[Liblas-commits] hg-main-tree: fix problem with writing zero points
liblas-commits at liblas.org liblas-commits at liblas.org
Tue Jul 26 18:46:51 EDT 2011
details:   http://hg.libpc.orghg-main-tree/rev/7f4fc73b65d2
changeset: 946:7f4fc73b65d2
user:      Michael P. Gerlek <mpg at flaxen.com>
date:      Tue Jul 26 15:45:34 2011 -0700
description:
Subject: hg-main-tree: don't need icky strings
details:   http://hg.libpc.orghg-main-tree/rev/244e92c53a02
changeset: 947:244e92c53a02
date:      Tue Jul 26 15:46:16 2011 -0700
description:
Subject: hg-main-tree: improve pipeline testing
details:   http://hg.libpc.orghg-main-tree/rev/858fefc45f55
changeset: 948:858fefc45f55
date:      Tue Jul 26 15:46:44 2011 -0700
description:
diffstat:
 include/pdal/PipelineManager.hpp  |   2 +-
 include/pdal/Writer.hpp           |   5 +++--
 src/PipelineManager.cpp           |   4 ++--
 src/Writer.cpp                    |  17 +++--------------
 src/filters/CropFilter.cpp        |   4 +---
 test/data/pipeline1.xml           |   4 ++--
 test/unit/PipelineManagerTest.cpp |  10 ++++++++--
 test/unit/StageFactoryTest.cpp    |  37 ++++++++++++++++++++-----------------
 8 files changed, 40 insertions(+), 43 deletions(-)
diffs (206 lines):
diff -r a768f37245fd -r 858fefc45f55 include/pdal/PipelineManager.hpp
--- a/include/pdal/PipelineManager.hpp	Tue Jul 26 15:14:02 2011 -0700
+++ b/include/pdal/PipelineManager.hpp	Tue Jul 26 15:46:44 2011 -0700
@@ -62,7 +62,7 @@
     MultiFilter* addMultiFilter(const std::string& type, const std::vector<const Stage*>& prevStages, const Options&);
     Writer* addWriter(const std::string& type, const Stage& prevStage, const Options&);
-    void readXml(const std::string&);
+    Writer* readWriterPipeline(const std::string&);
 private:
     void parsePipeline(const boost::property_tree::ptree&, Writer*& writer, Stage*& stage);
diff -r a768f37245fd -r 858fefc45f55 include/pdal/Writer.hpp
--- a/include/pdal/Writer.hpp	Tue Jul 26 15:14:02 2011 -0700
+++ b/include/pdal/Writer.hpp	Tue Jul 26 15:46:44 2011 -0700
@@ -57,10 +57,11 @@
     void setChunkSize(boost::uint32_t);
     boost::uint32_t getChunkSize() const;
-    // Read the  given number of points (or less, if the reader runs out first),
+    // Read the given number of points (or less, if the reader runs out first),
     // and then write them out to wherever.  Returns total number of points
     // actually written.
-    boost::uint64_t write(boost::uint64_t targetNumPointsToWrite);
+    // If given number of points is 0, do as many points as the reader supplies to us.
+    boost::uint64_t write(boost::uint64_t targetNumPointsToWrite=0);
 protected:
     // this is called once before the loop with the writeBuffer calls
diff -r a768f37245fd -r 858fefc45f55 src/PipelineManager.cpp
--- a/src/PipelineManager.cpp	Tue Jul 26 15:14:02 2011 -0700
+++ b/src/PipelineManager.cpp	Tue Jul 26 15:46:44 2011 -0700
@@ -367,7 +367,7 @@
-void PipelineManager::readXml(const std::string& filename)
+Writer* PipelineManager::readWriterPipeline(const std::string& filename)
     boost::property_tree::ptree tree;
     boost::property_tree::xml_parser::read_xml(filename, tree);
@@ -378,7 +378,7 @@
     Stage* stage = NULL;
     parsePipeline(pipeline, writer, stage);
-    return;
+    return writer;
diff -r a768f37245fd -r 858fefc45f55 src/Writer.cpp
--- a/src/Writer.cpp	Tue Jul 26 15:14:02 2011 -0700
+++ b/src/Writer.cpp	Tue Jul 26 15:46:44 2011 -0700
@@ -81,20 +81,7 @@
     m_targetNumPointsToWrite = targetNumPointsToWrite;
     m_actualNumPointsWritten = 0;
-    PointCountType count_type = m_prevStage.getPointCountType();
-    // passing in a 0 for the number of points means "write to the end"
-    // but we need to have an end to actually do that.  This code isn't
-    // currently sufficient to go on writing forever.
-    if (targetNumPointsToWrite == 0)
-        if (count_type == PointCount_Unknown)
-            throw pdal_error("Unable to write points with an unknowable point count");
     boost::scoped_ptr<StageSequentialIterator> iter(m_prevStage.createSequentialIterator());
     if (!iter) throw pdal_error("Unable to obtain iterator from previous stage!");
@@ -112,6 +99,8 @@
             numPointsWrittenThisChunk = writeBuffer(buffer);
             m_actualNumPointsWritten += numPointsWrittenThisChunk;
+            buffer.setNumPoints(0); // reset the buffer, so we can use it again
             numPointsReadThisChunk = iter->read(buffer);
     } else
diff -r a768f37245fd -r 858fefc45f55 src/filters/CropFilter.cpp
--- a/src/filters/CropFilter.cpp	Tue Jul 26 15:14:02 2011 -0700
+++ b/src/filters/CropFilter.cpp	Tue Jul 26 15:46:44 2011 -0700
@@ -47,10 +47,8 @@
 CropFilter::CropFilter(const Stage& prevStage, const Options& options)
     : pdal::Filter(prevStage, options)
+    , m_bounds(options.getOption<Bounds<double> >("bounds").getValue())
-    std::stringstream bounds_str ( options.getOption<std::string>("bounds").getValue() );
-    bounds_str >> m_bounds;
     initialize();
     return;
diff -r a768f37245fd -r 858fefc45f55 test/data/pipeline1.xml
--- a/test/data/pipeline1.xml	Tue Jul 26 15:14:02 2011 -0700
+++ b/test/data/pipeline1.xml	Tue Jul 26 15:46:44 2011 -0700
@@ -11,14 +11,14 @@
             <Type>filters.crop</Type>
             <Option>
                 <Name>bounds</Name>
-                <Value>([0,1],[0,1],[0,1])</Value>
+                <Value>([0,1000000],[0,1000000],[0,1000000])</Value>
             </Option>
             <Reader>
                 <Type>drivers.las.reader</Type>
                 <Option>
                     <Name>filename</Name>
                     <Value>../../test/data/1.2-with-color.las</Value>
-                </option>
+                </Option>
             </Reader>
         </Filter>
     </Writer>
diff -r a768f37245fd -r 858fefc45f55 test/unit/PipelineManagerTest.cpp
--- a/test/unit/PipelineManagerTest.cpp	Tue Jul 26 15:14:02 2011 -0700
+++ b/test/unit/PipelineManagerTest.cpp	Tue Jul 26 15:46:44 2011 -0700
@@ -57,13 +57,16 @@
     Reader* reader = mgr.addReader("drivers.las.reader", optsR);
     Options optsF;
-    optsF.add("bounds", Bounds<double>(0,0,0,1,1,1), "crop bounds");
+    optsF.add("bounds", Bounds<double>(0,0,0,1000000,1000000,1000000), "crop bounds");
     Filter* filter = mgr.addFilter("filters.crop", *reader, optsF);
     Options optsW;
     optsW.add("filename", "temp.las", "file to write to");
     Writer* writer = mgr.addWriter("drivers.las.writer", *filter, optsW);
+    const boost::uint64_t np = writer->write( reader->getNumPoints() );
+    BOOST_CHECK(np == 1065);
     return;
@@ -72,7 +75,10 @@
     PipelineManager mgr;
-    mgr.readXml(Support::datapath("pipeline1.xml"));
+    Writer* writer = mgr.readWriterPipeline(Support::datapath("pipeline1.xml"));
+    const boost::uint64_t np = writer->write();
     return;
diff -r a768f37245fd -r 858fefc45f55 test/unit/StageFactoryTest.cpp
--- a/test/unit/StageFactoryTest.cpp	Tue Jul 26 15:14:02 2011 -0700
+++ b/test/unit/StageFactoryTest.cpp	Tue Jul 26 15:46:44 2011 -0700
@@ -56,30 +56,33 @@
     StageFactory factory;
     Options optsR;
-    optsR.add("filename", Support::datapath("1.2-with-color.las"), "file to read from");
-    Reader* ptrR = factory.createReader("drivers.las.reader", optsR);
-    BOOST_CHECK(ptrR->getName() == "drivers.las.reader");
+    optsR.add("filename", Support::datapath("1.2-with-color.las"));
+    Reader* reader = factory.createReader("drivers.las.reader", optsR);
+    BOOST_CHECK(reader->getName() == "drivers.las.reader");
     Options optsF;
-    Filter* ptrF = factory.createFilter("filters.crop", *ptrR, optsF);
-    BOOST_CHECK(ptrF->getName() == "filters.crop");
+    optsF.add("bounds", Bounds<double>(0,0,0,1000000,1000000,1000000));
+    Filter* filter = factory.createFilter("filters.crop", *reader, optsF);
+    BOOST_CHECK(filter->getName() == "filters.crop");
-    Options optsM;
-    std::vector<const Stage*> stages;
-    stages.push_back(ptrR);
-    MultiFilter* ptrM = factory.createMultiFilter("filters.mosaic", stages, optsM);
-    BOOST_CHECK(ptrM->getName() == "filters.mosaic");
+    //Options optsM;
+    //std::vector<const Stage*> stages;
+    //stages.push_back(filter);
+    //MultiFilter* multifilter = factory.createMultiFilter("filters.mosaic", stages, optsM);
+    //BOOST_CHECK(multifilter->getName() == "filters.mosaic");
     Options optsW;
-    Writer* ptrW = factory.createWriter("drivers.las.writer", *ptrF, optsW);
-    BOOST_CHECK(ptrW->getName() == "drivers.las.writer");
+    Writer* writer = factory.createWriter("drivers.las.writer", *filter, optsW);
+    BOOST_CHECK(writer->getName() == "drivers.las.writer");
-    delete ptrW;
-    delete ptrM;
-    delete ptrF;
-    delete ptrR;
+    delete writer;
+    //delete multifilter;
+    delete filter;
+    delete reader;
     return;
More information about the Liblas-commits mailing list
