[Liblas-commits] laszip: forgot to uncomment a line. got rid of
tabs.
liblas-commits at liblas.org
Mon Jan 31 14:28:49 EST 2011
details: http://hg.liblas.orglaszip/rev/8f4361c46238
changeset: 171:8f4361c46238
user: isenburg
date: Mon Jan 31 11:28:38 2011 -0800
description:
forgot to uncomment a line. got rid of tabs.
diffstat:
src/lasreaditemcompressed_v1.cpp | 132 +++++++++++++++++++-------------------
src/laswriteitemcompressed_v1.cpp | 65 +++++++++---------
2 files changed, 98 insertions(+), 99 deletions(-)
diffs (truncated from 320 to 300 lines):
diff -r 272e64fc7bea -r 8f4361c46238 src/lasreaditemcompressed_v1.cpp
--- a/src/lasreaditemcompressed_v1.cpp Mon Jan 31 11:15:44 2011 -0800
+++ b/src/lasreaditemcompressed_v1.cpp Mon Jan 31 11:28:38 2011 -0800
@@ -67,12 +67,12 @@
/* create models and integer compressors */
ic_dx = new IntegerCompressor(dec, 32); // 32 bits, 1 context
- ic_dy = new IntegerCompressor(dec, 32, 20); // 32 bits, 20 contexts
- ic_z = new IntegerCompressor(dec, 32, 20); // 32 bits, 20 contexts
- ic_intensity = new IntegerCompressor(dec, 16);
- ic_scan_angle_rank = new IntegerCompressor(dec, 8, 2);
- ic_point_source_ID = new IntegerCompressor(dec, 16);
- m_changed_values = dec->createSymbolModel(64);
+ ic_dy = new IntegerCompressor(dec, 32, 20); // 32 bits, 20 contexts
+ ic_z = new IntegerCompressor(dec, 32, 20); // 32 bits, 20 contexts
+ ic_intensity = new IntegerCompressor(dec, 16);
+ ic_scan_angle_rank = new IntegerCompressor(dec, 8, 2);
+ ic_point_source_ID = new IntegerCompressor(dec, 16);
+ m_changed_values = dec->createSymbolModel(64);
for (i = 0; i < 256; i++)
m_bit_byte[i] = 0;
@@ -105,8 +105,8 @@
U32 i;
/* init state */
- last_x_diff[0] = last_x_diff[1] = last_x_diff[2] = 0;
- last_y_diff[0] = last_y_diff[1] = last_y_diff[2] = 0;
+ last_x_diff[0] = last_x_diff[1] = last_x_diff[2] = 0;
+ last_y_diff[0] = last_y_diff[1] = last_y_diff[2] = 0;
last_incr = 0;
/* init models and integer compressors */
@@ -186,61 +186,61 @@
k_bits = (k_bits + ic_dy->getK())/2;
((LASpoint10*)item)->z = ic_z->decompress(((LASpoint10*)last_item)->z, (k_bits < 19 ? k_bits : 19));
- // decompress which other values have changed
- I32 changed_values = dec->decodeSymbol(m_changed_values);
+ // decompress which other values have changed
+ I32 changed_values = dec->decodeSymbol(m_changed_values);
if (changed_values)
- // decompress the intensity if it has changed
- if (changed_values & 32)
- ((LASpoint10*)item)->intensity = (U16)ic_intensity->decompress(((LASpoint10*)last_item)->intensity);
+ // decompress the intensity if it has changed
+ if (changed_values & 32)
+ ((LASpoint10*)item)->intensity = (U16)ic_intensity->decompress(((LASpoint10*)last_item)->intensity);
- // decompress the edge_of_flight_line, scan_direction_flag, ... if it has changed
- if (changed_values & 16)
+ // decompress the edge_of_flight_line, scan_direction_flag, ... if it has changed
+ if (changed_values & 16)
if (m_bit_byte[last_item[14]] == 0)
m_bit_byte[last_item[14]] = dec->createSymbolModel(256);
dec->initSymbolModel(m_bit_byte[last_item[14]]);
- item[14] = (U8)dec->decodeSymbol(m_bit_byte[last_item[14]]);
+ item[14] = (U8)dec->decodeSymbol(m_bit_byte[last_item[14]]);
- // decompress the classification ... if it has changed
- if (changed_values & 8)
+ // decompress the classification ... if it has changed
+ if (changed_values & 8)
if (m_classification[last_item[15]] == 0)
m_classification[last_item[15]] = dec->createSymbolModel(256);
dec->initSymbolModel(m_classification[last_item[15]]);
- item[15] = (U8)dec->decodeSymbol(m_classification[last_item[15]]);
- // decompress the scan_angle_rank ... if it has changed
- if (changed_values & 4)
- item[16] = (U8)ic_scan_angle_rank->decompress(last_item[16], k_bits < 3);
+ item[15] = (U8)dec->decodeSymbol(m_classification[last_item[15]]);
+ // decompress the scan_angle_rank ... if it has changed
+ if (changed_values & 4)
+ item[16] = (U8)ic_scan_angle_rank->decompress(last_item[16], k_bits < 3);
- // decompress the user_data ... if it has changed
- if (changed_values & 2)
+ // decompress the user_data ... if it has changed
+ if (changed_values & 2)
if (m_user_data[last_item[17]] == 0)
m_user_data[last_item[17]] = dec->createSymbolModel(256);
dec->initSymbolModel(m_user_data[last_item[17]]);
- item[17] = (U8)dec->decodeSymbol(m_user_data[last_item[17]]);
+ item[17] = (U8)dec->decodeSymbol(m_user_data[last_item[17]]);
- // decompress the point_source_ID ... if it has changed
- if (changed_values & 1)
- ((LASpoint10*)item)->point_source_ID = (U16)ic_point_source_ID->decompress(((LASpoint10*)last_item)->point_source_ID);
+ // decompress the point_source_ID ... if it has changed
+ if (changed_values & 1)
+ ((LASpoint10*)item)->point_source_ID = (U16)ic_point_source_ID->decompress(((LASpoint10*)last_item)->point_source_ID);
// record the difference
@@ -325,38 +325,38 @@
last_gpstime_diff = gpstime_diff;
multi_extreme_counter = 0;
- else if (multi == 0)
+ else if (multi == 0)
gpstime_diff = ic_gpstime->decompress(last_gpstime_diff/4, 2);
multi_extreme_counter++;
- if (multi_extreme_counter > 3)
- last_gpstime_diff = gpstime_diff;
- multi_extreme_counter = 0;
- else if (multi < 10)
- gpstime_diff = ic_gpstime->decompress(multi*last_gpstime_diff, 3);
+ if (multi_extreme_counter > 3)
+ last_gpstime_diff = gpstime_diff;
+ multi_extreme_counter = 0;
+ else if (multi < 10)
+ gpstime_diff = ic_gpstime->decompress(multi*last_gpstime_diff, 3);
else if (multi < 50)
- gpstime_diff = ic_gpstime->decompress(multi*last_gpstime_diff, 4);
+ gpstime_diff = ic_gpstime->decompress(multi*last_gpstime_diff, 4);
else
- gpstime_diff = ic_gpstime->decompress(multi*last_gpstime_diff, 5);
- if (multi == LASZIP_GPSTIME_MULTIMAX-3)
- multi_extreme_counter++;
+ gpstime_diff = ic_gpstime->decompress(multi*last_gpstime_diff, 5);
+ if (multi == LASZIP_GPSTIME_MULTIMAX-3)
+ multi_extreme_counter++;
- last_gpstime.i64 += gpstime_diff;
+ last_gpstime.i64 += gpstime_diff;
else if (multi < LASZIP_GPSTIME_MULTIMAX-1)
@@ -577,7 +577,7 @@
U32 i;
for (i = 0; i < number; i++)
- item[i] = (U8)(ic_byte->decompress(last_item[i], i));
+ item[i] = (U8)(ic_byte->decompress(last_item[i], i));
memcpy(last_item, item, number);
return TRUE;
diff -r 272e64fc7bea -r 8f4361c46238 src/laswriteitemcompressed_v1.cpp
--- a/src/laswriteitemcompressed_v1.cpp Mon Jan 31 11:15:44 2011 -0800
+++ b/src/laswriteitemcompressed_v1.cpp Mon Jan 31 11:28:38 2011 -0800
@@ -66,12 +66,12 @@
ic_dx = new IntegerCompressor(enc, 32); // 32 bits, 1 context
- ic_dy = new IntegerCompressor(enc, 32, 20); // 32 bits, 20 contexts
- ic_z = new IntegerCompressor(enc, 32, 20); // 32 bits, 20 contexts
- ic_intensity = new IntegerCompressor(enc, 16);
- ic_scan_angle_rank = new IntegerCompressor(enc, 8, 2);
- ic_point_source_ID = new IntegerCompressor(enc, 16);
- m_changed_values = enc->createSymbolModel(64);
+ ic_dy = new IntegerCompressor(enc, 32, 20); // 32 bits, 20 contexts
+ ic_z = new IntegerCompressor(enc, 32, 20); // 32 bits, 20 contexts
+ ic_intensity = new IntegerCompressor(enc, 16);
+ ic_scan_angle_rank = new IntegerCompressor(enc, 8, 2);
+ ic_point_source_ID = new IntegerCompressor(enc, 16);
+ m_changed_values = enc->createSymbolModel(64);
m_bit_byte[i] = 0;
@@ -104,8 +104,8 @@
U32 i;
/* init state */
last_incr = 0;
@@ -224,8 +224,7 @@
// compress the scan_angle_rank ... if it has changed
- ic_scan_angle_rank->compress(((I8*)last_item)[16], ((I8*)item)[16], k_bits < 3);
-// ic_scan_angle_rank->compress(last_item[16], item[16], k_bits < 3);
+ ic_scan_angle_rank->compress(last_item[16], item[16], k_bits < 3);
// compress the user_data ... if it has changed
@@ -357,45 +356,45 @@
// compress this multiplier
enc->encodeSymbol(m_gpstime_multi, multi);
// compress the residual curr_gpstime_diff in dependance on the multiplier
- if (multi == 1)
+ if (multi == 1)
// this is the case we assume we get most often
- ic_gpstime->compress(last_gpstime_diff, curr_gpstime_diff, 1);
+ ic_gpstime->compress(last_gpstime_diff, curr_gpstime_diff, 1);
last_gpstime_diff = curr_gpstime_diff;
- else
+ else
if (multi == 0)
ic_gpstime->compress(last_gpstime_diff/4, curr_gpstime_diff, 2);
- last_gpstime_diff = curr_gpstime_diff;
+ last_gpstime_diff = curr_gpstime_diff;
ic_gpstime->compress(multi*last_gpstime_diff, curr_gpstime_diff, 3);
ic_gpstime->compress(multi*last_gpstime_diff, curr_gpstime_diff, 4);
else
ic_gpstime->compress(multi*last_gpstime_diff, curr_gpstime_diff, 5);
More information about the Liblas-commits
