[Liblas-commits] hg-main-tree: playing around with pipeline builder
liblas-commits at liblas.org
Tue Jul 12 23:39:04 EDT 2011
details: http://hg.libpc.orghg-main-tree/rev/92f26eab6619
changeset: 856:92f26eab6619
user: Michael P. Gerlek <mpg at flaxen.com>
date: Tue Jul 12 20:38:47 2011 -0700
description:
Subject: hg-main-tree: merge
details: http://hg.libpc.orghg-main-tree/rev/23549d6e8f19
changeset: 857:23549d6e8f19
date: Tue Jul 12 20:38:59 2011 -0700
description:
merge
diffstat:
apps/CMakeLists.txt | 8 +-
apps/qfit2las.cpp | 116 +++++++++++++++++++++++++
include/pdal/PipelineManager.hpp | 54 ++++++-----
include/pdal/Schema.hpp | 5 +
include/pdal/StageFactory.hpp | 99 +++++++++++++++++++++
src/CMakeLists.txt | 2 +
src/PipelineManager.cpp | 114 +++++++++++++++++++-----
src/Schema.cpp | 38 ++++++++-
src/StageFactory.cpp | 173 ++++++++++++++++++++++++++++++++++++++
src/drivers/las/Header.cpp | 18 ++-
src/drivers/qfit/Reader.cpp | 4 +-
test/unit/CMakeLists.txt | 1 +
test/unit/PipelineManagerTest.cpp | 5 +
test/unit/QFITReaderTest.cpp | 5 +-
test/unit/StageFactoryTest.cpp | 52 +++++++++++
15 files changed, 634 insertions(+), 60 deletions(-)
diffs (truncated from 929 to 300 lines):
diff -r 638cd2e5253c -r 23549d6e8f19 apps/CMakeLists.txt
--- a/apps/CMakeLists.txt Mon Jul 11 13:54:36 2011 -0700
+++ b/apps/CMakeLists.txt Tue Jul 12 20:38:59 2011 -0700
@@ -23,10 +23,11 @@
set(PC2PC pc2pc)
set(PCINFO pcinfo)
+set(QFIT2LAS qfit2las)
set(PDAL_UTILITIES
- ${PCINFO} ${PC2PC} ${PCVIEW})
+ ${PCINFO} ${PC2PC} ${PCVIEW} ${QFIT2LAS})
@@ -60,6 +61,11 @@
target_link_libraries(${PC2PC} ${APPS_CPP_DEPENDENCIES} )
endif()
+if(QFIT2LAS)
+ add_executable(${QFIT2LAS} qfit2las.cpp Application.cpp Application.hpp)
+ target_link_libraries(${QFIT2LAS} ${APPS_CPP_DEPENDENCIES} )
+endif()
# Targets installation
diff -r 638cd2e5253c -r 23549d6e8f19 apps/qfit2las.cpp
--- /dev/null Thu Jan 01 00:00:00 1970 +0000
+++ b/apps/qfit2las.cpp Tue Jul 12 20:38:59 2011 -0700
@@ -0,0 +1,116 @@
+ * Project: libLAS -- C/C++ read/write library for LAS LIDAR data
+ * Purpose: LAS translation with optional configuration
+ * Author: Howard Butler, hobu.inc at gmail.com
+ * Copyright (c) 2010, Howard Butler, hobu.inc at gmail.com
+ * See LICENSE.txt in this source distribution for more information.
+#include <iostream>
+#include <pdal/exceptions.hpp>
+#include <pdal/drivers/las/Reader.hpp>
+#include <pdal/drivers/las/Writer.hpp>
+#include <pdal/drivers/qfit/Reader.hpp>
+#include "Application.hpp"
+using namespace pdal;
+namespace po = boost::program_options;
+class Application_pc2pc : public Application
+public:
+ Application_pc2pc(int argc, char* argv[]);
+ int execute();
+private:
+ void addOptions();
+ bool validateOptions();
+ std::string m_inputFile;
+ std::string m_outputFile;
+Application_pc2pc::Application_pc2pc(int argc, char* argv[])
+ : Application(argc, argv, "pc2pc")
+bool Application_pc2pc::validateOptions()
+ if (!hasOption("input"))
+ usageError("--input/-i required");
+ return false;
+ if (!hasOption("output"))
+ usageError("--output/-o required");
+ return false;
+ return true;
+void Application_pc2pc::addOptions()
+ po::options_description* file_options = new po::options_description("file options");
+ file_options->add_options()
+ ("input,i", po::value<std::string>(&m_inputFile), "input file name")
+ ("output,o", po::value<std::string>(&m_outputFile), "output file name")
+ addOptionSet(file_options);
+int Application_pc2pc::execute()
+ if (!Utils::fileExists(m_inputFile))
+ runtimeError("file not found: " + m_inputFile);
+ return 1;
+ std::ostream* ofs = Utils::createFile(m_outputFile);
+ pdal::Options options;
+ pdal::Option<std::string> filename("input", m_inputFile, "Input filename for reader to use" );
+ options.add(filename);
+ pdal::drivers::qfit::Reader reader(options);
+ const boost::uint64_t numPoints = reader.getNumPoints();
+ pdal::drivers::las::LasWriter writer(reader, *ofs);
+ // writer.setPointFormat( reader.getPointFormat() );
+ writer.write(numPoints);
+ Utils::closeFile(ofs);
+ return 0;
+int main(int argc, char* argv[])
+ Application_pc2pc app(argc, argv);
+ return app.run();
diff -r 638cd2e5253c -r 23549d6e8f19 include/pdal/PipelineManager.hpp
--- a/include/pdal/PipelineManager.hpp Mon Jul 11 13:54:36 2011 -0700
+++ b/include/pdal/PipelineManager.hpp Tue Jul 12 20:38:59 2011 -0700
@@ -35,50 +35,56 @@
#ifndef INCLUDED_PIPELINEMANAGER_HPP
#define INCLUDED_PIPELINEMANAGER_HPP
+#include <pdal/pdal.hpp>
+#include <pdal/StageFactory.hpp>
+#include <boost/shared_ptr.hpp>
#include <vector>
-#include <pdal/Stage.hpp>
-#include <pdal/Filter.hpp>
-#include <pdal/Writer.hpp>
+#include <map>
+#include <string>
namespace pdal
-class OptionsNew;
+class Stage;
+class Reader;
+class Filter;
+class MultiFilter;
+class Writer;
+class Options;
class PDAL_DLL PipelineManager
public:
PipelineManager();
+ ~PipelineManager();
- boost::uint32_t addReader(const std::string& type, const OptionsNew&);
- boost::uint32_t addFilter(const std::string& type, boost::uint32_t prevStage, const OptionsNew&);
- boost::uint32_t addFilter(const std::string& type, const std::vector<boost::uint32_t>& prevStages, const OptionsNew&);
- boost::uint32_t addWriter(const std::string& type, boost::uint32_t prevStage, const OptionsNew&);
+ boost::uint32_t addReader(const std::string& type, const Options&);
+ boost::uint32_t addFilter(const std::string& type, boost::uint32_t prevStage, const Options&);
+ boost::uint32_t addMultiFilter(const std::string& type, const std::vector<boost::uint32_t>& prevStages, const Options&);
+ boost::uint32_t addWriter(const std::string& type, boost::uint32_t prevStage, const Options&);
- Stage* getStage(boost::uint32_t);
- Filter* getFilter(boost::uint32_t);
- Writer* getWriter(boost::uint32_t);
- typedef Stage* readerCreatorFunction(const OptionsNew&);
- typedef Filter* filter1CreatorFunction(boost::uint32_t prevStage, const OptionsNew&);
- typedef Filter* filterNCreatorFunction(const std::vector<boost::uint32_t>& prevStage, const OptionsNew&);
- typedef Writer* writerCreatorFunction(boost::uint32_t prevStage, const OptionsNew&);
- void registerReader(const std::string& type, readerCreatorFunction);
- void registerFilter(const std::string& type, filter1CreatorFunction);
- void registerFilter(const std::string& type, filterNCreatorFunction);
- void registerWriter(const std::string& type, writerCreatorFunction);
+ boost::shared_ptr<Reader> getReader(boost::uint32_t);
+ boost::shared_ptr<Filter> getFilter(boost::uint32_t);
+ boost::shared_ptr<MultiFilter> getMultiFilter(boost::uint32_t);
+ boost::shared_ptr<Writer> getWriter(boost::uint32_t);
private:
- void registerKnownReaders();
- void registerKnownFilters();
- void registerKnownWriters();
+ StageFactory m_factory;
+ std::vector<boost::shared_ptr<Reader>> m_readerStages;
+ std::vector<boost::shared_ptr<Filter>> m_filterStages;
+ std::vector<boost::shared_ptr<MultiFilter>> m_multifilterStages;
+ std::vector<boost::shared_ptr<Writer>> m_writerStages;
PipelineManager& operator=(const PipelineManager&); // not implemented
PipelineManager(const PipelineManager&); // not implemented
} // namespace pdal
#endif
diff -r 638cd2e5253c -r 23549d6e8f19 include/pdal/Schema.hpp
--- a/include/pdal/Schema.hpp Mon Jul 11 13:54:36 2011 -0700
+++ b/include/pdal/Schema.hpp Tue Jul 12 20:38:59 2011 -0700
@@ -88,6 +88,10 @@
> IndexMap;
+// typedef IndexMap::index<name>::type index_by_name;
+// typedef IndexMap::index<position>::type index_by_position;
+typedef IndexMap::index<index>::type index_by_index;
}} // pdal::schema::index
/// Schema definition
@@ -137,6 +141,7 @@
private:
std::vector<Dimension> m_dimensions;
+ pdal::schema::index::IndexMap m_index;
// this is a mapping from field name to index position in the
// m_dimensions array (or -1 if field not present)
diff -r 638cd2e5253c -r 23549d6e8f19 include/pdal/StageFactory.hpp
+++ b/include/pdal/StageFactory.hpp Tue Jul 12 20:38:59 2011 -0700
@@ -0,0 +1,99 @@
+* Copyright (c) 2011, Michael P. Gerlek (mpg at flaxen.com)
+* All rights reserved.
+* Redistribution and use in source and binary forms, with or without
+* modification, are permitted provided that the following
+* conditions are met:
+* * Redistributions of source code must retain the above copyright
+* notice, this list of conditions and the following disclaimer.
+* * Redistributions in binary form must reproduce the above copyright
+* notice, this list of conditions and the following disclaimer in
+* the documentation and/or other materials provided
+* with the distribution.
+* * Neither the name of Hobu, Inc. or Flaxen Geo Consulting nor the
+* names of its contributors may be used to endorse or promote
+* products derived from this software without specific prior
+* written permission.
+* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
+* "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
+* LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS
+* FOR A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE
+* COPYRIGHT OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT,
+* INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING,
+* BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS
+* OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED
+* AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY,
+* OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT
+* OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY
+* OF SUCH DAMAGE.
+#ifndef INCLUDED_STAGEFACTORY_HPP
+#define INCLUDED_STAGEFACTORY_HPP
+#include <vector>
More information about the Liblas-commits
