[Liblas-commits] libpc: tweak libLAS library detection to account
for lib naming ...
liblas-commits at liblas.org
Mon Mar 14 15:09:03 EDT 2011
details: http://hg.liblas.orglibpc/rev/96728b382993
changeset: 224:96728b382993
user: Howard Butler <hobu.inc at gmail.com>
date: Mon Mar 14 11:49:36 2011 -0500
description:
tweak libLAS library detection to account for lib naming on win32
Subject: libpc: put common libpc::driver.oci stuff into a single file
details: http://hg.liblas.orglibpc/rev/cb823c59552b
changeset: 225:cb823c59552b
date: Mon Mar 14 12:07:20 2011 -0500
description:
Subject: libpc: move more stuff into common.hpp
details: http://hg.liblas.orglibpc/rev/7286d652d315
changeset: 226:7286d652d315
date: Mon Mar 14 12:19:31 2011 -0500
description:
Subject: libpc: move gdal debug stuff into common.cpp
details: http://hg.liblas.orglibpc/rev/73220672f6ab
changeset: 227:73220672f6ab
date: Mon Mar 14 12:19:45 2011 -0500
description:
Subject: libpc: move more stuff into common spot
details: http://hg.liblas.orglibpc/rev/59f74b23f9c0
changeset: 228:59f74b23f9c0
date: Mon Mar 14 12:20:09 2011 -0500
description:
Subject: libpc: start on libpc::driver::oci::Reader scaffolding
details: http://hg.liblas.orglibpc/rev/8b81f9a870c6
changeset: 229:8b81f9a870c6
date: Mon Mar 14 12:20:27 2011 -0500
description:
Subject: libpc: giant messy merge
details: http://hg.liblas.orglibpc/rev/c4371adc6197
changeset: 230:c4371adc6197
date: Mon Mar 14 14:08:54 2011 -0500
description:
giant messy merge
diffstat:
apps/pc2pc.cpp | 19 +-
cmake/modules/FindLibLAS.cmake | 6 +-
include/libpc/CacheFilter.hpp | 29 +-
include/libpc/Dimension.hpp | 2 +-
include/libpc/FauxReader.hpp | 2 +-
include/libpc/Filter.hpp | 10 +-
include/libpc/LasReader.hpp | 2 +-
include/libpc/LruCache.hpp | 162 -------------
include/libpc/PointDataCache.hpp | 199 +++++++++++++++++
include/libpc/Producer.hpp | 13 +-
include/libpc/Stage.hpp | 36 +-
include/libpc/chipper.hpp | 3 +
src/CMakeLists.txt | 3 +-
src/CacheFilter.cpp | 119 ++++++---
src/CropFilter.cpp | 6 +-
src/Dimension.cpp | 2 +-
src/FauxReader.cpp | 6 +-
src/Filter.cpp | 20 -
src/LasHeader.cpp | 2 +-
src/LasReader.cpp | 6 +-
src/LasWriter.cpp | 6 +-
src/PointDataCache.cpp | 16 +
src/Producer.cpp | 27 --
src/Stage.cpp | 27 +-
src/drivers/liblas/reader.cpp | 14 +-
src/drivers/liblas/reader.hpp | 4 +-
src/drivers/liblas/writer.cpp | 6 +-
src/drivers/oci/CMakeLists.txt | 3 +-
src/drivers/oci/block.cpp | 53 ----
src/drivers/oci/block.hpp | 65 -----
src/drivers/oci/common.cpp | 150 ++++++++++++
src/drivers/oci/common.hpp | 92 +++++++
src/drivers/oci/reader.cpp | 76 ++++++
src/drivers/oci/reader.hpp | 74 ++++++
src/drivers/oci/writer.cpp | 432 ++++++++++++++++++++++++++++--------
src/drivers/oci/writer.hpp | 55 +---
test/unit/CMakeLists.txt | 2 +-
test/unit/CacheFilterTest.cpp | 53 +--
test/unit/DecimationFilterTest.cpp | 2 +-
test/unit/FauxReaderTest.cpp | 4 +-
test/unit/LruCacheTest.cpp | 116 ---------
test/unit/MosaicFilterTest.cpp | 2 +-
test/unit/PointDataCacheTest.cpp | 92 +++++++
43 files changed, 1266 insertions(+), 752 deletions(-)
diffs (truncated from 2730 to 300 lines):
diff -r 221d3a3d6a54 -r c4371adc6197 apps/pc2pc.cpp
--- a/apps/pc2pc.cpp Thu Mar 10 21:20:01 2011 -0600
+++ b/apps/pc2pc.cpp Mon Mar 14 14:08:54 2011 -0500
@@ -12,7 +12,7 @@
#include <iostream>
-//#include "libpc/exceptions.hpp"
+#include "libpc/exceptions.hpp"
//#include "libpc/libpc_config.hpp"
//#include "libpc/Bounds.hpp"
//#include "libpc/Color.hpp"
@@ -31,7 +31,9 @@
#include "libpc/../../src/drivers/liblas/writer.hpp"
#include "libpc/../../src/drivers/liblas/reader.hpp"
+#ifdef HAVE_ORACLE
#include "libpc/../../src/drivers/oci/writer.hpp"
+#endif
#include "Application.hpp"
@@ -120,11 +122,13 @@
writer.write(np);
+#ifdef HAVE_ORACLE
else if (hasOption("oracle"))
- LasReader reader(*ifs);
- std::cout << "running oracle test" << std::endl;
+#ifdef HAVE_ORACLE
+ LiblasReader reader(*ifs);
const boost::uint64_t numPoints = reader.getHeader().getNumPoints();
libpc::driver::oci::Options options;
@@ -135,7 +139,7 @@
tree.put("debug", true);
tree.put("verbose", true);
- CacheFilter cache(reader);
+ CacheFilter cache(reader, 1, 1024);
libpc::driver::oci::Writer writer(cache, options);
@@ -146,9 +150,12 @@
size_t np = (size_t)numPoints;
assert(numPoints == np); // BUG
- writer.write(np);
+ writer.write(np);
+#else
+ throw configuration_error("libPC not compiled with Oracle support");
+#endif
+#endif
else
diff -r 221d3a3d6a54 -r c4371adc6197 cmake/modules/FindLibLAS.cmake
--- a/cmake/modules/FindLibLAS.cmake Thu Mar 10 21:20:01 2011 -0600
+++ b/cmake/modules/FindLibLAS.cmake Mon Mar 14 14:08:54 2011 -0500
@@ -46,7 +46,11 @@
/tmp/lasjunk/include
${OSGEO4W_ROOT_DIR}/include)
-SET(LIBLAS_NAMES ${OSGEO4W_IMPORT_LIBRARY} liblas)
+if(WIN32)
+ SET(LIBLAS_NAMES ${OSGEO4W_IMPORT_LIBRARY} liblas)
+else()
+ SET(LIBLAS_NAMES ${OSGEO4W_IMPORT_LIBRARY} las)
+endif()
FIND_LIBRARY(LIBLAS_LIBRARY
NAMES ${LIBLAS_NAMES}
diff -r 221d3a3d6a54 -r c4371adc6197 include/libpc/CacheFilter.hpp
--- a/include/libpc/CacheFilter.hpp Thu Mar 10 21:20:01 2011 -0600
+++ b/include/libpc/CacheFilter.hpp Mon Mar 14 14:08:54 2011 -0500
@@ -40,6 +40,8 @@
namespace libpc
+class PointDataCache;
// This is just a very simple MRU filter -- future versions will be smarter.
// This cache has the following constraints:
// - only one block is cached
@@ -48,32 +50,41 @@
class LIBPC_DLL CacheFilter : public Filter
public:
- CacheFilter(Stage& prevStage);
+ CacheFilter(Stage& prevStage, boost::uint32_t numBlocks, boost::uint32_t blockSize);
~CacheFilter();
const std::string& getName() const;
+ // override
+ void seekToPoint(boost::uint64_t index);
+ // clear cache (but leave cache params unchanged)
+ void resetCache();
+ // clear cache, and change cache params too
+ void resetCache(boost::uint32_t numBlocks, boost::uint32_t blockSize);
// number of points requested from this filter via read()
boost::uint64_t getNumPointsRequested() const;
// num points this filter read from the previous stage
boost::uint64_t getNumPointsRead() const;
- // override
- boost::uint64_t getCurrentPointIndex() const;
- // override
- void seekToPoint(boost::uint64_t index);
+ void getCacheStats(boost::uint64_t& numCacheLookupMisses,
+ boost::uint64_t& numCacheLookupHits,
+ boost::uint64_t& numCacheInsertMisses,
+ boost::uint64_t& numCacheInsertHits) const;
private:
boost::uint32_t readBuffer(PointData&);
- boost::uint64_t m_currentPointIndex;
- boost::uint64_t m_storedPointIndex;
- PointData* m_storedPointData;
boost::uint64_t m_numPointsRequested;
boost::uint64_t m_numPointsRead;
+ PointDataCache* m_cache;
+ boost::uint32_t m_maxCacheBlocks;
+ boost::uint32_t m_cacheBlockSize;
CacheFilter& operator=(const CacheFilter&); // not implemented
CacheFilter(const CacheFilter&); // not implemented
diff -r 221d3a3d6a54 -r c4371adc6197 include/libpc/Dimension.hpp
--- a/include/libpc/Dimension.hpp Thu Mar 10 21:20:01 2011 -0600
+++ b/include/libpc/Dimension.hpp Mon Mar 14 14:08:54 2011 -0500
@@ -79,7 +79,7 @@
Field_ScanAngleRank,
Field_UserData,
Field_PointSourceId,
- Field_GpsTime,
+ Field_Time,
Field_Red,
Field_Green,
Field_Blue,
diff -r 221d3a3d6a54 -r c4371adc6197 include/libpc/FauxReader.hpp
--- a/include/libpc/FauxReader.hpp Thu Mar 10 21:20:01 2011 -0600
+++ b/include/libpc/FauxReader.hpp Mon Mar 14 14:08:54 2011 -0500
@@ -71,7 +71,7 @@
void seekToPoint(boost::uint64_t);
private:
- boost::uint32_t readBuffer(PointData& data);
+ boost::uint32_t readBuffer(PointData&);
Mode m_mode;
diff -r 221d3a3d6a54 -r c4371adc6197 include/libpc/Filter.hpp
--- a/include/libpc/Filter.hpp Thu Mar 10 21:20:01 2011 -0600
+++ b/include/libpc/Filter.hpp Mon Mar 14 14:08:54 2011 -0500
@@ -47,19 +47,11 @@
public:
- // default behaviour for filters is just to call readBegin() on the previous stage
- virtual void readBegin(boost::uint32_t numPointsToRead);
- // default behaviour for filters is just to call readEnd() on the previous stage
- virtual void readEnd(boost::uint32_t numPointsRead);
+protected:
// advance (or retreat) to the Nth point in the file (absolute,
// default behaviour for filters is just to call seek on the previous stage
virtual void seekToPoint(boost::uint64_t pointNum);
- // default behaviour for filters is just to call the previous stage
- virtual boost::uint64_t getCurrentPointIndex() const;
protected:
Stage& m_prevStage;
diff -r 221d3a3d6a54 -r c4371adc6197 include/libpc/LasReader.hpp
--- a/include/libpc/LasReader.hpp Thu Mar 10 21:20:01 2011 -0600
+++ b/include/libpc/LasReader.hpp Mon Mar 14 14:08:54 2011 -0500
@@ -57,7 +57,7 @@
const LasHeader& getLasHeader() const;
protected:
- virtual boost::uint32_t readBuffer(PointData&);
LasHeader& getLasHeader();
void setLasHeader(const LasHeader&);
diff -r 221d3a3d6a54 -r c4371adc6197 include/libpc/LruCache.hpp
--- a/include/libpc/LruCache.hpp Thu Mar 10 21:20:01 2011 -0600
+++ /dev/null Thu Jan 01 00:00:00 1970 +0000
@@ -1,162 +0,0 @@
- * Copyright (c) 2010, Tim Day <timday at timday.com>
- * Permission to use, copy, modify, and/or distribute this software for any
- * purpose with or without fee is hereby granted, provided that the above
- * copyright notice and this permission notice appear in all copies.
- * THE SOFTWARE IS PROVIDED "AS IS" AND THE AUTHOR DISCLAIMS ALL WARRANTIES
- * WITH REGARD TO THIS SOFTWARE INCLUDING ALL IMPLIED WARRANTIES OF
- * MERCHANTABILITY AND FITNESS. IN NO EVENT SHALL THE AUTHOR BE LIABLE FOR
- * ANY SPECIAL, DIRECT, INDIRECT, OR CONSEQUENTIAL DAMAGES OR ANY DAMAGES
- * WHATSOEVER RESULTING FROM LOSS OF USE, DATA OR PROFITS, WHETHER IN AN
- * ACTION OF CONTRACT, NEGLIGENCE OR OTHER TORTIOUS ACTION, ARISING OUT OF
- * OR IN CONNECTION WITH THE USE OR PERFORMANCE OF THIS SOFTWARE.
-// This code is from http://www.bottlenose.demon.co.uk/article/lru.htm. It is
-// under a Internet Systems Consortium (ISC) license (an OSI-approved BSD-alike license).
-#ifndef INCLUDED_LIBPC_LRUCACHE_HPP
-#define INCLUDED_LIBPC_LRUCACHE_HPP
-#ifdef _MSC_VER
-# pragma warning(push)
-# pragma warning(disable: 4512) // assignment operator could not be generated
-#endif
-#include <boost/bimap.hpp>
-#include <boost/bimap/list_of.hpp>
-#include <boost/bimap/set_of.hpp>
-#include <boost/function.hpp>
-#ifdef _MSC_VER
-# pragma warning(pop)
-#endif
-namespace libpc
-class PointData;
-class LruCache
-public:
- typedef int dummy_type;
- // Bimap with key access on left view, key access
- // history on right view, and associated value.
- typedef boost::bimaps::bimap<
- boost::bimaps::set_of<boost::uint32_t>,
- boost::bimaps::list_of<dummy_type>,
- boost::bimaps::with_info<PointData*>
- > cache_type;
- // Constuctor specifies the cached function and
- // the maximum number of records to be stored.
- LruCache(size_t c)
- :_capacity(c)
- assert(_capacity!=0);
- ~LruCache()
- for (cache_type::left_iterator it =_cache.left.begin(); it != _cache.left.end(); ++it)
- PointData* data = it->info;
- delete data;
- return;
- PointData* lookup(boost::uint32_t k)
- // Attempt to find existing record
- const cache_type::left_iterator it =_cache.left.find(k);
- if (it==_cache.left.end())
- // We don't have it:
- return NULL;
- else
- // We do have it:
- return it->info;
- // Obtain value of the cached function for k
- PointData* insert(boost::uint32_t k, PointData* v)
More information about the Liblas-commits
