[Liblas-commits] laszip: add Sphinx makefile
liblas-commits at liblas.org
Mon Jan 31 17:20:55 EST 2011
details: http://hg.liblas.orglaszip/rev/f69d912e6576
changeset: 175:f69d912e6576
user: Howard Butler <hobu.inc at gmail.com>
date: Mon Jan 31 16:20:49 2011 -0600
description:
add Sphinx makefile
diffstat:
docs/Makefile | 153 ++++++++++++++++++++++++++++++++++++++++++++++++++++++++++
1 files changed, 153 insertions(+), 0 deletions(-)
diffs (157 lines):
diff -r a0e2802c5b92 -r f69d912e6576 docs/Makefile
--- /dev/null Thu Jan 01 00:00:00 1970 +0000
+++ b/docs/Makefile Mon Jan 31 16:20:49 2011 -0600
@@ -0,0 +1,153 @@
+# Makefile for Sphinx documentation
+# You can set these variables from the command line.
+SPHINXOPTS =
+SPHINXBUILD = sphinx-build
+PAPER =
+BUILDDIR = build
+# Internal variables.
+PAPEROPT_a4 = -D latex_paper_size=a4
+PAPEROPT_letter = -D latex_paper_size=letter
+ALLSPHINXOPTS = -d $(BUILDDIR)/doctrees $(PAPEROPT_$(PAPER)) $(SPHINXOPTS) source
+# the i18n builder cannot share the environment and doctrees with the others
+I18NSPHINXOPTS = $(PAPEROPT_$(PAPER)) $(SPHINXOPTS) source
+.PHONY: help clean html dirhtml singlehtml pickle json htmlhelp qthelp devhelp epub latex latexpdf text man changes linkcheck doctest gettext
+help:
+ @echo "Please use \`make <target>' where <target> is one of"
+ @echo " html to make standalone HTML files"
+ @echo " dirhtml to make HTML files named index.html in directories"
+ @echo " singlehtml to make a single large HTML file"
+ @echo " pickle to make pickle files"
+ @echo " json to make JSON files"
+ @echo " htmlhelp to make HTML files and a HTML help project"
+ @echo " qthelp to make HTML files and a qthelp project"
+ @echo " devhelp to make HTML files and a Devhelp project"
+ @echo " epub to make an epub"
+ @echo " latex to make LaTeX files, you can set PAPER=a4 or PAPER=letter"
+ @echo " latexpdf to make LaTeX files and run them through pdflatex"
+ @echo " text to make text files"
+ @echo " man to make manual pages"
+ @echo " texinfo to make Texinfo files"
+ @echo " info to make Texinfo files and run them through makeinfo"
+ @echo " gettext to make PO message catalogs"
+ @echo " changes to make an overview of all changed/added/deprecated items"
+ @echo " linkcheck to check all external links for integrity"
+ @echo " doctest to run all doctests embedded in the documentation (if enabled)"
+clean:
+ -rm -rf $(BUILDDIR)/*
+html:
+ $(SPHINXBUILD) -b html $(ALLSPHINXOPTS) $(BUILDDIR)/html
+ @echo
+ @echo "Build finished. The HTML pages are in $(BUILDDIR)/html."
+dirhtml:
+ $(SPHINXBUILD) -b dirhtml $(ALLSPHINXOPTS) $(BUILDDIR)/dirhtml
+ @echo
+ @echo "Build finished. The HTML pages are in $(BUILDDIR)/dirhtml."
+singlehtml:
+ $(SPHINXBUILD) -b singlehtml $(ALLSPHINXOPTS) $(BUILDDIR)/singlehtml
+ @echo
+ @echo "Build finished. The HTML page is in $(BUILDDIR)/singlehtml."
+pickle:
+ $(SPHINXBUILD) -b pickle $(ALLSPHINXOPTS) $(BUILDDIR)/pickle
+ @echo
+ @echo "Build finished; now you can process the pickle files."
+json:
+ $(SPHINXBUILD) -b json $(ALLSPHINXOPTS) $(BUILDDIR)/json
+ @echo
+ @echo "Build finished; now you can process the JSON files."
+htmlhelp:
+ $(SPHINXBUILD) -b htmlhelp $(ALLSPHINXOPTS) $(BUILDDIR)/htmlhelp
+ @echo
+ @echo "Build finished; now you can run HTML Help Workshop with the" \
+ ".hhp project file in $(BUILDDIR)/htmlhelp."
+qthelp:
+ $(SPHINXBUILD) -b qthelp $(ALLSPHINXOPTS) $(BUILDDIR)/qthelp
+ @echo
+ @echo "Build finished; now you can run "qcollectiongenerator" with the" \
+ ".qhcp project file in $(BUILDDIR)/qthelp, like this:"
+ @echo "# qcollectiongenerator $(BUILDDIR)/qthelp/LASzip.qhcp"
+ @echo "To view the help file:"
+ @echo "# assistant -collectionFile $(BUILDDIR)/qthelp/LASzip.qhc"
+devhelp:
+ $(SPHINXBUILD) -b devhelp $(ALLSPHINXOPTS) $(BUILDDIR)/devhelp
+ @echo
+ @echo "Build finished."
+ @echo "# mkdir -p $$HOME/.local/share/devhelp/LASzip"
+ @echo "# ln -s $(BUILDDIR)/devhelp $$HOME/.local/share/devhelp/LASzip"
+ @echo "# devhelp"
+epub:
+ $(SPHINXBUILD) -b epub $(ALLSPHINXOPTS) $(BUILDDIR)/epub
+ @echo
+ @echo "Build finished. The epub file is in $(BUILDDIR)/epub."
+latex:
+ $(SPHINXBUILD) -b latex $(ALLSPHINXOPTS) $(BUILDDIR)/latex
+ @echo
+ @echo "Build finished; the LaTeX files are in $(BUILDDIR)/latex."
+ @echo "Run \`make' in that directory to run these through (pdf)latex" \
+ "(use \`make latexpdf' here to do that automatically)."
+latexpdf:
+ @echo "Running LaTeX files through pdflatex..."
+ make -C $(BUILDDIR)/latex all-pdf
+ @echo "pdflatex finished; the PDF files are in $(BUILDDIR)/latex."
+text:
+ $(SPHINXBUILD) -b text $(ALLSPHINXOPTS) $(BUILDDIR)/text
+ @echo
+ @echo "Build finished. The text files are in $(BUILDDIR)/text."
+man:
+ $(SPHINXBUILD) -b man $(ALLSPHINXOPTS) $(BUILDDIR)/man
+ @echo
+ @echo "Build finished. The manual pages are in $(BUILDDIR)/man."
+texinfo:
+ $(SPHINXBUILD) -b texinfo $(ALLSPHINXOPTS) $(BUILDDIR)/texinfo
+ @echo
+ @echo "Build finished. The Texinfo files are in $(BUILDDIR)/texinfo."
+ @echo "Run \`make' in that directory to run these through makeinfo" \
+ "(use \`make info' here to do that automatically)."
+info:
+ @echo "Running Texinfo files through makeinfo..."
+ make -C $(BUILDDIR)/texinfo info
+ @echo "makeinfo finished; the Info files are in $(BUILDDIR)/texinfo."
+gettext:
+ $(SPHINXBUILD) -b gettext $(I18NSPHINXOPTS) $(BUILDDIR)/locale
+ @echo
+ @echo "Build finished. The message catalogs are in $(BUILDDIR)/locale."
+changes:
+ $(SPHINXBUILD) -b changes $(ALLSPHINXOPTS) $(BUILDDIR)/changes
+ @echo
+ @echo "The overview file is in $(BUILDDIR)/changes."
+linkcheck:
+ $(SPHINXBUILD) -b linkcheck $(ALLSPHINXOPTS) $(BUILDDIR)/linkcheck
+ @echo
+ @echo "Link check complete; look for any errors in the above output " \
+ "or in $(BUILDDIR)/linkcheck/output.txt."
+doctest:
+ $(SPHINXBUILD) -b doctest $(ALLSPHINXOPTS) $(BUILDDIR)/doctest
+ @echo "Testing of doctests in the sources finished, look at the " \
+ "results in $(BUILDDIR)/doctest/output.txt."
More information about the Liblas-commits
