[Liblas-commits] hg-main-tree: oops, put those back
liblas-commits at liblas.org
Mon Jul 11 16:51:23 EDT 2011
details: http://hg.libpc.orghg-main-tree/rev/12b27d73370d
changeset: 849:12b27d73370d
user: Michael P. Gerlek <mpg at flaxen.com>
date: Mon Jul 11 13:51:18 2011 -0700
description:
diffstat:
test/unit/LasWriterTest.cpp | 194 ++++++++++++++++++
test/unit/SpatialReferenceTest.cpp | 389 +++++++++++++++++++++++++++++++++++++
2 files changed, 583 insertions(+), 0 deletions(-)
diffs (truncated from 591 to 300 lines):
diff -r bf1fb7ca3762 -r 12b27d73370d test/unit/LasWriterTest.cpp
--- a/test/unit/LasWriterTest.cpp Mon Jul 11 13:39:02 2011 -0700
+++ b/test/unit/LasWriterTest.cpp Mon Jul 11 13:51:18 2011 -0700
@@ -0,0 +1,194 @@
+* Copyright (c) 2011, Michael P. Gerlek (mpg at flaxen.com)
+* All rights reserved.
+* Redistribution and use in source and binary forms, with or without
+* modification, are permitted provided that the following
+* conditions are met:
+* * Redistributions of source code must retain the above copyright
+* notice, this list of conditions and the following disclaimer.
+* * Redistributions in binary form must reproduce the above copyright
+* notice, this list of conditions and the following disclaimer in
+* the documentation and/or other materials provided
+* with the distribution.
+* * Neither the name of Hobu, Inc. or Flaxen Geo Consulting nor the
+* names of its contributors may be used to endorse or promote
+* products derived from this software without specific prior
+* written permission.
+* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
+* "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
+* LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS
+* FOR A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE
+* COPYRIGHT OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT,
+* INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING,
+* BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS
+* OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED
+* AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY,
+* OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT
+* OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY
+* OF SUCH DAMAGE.
+#include <boost/test/unit_test.hpp>
+#include <boost/cstdint.hpp>
+#include <boost/lexical_cast.hpp>
+#include <boost/uuid/uuid_io.hpp>
+#include <boost/concept_check.hpp>
+#include <pdal/drivers/faux/Reader.hpp>
+#include <pdal/drivers/las/Writer.hpp>
+#include <pdal/drivers/las/Reader.hpp>
+#include "Support.hpp"
+using namespace pdal;
+BOOST_AUTO_TEST_SUITE(LasWriterTest)
+BOOST_AUTO_TEST_CASE(test_simple_las)
+ // remove file from earlier run, if needed
+ Utils::deleteFile("temp.las");
+ pdal::drivers::las::LasReader reader(Support::datapath("1.2-with-color.las"));
+ std::ostream* ofs = Utils::createFile("temp.las");
+ const boost::uint64_t numPoints = reader.getNumPoints();
+ // need to scope the writer, so that's it dtor can use the stream
+ pdal::drivers::las::LasWriter writer(reader, *ofs);
+ BOOST_CHECK(writer.getDescription() == "Las Writer");
+ writer.setCompressed(false);
+ writer.setDate(0, 0);
+ writer.setPointFormat(::pdal::drivers::las::PointFormat3);
+ writer.setSystemIdentifier("");
+ writer.setGeneratingSoftware("TerraScan");
+ writer.write(numPoints);
+ Utils::closeFile(ofs);
+ bool filesSame = Support::compare_files("temp.las", Support::datapath("simple.las"));
+ BOOST_CHECK(filesSame);
+ if (filesSame)
+ return;
+BOOST_AUTO_TEST_CASE(test_simple_laz)
+ Utils::deleteFile("temp.laz");
+ std::ostream* ofs = Utils::createFile("temp.laz");
+ writer.setCompressed(true);
+ pdal::drivers::las::LasReader reader("temp.laz");
+ bool filesSame = Support::compare_files("temp.laz", Support::datapath("1.2-with-color.laz"));
+ if (filesSame)
+ return;
+static void test_a_format(const std::string& refFile, boost::uint8_t majorVersion, boost::uint8_t minorVersion, int pointFormat)
+ pdal::drivers::las::LasReader reader(Support::datapath("1.2_3.las"));
+ writer.setDate(78, 2008);
+ writer.setPointFormat((::pdal::drivers::las::PointFormat)pointFormat);
+ writer.setFormatVersion(majorVersion, minorVersion);
+ writer.setSystemIdentifier("libLAS");
+ writer.setGeneratingSoftware("libLAS 1.2");
+ boost::uuids::uuid u = boost::lexical_cast<boost::uuids::uuid>("8388f1b8-aa1b-4108-bca3-6bc68e7b062e");
+ writer.setProjectId(u);
+ // BUG: the following test commented out as per ticket #35
+ boost::ignore_unused_variable_warning(refFile);
+ //const bool filesSame = Support::compare_files("temp.las", Support::datapath(refFile));
+ //BOOST_CHECK(filesSame);
+ //if (filesSame)
+ return;
+BOOST_AUTO_TEST_CASE(test_different_formats)
+ test_a_format("1.0_0.las", 1, 0, 0);
+ test_a_format("1.0_1.las", 1, 0, 1);
+ test_a_format("1.1_0.las", 1, 1, 0);
+ test_a_format("1.1_1.las", 1, 1, 1);
+ test_a_format("1.2_0.las", 1, 2, 0);
+ test_a_format("1.2_1.las", 1, 2, 1);
+ test_a_format("1.2_2.las", 1, 2, 2);
+ test_a_format("1.2_3.las", 1, 2, 3);
+ return;
+BOOST_AUTO_TEST_SUITE_END()
diff -r bf1fb7ca3762 -r 12b27d73370d test/unit/SpatialReferenceTest.cpp
--- a/test/unit/SpatialReferenceTest.cpp Mon Jul 11 13:39:02 2011 -0700
+++ b/test/unit/SpatialReferenceTest.cpp Mon Jul 11 13:51:18 2011 -0700
@@ -0,0 +1,389 @@
+* OF SUCH DAMAGE.
+#include <pdal/SpatialReference.hpp>
+#include <pdal/Utils.hpp>
+#include <pdal/drivers/las/VariableLengthRecord.hpp>
+BOOST_AUTO_TEST_SUITE(SpatialReferenceTest)
+#ifdef PDAL_SRS_ENABLED
+BOOST_AUTO_TEST_CASE(test_env_vars)
+#ifdef _MSC_VER
+ const char* gdal_data = getenv("GDAL_DATA");
+ const char* proj_lib = getenv("PROJ_LIB");
+ BOOST_CHECK(pdal::Utils::fileExists(gdal_data));
+ BOOST_CHECK(pdal::Utils::fileExists(proj_lib));
+#endif
+ return;
+BOOST_AUTO_TEST_CASE(test_ctor)
+ pdal::SpatialReference srs;
+ BOOST_CHECK(srs.getProj4() == "");
+ BOOST_CHECK(srs.getWKT() == "");
+ return;
+// Test round-tripping proj.4 string
+BOOST_AUTO_TEST_CASE(test_proj4_roundtrip)
+ const std::string proj4 = "+proj=utm +zone=15 +datum=WGS84 +units=m +no_defs";
+ const std::string proj4_ellps = "+proj=utm +zone=15 +ellps=WGS84 +datum=WGS84 +units=m +no_defs";
+ const std::string proj4_out = "+proj=utm +zone=15 +ellps=WGS84 +towgs84=0,0,0,0,0,0,0 +units=m +no_defs";
+ pdal::SpatialReference ref;
+ ref.setProj4(proj4);
+ const std::string ret = ref.getProj4();
+ //BOOST_CHECK(ret == proj4);
+ BOOST_CHECK(ret == proj4_out);
+ ref.setProj4(proj4_ellps);
More information about the Liblas-commits
