[Liblas-commits] laszip: static build option
liblas-commits at liblas.org
Fri Jan 21 14:29:33 EST 2011
details: http://hg.liblas.orglaszip/rev/24f8c5388535
changeset: 158:24f8c5388535
user: Howard Butler <hobu.inc at gmail.com>
date: Fri Jan 21 13:29:25 2011 -0600
description:
static build option
diffstat:
CMakeLists.txt | 2 ++
hobu-config.bat | 5 ++---
src/CMakeLists.txt | 11 +++++++++--
tools/CMakeLists.txt | 2 ++
4 files changed, 15 insertions(+), 5 deletions(-)
diffs (77 lines):
diff -r 053a9e23be31 -r 24f8c5388535 CMakeLists.txt
--- a/CMakeLists.txt Fri Jan 21 12:56:49 2011 -0600
+++ b/CMakeLists.txt Fri Jan 21 13:29:25 2011 -0600
@@ -59,6 +59,8 @@
# Output directory in which to build ARCHIVE target files.
set(CMAKE_ARCHIVE_OUTPUT_DIRECTORY ${LASZIP_BUILD_OUTPUT_DIRECTORY})
+set(BUILD_STATIC FALSE CACHE BOOL "Build LASzip statically" )
# Platform and compiler specific settings
diff -r 053a9e23be31 -r 24f8c5388535 hobu-config.bat
--- a/hobu-config.bat Fri Jan 21 12:56:49 2011 -0600
+++ b/hobu-config.bat Fri Jan 21 13:29:25 2011 -0600
@@ -3,8 +3,6 @@
set G="NMake Makefiles"
REM set G="Visual Studio 9 2008"
REM set G="Visual Studio 10"
-REM set G="Visual Studio 9 2008"
-set LASZIP=D:\laszip
REM set BUILD_TYPE=RelWithDebInfo
REM set BUILD_TYPE=Debug
set BUILD_TYPE=Release
@@ -12,4 +10,5 @@
cmake -G %G% ^
-DCMAKE_BUILD_TYPE=%BUILD_TYPE% ^
-DCMAKE_VERBOSE_MAKEFILE=OFF ^
- %LASZIP%
+ -DBUILD_STATIC=FALSE ^
diff -r 053a9e23be31 -r 24f8c5388535 src/CMakeLists.txt
--- a/src/CMakeLists.txt Fri Jan 21 12:56:49 2011 -0600
+++ b/src/CMakeLists.txt Fri Jan 21 13:29:25 2011 -0600
@@ -56,8 +56,10 @@
if(WIN32)
+if(NOT BUILD_STATIC)
add_definitions("-DLASZIP_DLL_EXPORT=1")
endif()
+endif()
# Group source files for IDE source explorers (e.g. Visual Studio)
source_group("CMake Files" FILES CMakeLists.txt)
@@ -68,10 +70,15 @@
include_directories(../include ../include/laszip .)
-add_library(${LASZIP_LIB_NAME} SHARED ${LASZIP_SOURCES})
+if(BUILD_STATIC)
+ add_library(${LASZIP_LIB_NAME} STATIC ${LASZIP_SOURCES})
+else()
+ add_library(${LASZIP_LIB_NAME} SHARED ${LASZIP_SOURCES})
+endif()
set_target_properties(${LASZIP_LIB_NAME}
PROPERTIES SOVERSION "${LASZIP_LIB_SOVERSION}" )
# Targets installation
diff -r 053a9e23be31 -r 24f8c5388535 tools/CMakeLists.txt
--- a/tools/CMakeLists.txt Fri Jan 21 12:56:49 2011 -0600
+++ b/tools/CMakeLists.txt Fri Jan 21 13:29:25 2011 -0600
@@ -26,8 +26,10 @@
if(WIN32)
endif()
+endif()
# TODO: Experimental and requires testing --mloskot
More information about the Liblas-commits
