[Liblas-commits] libpc: fixed bad types
liblas-commits at liblas.org
Thu Mar 3 19:47:03 EST 2011
details: http://hg.liblas.orglibpc/rev/9ccbaa4f4705
changeset: 168:9ccbaa4f4705
user: Michael P. Gerlek <mpg at flaxen.com>
date: Thu Mar 03 16:46:50 2011 -0800
description:
fixed bad types
diffstat:
src/FauxWriter.cpp | 6 +++---
src/drivers/liblas/writer.cpp | 6 +++---
test/unit/FauxReaderTest.cpp | 16 ++++++++--------
test/unit/LiblasReaderTest.cpp | 6 +++---
4 files changed, 17 insertions(+), 17 deletions(-)
diffs (81 lines):
diff -r 95b6b16e10c2 -r 9ccbaa4f4705 src/FauxWriter.cpp
--- a/src/FauxWriter.cpp Thu Mar 03 16:44:46 2011 -0800
+++ b/src/FauxWriter.cpp Thu Mar 03 16:46:50 2011 -0800
@@ -94,9 +94,9 @@
const boost::uint32_t numPoints = pointData.getNumPoints();
const Schema& schema = pointData.getSchemaLayout().getSchema();
- const std::size_t fieldIndexX = schema.getDimensionIndex(Dimension::Field_X);
- const std::size_t fieldIndexY = schema.getDimensionIndex(Dimension::Field_Y);
- const std::size_t fieldIndexZ = schema.getDimensionIndex(Dimension::Field_Z);
+ const int fieldIndexX = schema.getDimensionIndex(Dimension::Field_X);
+ const int fieldIndexY = schema.getDimensionIndex(Dimension::Field_Y);
+ const int fieldIndexZ = schema.getDimensionIndex(Dimension::Field_Z);
boost::uint32_t numValidPoints = 0;
for (boost::uint32_t pointIndex=0; pointIndex<numPoints; pointIndex++)
diff -r 95b6b16e10c2 -r 9ccbaa4f4705 src/drivers/liblas/writer.cpp
--- a/src/drivers/liblas/writer.cpp Thu Mar 03 16:44:46 2011 -0800
+++ b/src/drivers/liblas/writer.cpp Thu Mar 03 16:46:50 2011 -0800
@@ -93,9 +93,9 @@
setSystemIdentifier("libPC");
setGeneratingSoftware(GetVersionString());
- std::size_t indexX = getHeader().getSchema().getDimensionIndex(Dimension::Field_X);
- std::size_t indexY = getHeader().getSchema().getDimensionIndex(Dimension::Field_Y);
- std::size_t indexZ = getHeader().getSchema().getDimensionIndex(Dimension::Field_Z);
+ int indexX = getHeader().getSchema().getDimensionIndex(Dimension::Field_X);
+ int indexY = getHeader().getSchema().getDimensionIndex(Dimension::Field_Y);
+ int indexZ = getHeader().getSchema().getDimensionIndex(Dimension::Field_Z);
const Dimension& dimX = getHeader().getSchema().getDimension(indexX);
const Dimension& dimY = getHeader().getSchema().getDimension(indexY);
const Dimension& dimZ = getHeader().getSchema().getDimension(indexZ);
diff -r 95b6b16e10c2 -r 9ccbaa4f4705 test/unit/FauxReaderTest.cpp
--- a/test/unit/FauxReaderTest.cpp Thu Mar 03 16:44:46 2011 -0800
+++ b/test/unit/FauxReaderTest.cpp Thu Mar 03 16:46:50 2011 -0800
@@ -56,10 +56,10 @@
BOOST_CHECK(numRead == 750);
- std::size_t offsetX = schema.getDimensionIndex(Dimension::Field_X);
- std::size_t offsetY = schema.getDimensionIndex(Dimension::Field_Y);
- std::size_t offsetZ = schema.getDimensionIndex(Dimension::Field_Z);
- std::size_t offsetT = schema.getDimensionIndex(Dimension::Field_GpsTime);
+ int offsetX = schema.getDimensionIndex(Dimension::Field_X);
+ int offsetY = schema.getDimensionIndex(Dimension::Field_Y);
+ int offsetZ = schema.getDimensionIndex(Dimension::Field_Z);
+ int offsetT = schema.getDimensionIndex(Dimension::Field_GpsTime);
for (boost::uint32_t i=0; i<numRead; i++)
@@ -92,10 +92,10 @@
diff -r 95b6b16e10c2 -r 9ccbaa4f4705 test/unit/LiblasReaderTest.cpp
--- a/test/unit/LiblasReaderTest.cpp Thu Mar 03 16:44:46 2011 -0800
+++ b/test/unit/LiblasReaderTest.cpp Thu Mar 03 16:46:50 2011 -0800
@@ -48,9 +48,9 @@
static void checkPointXYZ(const PointData& data, size_t index, const Schema& schema,
double xref, double yref, double zref)
boost::int32_t x0raw = data.getField<boost::int32_t>(index, offsetX);
boost::int32_t y0raw = data.getField<boost::int32_t>(index, offsetY);
More information about the Liblas-commits
