[Liblas-commits] hg: added FileClose() support
liblas-commits at liblas.org
Wed Jan 12 16:44:31 EST 2011
details: http://hg.liblas.orghg/rev/5e840e292b2f
changeset: 2742:5e840e292b2f
user: Michael P. Gerlek <mpg at flaxen.com>
date: Wed Jan 12 13:39:02 2011 -0800
description:
Subject: hg: bindings almost working - still need to address the usual raft of lifetime/scoping issues
details: http://hg.liblas.orghg/rev/4df356157248
changeset: 2743:4df356157248
date: Wed Jan 12 13:39:43 2011 -0800
description:
Subject: hg: always remove the old laszip vlr (bug when doing "las2las -i x.laz -o y.laz")
details: http://hg.liblas.orghg/rev/09cdae390de2
changeset: 2744:09cdae390de2
date: Wed Jan 12 13:43:56 2011 -0800
description:
Subject: hg: pull-merge
details: http://hg.liblas.orghg/rev/a6dfd2c975c3
changeset: 2745:a6dfd2c975c3
date: Wed Jan 12 13:44:23 2011 -0800
description:
pull-merge
diffstat:
csharp-new/liblas_swig_cpp/liblas.i | 65 +++++--
csharp-new/liblas_swig_cpp/liblas_swig_cpp.vcxproj | 32 +--
csharp-new/liblas_swig_cs/liblas_swig_cs.csproj | 5 +-
csharp-new/liblas_swig_test/Program.cs | 168 ++++++++++++++++---
csharp-new/liblas_swig_test/TestGuid.cs | 35 ++++
csharp-new/liblas_swig_test/TestHeader.cs | 74 ++++++++
csharp-new/liblas_swig_test/TestPoint.cs | 46 +++++
csharp-new/liblas_swig_test/TestReader.cs | 31 +++
csharp-new/liblas_swig_test/TestSpatialReference.cs | 23 ++
csharp-new/liblas_swig_test/TestVariableRecord.cs | 47 +++++
csharp-new/liblas_swig_test/liblas_swig_test.csproj | 5 +-
include/liblas/detail/reader/zipreader.hpp | 6 +-
include/liblas/factory.hpp | 2 +
src/detail/reader/zipreader.cpp | 10 +-
src/detail/writer/header.cpp | 1 +
src/detail/zippoint.cpp | 6 +
src/factory.cpp | 18 ++
17 files changed, 492 insertions(+), 82 deletions(-)
diffs (truncated from 877 to 300 lines):
diff -r e3efe5548e3b -r a6dfd2c975c3 csharp-new/liblas_swig_cpp/liblas.i
--- a/csharp-new/liblas_swig_cpp/liblas.i Wed Jan 12 10:50:47 2011 -0600
+++ b/csharp-new/liblas_swig_cpp/liblas.i Wed Jan 12 13:44:23 2011 -0800
@@ -38,12 +38,13 @@
* OF SUCH DAMAGE.
-%module WrapperCpp
+%module liblas_swig_cpp
#include "liblas/liblas.hpp"
#include "liblas/version.hpp"
#include "liblas/reader.hpp"
+#include "liblas/writer.hpp"
#include "liblas/classification.hpp"
#include "liblas/header.hpp"
#include "liblas/point.hpp"
@@ -105,8 +106,8 @@
class guid
public:
- std::string to_string() const;
- //void output_data(boost::uint32_t& d1, boost::uint16_t& d2, boost::uint16_t& d3, boost::uint8_t (&d4)[8]) const;
+ guid(char const* const str);
+ std::string to_string() const;
@@ -175,13 +176,11 @@
class VariableRecord
public:
- boost::uint16_t GetReserved() const;
- std::string GetUserId(bool pad ) const;
+ std::string GetUserId(bool pad) const;
boost::uint16_t GetRecordId() const;
boost::uint16_t GetRecordLength() const;
- std::string GetDescription(bool pad ) const;
+ std::string GetDescription(bool pad) const;
std::vector<boost::uint8_t> const& GetData() const;
- std::size_t GetTotalSize() const;
@@ -213,17 +212,30 @@
class Header
public:
+ Header(Header const& other);
std::string GetFileSignature() const;
boost::uint16_t GetFileSourceId() const;
+ void SetFileSourceId(boost::uint16_t v);
guid GetProjectId() const;
+ void SetProjectId(guid const& v);
boost::uint8_t GetVersionMajor() const;
+ void SetVersionMajor(boost::uint8_t v);
boost::uint8_t GetVersionMinor() const;
+ void SetVersionMinor(boost::uint8_t v);
std::string GetSystemId(bool pad = false) const;
+ void SetSystemId(std::string const& v);
std::string GetSoftwareId(bool pad = false) const;
+ void SetSoftwareId(std::string const& v);
boost::uint16_t GetCreationDOY() const;
+ void SetCreationDOY(boost::uint16_t v);
boost::uint16_t GetCreationYear() const;
+ void SetCreationYear(boost::uint16_t v);
+ PointFormatName GetDataFormatId() const;
+ void SetDataFormatId(PointFormatName v);
boost::uint32_t GetRecordsCount() const;
- PointFormatName GetDataFormatId() const;
boost::uint32_t GetPointRecordsCount() const;
double GetScaleX() const;
@@ -238,12 +250,17 @@
double GetMinY() const;
double GetMaxZ() const;
double GetMinZ() const;
+ void SetScale(double x, double y, double z);
+ void SetOffset(double x, double y, double z);
+ void SetMax(double x, double y, double z);
+ void SetMin(double x, double y, double z);
const std::vector<VariableRecord>& GetVLRs() const;
SpatialReference GetSRS() const;
bool Compressed() const;
+ void SetCompressed(bool b);
@@ -266,30 +283,34 @@
+class Writer
+public:
+ Writer(std::ostream& ofs, Header const& header);
+ Header const& GetHeader() const;
+ bool WritePoint(Point const& point);
+ //void WriteHeader(Header& header);
+ //void SetFilters(std::vector<liblas::FilterPtr> const& filters);
+ //void SetTransforms(std::vector<liblas::TransformPtr> const& transforms);
class ReaderFactory
public:
Reader CreateCached(std::istream& stream, boost::uint32_t cache_size);
Reader CreateWithStream(std::istream& stream);
static std::istream* FileOpen(std::string const& filename);
+ static void FileClose(std::istream*);
class WriterFactory
public:
- enum FileType
- FileType_Unknown,
- FileType_LAS,
- FileType_LAZ
- //static WriterIPtr CreateWithStream(std::ostream& stream, Header const& header);
- static FileType InferFileTypeFromExtension(const std::string&);
- static std::ostream* WriterFactory::FileCreate(std::string const& filename);
+ static std::ostream* FileCreate(std::string const& filename);
+ static void FileClose(std::ostream*);
-}; // end namespace
+}; // namespace
diff -r e3efe5548e3b -r a6dfd2c975c3 csharp-new/liblas_swig_cpp/liblas_swig_cpp.vcxproj
--- a/csharp-new/liblas_swig_cpp/liblas_swig_cpp.vcxproj Wed Jan 12 10:50:47 2011 -0600
+++ b/csharp-new/liblas_swig_cpp/liblas_swig_cpp.vcxproj Wed Jan 12 13:44:23 2011 -0800
@@ -23,34 +23,28 @@
<FileType>Document</FileType>
<Command Condition="'$(Configuration)|$(Platform)'=='Debug|x64'">swig.exe -c++ -csharp -outdir ../liblas_swig_cs -namespace Liblas -o liblas_wrap.cpp "%(FullPath)"
</Command>
- <Command Condition="'$(Configuration)|$(Platform)'=='Debug|Win32'">echo Invoking SWIG...
-echo on
-..\..\..\swig.exe -csharp "%(FullPath)"
-%40echo off
+ <Command Condition="'$(Configuration)|$(Platform)'=='Debug|Win32'">swig.exe -c++ -csharp -outdir ../liblas_swig_cs -namespace Liblas -o liblas_wrap.cpp "%(FullPath)"
</Command>
<AdditionalInputs Condition="'$(Configuration)|$(Platform)'=='Debug|Win32'">
</AdditionalInputs>
- <Command Condition="'$(Configuration)|$(Platform)'=='Release|Win32'">echo Invoking SWIG...
-echo on
-%40echo off
+ <Command Condition="'$(Configuration)|$(Platform)'=='Release|Win32'">swig.exe -c++ -csharp -outdir ../liblas_swig_cs -namespace Liblas -o liblas_wrap.cpp "%(FullPath)"
</Command>
<AdditionalInputs Condition="'$(Configuration)|$(Platform)'=='Release|Win32'">
</AdditionalInputs>
<AdditionalInputs Condition="'$(Configuration)|$(Platform)'=='Debug|x64'">
</AdditionalInputs>
- <Command Condition="'$(Configuration)|$(Platform)'=='Release|x64'">echo Invoking SWIG...
-echo on
-%40echo off
+ <Command Condition="'$(Configuration)|$(Platform)'=='Release|x64'">swig.exe -c++ -csharp -outdir ../liblas_swig_cs -namespace Liblas -o liblas_wrap.cpp "%(FullPath)"
</Command>
<AdditionalInputs Condition="'$(Configuration)|$(Platform)'=='Release|x64'">
</AdditionalInputs>
<Outputs Condition="'$(Configuration)|$(Platform)'=='Debug|x64'">%(Filename)_wrap.cpp;%(Outputs)</Outputs>
- <Outputs Condition="'$(Configuration)|$(Platform)'=='Debug|Win32'">%(Filename)_wrap.c;%(Outputs)</Outputs>
- <Outputs Condition="'$(Configuration)|$(Platform)'=='Release|Win32'">%(Filename)_wrap.c;%(Outputs)</Outputs>
- <Outputs Condition="'$(Configuration)|$(Platform)'=='Release|x64'">%(Filename)_wrap.c;%(Outputs)</Outputs>
+ <Outputs Condition="'$(Configuration)|$(Platform)'=='Debug|Win32'">%(Filename)_wrap.cpp;%(Outputs)</Outputs>
+ <Outputs Condition="'$(Configuration)|$(Platform)'=='Release|Win32'">%(Filename)_wrap.cpp;%(Outputs)</Outputs>
+ <Outputs Condition="'$(Configuration)|$(Platform)'=='Release|x64'">%(Filename)_wrap.cpp;%(Outputs)</Outputs>
<Message Condition="'$(Configuration)|$(Platform)'=='Debug|x64'">Invoking SWIG...</Message>
+ <Message Condition="'$(Configuration)|$(Platform)'=='Debug|Win32'">Invoking SWIG...</Message>
+ <Message Condition="'$(Configuration)|$(Platform)'=='Release|Win32'">Invoking SWIG...</Message>
+ <Message Condition="'$(Configuration)|$(Platform)'=='Release|x64'">Invoking SWIG...</Message>
</CustomBuild>
</ItemGroup>
<ItemGroup>
@@ -130,9 +124,9 @@
</ClCompile>
<Link>
<GenerateDebugInformation>true</GenerateDebugInformation>
- <AdditionalDependencies>C:\Program Files (x86)\boost\boost_1_44\lib\libboost_program_options-vc100-mt-gd-1_44.lib;%(AdditionalDependencies);C:\Program Files (x86)\boost\boost_1_44\lib\libboost_serialization-vc100-mt-gd-1_44.lib;c:\dev\liblas\bin\RelWithDebInfo\Debug\liblas.lib</AdditionalDependencies>
+ <AdditionalDependencies>%(AdditionalDependencies);c:\dev\liblas\bin\Debug\Debug\liblas.lib</AdditionalDependencies>
<OutputFile>$(OutDir)$(TargetName)$(TargetExt)</OutputFile>
- <AdditionalLibraryDirectories>C:/Program Files (x86)/boost/boost_1_44/lib;C:/Program Files (x86)/boost/boost_1_44/lib/$(Configuration);%(AdditionalLibraryDirectories)</AdditionalLibraryDirectories>
+ <AdditionalLibraryDirectories>%(AdditionalLibraryDirectories)</AdditionalLibraryDirectories>
</Link>
</ItemDefinitionGroup>
<ItemDefinitionGroup Condition="'$(Configuration)|$(Platform)'=='Debug|x64'">
@@ -148,7 +142,7 @@
+ <AdditionalLibraryDirectories>C:\Program Files (x86)\boost\boost_1_44\lib;%(AdditionalLibraryDirectories)</AdditionalLibraryDirectories>
</Link>
<ItemDefinitionGroup Condition="'$(Configuration)|$(Platform)'=='Release|Win32'">
@@ -162,6 +156,7 @@
<EnableCOMDATFolding>true</EnableCOMDATFolding>
<OptimizeReferences>true</OptimizeReferences>
+ <AdditionalDependencies>%(AdditionalDependencies);c:\dev\liblas\bin\Release\Release\liblas.lib</AdditionalDependencies>
</Link>
<ItemDefinitionGroup Condition="'$(Configuration)|$(Platform)'=='Release|x64'">
@@ -175,6 +170,7 @@
</Link>
<Import Project="$(VCTargetsPath)\Microsoft.Cpp.targets" />
diff -r e3efe5548e3b -r a6dfd2c975c3 csharp-new/liblas_swig_cs/liblas_swig_cs.csproj
--- a/csharp-new/liblas_swig_cs/liblas_swig_cs.csproj Wed Jan 12 10:50:47 2011 -0600
+++ b/csharp-new/liblas_swig_cs/liblas_swig_cs.csproj Wed Jan 12 13:44:23 2011 -0800
@@ -91,6 +91,8 @@
<Compile Include="Color.cs" />
<Compile Include="guid.cs" />
<Compile Include="Header.cs" />
+ <Compile Include="liblas_swig_cpp.cs" />
+ <Compile Include="liblas_swig_cppPINVOKE.cs" />
<Compile Include="Point.cs" />
<Compile Include="PointFormatName.cs" />
<Compile Include="Properties\AssemblyInfo.cs" />
@@ -103,8 +105,7 @@
<Compile Include="VectorU32.cs" />
<Compile Include="VectorU8.cs" />
<Compile Include="VectorVariableRecord.cs" />
- <Compile Include="WrapperCpp.cs" />
- <Compile Include="WrapperCppPINVOKE.cs" />
+ <Compile Include="Writer.cs" />
<Compile Include="WriterFactory.cs" />
</ItemGroup>
<Import Project="$(MSBuildToolsPath)\Microsoft.CSharp.targets" />
diff -r e3efe5548e3b -r a6dfd2c975c3 csharp-new/liblas_swig_test/Program.cs
--- a/csharp-new/liblas_swig_test/Program.cs Wed Jan 12 10:50:47 2011 -0600
+++ b/csharp-new/liblas_swig_test/Program.cs Wed Jan 12 13:44:23 2011 -0800
@@ -50,6 +50,10 @@
public class Program
+ static string fileA = @"..\..\test\data\1.2-with-color.las";
+ static string fileB = @"..\..\test\data\1.2-with-color.laz";
+ static string fileT = @"tmp.laz";
static public bool IsApprox(double a, double b, double tol)
double min = Math.Min(a, b);
@@ -62,43 +66,143 @@
static int Main(string[] args)
- string fileA = @"..\..\test\data\1.2-with-color.las";
- string fileB = @"..\..\test\data\1.2-with-color.laz";
- ReaderFactory factory = new ReaderFactory();
+ // reader tests for A
+ Test_ReadA();
- // tests for A
- SWIGTYPE_p_std__istream ifs = Liblas.ReaderFactory.FileOpen(fileA);
+ // reader tests for B
+ Test_ReadB();
- Reader reader = factory.CreateWithStream(ifs);
- TestReader.Test_A(reader);
+ // writer tests
+ Test_WriteT();
- Header header = reader.GetHeader();
- TestHeader.Test_A(header);
- bool ok = reader.ReadPointAt(2);
- Debug.Assert(ok);
- Point pt = reader.GetPoint();
- TestPoint.Test_A2(pt);
- // tests for B
- SWIGTYPE_p_std__istream ifs = Liblas.ReaderFactory.FileOpen(fileB);
- TestReader.Test_B(reader);
More information about the Liblas-commits
