[Liblas-commits] hg: fix up ts2las. It was quite broken after the point refactor...
liblas-commits at liblas.org liblas-commits at liblas.org
Tue Jan 11 11:49:28 EST 2011
details:   http://hg.liblas.orghg/rev/47ff872c9d5b
changeset: 2721:47ff872c9d5b
user:      Howard Butler <hobu.inc at gmail.com>
date:      Tue Jan 11 10:49:21 2011 -0600
description:
fix up ts2las.  It was quite broken after the point refactoring and used some old idioms that we no longer use -- providing a bad example
diffstat:
 apps/CMakeLists.txt |    2 +-
 apps/ts2las.cpp     |  467 ++++++++++++++++++++++++++++-----------------------
 2 files changed, 260 insertions(+), 209 deletions(-)
diffs (truncated from 569 to 300 lines):
diff -r 3b90c0b0382e -r 47ff872c9d5b apps/CMakeLists.txt
--- a/apps/CMakeLists.txt	Tue Jan 11 09:08:12 2011 -0600
+++ b/apps/CMakeLists.txt	Tue Jan 11 10:49:21 2011 -0600
@@ -132,7 +132,7 @@
 endif()
 if(TS2LAS)
-    add_executable(${TS2LAS} ts2las.cpp )
+    add_executable(${TS2LAS} ts2las.cpp laskernel.cpp)
     target_link_libraries(${TS2LAS} ${APPS_CPP_DEPENDENCIES} )
 endif()
diff -r 3b90c0b0382e -r 47ff872c9d5b apps/ts2las.cpp
--- a/apps/ts2las.cpp	Tue Jan 11 09:08:12 2011 -0600
+++ b/apps/ts2las.cpp	Tue Jan 11 10:49:21 2011 -0600
@@ -11,6 +11,21 @@
 // http://www.opensource.org/licenses/bsd-license.php)
 #include "ts2las.hpp"
+#include "laskernel.hpp"
+// boost
+#ifdef _MSC_VER
+#pragma warning(push)
+#pragma warning(disable : 4512)
+#endif
+#include <boost/program_options.hpp>
+#ifdef _MSC_VER
+#pragma warning(pop)
+#endif
+namespace po = boost::program_options;
 #include <fstream>
 #include <iostream>
@@ -18,55 +33,55 @@
 using namespace liblas;
-std::istream* OpenInput(std::string filename)
-    std::ios::openmode const mode = std::ios::in | std::ios::binary;
-    std::istream* istrm;
-    if (compare_no_case(filename.c_str(),"STDIN",5) == 0)
-        istrm = &std::cin;
-    else
-        istrm = new std::ifstream(filename.c_str(), mode);
-    if (!istrm->good())
-        delete istrm;
-        throw std::runtime_error("Reading stream was not able to be created");
-        exit(1);
-    return istrm;
+// std::istream* OpenInput(std::string filename)
+//     std::ios::openmode const mode = std::ios::in | std::ios::binary;
+//     std::istream* istrm;
+//     if (compare_no_case(filename.c_str(),"STDIN",5) == 0)
+//         istrm = &std::cin;
+//     else
+//         istrm = new std::ifstream(filename.c_str(), mode);
+//     if (!istrm->good())
+//         delete istrm;
+//         throw std::runtime_error("Reading stream was not able to be created");
+//         exit(1);
+//     return istrm;
+// std::ostream* OpenOutput(std::string filename)
+//     std::ostream* ostrm;
+//     std::ios::openmode m;
+//     m = std::ios::out | std::ios::binary | std::ios::ate;
+//     if (compare_no_case(filename.c_str(),"STOUT",5) == 0)
+//         ostrm = &std::cout;
+//     else
+//         ostrm = new std::ofstream(filename.c_str(), m);
+//     if (!ostrm->good())
+//         delete ostrm;
+//         throw std::runtime_error("Writing stream was not able to be created");
+//         exit(1);
+//     return ostrm;
-std::ostream* OpenOutput(std::string filename)
-    std::ostream* ostrm;
-    std::ios::openmode m;
-    m = std::ios::out | std::ios::binary | std::ios::ate;
-    if (compare_no_case(filename.c_str(),"STOUT",5) == 0)
-        ostrm = &std::cout;
-    else
-        ostrm = new std::ofstream(filename.c_str(), m);
-    if (!ostrm->good())
-        delete ostrm;
-        throw std::runtime_error("Writing stream was not able to be created");
-        exit(1);
-    return ostrm;
-liblas::Header CreateHeader(ScanHdr* hdr)
+liblas::Header CreateHeader(ScanHdr* hdr, bool verbose)
     liblas::Header header;
@@ -84,25 +99,42 @@
     header.SetVersionMinor(2);
     header.SetDataFormatId(format);
-    // header.SetPointRecordsCount(hdr->PntCnt);
-    std::cout << "units: " << hdr->Units << std::endl;
-    std::cout << "format: " << format << std::endl;
     double scale = 1.0/(double)hdr->Units;
-    std::cout << "scale: " << scale << std::endl;
     header.SetScale(scale, scale, scale);
     header.SetOffset(hdr->OrgX*scale, hdr->OrgY*scale, hdr->OrgZ*scale);
-    std::cout << "offset x: " << header.GetOffsetX()
-              << " offset y: " << header.GetOffsetY()
-              << " offset z: " <<header.GetOffsetZ() << std::endl;
+    header.SetPointRecordsCount(hdr->PntCnt);
+    if (verbose)
+        std::cout << "The file says there should be " << hdr->PntCnt << " points" << std::endl;
+        std::cout << "units: " << hdr->Units << std::endl;
+        std::cout << "format: " << format << std::endl;
+        std::cout << "scale: " << scale << std::endl;
+        std::cout << "x origin: " << hdr->OrgX << std::endl;
+        std::cout << "y origin: " << hdr->OrgY << std::endl;
+        std::cout << "z origin: " << hdr->OrgZ << std::endl;
+        boost::uint32_t precision = GetStreamPrecision(scale);
+        std::cout.setf(std::ios_base::fixed, std::ios_base::floatfield);
+        std::cout.precision(precision);
+        std::cout << "offset x: " << header.GetOffsetX() << std::endl;
+        std::cout << "offset y: " << header.GetOffsetY() << std::endl;
+        std::cout << "offset z: " << header.GetOffsetZ() << std::endl;
     return header;
-bool ReadHeader(ScanHdr* hdr, std::istream* istrm)
+bool ReadHeader(ScanHdr* hdr, std::istream& istrm)
     try
-        liblas::detail::read_n(*hdr, *istrm, sizeof(ScanHdr));
+        liblas::detail::read_n(*hdr, istrm, sizeof(ScanHdr));
         if (hdr->Tunniste != 970401) return false;
         if (memcmp(hdr->Magic,"CXYZ",4)) return false;
@@ -115,127 +147,145 @@
         if (( version > 20020715) && (version < 20051231)) return true;
         return false;
-    catch (std::exception const)
+    catch (std::exception const&)
         return false;
-bool WritePoints(liblas::Writer* writer, std::istream* strm, ScanHdr* hdr)
+bool WritePoints(liblas::Writer& writer, std::istream& strm, ScanHdr* hdr, bool verbose)
     ScanPnt* point = new ScanPnt;
     ScanRow* row = new ScanRow;
-    while (true)
+    boost::uint32_t i = 0;
+    for (std::size_t t = 0; t < static_cast<std::size_t>(hdr->PntCnt); t++)
-///std::cout << "We have header version" << std::endl;
-            try
+        if (hdr->HdrVersion == 20020715) {
+            try
-                // std::cout << "stream position is: " << strm->tellg() << std::endl;
-                if (hdr->HdrVersion == 20020715) {
-                    liblas::detail::read_n(*point, *strm, sizeof(ScanPnt));
-                } else{
-                    liblas::detail::read_n(*row, *strm, sizeof(ScanRow));
-                    point->Pnt.x = row->x;
-                    point->Pnt.y = row->y;
-                    point->Pnt.z = row->z;
-                    point->Code = row->Code;
-                    point->Line = row->Line;
-                    point->Intensity = row->EchoInt & 0x3FFF;
-                    point->Echo = (row->EchoInt >> 14);
-                Point p;
-                p.SetCoordinates( point->Pnt.x,
-                                    point->Pnt.y,
-                                    point->Pnt.z);
-                // std::cout << "read x: " << point->Pnt.x << " y: "<< point->Pnt.y << " z: " <<point->Pnt.z<< std::endl;
-                // std::cout << "wrote x: " << p.GetX() << " y: "<< p.GetY() << " z: " <<p.GetZ()<< std::endl;
-                // std::cout << "Code: " << point->Code << " Intensity: "<< point->Intensity << std::endl;
-                p.SetClassification(point->Code);
-                p.SetIntensity(point->Intensity);
-                if (hdr->Time) {
-                    boost::uint32_t t = 0xFFFFFFFF;
-                    liblas::detail::read_n(t, *strm, sizeof(t));
-                    // Time stamps are assumed to be GPS week seconds. The
-                    // storage format is a 32 bit unsigned integer where
-                    // each integer step is 0.0002 seconds.
-                    p.SetTime(t*0.0002);
-                if (hdr->Color) {
-                    boost::uint8_t r, g, b, a = 0;
-                    liblas::Color color;
-                    liblas::detail::read_n(r, *strm, sizeof(r));
-                    liblas::detail::read_n(b, *strm, sizeof(b));
-                    liblas::detail::read_n(g, *strm, sizeof(g));
-                    // TS .bin says to read 4 bytes here for some reason.  Maybe
-                    // this is an alpha value or something
-                    liblas::detail::read_n(a, *strm, sizeof(a));
-                    color.SetGreen(g);
-                    color.SetBlue(b);
-                    color.SetRed(r);
-                    p.SetColor(color);
-                // Set return number
-                    TerraScan uses two bits for storing echo information. The possible values are:
-                    0 Only echo
-                    1 First of many echo
-                    2 Intermediate echo
-                    3 Last of many echo
-                if (point->Echo == 0) {
-                    p.SetNumberOfReturns(1);
-                    p.SetReturnNumber(1);
-                } else if (point->Echo == 1) {
-                } else if (point->Echo == 3) {
-                    p.SetReturnNumber(2);
-                    p.SetNumberOfReturns(2);
-                } else {
-                    // I don't know what the hell to do here without cumulating
-                    // through all of the points.  Why wouldn't you store the return
-                    // number?!
-                    p.SetNumberOfReturns(3);
-                try {
-                    writer->WritePoint(p);
-                } catch (std::exception)
More information about the Liblas-commits mailing list
