[Liblas-commits] hg-main-tree: update ref files to bring liblas and
native back i...
liblas-commits at liblas.org
Mon Jul 11 16:39:09 EDT 2011
details: http://hg.libpc.orghg-main-tree/rev/bf1fb7ca3762
changeset: 848:bf1fb7ca3762
user: Michael P. Gerlek <mpg at flaxen.com>
date: Mon Jul 11 13:39:02 2011 -0700
description:
update ref files to bring liblas and native back in sync
diffstat:
test/data/1.2-with-color.laz | 0
test/data/1.2-with-color_LIBLAS.laz | 0
test/data/1.2-with-color_NATIVE.laz | 0
test/unit/LasWriterTest.cpp | 194 -----------------
test/unit/LiblasWriterTest.cpp | 2 +-
test/unit/SpatialReferenceTest.cpp | 389 ------------------------------------
6 files changed, 1 insertions(+), 584 deletions(-)
diffs (truncated from 609 to 300 lines):
diff -r 21362c2fefc2 -r bf1fb7ca3762 test/data/1.2-with-color.laz
Binary file test/data/1.2-with-color.laz has changed
diff -r 21362c2fefc2 -r bf1fb7ca3762 test/data/1.2-with-color_LIBLAS.laz
Binary file test/data/1.2-with-color_LIBLAS.laz has changed
diff -r 21362c2fefc2 -r bf1fb7ca3762 test/data/1.2-with-color_NATIVE.laz
Binary file test/data/1.2-with-color_NATIVE.laz has changed
diff -r 21362c2fefc2 -r bf1fb7ca3762 test/unit/LasWriterTest.cpp
--- a/test/unit/LasWriterTest.cpp Mon Jul 11 11:37:13 2011 -0500
+++ b/test/unit/LasWriterTest.cpp Mon Jul 11 13:39:02 2011 -0700
@@ -1,194 +0,0 @@
-* Copyright (c) 2011, Michael P. Gerlek (mpg at flaxen.com)
-* All rights reserved.
-* Redistribution and use in source and binary forms, with or without
-* modification, are permitted provided that the following
-* conditions are met:
-* * Redistributions of source code must retain the above copyright
-* notice, this list of conditions and the following disclaimer.
-* * Redistributions in binary form must reproduce the above copyright
-* notice, this list of conditions and the following disclaimer in
-* the documentation and/or other materials provided
-* with the distribution.
-* * Neither the name of Hobu, Inc. or Flaxen Geo Consulting nor the
-* names of its contributors may be used to endorse or promote
-* products derived from this software without specific prior
-* written permission.
-* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
-* "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
-* LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS
-* FOR A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE
-* COPYRIGHT OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT,
-* INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING,
-* BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS
-* OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED
-* AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY,
-* OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT
-* OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY
-* OF SUCH DAMAGE.
-#include <boost/test/unit_test.hpp>
-#include <boost/cstdint.hpp>
-#include <boost/lexical_cast.hpp>
-#include <boost/uuid/uuid_io.hpp>
-#include <boost/concept_check.hpp>
-#include <pdal/drivers/faux/Reader.hpp>
-#include <pdal/drivers/las/Writer.hpp>
-#include <pdal/drivers/las/Reader.hpp>
-#include "Support.hpp"
-using namespace pdal;
-BOOST_AUTO_TEST_SUITE(LasWriterTest)
-BOOST_AUTO_TEST_CASE(test_simple_las)
- // remove file from earlier run, if needed
- Utils::deleteFile("temp.las");
- pdal::drivers::las::LasReader reader(Support::datapath("1.2-with-color.las"));
- std::ostream* ofs = Utils::createFile("temp.las");
- const boost::uint64_t numPoints = reader.getNumPoints();
- // need to scope the writer, so that's it dtor can use the stream
- pdal::drivers::las::LasWriter writer(reader, *ofs);
- BOOST_CHECK(writer.getDescription() == "Las Writer");
- writer.setCompressed(false);
- writer.setDate(0, 0);
- writer.setPointFormat(::pdal::drivers::las::PointFormat3);
- writer.setSystemIdentifier("");
- writer.setGeneratingSoftware("TerraScan");
- writer.write(numPoints);
- Utils::closeFile(ofs);
- bool filesSame = Support::compare_files("temp.las", Support::datapath("simple.las"));
- BOOST_CHECK(filesSame);
- if (filesSame)
- return;
-BOOST_AUTO_TEST_CASE(test_simple_laz)
- Utils::deleteFile("temp.laz");
- std::ostream* ofs = Utils::createFile("temp.laz");
- writer.setCompressed(true);
- pdal::drivers::las::LasReader reader("temp.laz");
- bool filesSame = Support::compare_files("temp.laz", Support::datapath("1.2-with-color_NATIVE.laz"));
- if (filesSame)
- return;
-static void test_a_format(const std::string& refFile, boost::uint8_t majorVersion, boost::uint8_t minorVersion, int pointFormat)
- pdal::drivers::las::LasReader reader(Support::datapath("1.2_3.las"));
- writer.setDate(78, 2008);
- writer.setPointFormat((::pdal::drivers::las::PointFormat)pointFormat);
- writer.setFormatVersion(majorVersion, minorVersion);
- writer.setSystemIdentifier("libLAS");
- writer.setGeneratingSoftware("libLAS 1.2");
- boost::uuids::uuid u = boost::lexical_cast<boost::uuids::uuid>("8388f1b8-aa1b-4108-bca3-6bc68e7b062e");
- writer.setProjectId(u);
- // BUG: the following test commented out as per ticket #35
- boost::ignore_unused_variable_warning(refFile);
- //const bool filesSame = Support::compare_files("temp.las", Support::datapath(refFile));
- //BOOST_CHECK(filesSame);
- //if (filesSame)
- return;
-BOOST_AUTO_TEST_CASE(test_different_formats)
- test_a_format("1.0_0.las", 1, 0, 0);
- test_a_format("1.0_1.las", 1, 0, 1);
- test_a_format("1.1_0.las", 1, 1, 0);
- test_a_format("1.1_1.las", 1, 1, 1);
- test_a_format("1.2_0.las", 1, 2, 0);
- test_a_format("1.2_1.las", 1, 2, 1);
- test_a_format("1.2_2.las", 1, 2, 2);
- test_a_format("1.2_3.las", 1, 2, 3);
- return;
-BOOST_AUTO_TEST_SUITE_END()
diff -r 21362c2fefc2 -r bf1fb7ca3762 test/unit/LiblasWriterTest.cpp
--- a/test/unit/LiblasWriterTest.cpp Mon Jul 11 11:37:13 2011 -0500
+++ b/test/unit/LiblasWriterTest.cpp Mon Jul 11 13:39:02 2011 -0700
@@ -113,7 +113,7 @@
- bool filesSame = Support::compare_files("temp.laz", Support::datapath("1.2-with-color_LIBLAS.laz"));
+ bool filesSame = Support::compare_files("temp.laz", Support::datapath("1.2-with-color.laz"));
if (filesSame)
diff -r 21362c2fefc2 -r bf1fb7ca3762 test/unit/SpatialReferenceTest.cpp
--- a/test/unit/SpatialReferenceTest.cpp Mon Jul 11 11:37:13 2011 -0500
+++ b/test/unit/SpatialReferenceTest.cpp Mon Jul 11 13:39:02 2011 -0700
@@ -1,389 +0,0 @@
-* OF SUCH DAMAGE.
-#include <pdal/SpatialReference.hpp>
-#include <pdal/Utils.hpp>
-#include <pdal/drivers/las/VariableLengthRecord.hpp>
-BOOST_AUTO_TEST_SUITE(SpatialReferenceTest)
-#ifdef PDAL_SRS_ENABLED
-BOOST_AUTO_TEST_CASE(test_env_vars)
-#ifdef _MSC_VER
- const char* gdal_data = getenv("GDAL_DATA");
- const char* proj_lib = getenv("PROJ_LIB");
- BOOST_CHECK(pdal::Utils::fileExists(gdal_data));
- BOOST_CHECK(pdal::Utils::fileExists(proj_lib));
-#endif
- return;
-BOOST_AUTO_TEST_CASE(test_ctor)
- pdal::SpatialReference srs;
- BOOST_CHECK(srs.getProj4() == "");
- BOOST_CHECK(srs.getWKT() == "");
- return;
-// Test round-tripping proj.4 string
-BOOST_AUTO_TEST_CASE(test_proj4_roundtrip)
- const std::string proj4 = "+proj=utm +zone=15 +datum=WGS84 +units=m +no_defs";
- const std::string proj4_ellps = "+proj=utm +zone=15 +ellps=WGS84 +datum=WGS84 +units=m +no_defs";
- const std::string proj4_out = "+proj=utm +zone=15 +ellps=WGS84 +towgs84=0,0,0,0,0,0,0 +units=m +no_defs";
More information about the Liblas-commits
