[Liblas-commits] laszip: mean bug fix due to floating-point 'Inf' compiler differ...
liblas-commits at liblas.org liblas-commits at liblas.org
Mon Jan 31 16:22:42 EST 2011
details:   http://hg.liblas.orglaszip/rev/a372803f1069
changeset: 172:a372803f1069
user:      isenburg
date:      Mon Jan 31 13:22:30 2011 -0800
description:
mean bug fix due to floating-point 'Inf' compiler differences
diffstat:
 src/arithmeticdecoder.cpp         |  14 +++++++-------
 src/arithmeticencoder.cpp         |  12 ++++++------
 src/lasreaditemcompressed_v1.cpp  |  14 +++++++-------
 src/lasreaditemcompressed_v1.hpp  |   2 +-
 src/laswriteitemcompressed_v1.cpp |  20 ++++++++++----------
 src/laswriteitemcompressed_v1.hpp |   2 +-
 src/mydefs.hpp                    |   8 ++++----
 7 files changed, 36 insertions(+), 36 deletions(-)
diffs (209 lines):
diff -r 8f4361c46238 -r a372803f1069 src/arithmeticdecoder.cpp
--- a/src/arithmeticdecoder.cpp	Mon Jan 31 11:28:38 2011 -0800
+++ b/src/arithmeticdecoder.cpp	Mon Jan 31 13:22:30 2011 -0800
@@ -247,7 +247,7 @@
   return (U8)sym;
-unsigned short ArithmeticDecoder::readShort()
+U16 ArithmeticDecoder::readShort()
   U32 sym = value / (length >>= 16);           // decode symbol, change length
   value -= length * sym;                                    // update interval
@@ -268,9 +268,9 @@
 inline F32 ArithmeticDecoder::readFloat()
-  U32F32 u32f32;
-  u32f32.u32 = readInt();
-  return u32f32.f32;
+  U32I32F32 u32i32f32;
+  u32i32f32.u32 = readInt();
+  return u32i32f32.f32;
 inline U64 ArithmeticDecoder::readInt64()
@@ -282,9 +282,9 @@
 inline F64 ArithmeticDecoder::readDouble()
-  U64F64 u64f64;
-  u64f64.u64 = readInt64();
-  return u64f64.f64;
+  U64I64F64 u64i64f64;
+  u64i64f64.u64 = readInt64();
+  return u64i64f64.f64;
 ArithmeticDecoder::~ArithmeticDecoder()
diff -r 8f4361c46238 -r a372803f1069 src/arithmeticencoder.cpp
--- a/src/arithmeticencoder.cpp	Mon Jan 31 11:28:38 2011 -0800
+++ b/src/arithmeticencoder.cpp	Mon Jan 31 13:22:30 2011 -0800
@@ -268,9 +268,9 @@
 inline void ArithmeticEncoder::writeFloat(F32 sym)
-  U32F32 u32f32;
-  u32f32.f32 = sym;
-  writeInt(u32f32.u32);
+  u32i32f32.f32 = sym;
+  writeInt(u32i32f32.u32);
 inline void ArithmeticEncoder::writeInt64(U64 sym)
@@ -281,9 +281,9 @@
 inline void ArithmeticEncoder::writeDouble(F64 sym)
-  U64F64 u64f64;
-  u64f64.f64 = sym;
-  writeInt64(u64f64.u64);
+  u64i64f64.f64 = sym;
+  writeInt64(u64i64f64.u64);
 inline void ArithmeticEncoder::propagate_carry()
diff -r 8f4361c46238 -r a372803f1069 src/lasreaditemcompressed_v1.cpp
--- a/src/lasreaditemcompressed_v1.cpp	Mon Jan 31 11:28:38 2011 -0800
+++ b/src/lasreaditemcompressed_v1.cpp	Mon Jan 31 13:22:30 2011 -0800
@@ -309,7 +309,7 @@
     else if (multi == 2) // the difference is huge
-      last_gpstime.i64 = dec->readInt64();
+      last_gpstime.u64 = dec->readInt64();
   else
@@ -360,10 +360,10 @@
     else if (multi <  LASZIP_GPSTIME_MULTIMAX-1)
-  *((F64*)item) = last_gpstime.f64;
+  *((I64*)item) = last_gpstime.i64;
   return TRUE;
@@ -436,10 +436,10 @@
   U64 offset;
   U32 packet_size;
-  I32F32 return_point;
-  I32F32 x;
-  I32F32 y;
-  I32F32 z;
+  U32I32F32 return_point;
+  U32I32F32 x;
+  U32I32F32 y;
+  U32I32F32 z;
 LASreadItemCompressed_WAVEPACKET13_v1::LASreadItemCompressed_WAVEPACKET13_v1(EntropyDecoder* dec)
diff -r 8f4361c46238 -r a372803f1069 src/lasreaditemcompressed_v1.hpp
--- a/src/lasreaditemcompressed_v1.hpp	Mon Jan 31 11:28:38 2011 -0800
+++ b/src/lasreaditemcompressed_v1.hpp	Mon Jan 31 13:22:30 2011 -0800
@@ -79,7 +79,7 @@
 private:
   EntropyDecoder* dec;
-  I64F64 last_gpstime;
+  U64I64F64 last_gpstime;
   EntropyModel* m_gpstime_multi;
   EntropyModel* m_gpstime_0diff;
diff -r 8f4361c46238 -r a372803f1069 src/laswriteitemcompressed_v1.cpp
--- a/src/laswriteitemcompressed_v1.cpp	Mon Jan 31 11:28:38 2011 -0800
+++ b/src/laswriteitemcompressed_v1.cpp	Mon Jan 31 13:22:30 2011 -0800
@@ -299,8 +299,8 @@
 inline BOOL LASwriteItemCompressed_GPSTIME11_v1::write(const U8* item)
-  I64F64 this_gpstime;
-  this_gpstime.f64 = *((F64*)item);
+  U64I64F64 this_gpstime;
+  this_gpstime.i64 = *((I64*)item);
   if (last_gpstime_diff == 0) // if the last integer difference was zero
@@ -322,9 +322,9 @@
       else
         enc->encodeSymbol(m_gpstime_0diff, 2); // the difference is huge
-        enc->writeInt64(this_gpstime.i64);
+        enc->writeInt64(this_gpstime.u64);
-      last_gpstime.f64 = this_gpstime.f64;
+      last_gpstime.i64 = this_gpstime.i64;
   else // the last integer difference was *not* zero
@@ -402,9 +402,9 @@
         // if difference is so huge ... we simply write the double
         enc->encodeSymbol(m_gpstime_multi, LASZIP_GPSTIME_MULTIMAX-2);
   return TRUE;
@@ -479,10 +479,10 @@
   U64 offset;
   U32 packet_size;
-  I32F32 x;
-  I32F32 y;
-  I32F32 z;
+  U32I32F32 x;
+  U32I32F32 y;
+  U32I32F32 z;
 LASwriteItemCompressed_WAVEPACKET13_v1::LASwriteItemCompressed_WAVEPACKET13_v1(EntropyEncoder* enc)
diff -r 8f4361c46238 -r a372803f1069 src/laswriteitemcompressed_v1.hpp
--- a/src/laswriteitemcompressed_v1.hpp	Mon Jan 31 11:28:38 2011 -0800
+++ b/src/laswriteitemcompressed_v1.hpp	Mon Jan 31 13:22:30 2011 -0800
@@ -79,7 +79,7 @@
 private:
   EntropyEncoder* enc;
diff -r 8f4361c46238 -r a372803f1069 src/mydefs.hpp
--- a/src/mydefs.hpp	Mon Jan 31 11:28:38 2011 -0800
+++ b/src/mydefs.hpp	Mon Jan 31 13:22:30 2011 -0800
@@ -4,6 +4,8 @@
   FILE:  mydefs.hpp
   CONTENTS:
+    Basic data type definitions to be robust across platforms.
   PROGRAMMERS:
@@ -55,10 +57,8 @@
 typedef bool               BOOL;
 #endif
-typedef union U32F32 { U32 u32; F32 f32; } U32F32;
-typedef union U64F64 { U64 u64; F64 f64; } U64F64;
-typedef union I32F32 { I32 i32; F32 f32; } I32F32;
-typedef union I64F64 { I64 i64; F64 f64; } I64F64;
+typedef union U32I32F32 { U32 u32; I32 i32; F32 f32; } U32I32F32;
+typedef union U64I64F64 { U64 u64; I64 i64; F64 f64; } U64I64F64;
 #define F32_MAX            +1.0e+30f
 #define F32_MIN            -1.0e+30f
More information about the Liblas-commits mailing list
