 09:08:12 2011 -0600
@@ -768,11 +768,11 @@
         data.push_back(*i);
-    if (data.size() > std::numeric_limits<boost::uint16_t>::max()) {
+    if (data.size() > (std::numeric_limits<boost::uint16_t>::max())) {
         std::ostringstream oss;
         oss << "This schema with length " << data.size() << " does"
             << " not fit within the maximum VLR size of "
-            << std::numeric_limits<boost::uint16_t>::max();
+            << (std::numeric_limits<boost::uint16_t>::max());
         throw std::runtime_error(oss.str());
     vlr.SetData(data);
diff -r 97ca1d940f20 -r 3b90c0b0382e src/spatialreference.cpp
--- a/src/spatialreference.cpp	Mon Jan 10 14:08:20 2011 -0600
+++ b/src/spatialreference.cpp	Tue Jan 11 09:08:12 2011 -0600
@@ -380,13 +380,13 @@
          record.SetData(data);
More information about the Liblas-commits mailing list
