[Liblas-commits] libpc: get chipper working. bolt on some testing
liblas-commits at liblas.org liblas-commits at liblas.org
Fri Mar 4 13:27:35 EST 2011
details:   http://hg.liblas.orglibpc/rev/bc4b2a24fe12
changeset: 171:bc4b2a24fe12
user:      Howard Butler <hobu.inc at gmail.com>
date:      Fri Mar 04 12:27:30 2011 -0600
description:
diffstat:
 src/chipper.cpp           |  37 +++++++++++++----
 test/unit/CMakeLists.txt  |   1 +
 test/unit/ChipperTest.cpp |  96 +++++++++++++++++++++++++++++++++++++++++++++++
 3 files changed, 124 insertions(+), 10 deletions(-)
diffs (179 lines):
diff -r b90ead329da0 -r bc4b2a24fe12 src/chipper.cpp
--- a/src/chipper.cpp	Thu Mar 03 17:39:35 2011 -0800
+++ b/src/chipper.cpp	Fri Mar 04 12:27:30 2011 -0600
@@ -109,8 +109,8 @@
     yvec.reserve(count);
     spare.resize(count);
-    boost::uint32_t chunks = count/m_threshold;
-    count = 0;
+    // boost::uint32_t chunks = count/m_threshold;
     const int indexX = schema.getDimensionIndex(Dimension::Field_X);
@@ -124,12 +124,22 @@
     double xoffset = dimX.getNumericOffset();
     double yoffset = dimY.getNumericOffset();
+    std::size_t num_points_loaded = 0;
+    std::size_t num_points_to_load = count;
-    for (boost::uint32_t i = 0; i < chunks; i++)
+    boost::uint32_t counter = 0;
+    while (num_points_loaded < num_points_to_load)
-        PointData buffer(schema, m_threshold);
-        m_stage.read(buffer);
+        boost::uint64_t num_remaining = num_points_to_load - num_points_loaded;
+        boost::uint32_t num_to_read = static_cast<boost::uint32_t>(std::min<boost::uint64_t>(num_remaining, m_threshold));
+        PointData buffer(schema, num_to_read);
+        boost::uint32_t num_read =  m_stage.read(buffer);
+        assert(num_read <= num_to_read);
         for (boost::uint32_t j = 0; j < m_threshold; j++)
             // (v * m_header->GetScaleX()) + m_header->GetOffsetX();
@@ -137,15 +147,22 @@
             const double y = (buffer.getField<boost::int32_t>(j, indexY) * yscale) + yoffset;
             // const double z = (buffer.getField<boost::int32_t>(j, indexZ) * zscale) + zoffset;
             ref.m_pos = x;
-            ref.m_ptindex = j;
+            ref.m_ptindex = counter;
             xvec.push_back(ref);
             ref.m_pos = y;
             yvec.push_back(ref);
+            counter++;
+        num_points_loaded += num_read;
+        if (m_stage.atEnd())
+            break;
     // while (m_reader->ReadNextPoint()) {
     //     const liblas::Point& pt = m_reader->GetPoint();
diff -r b90ead329da0 -r bc4b2a24fe12 test/unit/CMakeLists.txt
--- a/test/unit/CMakeLists.txt	Thu Mar 03 17:39:35 2011 -0800
+++ b/test/unit/CMakeLists.txt	Fri Mar 04 12:27:30 2011 -0600
@@ -9,6 +9,7 @@
 SET(LIBPC_UNIT_TEST_SRC
 	BoundsTest.cpp
+	ChipperTest.cpp
 	ColorTest.cpp
 	ConfigTest.cpp
 	CropFilterTest.cpp
diff -r b90ead329da0 -r bc4b2a24fe12 test/unit/ChipperTest.cpp
--- /dev/null	Thu Jan 01 00:00:00 1970 +0000
+++ b/test/unit/ChipperTest.cpp	Fri Mar 04 12:27:30 2011 -0600
@@ -0,0 +1,96 @@
+* Copyright (c) 2011, Michael P. Gerlek (mpg at flaxen.com)
+* All rights reserved.
+* Redistribution and use in source and binary forms, with or without
+* modification, are permitted provided that the following
+* conditions are met:
+*     * Redistributions of source code must retain the above copyright
+*       notice, this list of conditions and the following disclaimer.
+*     * Redistributions in binary form must reproduce the above copyright
+*       notice, this list of conditions and the following disclaimer in
+*       the documentation and/or other materials provided
+*       with the distribution.
+*     * Neither the name of Hobu, Inc. or Flaxen Geo Consulting nor the
+*       names of its contributors may be used to endorse or promote
+*       products derived from this software without specific prior
+*       written permission.
+* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
+* "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
+* LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS
+* FOR A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE
+* COPYRIGHT OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT,
+* INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING,
+* BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS
+* OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED
+* AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY,
+* OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT
+* OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY
+* OF SUCH DAMAGE.
+#include <boost/test/unit_test.hpp>
+#include <boost/cstdint.hpp>
+#include "libpc/chipper.hpp"
+#include "libpc/../../src/drivers/liblas/writer.hpp"
+#include "libpc/../../src/drivers/liblas/reader.hpp"
+#include "support.hpp"
+using namespace libpc;
+BOOST_AUTO_TEST_SUITE(ChipperTest)
+BOOST_AUTO_TEST_CASE(test_construction)
+    std::istream* ifs = Utils::openFile("../../test/data/1.2-with-color.las");
+    LiblasReader reader(*ifs);
+        const boost::uint64_t num_points = reader.getHeader().getNumPoints();
+        // need to scope the writer, so that's it dtor can use the stream
+        libpc::chipper::Chipper chipper(reader, 15);
+        chipper.Chip();
+        boost::uint32_t num_blocks = chipper.GetBlockCount();
+        BOOST_CHECK(num_points == 1065);
+        BOOST_CHECK(num_blocks==71);
+        libpc::Bounds<double> const& bounds = chipper.GetBlock(0).GetBounds();
+        std::vector< Range<double> > ranges = bounds.dimensions();
+        libpc::Range<double> x = ranges[0];
+        libpc::Range<double> y = ranges[1];
+        BOOST_CHECK(Utils::compare_approx(x.getMinimum(), (double)635674, (double) 1) == true);
+        BOOST_CHECK(Utils::compare_approx(x.getMaximum(), (double)635994, (double) 1) == true);
+        BOOST_CHECK(Utils::compare_approx(y.getMinimum(), (double)848992, (double) 1) == true);
+        BOOST_CHECK(Utils::compare_approx(y.getMaximum(), (double)849427, (double) 1) == true);
+        std::vector<boost::uint32_t> ids = chipper.GetBlock(70).GetIDs();
+        BOOST_CHECK(ids.size() == 15);
+        BOOST_CHECK(ids[14] == 1050 );
+    Utils::closeFile(ifs);
+    return;
+BOOST_AUTO_TEST_SUITE_END()
More information about the Liblas-commits mailing list
