[Liblas-commits] libpc: don't expose liblas headers\!
liblas-commits at liblas.org
Thu Mar 3 20:40:11 EST 2011
details: http://hg.liblas.orglibpc/rev/acd792209405
changeset: 169:acd792209405
user: Michael P. Gerlek <mpg at flaxen.com>
date: Thu Mar 03 17:03:54 2011 -0800
description:
Subject: libpc: swig work
details: http://hg.liblas.orglibpc/rev/b90ead329da0
changeset: 170:b90ead329da0
date: Thu Mar 03 17:39:35 2011 -0800
description:
swig work
diffstat:
.hgignore | 1 +
csharp/libpc_swig_cpp/libpc.i | 66 +++++++++++++++++++++++++++
csharp/libpc_swig_cs/libpc_swig_cs.csproj | 8 +++
csharp/libpc_swig_test/Program.cs | 2 +
csharp/libpc_swig_test/TestLiblasReader.cs | 26 ++++++++++
csharp/libpc_swig_test/libpc_swig_test.csproj | 1 +
src/drivers/liblas/reader.cpp | 22 ++++----
src/drivers/liblas/reader.hpp | 5 +-
8 files changed, 116 insertions(+), 15 deletions(-)
diffs (260 lines):
diff -r 9ccbaa4f4705 -r b90ead329da0 .hgignore
--- a/.hgignore Thu Mar 03 16:46:50 2011 -0800
+++ b/.hgignore Thu Mar 03 17:39:35 2011 -0800
@@ -31,3 +31,4 @@
# generated swig files
csharp/libpc_swig_cs/*.cs
+csharp/libpc_swig_cpp/libpc_wrap.cpp
diff -r 9ccbaa4f4705 -r b90ead329da0 csharp/libpc_swig_cpp/libpc.i
--- a/csharp/libpc_swig_cpp/libpc.i Thu Mar 03 16:46:50 2011 -0800
+++ b/csharp/libpc_swig_cpp/libpc.i Thu Mar 03 17:39:35 2011 -0800
@@ -43,6 +43,11 @@
#include "libpc/libpc_config.hpp"
#include "libpc/Dimension.hpp"
+#include "libpc/Header.hpp"
+#include "libpc/Schema.hpp"
+#include "libpc/Reader.hpp"
+#include "libpc/../../src/drivers/liblas/reader.hpp"
+#include "libpc/../../src/drivers/liblas/header.hpp"
%include "typemaps.i"
@@ -72,6 +77,8 @@
typedef signed short int16_t;
typedef unsigned int uint32_t;
typedef signed int int32_t;
+ typedef unsigned long long uint64_t;
+ typedef signed long long int64_t;
// BUG: how do I do a rename such that "SWIGTYPE_p_std__istream" can
@@ -147,4 +154,63 @@
+class LiblasReader
+public:
+ LiblasReader(std::istream&);
+ const libpc::LiblasHeader& getLiblasHeader() const;
+ boost::int8_t getPointFormatNumber() const;
+class Stage
+public:
+ Stage();
+ virtual const std::string& getName() const = 0;
+ boost::uint32_t read(PointData&);
+ virtual void readBegin(boost::uint32_t numPointsToRead) = 0;
+ virtual boost::uint32_t readBuffer(PointData&) = 0;
+ virtual void readEnd(boost::uint32_t numPointsRead) = 0;
+ virtual void seekToPoint(boost::uint64_t pointNum) = 0;
+ virtual boost::uint64_t getCurrentPointIndex() const = 0;
+ boost::uint64_t getNumPoints() const;
+ bool atEnd() const;
+ const Header& getHeader() const;
+class Reader : public Stage
+public:
+ Reader();
+ virtual void readBegin(boost::uint32_t numPointsToRead);
+ virtual void readEnd(boost::uint32_t numPointsRead);
+ virtual void seekToPoint(boost::uint64_t pointNum);
+ virtual boost::uint64_t getCurrentPointIndex() const;
+class LiblasHeader : public Reader
+public:
+ LiblasHeader();
+class Utils
+public:
+ static std::istream* openFile(std::string const& filename, bool asBinary=true);
+ static void closeFile(std::istream* ifs);
}; // namespace
diff -r 9ccbaa4f4705 -r b90ead329da0 csharp/libpc_swig_cs/libpc_swig_cs.csproj
--- a/csharp/libpc_swig_cs/libpc_swig_cs.csproj Thu Mar 03 16:46:50 2011 -0800
+++ b/csharp/libpc_swig_cs/libpc_swig_cs.csproj Thu Mar 03 17:39:35 2011 -0800
@@ -88,9 +88,17 @@
</ItemGroup>
<ItemGroup>
<Compile Include="Dimension.cs" />
+ <Compile Include="LiblasHeader.cs" />
+ <Compile Include="LiblasReader.cs" />
<Compile Include="libpc_swig_cpp.cs" />
<Compile Include="libpc_swig_cppPINVOKE.cs" />
<Compile Include="Properties\AssemblyInfo.cs" />
+ <Compile Include="Reader.cs" />
+ <Compile Include="Stage.cs" />
+ <Compile Include="SWIGTYPE_p_Header.cs" />
+ <Compile Include="SWIGTYPE_p_PointData.cs" />
+ <Compile Include="SWIGTYPE_p_std__istream.cs" />
+ <Compile Include="Utils.cs" />
<Compile Include="VectorU32.cs" />
<Compile Include="VectorU8.cs" />
</ItemGroup>
diff -r 9ccbaa4f4705 -r b90ead329da0 csharp/libpc_swig_test/Program.cs
--- a/csharp/libpc_swig_test/Program.cs Thu Mar 03 16:46:50 2011 -0800
+++ b/csharp/libpc_swig_test/Program.cs Thu Mar 03 17:39:35 2011 -0800
@@ -48,6 +48,8 @@
static int Main(string[] args)
TestDimension a = new TestDimension();
+ TestLiblasReader r = new TestLiblasReader();
return 0;
diff -r 9ccbaa4f4705 -r b90ead329da0 csharp/libpc_swig_test/TestLiblasReader.cs
--- /dev/null Thu Jan 01 00:00:00 1970 +0000
+++ b/csharp/libpc_swig_test/TestLiblasReader.cs Thu Mar 03 17:39:35 2011 -0800
@@ -0,0 +1,26 @@
+using System;
+using System.Collections.Generic;
+using System.Linq;
+using System.Text;
+using Libpc;
+using System.Diagnostics;
+namespace libpc_swig_test
+ internal class TestLiblasReader : TestBase
+ public TestLiblasReader()
+ Test1();
+ private void Test1()
+ SWIGTYPE_p_std__istream str = Utils.openFile("../../test/data/simple.las");
+ LiblasReader r = new LiblasReader(str);
+ return;
diff -r 9ccbaa4f4705 -r b90ead329da0 csharp/libpc_swig_test/libpc_swig_test.csproj
--- a/csharp/libpc_swig_test/libpc_swig_test.csproj Thu Mar 03 16:46:50 2011 -0800
+++ b/csharp/libpc_swig_test/libpc_swig_test.csproj Thu Mar 03 17:39:35 2011 -0800
@@ -78,6 +78,7 @@
<Compile Include="Program.cs" />
<Compile Include="TestDimension.cs" />
+ <Compile Include="TestLiblasReader.cs" />
</ItemGroup>
<ItemGroup>
<ProjectReference Include="..\libpc_swig_cs\libpc_swig_cs.csproj">
diff -r 9ccbaa4f4705 -r b90ead329da0 src/drivers/liblas/reader.cpp
--- a/src/drivers/liblas/reader.cpp Thu Mar 03 16:46:50 2011 -0800
+++ b/src/drivers/liblas/reader.cpp Thu Mar 03 17:39:35 2011 -0800
@@ -56,7 +56,7 @@
, m_offsetY(0.0)
, m_offsetZ(0.0)
, m_isCompressed(false)
- , m_pointFormat(liblas::ePointFormatUnknown)
+ , m_pointFormatNumber(-1)
, m_hasTimeData(false)
, m_hasColorData(false)
, m_hasWaveData(false)
@@ -92,7 +92,7 @@
boost::int8_t LiblasReader::getPointFormatNumber() const
- return (boost::uint8_t)m_pointFormat;
+ return m_pointFormatNumber;
void LiblasReader::processExternalHeader()
@@ -118,33 +118,33 @@
m_isCompressed = externalHeader.Compressed();
- m_pointFormat = externalHeader.GetDataFormatId();
+ m_pointFormatNumber = (boost::int8_t)externalHeader.GetDataFormatId();
m_hasTimeData = m_hasColorData = m_hasWaveData = false;
- switch (m_pointFormat)
+ switch (m_pointFormatNumber)
- case liblas::ePointFormat0:
+ case 0:
break;
- case liblas::ePointFormat1:
+ case 1:
m_hasTimeData = true;
break;
- case liblas::ePointFormat2:
+ case 2:
m_hasColorData = true;
break;
- case liblas::ePointFormat3:
+ case 3:
break;
- case liblas::ePointFormat4:
+ case 4:
m_hasWaveData = true;
break;
- case liblas::ePointFormat5:
+ case 5:
break;
- case liblas::ePointFormatUnknown:
+ default:
throw not_yet_implemented("Unknown point format encountered");
diff -r 9ccbaa4f4705 -r b90ead329da0 src/drivers/liblas/reader.hpp
--- a/src/drivers/liblas/reader.hpp Thu Mar 03 16:46:50 2011 -0800
+++ b/src/drivers/liblas/reader.hpp Thu Mar 03 17:39:35 2011 -0800
@@ -41,13 +41,10 @@
#include "header.hpp"
-#include <liblas/version.hpp>
// fwd decls
namespace liblas
class Reader;
- // enum PointFormatName;
@@ -93,7 +90,7 @@
double m_offsetZ;
bool m_isCompressed;
- liblas::PointFormatName m_pointFormat;
+ boost::int8_t m_pointFormatNumber; // should be an enum
bool m_hasTimeData;
bool m_hasColorData;
bool m_hasWaveData;
More information about the Liblas-commits
