[Liblas-commits] libpc: GpsTime --> Time
liblas-commits at liblas.org
Fri Mar 11 18:36:13 EST 2011
details: http://hg.liblas.orglibpc/rev/734f4bc84222
changeset: 219:734f4bc84222
user: Michael P. Gerlek <mpg at flaxen.com>
date: Fri Mar 11 15:36:08 2011 -0800
description:
GpsTime --> Time
diffstat:
include/libpc/Dimension.hpp | 2 +-
src/Dimension.cpp | 2 +-
src/FauxReader.cpp | 4 ++--
src/LasHeader.cpp | 2 +-
src/LasReader.cpp | 6 +++---
src/LasWriter.cpp | 6 +++---
src/drivers/liblas/reader.cpp | 8 ++++----
src/drivers/liblas/writer.cpp | 6 +++---
test/unit/CacheFilterTest.cpp | 2 +-
test/unit/DecimationFilterTest.cpp | 2 +-
test/unit/FauxReaderTest.cpp | 4 ++--
test/unit/MosaicFilterTest.cpp | 2 +-
12 files changed, 23 insertions(+), 23 deletions(-)
diffs (230 lines):
diff -r f338384ff966 -r 734f4bc84222 include/libpc/Dimension.hpp
--- a/include/libpc/Dimension.hpp Fri Mar 11 15:31:26 2011 -0800
+++ b/include/libpc/Dimension.hpp Fri Mar 11 15:36:08 2011 -0800
@@ -79,7 +79,7 @@
Field_ScanAngleRank,
Field_UserData,
Field_PointSourceId,
- Field_GpsTime,
+ Field_Time,
Field_Red,
Field_Green,
Field_Blue,
diff -r f338384ff966 -r 734f4bc84222 src/Dimension.cpp
--- a/src/Dimension.cpp Fri Mar 11 15:31:26 2011 -0800
+++ b/src/Dimension.cpp Fri Mar 11 15:36:08 2011 -0800
@@ -361,7 +361,7 @@
s_fieldNames[Field_ScanAngleRank] = "ScanAngleRank";
s_fieldNames[Field_UserData] = "UserData";
s_fieldNames[Field_PointSourceId] = "PointSourceId";
- s_fieldNames[Field_GpsTime] = "GpsTime";
+ s_fieldNames[Field_Time] = "Time";
s_fieldNames[Field_Red] = "Red";
s_fieldNames[Field_Green] = "Green";
s_fieldNames[Field_Blue] = "Blue";
diff -r f338384ff966 -r 734f4bc84222 src/FauxReader.cpp
--- a/src/FauxReader.cpp Fri Mar 11 15:31:26 2011 -0800
+++ b/src/FauxReader.cpp Fri Mar 11 15:36:08 2011 -0800
@@ -56,7 +56,7 @@
schema.addDimension(Dimension(Dimension::Field_X, Dimension::Float));
schema.addDimension(Dimension(Dimension::Field_Y, Dimension::Float));
schema.addDimension(Dimension(Dimension::Field_Z, Dimension::Float));
- schema.addDimension(Dimension(Dimension::Field_GpsTime, Dimension::Uint64));
+ schema.addDimension(Dimension(Dimension::Field_Time, Dimension::Uint64));
header->setNumPoints(numPoints);
header->setBounds(bounds);
@@ -118,7 +118,7 @@
const double minZ = dims[2].getMinimum();
const double maxZ = dims[2].getMaximum();
- const int offsetT = schema.getDimensionIndex(Dimension::Field_GpsTime);
+ const int offsetT = schema.getDimensionIndex(Dimension::Field_Time);
const int offsetX = schema.getDimensionIndex(Dimension::Field_X);
const int offsetY = schema.getDimensionIndex(Dimension::Field_Y);
const int offsetZ = schema.getDimensionIndex(Dimension::Field_Z);
diff -r f338384ff966 -r 734f4bc84222 src/LasHeader.cpp
--- a/src/LasHeader.cpp Fri Mar 11 15:31:26 2011 -0800
+++ b/src/LasHeader.cpp Fri Mar 11 15:36:08 2011 -0800
@@ -866,7 +866,7 @@
std::ostringstream text;
- Dimension t(Dimension::Field_GpsTime, Dimension::Uint64);
+ Dimension t(Dimension::Field_Time, Dimension::Uint64);
text << "The GPS Time is the double floating point time tag value at "
"which the point was acquired. It is GPS Week Time if the "
"Global Encoding low bit is clear and Adjusted Standard GPS "
diff -r f338384ff966 -r 734f4bc84222 src/LasReader.cpp
--- a/src/LasReader.cpp Fri Mar 11 15:31:26 2011 -0800
+++ b/src/LasReader.cpp Fri Mar 11 15:36:08 2011 -0800
@@ -141,7 +141,7 @@
const int fieldIndexUserData = schema.getDimensionIndex(Dimension::Field_UserData);
const int fieldIndexPointSource = schema.getDimensionIndex(Dimension::Field_PointSourceId);
- const int fieldIndexTime = (hasTimeData ? schema.getDimensionIndex(Dimension::Field_GpsTime) : 0);
+ const int fieldIndexTime = (hasTimeData ? schema.getDimensionIndex(Dimension::Field_Time) : 0);
const int fieldIndexRed = (hasColorData ? schema.getDimensionIndex(Dimension::Field_Red) : 0);
const int fieldIndexGreen = (hasColorData ? schema.getDimensionIndex(Dimension::Field_Green) : 0);
@@ -212,7 +212,7 @@
const boost::int8_t scanAngleRank = Utils::read_field<boost::int8_t>(p);
const boost::uint8_t user = Utils::read_field<boost::uint8_t>(p);
const boost::uint16_t pointSourceId = Utils::read_field<boost::uint16_t>(p);
- const double gpsTime = Utils::read_field<double>(p);
+ const double time = Utils::read_field<double>(p);
const boost::uint16_t red = Utils::read_field<boost::uint16_t>(p);
const boost::uint16_t green = Utils::read_field<boost::uint16_t>(p);
const boost::uint16_t blue = Utils::read_field<boost::uint16_t>(p);
@@ -234,7 +234,7 @@
pointData.setField<boost::int8_t>(pointIndex, fieldIndexScanAngle, scanAngleRank);
pointData.setField<boost::uint8_t>(pointIndex, fieldIndexUserData, user);
pointData.setField<boost::uint16_t>(pointIndex, fieldIndexPointSource, pointSourceId);
- pointData.setField<double>(pointIndex, fieldIndexTime, gpsTime);
+ pointData.setField<double>(pointIndex, fieldIndexTime, time);
pointData.setField<boost::uint16_t>(pointIndex, fieldIndexRed, red);
pointData.setField<boost::uint16_t>(pointIndex, fieldIndexGreen, green);
pointData.setField<boost::uint16_t>(pointIndex, fieldIndexBlue, blue);
diff -r f338384ff966 -r 734f4bc84222 src/LasWriter.cpp
--- a/src/LasWriter.cpp Fri Mar 11 15:31:26 2011 -0800
+++ b/src/LasWriter.cpp Fri Mar 11 15:36:08 2011 -0800
@@ -139,7 +139,7 @@
@@ -216,7 +216,7 @@
const boost::int8_t scanAngleRank = pointData.getField<boost::int8_t>(pointIndex, fieldIndexScanAngle);
const boost::uint8_t user = pointData.getField<boost::uint8_t>(pointIndex, fieldIndexUserData);
const boost::uint16_t pointSourceId = pointData.getField<boost::uint16_t>(pointIndex, fieldIndexPointSource);
- const double gpsTime = pointData.getField<double>(pointIndex, fieldIndexTime);
+ const double time = pointData.getField<double>(pointIndex, fieldIndexTime);
const boost::uint16_t red = pointData.getField<boost::uint16_t>(pointIndex, fieldIndexRed);
const boost::uint16_t green = pointData.getField<boost::uint16_t>(pointIndex, fieldIndexGreen);
const boost::uint16_t blue = pointData.getField<boost::uint16_t>(pointIndex, fieldIndexBlue);
@@ -230,7 +230,7 @@
Utils::write_field<boost::int8_t>(p, scanAngleRank);
Utils::write_field<boost::uint8_t>(p, user);
Utils::write_field<boost::uint16_t>(p, pointSourceId);
- Utils::write_field<double>(p, gpsTime);
+ Utils::write_field<double>(p, time);
Utils::write_field<boost::uint16_t>(p, red);
Utils::write_field<boost::uint16_t>(p, green);
Utils::write_field<boost::uint16_t>(p, blue);
diff -r f338384ff966 -r 734f4bc84222 src/drivers/liblas/reader.cpp
--- a/src/drivers/liblas/reader.cpp Fri Mar 11 15:31:26 2011 -0800
+++ b/src/drivers/liblas/reader.cpp Fri Mar 11 15:36:08 2011 -0800
@@ -188,7 +188,7 @@
if (m_hasTimeData)
- schema.addDimension(Dimension(Dimension::Field_GpsTime, Dimension::Double));
+ schema.addDimension(Dimension(Dimension::Field_Time, Dimension::Double));
if (m_hasColorData)
@@ -254,7 +254,7 @@
const int indexUserData = schema.getDimensionIndex(Dimension::Field_UserData);
const int indexPointSourceId = schema.getDimensionIndex(Dimension::Field_PointSourceId);
- const int indexGpsTime = (m_hasTimeData ? schema.getDimensionIndex(Dimension::Field_GpsTime) : 0);
+ const int indexTime = (m_hasTimeData ? schema.getDimensionIndex(Dimension::Field_Time) : 0);
const int indexRed = (m_hasColorData ? schema.getDimensionIndex(Dimension::Field_Red) : 0);
const int indexGreen = (m_hasColorData ? schema.getDimensionIndex(Dimension::Field_Green) : 0);
@@ -307,9 +307,9 @@
if (m_hasTimeData)
- const double gpsTime = pt.GetTime();
+ const double time = pt.GetTime();
- pointData.setField(i, indexGpsTime, gpsTime);
+ pointData.setField(i, indexTime, time);
if (m_hasColorData)
diff -r f338384ff966 -r 734f4bc84222 src/drivers/liblas/writer.cpp
--- a/src/drivers/liblas/writer.cpp Fri Mar 11 15:31:26 2011 -0800
+++ b/src/drivers/liblas/writer.cpp Fri Mar 11 15:36:08 2011 -0800
@@ -216,7 +216,7 @@
- const int indexGpsTime = (hasTimeData ? schema.getDimensionIndex(Dimension::Field_GpsTime) : 0);
+ const int indexTime = (hasTimeData ? schema.getDimensionIndex(Dimension::Field_Time) : 0);
const int indexRed = (hasColorData ? schema.getDimensionIndex(Dimension::Field_Red) : 0);
const int indexGreen = (hasColorData ? schema.getDimensionIndex(Dimension::Field_Green) : 0);
@@ -262,8 +262,8 @@
if (hasTimeData)
- const double gpsTime = pointData.getField<double>(i, indexGpsTime);
- pt.SetTime(gpsTime);
+ const double time = pointData.getField<double>(i, indexTime);
+ pt.SetTime(time);
if (hasColorData)
diff -r f338384ff966 -r 734f4bc84222 test/unit/CacheFilterTest.cpp
--- a/test/unit/CacheFilterTest.cpp Fri Mar 11 15:31:26 2011 -0800
+++ b/test/unit/CacheFilterTest.cpp Fri Mar 11 15:36:08 2011 -0800
@@ -52,7 +52,7 @@
const Schema& schema = reader.getHeader().getSchema();
SchemaLayout layout(schema);
PointData dataBig(layout, 1024);
PointData dataSmall(layout, 1);
diff -r f338384ff966 -r 734f4bc84222 test/unit/DecimationFilterTest.cpp
--- a/test/unit/DecimationFilterTest.cpp Fri Mar 11 15:31:26 2011 -0800
+++ b/test/unit/DecimationFilterTest.cpp Fri Mar 11 15:36:08 2011 -0800
@@ -61,7 +61,7 @@
BOOST_CHECK(numRead == 3);
- int offsetT = schema.getDimensionIndex(Dimension::Field_GpsTime);
+ int offsetT = schema.getDimensionIndex(Dimension::Field_Time);
boost::uint64_t t0 = data.getField<boost::uint64_t>(0, offsetT);
boost::uint64_t t1 = data.getField<boost::uint64_t>(1, offsetT);
diff -r f338384ff966 -r 734f4bc84222 test/unit/FauxReaderTest.cpp
--- a/test/unit/FauxReaderTest.cpp Fri Mar 11 15:31:26 2011 -0800
+++ b/test/unit/FauxReaderTest.cpp Fri Mar 11 15:36:08 2011 -0800
@@ -59,7 +59,7 @@
for (boost::uint32_t i=0; i<numRead; i++)
@@ -95,7 +95,7 @@
diff -r f338384ff966 -r 734f4bc84222 test/unit/MosaicFilterTest.cpp
--- a/test/unit/MosaicFilterTest.cpp Fri Mar 11 15:31:26 2011 -0800
+++ b/test/unit/MosaicFilterTest.cpp Fri Mar 11 15:36:08 2011 -0800
@@ -69,7 +69,7 @@
BOOST_CHECK(numRead == 300);
More information about the Liblas-commits
