[Liblas-commits] libpc: get rid of readBegin/End; each concrete stage must manage...
liblas-commits at liblas.org liblas-commits at liblas.org
Fri Mar 11 19:24:06 EST 2011
details:   http://hg.liblas.orglibpc/rev/f57baec8e09d
changeset: 220:f57baec8e09d
user:      Michael P. Gerlek <mpg at flaxen.com>
date:      Fri Mar 11 16:23:59 2011 -0800
description:
get rid of readBegin/End; each concrete stage must manage currentPointIndex on its own now
diffstat:
 include/libpc/CacheFilter.hpp |   6 ------
 include/libpc/FauxReader.hpp  |   2 +-
 include/libpc/Filter.hpp      |  10 +---------
 include/libpc/LasReader.hpp   |   2 +-
 include/libpc/Producer.hpp    |  13 +------------
 include/libpc/Stage.hpp       |  36 +++++++++++++++---------------------
 src/CacheFilter.cpp           |  33 ++++++++++++---------------------
 src/CropFilter.cpp            |   6 +++---
 src/FauxReader.cpp            |   2 ++
 src/Filter.cpp                |  20 --------------------
 src/Producer.cpp              |  27 ---------------------------
 src/Stage.cpp                 |  27 +++++++++++++++++++--------
 src/drivers/liblas/reader.hpp |   4 +---
 13 files changed, 56 insertions(+), 132 deletions(-)
diffs (truncated from 436 to 300 lines):
diff -r 734f4bc84222 -r f57baec8e09d include/libpc/CacheFilter.hpp
--- a/include/libpc/CacheFilter.hpp	Fri Mar 11 15:36:08 2011 -0800
+++ b/include/libpc/CacheFilter.hpp	Fri Mar 11 16:23:59 2011 -0800
@@ -56,9 +56,6 @@
     const std::string& getName() const;
     // override
-    boost::uint64_t getCurrentPointIndex() const;
-    // override
     void seekToPoint(boost::uint64_t index);
     // clear cache (but leave cache params unchanged)
@@ -81,9 +78,6 @@
 private:
     boost::uint32_t readBuffer(PointData&);
-    boost::uint64_t m_currentPointIndex;
-    boost::uint64_t m_storedPointIndex;
-    PointData* m_storedPointData;
     boost::uint64_t m_numPointsRequested;
     boost::uint64_t m_numPointsRead;
diff -r 734f4bc84222 -r f57baec8e09d include/libpc/FauxReader.hpp
--- a/include/libpc/FauxReader.hpp	Fri Mar 11 15:36:08 2011 -0800
+++ b/include/libpc/FauxReader.hpp	Fri Mar 11 16:23:59 2011 -0800
@@ -71,7 +71,7 @@
     void seekToPoint(boost::uint64_t);
 private:
-    boost::uint32_t readBuffer(PointData& data);
+    boost::uint32_t readBuffer(PointData&);
     Mode m_mode;
diff -r 734f4bc84222 -r f57baec8e09d include/libpc/Filter.hpp
--- a/include/libpc/Filter.hpp	Fri Mar 11 15:36:08 2011 -0800
+++ b/include/libpc/Filter.hpp	Fri Mar 11 16:23:59 2011 -0800
@@ -47,19 +47,11 @@
 public:
     Filter(Stage& prevStage);
-    // default behaviour for filters is just to call readBegin() on the previous stage
-    virtual void readBegin(boost::uint32_t numPointsToRead);
-    // default behaviour for filters is just to call readEnd() on the previous stage
-    virtual void readEnd(boost::uint32_t numPointsRead);
+protected:
     // advance (or retreat) to the Nth point in the file (absolute,
     // default behaviour for filters is just to call seek on the previous stage
     virtual void seekToPoint(boost::uint64_t pointNum);
-    // default behaviour for filters is just to call the previous stage
-    virtual boost::uint64_t getCurrentPointIndex() const;
 protected:
     Stage& m_prevStage;
diff -r 734f4bc84222 -r f57baec8e09d include/libpc/LasReader.hpp
--- a/include/libpc/LasReader.hpp	Fri Mar 11 15:36:08 2011 -0800
+++ b/include/libpc/LasReader.hpp	Fri Mar 11 16:23:59 2011 -0800
@@ -57,7 +57,7 @@
     const LasHeader& getLasHeader() const;
 protected:
-    virtual boost::uint32_t readBuffer(PointData&);
     LasHeader& getLasHeader();
     void setLasHeader(const LasHeader&);
diff -r 734f4bc84222 -r f57baec8e09d include/libpc/Producer.hpp
--- a/include/libpc/Producer.hpp	Fri Mar 11 15:36:08 2011 -0800
+++ b/include/libpc/Producer.hpp	Fri Mar 11 16:23:59 2011 -0800
@@ -46,22 +46,11 @@
 public:
     Producer();
-    // default is to reset() and then read N points manually
+    // default is to read N points manually
     // override this if you can
-protected:
-    void setCurrentPointIndex(boost::uint64_t);
 private:
     Producer& operator=(const Producer&); // not implemented
     Producer(const Producer&); // not implemented
diff -r 734f4bc84222 -r f57baec8e09d include/libpc/Stage.hpp
--- a/include/libpc/Stage.hpp	Fri Mar 11 15:36:08 2011 -0800
+++ b/include/libpc/Stage.hpp	Fri Mar 11 16:23:59 2011 -0800
@@ -65,30 +65,11 @@
     // we need to write into.
     // This is NOT virtual.  Derived classes should override the
-    // readBegin/readBuffer/readEnd functions below, not this one.
+    // readBuffer function below, not this one.
     // Returns the number of valid points read.
     boost::uint32_t read(PointData&);
-    // Implement this to do any setup work you need to do before the
-    // sequence of calls the readBuffer starts up.
-    // Do not call this yourself -- use the read() call above.
-    virtual void readBegin(boost::uint32_t numPointsToRead) = 0;
-    // Implement this to do the actual work to fill in a buffer of points.
-    // This is called after readBegin() is called.  It may be called
-    // multiple times for one read() call.
-    virtual boost::uint32_t readBuffer(PointData&) = 0;
-    // This is called once, after the readBuffer() calls are done.
-    virtual void readEnd(boost::uint32_t numPointsRead) = 0;
     // not relative).  In some cases, this might be a very slow, painful
     // function to call.
@@ -97,7 +78,7 @@
     // Returns the current point number.  The first point is 0.
     // If this number if > getNumPoints(), then no more points
     // may be read (and atEnd() should be true).
-    virtual boost::uint64_t getCurrentPointIndex() const = 0;
+    boost::uint64_t getCurrentPointIndex() const;
     // returns the number of points this stage has available
     // (actually a convenience function that gets it from the header)
@@ -111,10 +92,23 @@
     Header& getHeader();
 protected:
+    // Implement this to do the actual work to fill in a buffer of points.
+    virtual boost::uint32_t readBuffer(PointData&) = 0;
+    // Each concrete stage is repsonsible for managing its own current
+    // point index when a read or seek occurs.  Call this function to set
+    // the value.
+    void setCurrentPointIndex(boost::uint64_t delta);
+    // this is easier than saying setCurrentPointIndex(getCurrentPointIndex()+n)
+    void incrementCurrentPointIndex(boost::uint64_t currentPointDelta);
     void setHeader(Header*); // stage takes ownership
 private:
     Header* m_header;
+    boost::uint64_t m_currentPointIndex;
     Stage& operator=(const Stage&); // not implemented
     Stage(const Stage&); // not implemented
diff -r 734f4bc84222 -r f57baec8e09d src/CacheFilter.cpp
--- a/src/CacheFilter.cpp	Fri Mar 11 15:36:08 2011 -0800
+++ b/src/CacheFilter.cpp	Fri Mar 11 16:23:59 2011 -0800
@@ -43,9 +43,6 @@
 // cache block size is measured in Points, not bytes
 CacheFilter::CacheFilter(Stage& prevStage, boost::uint32_t maxCacheBlocks, boost::uint32_t cacheBlockSize)
     : Filter(prevStage)
-    , m_currentPointIndex(0)
-    , m_storedPointIndex(0)
-    , m_storedPointData(NULL)
     , m_numPointsRequested(0)
     , m_numPointsRead(0)
     , m_cache(NULL)
@@ -59,8 +56,6 @@
 CacheFilter::~CacheFilter()
-    delete m_storedPointData;
     delete m_cache;
@@ -99,15 +94,9 @@
-boost::uint64_t CacheFilter::getCurrentPointIndex() const
-    return m_currentPointIndex;
 void CacheFilter::seekToPoint(boost::uint64_t index)
-    m_currentPointIndex = index;
+    setCurrentPointIndex(index);
     m_prevStage.seekToPoint(index);
@@ -126,6 +115,8 @@
 boost::uint32_t CacheFilter::readBuffer(PointData& data)
+    const boost::uint64_t currentPointIndex = getCurrentPointIndex();
     // for now, we only read from the cache if they are asking for one point
     // (this avoids the problem of an N-point request needing more than one
     // cached block to satisfy it)
@@ -137,15 +128,15 @@
         // and the block we got is properly aligned and not already cached,
         // then let's cache it!
         if (data.getNumPoints() == m_cacheBlockSize && numRead == m_cacheBlockSize &&
-            (m_currentPointIndex % m_cacheBlockSize == 0) &&
-            m_cache->lookup(m_currentPointIndex) == NULL)
+            (currentPointIndex % m_cacheBlockSize == 0) &&
+            m_cache->lookup(currentPointIndex) == NULL)
             PointData* block = new PointData(data.getSchemaLayout(), m_cacheBlockSize);
             block->copyPointsFast(0, 0, data, m_cacheBlockSize);
-            m_cache->insert(m_currentPointIndex, block);
+            m_cache->insert(currentPointIndex, block);
-        m_currentPointIndex += numRead;
+        incrementCurrentPointIndex(numRead);
         m_numPointsRead += data.getNumPoints();
         m_numPointsRequested += data.getNumPoints();
@@ -154,18 +145,18 @@
     // they asked for just one point -- first, check Mister Cache
-    boost::uint64_t blockNum = m_currentPointIndex / m_cacheBlockSize;
+    const boost::uint64_t blockNum = currentPointIndex / m_cacheBlockSize;
     PointData* block = m_cache->lookup(blockNum);
     if (block != NULL)
         // A hit! A palpable hit!
-        data.copyPointFast(0,  m_currentPointIndex % m_cacheBlockSize, *block);
+        data.copyPointFast(0,  currentPointIndex % m_cacheBlockSize, *block);
         m_numPointsRead += 0;
         m_numPointsRequested += 1;
-        m_currentPointIndex += 1;
+        incrementCurrentPointIndex(1);
-        m_prevStage.seekToPoint(m_currentPointIndex);
+        m_prevStage.seekToPoint(getCurrentPointIndex());
         return 1;
@@ -173,7 +164,7 @@
     const boost::uint32_t numRead = m_prevStage.read(data);
     m_numPointsRead += numRead;
     m_numPointsRequested += numRead;
     return numRead;
diff -r 734f4bc84222 -r f57baec8e09d src/CropFilter.cpp
--- a/src/CropFilter.cpp	Fri Mar 11 15:36:08 2011 -0800
+++ b/src/CropFilter.cpp	Fri Mar 11 16:23:59 2011 -0800
@@ -58,9 +58,7 @@
 boost::uint32_t CropFilter::readBuffer(PointData& data)
-    m_prevStage.read(data);
-    boost::uint32_t numPoints = data.getNumPoints();
+    boost::uint32_t numPoints = m_prevStage.read(data);
     const SchemaLayout& schemaLayout = data.getSchemaLayout();
     const Schema& schema = schemaLayout.getSchema();
@@ -92,6 +90,8 @@
+    incrementCurrentPointIndex(numPoints);
     return numValidPoints;
diff -r 734f4bc84222 -r f57baec8e09d src/FauxReader.cpp
--- a/src/FauxReader.cpp	Fri Mar 11 15:36:08 2011 -0800
+++ b/src/FauxReader.cpp	Fri Mar 11 16:23:59 2011 -0800
@@ -153,6 +153,8 @@
         ++time;
     return numPoints;
More information about the Liblas-commits mailing list
