[Liblas-commits] laszip: pull-merge
liblas-commits at liblas.org
Wed Jan 12 16:57:13 EST 2011
details: http://hg.liblas.orglaszip/rev/d464a9150b13
changeset: 143:d464a9150b13
user: Michael P. Gerlek <mpg at flaxen.com>
date: Wed Jan 12 13:55:19 2011 -0800
description:
pull-merge
diffstat:
include/laszip/export.hpp | 23 -----------
include/laszip/laszipexport.hpp | 23 +++++++++++
src/CMakeLists.txt | 2 +-
src/lasreaditemcompressed_v1.cpp | 1 +
src/laswriteitemcompressed_v1.cpp | 1 +
src/laswritepoint.cpp | 76 ++++++++++++++++++++------------------
tools/laszippertest.cpp | 45 ++++++++++++++++++----
7 files changed, 101 insertions(+), 70 deletions(-)
diffs (truncated from 377 to 300 lines):
diff -r cd0c52aa33c2 -r d464a9150b13 include/laszip/export.hpp
--- a/include/laszip/export.hpp Wed Jan 12 13:28:11 2011 -0800
+++ /dev/null Thu Jan 01 00:00:00 1970 +0000
@@ -1,23 +0,0 @@
-/* DLL export definitions for LASzip */
-#ifndef LASZIPEXPORT_H
-#define LASZIPEXPORT_H
-#ifndef LASZIP_DLL
-#if (defined(_MSC_VER) || defined __CYGWIN__) && !defined(LAS_DISABLE_DLL)
- #if defined(LASZIP_DLL_EXPORT)
- # define LASZIP_DLL __declspec(dllexport)
- #elif defined(LASZIP_DLL_IMPORT)
- # define LASZIP_DLL __declspec(dllimport)
- #endif
-#else
- # if defined(USE_GCC_VISIBILITY_FLAG)
- # define LASZIP_DLL __attribute__ ((visibility("default")))
- # else
- # endif
-#endif
-#endif
-#endif
diff -r cd0c52aa33c2 -r d464a9150b13 include/laszip/laszipexport.hpp
--- /dev/null Thu Jan 01 00:00:00 1970 +0000
+++ b/include/laszip/laszipexport.hpp Wed Jan 12 13:55:19 2011 -0800
@@ -0,0 +1,23 @@
+/* DLL export definitions for LASzip */
+#ifndef LASZIPEXPORT_H
+#define LASZIPEXPORT_H
+#ifndef LASZIP_DLL
+#if (defined(_MSC_VER) || defined __CYGWIN__) && !defined(LAS_DISABLE_DLL)
+ #if defined(LASZIP_DLL_EXPORT)
+ # define LASZIP_DLL __declspec(dllexport)
+ #elif defined(LASZIP_DLL_IMPORT)
+ # define LASZIP_DLL __declspec(dllimport)
+ #endif
+#else
+ # if defined(USE_GCC_VISIBILITY_FLAG)
+ # define LASZIP_DLL __attribute__ ((visibility("default")))
+ # else
+ # endif
+#endif
+#endif
+#endif
diff -r cd0c52aa33c2 -r d464a9150b13 src/CMakeLists.txt
--- a/src/CMakeLists.txt Wed Jan 12 13:28:11 2011 -0800
+++ b/src/CMakeLists.txt Wed Jan 12 13:55:19 2011 -0800
@@ -9,7 +9,7 @@
set(LASZIP_HEADERS_DIR ../include/laszip)
set(LASZIP_HPP
- ${LASZIP_HEADERS_DIR}/export.hpp
+ ${LASZIP_HEADERS_DIR}/laszipexport.hpp
${LASZIP_HEADERS_DIR}/laszip.hpp
${LASZIP_HEADERS_DIR}/laszipper.hpp
${LASZIP_HEADERS_DIR}/lasunzipper.hpp
diff -r cd0c52aa33c2 -r d464a9150b13 src/lasreaditemcompressed_v1.cpp
--- a/src/lasreaditemcompressed_v1.cpp Wed Jan 12 13:28:11 2011 -0800
+++ b/src/lasreaditemcompressed_v1.cpp Wed Jan 12 13:55:19 2011 -0800
@@ -290,6 +290,7 @@
LASreadItemCompressed_GPSTIME11_v1::~LASreadItemCompressed_GPSTIME11_v1()
dec->destroySymbolModel(m_gpstime_multi);
+ dec->destroySymbolModel(m_gpstime_0diff);
delete ic_gpstime;
diff -r cd0c52aa33c2 -r d464a9150b13 src/laswriteitemcompressed_v1.cpp
--- a/src/laswriteitemcompressed_v1.cpp Wed Jan 12 13:28:11 2011 -0800
+++ b/src/laswriteitemcompressed_v1.cpp Wed Jan 12 13:55:19 2011 -0800
@@ -292,6 +292,7 @@
LASwriteItemCompressed_GPSTIME11_v1::~LASwriteItemCompressed_GPSTIME11_v1()
enc->destroySymbolModel(m_gpstime_multi);
+ enc->destroySymbolModel(m_gpstime_0diff);
delete ic_gpstime;
diff -r cd0c52aa33c2 -r d464a9150b13 src/laswritepoint.cpp
--- a/src/laswritepoint.cpp Wed Jan 12 13:28:11 2011 -0800
+++ b/src/laswritepoint.cpp Wed Jan 12 13:55:19 2011 -0800
@@ -16,40 +16,40 @@
- FILE: laswritepoint.cpp
- CONTENTS:
- see corresponding header file
- PROGRAMMERS:
- martin isenburg at cs.unc.edu
- COPYRIGHT:
- copyright (C) 2007-10 martin isenburg at cs.unc.edu
- This software is distributed in the hope that it will be useful,
- but WITHOUT ANY WARRANTY; without even the implied warranty of
- MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
- CHANGE HISTORY:
-#include "laswritepoint.hpp"
+ FILE: laswritepoint.cpp
+ CONTENTS:
+ see corresponding header file
+ PROGRAMMERS:
+ martin isenburg at cs.unc.edu
+ COPYRIGHT:
+ copyright (C) 2007-10 martin isenburg at cs.unc.edu
+ This software is distributed in the hope that it will be useful,
+ but WITHOUT ANY WARRANTY; without even the implied warranty of
+ MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
+ CHANGE HISTORY:
+#include "laswritepoint.hpp"
#include "arithmeticencoder.hpp"
-#ifdef LASZIP_HAVE_RANGECODER
+#ifdef LASZIP_HAVE_RANGECODER
#include "rangeencoder.hpp"
-#endif
+#endif
#include "laswriteitemraw.hpp"
#include "laswriteitemcompressed_v1.hpp"
@@ -81,11 +81,11 @@
case LASzip::POINT_BY_POINT_RAW:
enc = 0;
break;
case LASzip::POINT_BY_POINT_RANGE:
enc = new RangeEncoder();
break;
-#endif
+#endif
case LASzip::POINT_BY_POINT_ARITHMETIC:
enc = new ArithmeticEncoder();
break;
@@ -222,7 +222,7 @@
return TRUE;
BOOL LASwritePoint::done()
if (enc)
@@ -232,16 +232,17 @@
return TRUE;
-LASwritePoint::~LASwritePoint()
+LASwritePoint::~LASwritePoint()
U32 i;
if (writers_raw)
for (i = 0; i < num_writers; i++)
delete writers_raw[i];
+ delete[] writers_raw;
if (writers_compressed)
@@ -249,9 +250,10 @@
delete writers_compressed[i];
+ delete[] writers_compressed;
if (enc)
delete enc;
diff -r cd0c52aa33c2 -r d464a9150b13 tools/laszippertest.cpp
--- a/tools/laszippertest.cpp Wed Jan 12 13:28:11 2011 -0800
+++ b/tools/laszippertest.cpp Wed Jan 12 13:55:19 2011 -0800
@@ -142,7 +142,10 @@
LASzipper* laszipper1 = new LASzipper(); // without compression
LASzipper* laszipper2 = new LASzipper(); // with arithmetic compression
- LASzipper* laszipper3 = new LASzipper(); // with range compression
+ LASzipper* laszipper3 = NULL;
+ laszipper3 = new LASzipper(); // with range compression
+#endif
if (use_iostream)
@@ -174,6 +177,7 @@
return 0;
#ifdef LZ_WIN32_VC6
ofb3.open("test3.lax", ios::out);
ofb3.setmode(filebuf::binary);
@@ -187,6 +191,9 @@
fprintf(stderr, "ERROR: could not open laszipper3\n");
return 0;
+#else
+ fprintf(stderr, "(skipping range coder test)\n");
+#endif
else
@@ -204,12 +211,16 @@
return 0;
ofile3 = fopen("test3.lax", "wb");
if (laszipper3->open(ofile3, num_items, items, LASzip::POINT_BY_POINT_RANGE) != 0)
return 0;
+#else
+#endif
// write / compress num_points with "random" data
@@ -244,6 +255,7 @@
end_time = taketime();
fprintf(stderr, "laszipper2 wrote %d bytes in %g seconds\n", num_bytes, end_time-start_time);
start_time = taketime();
c = 0;
for (i = 0; i < num_points; i++)
@@ -258,11 +270,11 @@
num_bytes = laszipper3->close();
fprintf(stderr, "laszipper3 wrote %d bytes in %g seconds\n", num_bytes, end_time-start_time);
+#endif
delete laszipper1;
delete laszipper2;
delete laszipper3;
if (use_iostream)
delete ostream1;
@@ -276,14 +288,20 @@
else
- fclose(ofile1);
- fclose(ofile2);
- fclose(ofile3);
+ if (ofile1)
+ fclose(ofile1);
+ if (ofile2)
+ fclose(ofile2);
More information about the Liblas-commits
