[Liblas-commits] hg: add WITH_STATIC_LASZIP advanced variable
liblas-commits at liblas.org
Fri Jan 21 15:06:20 EST 2011
details: http://hg.liblas.orghg/rev/c696c43b1032
changeset: 2811:c696c43b1032
user: Howard Butler <hobu.inc at gmail.com>
date: Fri Jan 21 14:05:28 2011 -0600
description:
Subject: hg: WITH_STATIC_LASZIP variable
details: http://hg.liblas.orghg/rev/c9123cb61570
changeset: 2812:c9123cb61570
date: Fri Jan 21 14:05:58 2011 -0600
description:
diffstat:
CMakeLists.txt | 5 ++++-
hobu-config.bat | 9 +++++----
src/CMakeLists.txt | 2 ++
3 files changed, 11 insertions(+), 5 deletions(-)
diffs (55 lines):
diff -r 187599d6d530 -r c9123cb61570 CMakeLists.txt
--- a/CMakeLists.txt Fri Jan 21 11:46:20 2011 -0600
+++ b/CMakeLists.txt Fri Jan 21 14:05:58 2011 -0600
@@ -295,7 +295,10 @@
endif()
# LASZIP support - optional, default=OFF
-set(WITH_LASZIP FALSE CACHE BOOL "Choose if LASZIP support should be built")
+set(WITH_LASZIP FALSE CACHE BOOL "Choose if LASzip support should be built")
+set(WITH_STATIC_LASZIP FALSE CACHE BOOL "Choose of LASzip should be statically linked")
+mark_as_advanced(WITH_STATIC_LASZIP)
if(WITH_LASZIP)
find_package(LASzip 1.0.0)
diff -r 187599d6d530 -r c9123cb61570 hobu-config.bat
--- a/hobu-config.bat Fri Jan 21 11:46:20 2011 -0600
+++ b/hobu-config.bat Fri Jan 21 14:05:58 2011 -0600
@@ -9,8 +9,8 @@
set ORACLE_HOME=%OSGEO4W%
set LASZIP_ROOT=d:\laszip
REM set BUILD_TYPE=RelWithDebInfo
-REM set BUILD_TYPE=Debug
-set BUILD_TYPE=Release
+set BUILD_TYPE=Debug
+REM set BUILD_TYPE=Release
set PATH=%OSGEO4W%\apps\gdal-dev\bin;%OSGEO4W%\bin;%PATH%
@@ -29,8 +29,9 @@
-DGDAL_LIBRARY=%OSGEO4W%\apps\gdal-dev\lib\gdal_i.lib ^
-DORACLE_INCLUDE_DIR=%ORACLE_HOME%\include ^
-DORACLE_OCI_LIBRARY=%ORACLE_HOME%\lib\oci.lib ^
- -DLASZIP_INCLUDE_DIR=%OSGEO4W%\include ^
- -DLASZIP_LIBRARY=%OSGEO4W%\lib\laszip.lib ^
+ -DLASZIP_INCLUDE_DIR=d:\laszip\include ^
+ -DLASZIP_LIBRARY=d:\laszip\bin\Debug\laszip.lib ^
-DCMAKE_BUILD_TYPE=%BUILD_TYPE% ^
-DCMAKE_VERBOSE_MAKEFILE=OFF ^
+ -DWITH_STATIC_LASZIP=FALSE ^
%LIBLAS%
diff -r 187599d6d530 -r c9123cb61570 src/CMakeLists.txt
--- a/src/CMakeLists.txt Fri Jan 21 11:46:20 2011 -0600
+++ b/src/CMakeLists.txt Fri Jan 21 14:05:58 2011 -0600
@@ -215,8 +215,10 @@
if(WIN32)
add_definitions("-DLAS_DLL_EXPORT=1")
+if (NOT WITH_STATIC_LASZIP)
add_definitions("-DLASZIP_DLL_IMPORT=1")
endif()
+endif()
add_library(${LIBLAS_LIB_NAME} SHARED ${LIBLAS_SOURCES})
add_library(${LIBLAS_C_LIB_NAME} SHARED ${LIBLAS_C_SOURCES})
More information about the Liblas-commits
