[Liblas-commits] laszip: compress/decompress scan angle as U8
avoids danger
liblas-commits at liblas.org
Mon Jan 31 14:16:06 EST 2011
details: http://hg.liblas.orglaszip/rev/272e64fc7bea
changeset: 170:272e64fc7bea
user: isenburg
date: Mon Jan 31 11:15:44 2011 -0800
description:
compress/decompress scan angle as U8 avoids danger
diffstat:
src/lasreaditemcompressed_v1.cpp | 1124 +++++++++++++++---------------
src/laswriteitemcompressed_v1.cpp | 1312 ++++++++++++++++++------------------
2 files changed, 1214 insertions(+), 1222 deletions(-)
diffs (truncated from 2475 to 300 lines):
diff -r 70c18563cbe5 -r 272e64fc7bea src/lasreaditemcompressed_v1.cpp
--- a/src/lasreaditemcompressed_v1.cpp Mon Jan 31 10:17:43 2011 -0800
+++ b/src/lasreaditemcompressed_v1.cpp Mon Jan 31 11:15:44 2011 -0800
@@ -7,20 +7,20 @@
see corresponding header file
- PROGRAMMERS:
- martin.isenburg at gmail.com
- COPYRIGHT:
- (c) 2011, Martin Isenburg, LASSO - tools to catch reality
- This is free software; you can redistribute and/or modify it under the
- terms of the GNU Lesser General Licence as published by the Free Software
- Foundation. See the COPYING file for more information.
- This software is distributed WITHOUT ANY WARRANTY and without even the
- implied warranty of MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
+ PROGRAMMERS:
+ martin.isenburg at gmail.com
+ COPYRIGHT:
+ (c) 2011, Martin Isenburg, LASSO - tools to catch reality
+ This is free software; you can redistribute and/or modify it under the
+ terms of the GNU Lesser General Licence as published by the Free Software
+ Foundation. See the COPYING file for more information.
+ This software is distributed WITHOUT ANY WARRANTY and without even the
+ implied warranty of MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
CHANGE HISTORY:
@@ -30,559 +30,555 @@
#include "lasreaditemcompressed_v1.hpp"
-#include <assert.h>
-#include <string.h>
-#include <stdio.h>
-#include <stdlib.h>
- LASreadItemCompressed_POINT10_v1
-struct LASpoint10
- I32 x;
- I32 y;
- I32 z;
- U16 intensity;
- U8 return_number : 3;
- U8 number_of_returns_of_given_pulse : 3;
- U8 scan_direction_flag : 1;
- U8 edge_of_flight_line : 1;
- U8 classification;
- I8 scan_angle_rank;
- U8 user_data;
- U16 point_source_ID;
+#include <assert.h>
+#include <string.h>
+#include <stdio.h>
+ LASreadItemCompressed_POINT10_v1
+struct LASpoint10
+ I32 x;
+ I32 y;
+ I32 z;
+ U16 intensity;
+ U8 return_number : 3;
+ U8 number_of_returns_of_given_pulse : 3;
+ U8 scan_direction_flag : 1;
+ U8 edge_of_flight_line : 1;
+ U8 classification;
+ I8 scan_angle_rank;
+ U8 user_data;
+ U16 point_source_ID;
LASreadItemCompressed_POINT10_v1::LASreadItemCompressed_POINT10_v1(EntropyDecoder* dec)
- U32 i;
- /* set decoder */
- assert(dec);
- this->dec = dec;
- /* create models and integer compressors */
- ic_dx = new IntegerCompressor(dec, 32); // 32 bits, 1 context
- ic_dy = new IntegerCompressor(dec, 32, 20); // 32 bits, 20 contexts
- ic_z = new IntegerCompressor(dec, 32, 20); // 32 bits, 20 contexts
- ic_intensity = new IntegerCompressor(dec, 16);
- ic_scan_angle_rank = new IntegerCompressor(dec, 8, 2);
- ic_point_source_ID = new IntegerCompressor(dec, 16);
- m_changed_values = dec->createSymbolModel(64);
- for (i = 0; i < 256; i++)
- m_bit_byte[i] = 0;
- m_classification[i] = 0;
- m_user_data[i] = 0;
+ U32 i;
+ /* set decoder */
+ assert(dec);
+ this->dec = dec;
+ /* create models and integer compressors */
+ ic_dx = new IntegerCompressor(dec, 32); // 32 bits, 1 context
+ ic_dy = new IntegerCompressor(dec, 32, 20); // 32 bits, 20 contexts
+ ic_z = new IntegerCompressor(dec, 32, 20); // 32 bits, 20 contexts
+ ic_intensity = new IntegerCompressor(dec, 16);
+ ic_scan_angle_rank = new IntegerCompressor(dec, 8, 2);
+ ic_point_source_ID = new IntegerCompressor(dec, 16);
+ m_changed_values = dec->createSymbolModel(64);
+ for (i = 0; i < 256; i++)
+ m_bit_byte[i] = 0;
+ m_classification[i] = 0;
+ m_user_data[i] = 0;
-LASreadItemCompressed_POINT10_v1::~LASreadItemCompressed_POINT10_v1()
- U32 i;
- delete ic_dx;
- delete ic_dy;
- delete ic_z;
- delete ic_intensity;
- delete ic_scan_angle_rank;
- delete ic_point_source_ID;
- dec->destroySymbolModel(m_changed_values);
- if (m_bit_byte[i]) dec->destroySymbolModel(m_bit_byte[i]);
- if (m_classification[i]) dec->destroySymbolModel(m_classification[i]);
- if (m_user_data[i]) dec->destroySymbolModel(m_user_data[i]);
+LASreadItemCompressed_POINT10_v1::~LASreadItemCompressed_POINT10_v1()
+ U32 i;
+ delete ic_dx;
+ delete ic_dy;
+ delete ic_z;
+ delete ic_intensity;
+ delete ic_scan_angle_rank;
+ delete ic_point_source_ID;
+ dec->destroySymbolModel(m_changed_values);
+ if (m_bit_byte[i]) dec->destroySymbolModel(m_bit_byte[i]);
+ if (m_classification[i]) dec->destroySymbolModel(m_classification[i]);
+ if (m_user_data[i]) dec->destroySymbolModel(m_user_data[i]);
BOOL LASreadItemCompressed_POINT10_v1::init(const U8* item)
- U32 i;
- /* init state */
- last_x_diff[0] = last_x_diff[1] = last_x_diff[2] = 0;
- last_y_diff[0] = last_y_diff[1] = last_y_diff[2] = 0;
- last_incr = 0;
- /* init models and integer compressors */
- ic_dx->initDecompressor();
- ic_dy->initDecompressor();
- ic_z->initDecompressor();
- ic_intensity->initDecompressor();
- ic_scan_angle_rank->initDecompressor();
- ic_point_source_ID->initDecompressor();
- dec->initSymbolModel(m_changed_values);
- if (m_bit_byte[i]) dec->initSymbolModel(m_bit_byte[i]);
- if (m_classification[i]) dec->initSymbolModel(m_classification[i]);
- if (m_user_data[i]) dec->initSymbolModel(m_user_data[i]);
- /* init last item */
- memcpy(last_item, item, 20);
- return TRUE;
-inline BOOL LASreadItemCompressed_POINT10_v1::read(U8* item)
- // find median difference for x and y from 3 preceding differences
- I32 median_x;
- if (last_x_diff[0] < last_x_diff[1])
- if (last_x_diff[1] < last_x_diff[2])
- median_x = last_x_diff[1];
- else if (last_x_diff[0] < last_x_diff[2])
- median_x = last_x_diff[2];
- else
- median_x = last_x_diff[0];
- else
- if (last_x_diff[0] < last_x_diff[2])
- else if (last_x_diff[1] < last_x_diff[2])
- else
- I32 median_y;
- if (last_y_diff[0] < last_y_diff[1])
- if (last_y_diff[1] < last_y_diff[2])
- median_y = last_y_diff[1];
- else if (last_y_diff[0] < last_y_diff[2])
- median_y = last_y_diff[2];
- else
- median_y = last_y_diff[0];
- else
- if (last_y_diff[0] < last_y_diff[2])
- else if (last_y_diff[1] < last_y_diff[2])
- else
- // copy point from last point
- memcpy(item, last_item, 20);
- // decompress x y z coordinates
- I32 x_diff = ic_dx->decompress(median_x);
- ((LASpoint10*)item)->x += x_diff;
- // we use the number k of bits corrector bits to switch contexts
- U32 k_bits = ic_dx->getK();
- I32 y_diff = ic_dy->decompress(median_y, (k_bits < 19 ? k_bits : 19));
- ((LASpoint10*)item)->y += y_diff;
- k_bits = (k_bits + ic_dy->getK())/2;
- ((LASpoint10*)item)->z = ic_z->decompress(((LASpoint10*)last_item)->z, (k_bits < 19 ? k_bits : 19));
- // decompress which other values have changed
- I32 changed_values = dec->decodeSymbol(m_changed_values);
- if (changed_values)
- // decompress the intensity if it has changed
- if (changed_values & 32)
- ((LASpoint10*)item)->intensity = ic_intensity->decompress(((LASpoint10*)last_item)->intensity);
- // decompress the edge_of_flight_line, scan_direction_flag, ... if it has changed
- if (changed_values & 16)
- if (m_bit_byte[last_item[14]] == 0)
- m_bit_byte[last_item[14]] = dec->createSymbolModel(256);
- dec->initSymbolModel(m_bit_byte[last_item[14]]);
- item[14] = dec->decodeSymbol(m_bit_byte[last_item[14]]);
- // decompress the classification ... if it has changed
- if (changed_values & 8)
- if (m_classification[last_item[15]] == 0)
- m_classification[last_item[15]] = dec->createSymbolModel(256);
- dec->initSymbolModel(m_classification[last_item[15]]);
- item[15] = dec->decodeSymbol(m_classification[last_item[15]]);
- // decompress the scan_angle_rank ... if it has changed
- if (changed_values & 4)
More information about the Liblas-commits
