[Liblas-commits] hg-main-tree: added stage dumping out to pipeline xml
liblas-commits at liblas.org liblas-commits at liblas.org
Tue Jul 26 21:15:12 EDT 2011
details:   http://hg.libpc.orghg-main-tree/rev/bfd294cde5f9
changeset: 949:bfd294cde5f9
user:      Michael P. Gerlek <mpg at flaxen.com>
date:      Tue Jul 26 18:15:04 2011 -0700
description:
diffstat:
 include/pdal/Filter.hpp           |   2 +
 include/pdal/MultiFilter.hpp      |   2 +
 include/pdal/Options.hpp          |  33 +++++++++++++-----------
 include/pdal/PipelineManager.hpp  |  13 +++++++++-
 include/pdal/Reader.hpp           |   2 +
 include/pdal/Stage.hpp            |   2 +-
 include/pdal/StageBase.hpp        |   4 +++
 include/pdal/Writer.hpp           |   4 ++-
 src/Filter.cpp                    |  21 +++++++++++++++
 src/MultiFilter.cpp               |  22 ++++++++++++++++
 src/PipelineManager.cpp           |  44 +++++++++++++++++++++++++++++++-
 src/Reader.cpp                    |  16 ++++++++++++
 src/Stage.cpp                     |   1 +
 src/Writer.cpp                    |  23 ++++++++++++++++-
 test/data/pipeline1.xml           |  25 ------------------
 test/data/pipeline_read.xml       |  17 ++++++++++++
 test/data/pipeline_write.xml      |  25 ++++++++++++++++++
 test/data/pipeline_write_out.xml  |   2 +
 test/unit/OptionsTest.cpp         |   4 +-
 test/unit/PipelineManagerTest.cpp |  52 ++++++++++++++++++++++++++++++++++++---
 20 files changed, 262 insertions(+), 52 deletions(-)
diffs (truncated from 571 to 300 lines):
diff -r 858fefc45f55 -r bfd294cde5f9 include/pdal/Filter.hpp
--- a/include/pdal/Filter.hpp	Tue Jul 26 15:46:44 2011 -0700
+++ b/include/pdal/Filter.hpp	Tue Jul 26 18:15:04 2011 -0700
@@ -49,6 +49,8 @@
     const Stage& getPrevStage() const;
+    virtual boost::property_tree::ptree generatePTree() const;
 protected:
     const Stage& m_prevStage;
diff -r 858fefc45f55 -r bfd294cde5f9 include/pdal/MultiFilter.hpp
--- a/include/pdal/MultiFilter.hpp	Tue Jul 26 15:46:44 2011 -0700
+++ b/include/pdal/MultiFilter.hpp	Tue Jul 26 18:15:04 2011 -0700
@@ -51,6 +51,8 @@
     const std::vector<const Stage*>& getPrevStages() const;
 protected:
     std::vector<const Stage*> m_prevStages;
diff -r 858fefc45f55 -r bfd294cde5f9 include/pdal/Options.hpp
--- a/include/pdal/Options.hpp	Tue Jul 26 15:46:44 2011 -0700
+++ b/include/pdal/Options.hpp	Tue Jul 26 18:15:04 2011 -0700
@@ -68,8 +68,8 @@
 // Dumped as XML, it looks like this:
 //     <?xml...>
 //     <Name>myname</Name>
+//     <Value>17</Value>
 //     <Description>my descr</Description>
-//     <Value>17</Value>
 // although of course that's not valid XML, since it has no single root element.
 template <typename T>
@@ -79,8 +79,8 @@
     // construct it manually
     Option(std::string const& name, T value, std::string const& description="")
         : m_name(name)
+        , m_value(value)
         , m_description(description)
-        , m_value(value)
     // construct it from an xml stream
@@ -103,16 +103,19 @@
     // getters
     std::string const& getName() const { return m_name; }
+    T const& getValue() const { return m_value; }
     std::string const& getDescription() const { return m_description; }
-    T const& getValue() const { return m_value; }
     // return a ptree representation
     boost::property_tree::ptree getPTree() const
         boost::property_tree::ptree t;
         t.put("Name", getName());
-        t.put("Description", getDescription());
         t.put("Value", getValue());
+        if (getDescription() != "")
+            t.put("Description", getDescription());
         return t;
@@ -126,8 +129,8 @@
 private:
     std::string m_name;
-    std::string m_description;
     T m_value;
+    std::string m_description; // optional field
@@ -137,16 +140,16 @@
 // Dumped as XML, an Options object with two Option objects looks like this:
 //     <?xml...>
-//     <option>
-//       <name>myname</name>
-//       <description>my descr</description>
-//       <value>17</value>
-//     </option>
-//     <option>
-//       <name>myname2</name>
-//       <description>my descr2</description>
-//       <value>13</value>
-//     </option>
+//     <Option>
+//       <Name>myname</name>
+//       <Value>17</value>
+//       <Description>my descr</description>
+//     </Option>
+//     <Option>
+//       <Name>myname2</name>
+//       <Value>13</value>
+//       <Description>my descr2</description>
+//     </Option>
 class PDAL_DLL Options
diff -r 858fefc45f55 -r bfd294cde5f9 include/pdal/PipelineManager.hpp
--- a/include/pdal/PipelineManager.hpp	Tue Jul 26 15:46:44 2011 -0700
+++ b/include/pdal/PipelineManager.hpp	Tue Jul 26 18:15:04 2011 -0700
@@ -57,12 +57,23 @@
     PipelineManager();
     ~PipelineManager();
+    // Use these to manually add stages into the pipeline manager.
     Reader* addReader(const std::string& type, const Options&);
     Filter* addFilter(const std::string& type, const Stage& prevStage, const Options&);
     MultiFilter* addMultiFilter(const std::string& type, const std::vector<const Stage*>& prevStages, const Options&);
     Writer* addWriter(const std::string& type, const Stage& prevStage, const Options&);
-    Writer* readWriterPipeline(const std::string&);
+    // Use this to fill in a pipeline manager with an XML file that
+    // contains a <Writer> as the last pipeline stage.
+    Writer& readWriterPipeline(const std::string&);
+    // don't contain a <Writer>.  (Even though this is called "parse
+    // READER pipeline", it actually returns a Stage; it can be used
+    // where the last pipeline stage is a Reader or Filter.)
+    const Stage& readReaderPipeline(const std::string&);
+    void writeWriterPipeline(const std::string& filename) const;
 private:
     void parsePipeline(const boost::property_tree::ptree&, Writer*& writer, Stage*& stage);
diff -r 858fefc45f55 -r bfd294cde5f9 include/pdal/Reader.hpp
--- a/include/pdal/Reader.hpp	Tue Jul 26 15:46:44 2011 -0700
+++ b/include/pdal/Reader.hpp	Tue Jul 26 18:15:04 2011 -0700
@@ -51,6 +51,8 @@
 public:
     Reader(const Options& options);
     virtual ~Reader();
 } // namespace pdal
diff -r 858fefc45f55 -r bfd294cde5f9 include/pdal/Stage.hpp
--- a/include/pdal/Stage.hpp	Tue Jul 26 15:46:44 2011 -0700
+++ b/include/pdal/Stage.hpp	Tue Jul 26 18:15:04 2011 -0700
@@ -75,7 +75,7 @@
     virtual StageBlockIterator* createBlockIterator() const  { return NULL; }
     void dump() const;
 protected:
     // setters for the core properties
     Schema& getSchemaRef();
diff -r 858fefc45f55 -r bfd294cde5f9 include/pdal/StageBase.hpp
--- a/include/pdal/StageBase.hpp	Tue Jul 26 15:46:44 2011 -0700
+++ b/include/pdal/StageBase.hpp	Tue Jul 26 18:15:04 2011 -0700
@@ -53,6 +53,10 @@
     const Options& getOptions() const;
+    // This is used to generate pipeline xml files.  It will
+    // recursively visit all child stages to populate the tree.
+    virtual boost::property_tree::ptree generatePTree() const = 0;
     // For Name, Description, and DefaultOptions:
     //   each concrete class should provide a static function s_getX() which returns a static object
     //   each concrete class should provide a virtual getX() which returns s_getX()
diff -r 858fefc45f55 -r bfd294cde5f9 include/pdal/Writer.hpp
--- a/include/pdal/Writer.hpp	Tue Jul 26 15:46:44 2011 -0700
+++ b/include/pdal/Writer.hpp	Tue Jul 26 18:15:04 2011 -0700
@@ -63,6 +63,8 @@
     // If given number of points is 0, do as many points as the reader supplies to us.
     boost::uint64_t write(boost::uint64_t targetNumPointsToWrite=0);
 protected:
     // this is called once before the loop with the writeBuffer calls
     virtual void writeBegin() = 0;
@@ -73,7 +75,7 @@
     // called once, after the writeBuffer calls
     virtual void writeEnd() = 0;
-    const Stage& getPrevStage();
+    const Stage& getPrevStage() const;
     // these two are valid for use after writeBegin has been called
     boost::uint64_t m_actualNumPointsWritten;
diff -r 858fefc45f55 -r bfd294cde5f9 src/Filter.cpp
--- a/src/Filter.cpp	Tue Jul 26 15:46:44 2011 -0700
+++ b/src/Filter.cpp	Tue Jul 26 18:15:04 2011 -0700
@@ -56,4 +56,25 @@
+boost::property_tree::ptree Filter::generatePTree() const
+    boost::property_tree::ptree tree;
+    tree.add("Type", getName());
+    boost::property_tree::ptree optiontree = getOptions().getPTree();
+    tree.add_child(optiontree.begin()->first, optiontree.begin()->second);
+    const Stage& stage = getPrevStage();
+    boost::property_tree::ptree subtree = stage.generatePTree();
+    tree.add_child(subtree.begin()->first, subtree.begin()->second);
+    boost::property_tree::ptree root;
+    root.add_child("Filter", tree);
+    return root;
 } // namespace pdal
diff -r 858fefc45f55 -r bfd294cde5f9 src/MultiFilter.cpp
--- a/src/MultiFilter.cpp	Tue Jul 26 15:46:44 2011 -0700
+++ b/src/MultiFilter.cpp	Tue Jul 26 18:15:04 2011 -0700
@@ -96,5 +96,27 @@
+boost::property_tree::ptree MultiFilter::generatePTree() const
+    BOOST_FOREACH(const Stage* stage, getPrevStages())
+        boost::property_tree::ptree subtree = stage->generatePTree();
+    root.add_child("MultiFilter", tree);
+    return root;
 } // namespace pdal
diff -r 858fefc45f55 -r bfd294cde5f9 src/PipelineManager.cpp
--- a/src/PipelineManager.cpp	Tue Jul 26 15:46:44 2011 -0700
+++ b/src/PipelineManager.cpp	Tue Jul 26 18:15:04 2011 -0700
@@ -367,7 +367,7 @@
-Writer* PipelineManager::readWriterPipeline(const std::string& filename)
+Writer& PipelineManager::readWriterPipeline(const std::string& filename)
     boost::property_tree::xml_parser::read_xml(filename, tree);
@@ -378,8 +378,48 @@
     Stage* stage = NULL;
     parsePipeline(pipeline, writer, stage);
-    return writer;
+    return *writer;
+const Stage& PipelineManager::readReaderPipeline(const std::string& filename)
+    boost::property_tree::xml_parser::read_xml(filename, tree);
+    boost::property_tree::ptree pipeline = tree.get_child("Pipeline"); // err check
+    Writer* writer = NULL;
+    Stage* stage = NULL;
+    parsePipeline(pipeline, writer, stage);
+    return *stage;
+static boost::property_tree::ptree generateTreeFromWriter(const Writer& writer)
+    boost::property_tree::ptree subtree = writer.generatePTree();
+    tree.add_child("Pipeline", subtree);
+    return tree;
More information about the Liblas-commits mailing list
