[Liblas-commits] laszip: add Sphinx dox for website
liblas-commits at liblas.org liblas-commits at liblas.org
Mon Jan 31 17:04:18 EST 2011
details:   http://hg.liblas.orglaszip/rev/a0e2802c5b92
changeset: 174:a0e2802c5b92
user:      Howard Butler <hobu.inc at gmail.com>
date:      Mon Jan 31 16:04:13 2011 -0600
description:
diffstat:
 docs/make.bat         |  190 ++++++++++++++++++++++++++++++++++
 docs/source/conf.py   |  275 ++++++++++++++++++++++++++++++++++++++++++++++++++
 docs/source/index.rst |   57 ++++++++++
 3 files changed, 522 insertions(+), 0 deletions(-)
diffs (truncated from 535 to 300 lines):
diff -r 729745b3b317 -r a0e2802c5b92 docs/make.bat
--- /dev/null	Thu Jan 01 00:00:00 1970 +0000
+++ b/docs/make.bat	Mon Jan 31 16:04:13 2011 -0600
@@ -0,0 +1,190 @@
+ at ECHO OFF
+REM Command file for Sphinx documentation
+if "%SPHINXBUILD%" == "" (
+	set SPHINXBUILD=sphinx-build
+set BUILDDIR=build
+set ALLSPHINXOPTS=-d %BUILDDIR%/doctrees %SPHINXOPTS% source
+set I18NSPHINXOPTS=%SPHINXOPTS% source
+if NOT "%PAPER%" == "" (
+	set ALLSPHINXOPTS=-D latex_paper_size=%PAPER% %ALLSPHINXOPTS%
+	set I18NSPHINXOPTS=-D latex_paper_size=%PAPER% %I18NSPHINXOPTS%
+if "%1" == "" goto help
+if "%1" == "help" (
+	:help
+	echo.Please use `make ^<target^>` where ^<target^> is one of
+	echo.  html       to make standalone HTML files
+	echo.  dirhtml    to make HTML files named index.html in directories
+	echo.  singlehtml to make a single large HTML file
+	echo.  pickle     to make pickle files
+	echo.  json       to make JSON files
+	echo.  htmlhelp   to make HTML files and a HTML help project
+	echo.  qthelp     to make HTML files and a qthelp project
+	echo.  devhelp    to make HTML files and a Devhelp project
+	echo.  epub       to make an epub
+	echo.  latex      to make LaTeX files, you can set PAPER=a4 or PAPER=letter
+	echo.  text       to make text files
+	echo.  man        to make manual pages
+	echo.  texinfo    to make Texinfo files
+	echo.  gettext    to make PO message catalogs
+	echo.  changes    to make an overview over all changed/added/deprecated items
+	echo.  linkcheck  to check all external links for integrity
+	echo.  doctest    to run all doctests embedded in the documentation if enabled
+	goto end
+if "%1" == "clean" (
+	for /d %%i in (%BUILDDIR%\*) do rmdir /q /s %%i
+	del /q /s %BUILDDIR%\*
+	goto end
+if "%1" == "html" (
+	%SPHINXBUILD% -b html %ALLSPHINXOPTS% %BUILDDIR%/html
+	if errorlevel 1 exit /b 1
+	echo.
+	echo.Build finished. The HTML pages are in %BUILDDIR%/html.
+	goto end
+if "%1" == "dirhtml" (
+	%SPHINXBUILD% -b dirhtml %ALLSPHINXOPTS% %BUILDDIR%/dirhtml
+	echo.
+	echo.Build finished. The HTML pages are in %BUILDDIR%/dirhtml.
+	goto end
+if "%1" == "singlehtml" (
+	%SPHINXBUILD% -b singlehtml %ALLSPHINXOPTS% %BUILDDIR%/singlehtml
+	echo.
+	echo.Build finished. The HTML pages are in %BUILDDIR%/singlehtml.
+	goto end
+if "%1" == "pickle" (
+	%SPHINXBUILD% -b pickle %ALLSPHINXOPTS% %BUILDDIR%/pickle
+	echo.
+	echo.Build finished; now you can process the pickle files.
+	goto end
+if "%1" == "json" (
+	%SPHINXBUILD% -b json %ALLSPHINXOPTS% %BUILDDIR%/json
+	echo.
+	echo.Build finished; now you can process the JSON files.
+	goto end
+if "%1" == "htmlhelp" (
+	%SPHINXBUILD% -b htmlhelp %ALLSPHINXOPTS% %BUILDDIR%/htmlhelp
+	echo.
+	echo.Build finished; now you can run HTML Help Workshop with the ^
+.hhp project file in %BUILDDIR%/htmlhelp.
+	goto end
+if "%1" == "qthelp" (
+	%SPHINXBUILD% -b qthelp %ALLSPHINXOPTS% %BUILDDIR%/qthelp
+	echo.
+	echo.Build finished; now you can run "qcollectiongenerator" with the ^
+.qhcp project file in %BUILDDIR%/qthelp, like this:
+	echo.^> qcollectiongenerator %BUILDDIR%\qthelp\LASzip.qhcp
+	echo.To view the help file:
+	echo.^> assistant -collectionFile %BUILDDIR%\qthelp\LASzip.ghc
+	goto end
+if "%1" == "devhelp" (
+	%SPHINXBUILD% -b devhelp %ALLSPHINXOPTS% %BUILDDIR%/devhelp
+	echo.
+	goto end
+if "%1" == "epub" (
+	%SPHINXBUILD% -b epub %ALLSPHINXOPTS% %BUILDDIR%/epub
+	echo.
+	echo.Build finished. The epub file is in %BUILDDIR%/epub.
+	goto end
+if "%1" == "latex" (
+	%SPHINXBUILD% -b latex %ALLSPHINXOPTS% %BUILDDIR%/latex
+	echo.
+	echo.Build finished; the LaTeX files are in %BUILDDIR%/latex.
+	goto end
+if "%1" == "text" (
+	%SPHINXBUILD% -b text %ALLSPHINXOPTS% %BUILDDIR%/text
+	echo.
+	echo.Build finished. The text files are in %BUILDDIR%/text.
+	goto end
+if "%1" == "man" (
+	%SPHINXBUILD% -b man %ALLSPHINXOPTS% %BUILDDIR%/man
+	echo.
+	echo.Build finished. The manual pages are in %BUILDDIR%/man.
+	goto end
+if "%1" == "texinfo" (
+	%SPHINXBUILD% -b texinfo %ALLSPHINXOPTS% %BUILDDIR%/texinfo
+	echo.
+	echo.Build finished. The Texinfo files are in %BUILDDIR%/texinfo.
+	goto end
+if "%1" == "gettext" (
+	%SPHINXBUILD% -b gettext %I18NSPHINXOPTS% %BUILDDIR%/locale
+	echo.
+	echo.Build finished. The message catalogs are in %BUILDDIR%/locale.
+	goto end
+if "%1" == "changes" (
+	%SPHINXBUILD% -b changes %ALLSPHINXOPTS% %BUILDDIR%/changes
+	echo.
+	echo.The overview file is in %BUILDDIR%/changes.
+	goto end
+if "%1" == "linkcheck" (
+	%SPHINXBUILD% -b linkcheck %ALLSPHINXOPTS% %BUILDDIR%/linkcheck
+	echo.
+	echo.Link check complete; look for any errors in the above output ^
+or in %BUILDDIR%/linkcheck/output.txt.
+	goto end
+if "%1" == "doctest" (
+	%SPHINXBUILD% -b doctest %ALLSPHINXOPTS% %BUILDDIR%/doctest
+	echo.
+	echo.Testing of doctests in the sources finished, look at the ^
+results in %BUILDDIR%/doctest/output.txt.
+	goto end
+:end
diff -r 729745b3b317 -r a0e2802c5b92 docs/source/conf.py
+++ b/docs/source/conf.py	Mon Jan 31 16:04:13 2011 -0600
@@ -0,0 +1,275 @@
+# -*- coding: utf-8 -*-
+# LASzip documentation build configuration file, created by
+# sphinx-quickstart on Mon Jan 31 15:24:10 2011.
+# This file is execfile()d with the current directory set to its containing dir.
+# Note that not all possible configuration values are present in this
+# autogenerated file.
+# All configuration values have a default; values that are commented out
+# serve to show the default.
+import sys, os
+# If extensions (or modules to document with autodoc) are in another directory,
+# add these directories to sys.path here. If the directory is relative to the
+# documentation root, use os.path.abspath to make it absolute, like shown here.
+#sys.path.insert(0, os.path.abspath('.'))
+# -- General configuration -----------------------------------------------------
+# If your documentation needs a minimal Sphinx version, state it here.
+#needs_sphinx = '1.0'
+# Add any Sphinx extension module names here, as strings. They can be extensions
+# coming with Sphinx (named 'sphinx.ext.*') or your custom ones.
+extensions = []
+# Add any paths that contain templates here, relative to this directory.
+templates_path = ['_templates']
+# The suffix of source filenames.
+source_suffix = '.rst'
+# The encoding of source files.
+#source_encoding = 'utf-8-sig'
+# The master toctree document.
+master_doc = 'index'
+# General information about the project.
+project = u'LASzip'
+copyright = u'2011, Martin Isenburg'
+# The version info for the project you're documenting, acts as replacement for
+# |version| and |release|, also used in various other places throughout the
+# built documents.
+# The short X.Y version.
+version = '1.0.1'
+# The full version, including alpha/beta/rc tags.
+release = '1.0.1'
+# The language for content autogenerated by Sphinx. Refer to documentation
+# for a list of supported languages.
+#language = None
+# There are two options for replacing |today|: either, you set today to some
+# non-false value, then it is used:
+#today = ''
+# Else, today_fmt is used as the format for a strftime call.
+#today_fmt = '%B %d, %Y'
+# List of patterns, relative to source directory, that match files and
+# directories to ignore when looking for source files.
+exclude_patterns = []
+# The reST default role (used for this markup: `text`) to use for all documents.
+#default_role = None
+# If true, '()' will be appended to :func: etc. cross-reference text.
+#add_function_parentheses = True
+# If true, the current module name will be prepended to all description
+# unit titles (such as .. function::).
+#add_module_names = True
+# If true, sectionauthor and moduleauthor directives will be shown in the
+# output. They are ignored by default.
+#show_authors = False
+# The name of the Pygments (syntax highlighting) style to use.
+pygments_style = 'sphinx'
+# A list of ignored prefixes for module index sorting.
+#modindex_common_prefix = []
+# -- Options for HTML output ---------------------------------------------------
+# The theme to use for HTML and HTML Help pages.  See the documentation for
+# a list of builtin themes.
+html_theme = 'scrolls'
+# Theme options are theme-specific and customize the look and feel of a theme
+# further.  For a list of options available for each theme, see the
+# documentation.
+#html_theme_options = {}
+# Add any paths that contain custom themes here, relative to this directory.
+#html_theme_path = []
More information about the Liblas-commits mailing list
