[Liblas-commits] hg-main-tree: some riffing around with
boost::multi_index to con...
liblas-commits at liblas.org
Tue Jul 12 17:00:56 EDT 2011
details: http://hg.libpc.orghg-main-tree/rev/34e04ba6b651
changeset: 855:34e04ba6b651
user: Howard Butler <hobu.inc at gmail.com>
date: Tue Jul 12 16:00:41 2011 -0500
description:
some riffing around with boost::multi_index to contain the pdal::Dimensions for the pdal::Schema
diffstat:
include/pdal/Schema.hpp | 5 +++++
src/Schema.cpp | 38 +++++++++++++++++++++++++++++++++++++-
2 files changed, 42 insertions(+), 1 deletions(-)
diffs (103 lines):
diff -r 650c22afc8ac -r 34e04ba6b651 include/pdal/Schema.hpp
--- a/include/pdal/Schema.hpp Tue Jul 12 09:29:29 2011 -0500
+++ b/include/pdal/Schema.hpp Tue Jul 12 16:00:41 2011 -0500
@@ -88,6 +88,10 @@
> IndexMap;
+// typedef IndexMap::index<name>::type index_by_name;
+// typedef IndexMap::index<position>::type index_by_position;
+typedef IndexMap::index<index>::type index_by_index;
}} // pdal::schema::index
/// Schema definition
@@ -137,6 +141,7 @@
private:
std::vector<Dimension> m_dimensions;
+ pdal::schema::index::IndexMap m_index;
// this is a mapping from field name to index position in the
// m_dimensions array (or -1 if field not present)
diff -r 650c22afc8ac -r 34e04ba6b651 src/Schema.cpp
--- a/src/Schema.cpp Tue Jul 12 09:29:29 2011 -0500
+++ b/src/Schema.cpp Tue Jul 12 16:00:41 2011 -0500
@@ -42,9 +42,12 @@
#include <pdal/Schema.hpp>
#include <iostream>
+#include <algorithm>
#include <pdal/exceptions.hpp>
+#include <boost/lambda/lambda.hpp>
#ifdef PDAL_HAVE_LIBXML2
#include <pdal/XMLSchema.hpp>
#endif
@@ -53,12 +56,13 @@
-Schema::Schema()
+Schema::Schema()
for (int i=0; i<Dimension::Field_LAST; i++)
m_indexTable[i] = -1;
+ m_index.reserve(512);
return;
@@ -146,10 +150,19 @@
const Dimension::Field field = dim.getField();
assert(m_indexTable[field] == -1);
m_indexTable[field] = (int)index;
+ schema::index::index_by_index & idx = m_index.get<schema::index::index>();
+ idx.push_back(dim);
return;
+bool SameDimension(Dimension const& dim1, Dimension const& dim2)
+ if (dim1 == dim2) return true;
+ return false;
void Schema::removeDimension(Dimension const& dim)
@@ -160,6 +173,29 @@
//std::size_t index = getDimensionIndex(dim);
//m_dimensions[index] = Dimension(Dimension::Field_INVALID, Dimension::Int32);
+ // Add/reset the dimension ptr on the dimensions map
+ schema::index::index_by_index::iterator it = idx.begin();
+ while (it != idx.end())
+ if (*it == dim)
+ idx.erase(it);
+ break;
+ ++it;
+ // if (it != name_index.end())
+ // name_index.replace(it, dim);
+ // else
+ // m_index.insert(d);
return;
More information about the Liblas-commits
