[Liblas-commits] libpc: unused
liblas-commits at liblas.org
Tue Mar 15 13:44:35 EDT 2011
details: http://hg.liblas.orglibpc/rev/03e610e04788
changeset: 231:03e610e04788
user: Michael P. Gerlek <mpg at flaxen.com>
date: Mon Mar 14 11:30:00 2011 -0700
description:
unused
Subject: libpc: make less chatty; fix libpc/liblas typo
details: http://hg.liblas.orglibpc/rev/c65135ad4d3f
changeset: 232:c65135ad4d3f
date: Mon Mar 14 11:39:07 2011 -0700
description:
Subject: libpc: start to add swig build
details: http://hg.liblas.orglibpc/rev/aa919b5074fc
changeset: 233:aa919b5074fc
date: Mon Mar 14 11:42:10 2011 -0700
description:
Subject: libpc: merge
details: http://hg.liblas.orglibpc/rev/87ccbec1b512
changeset: 234:87ccbec1b512
date: Mon Mar 14 13:39:47 2011 -0700
description:
merge
Subject: libpc: fix boost version; tweak mpg builds
details: http://hg.liblas.orglibpc/rev/298237820520
changeset: 235:298237820520
date: Tue Mar 15 13:44:03 2011 -0400
description:
diffstat:
CMakeLists.txt | 24 +-
apps/Application.cpp | 48 +-
apps/Application.hpp | 2 +
apps/pc2pc.cpp | 42 +-
apps/pcinfo.cpp | 59 ++
cmake/libPC.vcproj.user.template | 121 -----
cmake/modules/FindGDAL.cmake | 4 +-
cmake/modules/FindGeoTIFF.cmake | 4 +-
cmake/modules/FindLASzip.cmake | 4 +-
cmake/modules/FindLibLAS.cmake | 22 +-
csharp/CMakeLists.txt | 1 +
doc/model/ClassDiagram.classdiagram | 215 ----------
doc/model/ClassDiagram.classdiagram.layout | 193 ---------
doc/model/ModelDefinition/ModelProject.uml | 596 +++++++++++++++++++++++-----
doc/model/ModelProject.modelproj | 13 +-
doc/model/PointData.classdiagram | 182 ++++++++
doc/model/PointData.classdiagram.layout | 103 +++++
doc/model/Stage.classdiagram | 182 ++++++++
doc/model/Stage.classdiagram.layout | 111 +++++
doc/sprint/libpc-design.pptx | 0
doc/sprint/libpc-implementation.pptx | 0
doc/sprint/notes.txt | 68 +++
include/libpc/CacheFilter.hpp | 29 +-
include/libpc/Dimension.hpp | 2 +-
include/libpc/FauxReader.hpp | 2 +-
include/libpc/Filter.hpp | 10 +-
include/libpc/Header.hpp | 2 +
include/libpc/LasReader.hpp | 2 +-
include/libpc/PointDataCache.hpp | 199 +++++++++
include/libpc/Producer.hpp | 13 +-
include/libpc/SchemaLayout.hpp | 4 +-
include/libpc/Stage.hpp | 36 +-
include/libpc/chipper.hpp | 3 +
mpg-config.bat | 10 +-
src/CMakeLists.txt | 2 +
src/CacheFilter.cpp | 119 +++--
src/CropFilter.cpp | 6 +-
src/Dimension.cpp | 2 +-
src/FauxReader.cpp | 6 +-
src/Filter.cpp | 20 -
src/Header.cpp | 6 +
src/LasHeader.cpp | 2 +-
src/LasReader.cpp | 10 +-
src/LasWriter.cpp | 6 +-
src/PointData.cpp | 4 +-
src/PointDataCache.cpp | 16 +
src/Producer.cpp | 27 -
src/Stage.cpp | 27 +-
src/chipper.cpp | 2 +
src/drivers/liblas/reader.cpp | 14 +-
src/drivers/liblas/reader.hpp | 4 +-
src/drivers/liblas/writer.cpp | 6 +-
src/drivers/oci/CMakeLists.txt | 3 +-
src/drivers/oci/block.cpp | 53 --
src/drivers/oci/block.hpp | 65 ---
src/drivers/oci/common.cpp | 150 +++++++
src/drivers/oci/common.hpp | 92 ++++
src/drivers/oci/reader.cpp | 76 +++
src/drivers/oci/reader.hpp | 74 +++
src/drivers/oci/writer.cpp | 479 ++++++++++++++++++-----
src/drivers/oci/writer.hpp | 53 +-
test/unit/CMakeLists.txt | 1 +
test/unit/CacheFilterTest.cpp | 53 +-
test/unit/DecimationFilterTest.cpp | 2 +-
test/unit/FauxReaderTest.cpp | 4 +-
test/unit/MosaicFilterTest.cpp | 2 +-
test/unit/PointDataCacheTest.cpp | 92 ++++
67 files changed, 2618 insertions(+), 1166 deletions(-)
diffs (truncated from 5011 to 300 lines):
diff -r ca3ff449d03a -r 298237820520 CMakeLists.txt
--- a/CMakeLists.txt Wed Mar 09 14:04:43 2011 -0600
+++ b/CMakeLists.txt Tue Mar 15 13:44:03 2011 -0400
@@ -178,7 +178,7 @@
endif(WIN32)
# BUG: are there other Boost components we're using?
-find_package(Boost 1.45 COMPONENTS program_options thread iostreams filesystem system unit_test_framework REQUIRED)
+find_package(Boost 1.44 COMPONENTS program_options thread iostreams filesystem system unit_test_framework REQUIRED)
if(Boost_FOUND AND Boost_PROGRAM_OPTIONS_FOUND)
include_directories(${Boost_INCLUDE_DIRS})
@@ -245,6 +245,24 @@
# settings for other 3rd party dependencies
+# swig support
+if (WIN32)
+ set(WITH_SWIG_CSHARP TRUE CACHE BOOL "Choose if you want to make C# bindings via Swig")
+else()
+ set(WITH_SWIG_CSHARP FALSE CACHE BOOL "Choose if you want to make C# bindings via Swig")
+endif()
+if(WITH_SWIG_CSHARP)
+ find_package(swig 2.0.1)
+ if(SWIG_FOUND)
+ add_subdirectory(csharp)
+ set(LIBPC_HAVE_SWIG_CSHARP 1)
+ message(STATUS "Found Swig version ${SWIG_VERSION}")
+ else()
+ message(FATAL_ERROR "Swig not found (required for C# bindings)")
+ endif()
+endif()
# libxml2 support - optional, default=ON
set(WITH_LIBXML2 FALSE CACHE BOOL "Choose if libxml2 support should be built ")
@@ -266,7 +284,7 @@
if(ORACLE_FOUND)
include_directories(${ORACLE_INCLUDE_DIR})
- set(LIBPC_HAVE_ORACLE 1)
+ add_definitions(-DHAVE_ORACLE=1)
endif()
endif()
@@ -355,7 +373,7 @@
# installation commands
-install(FILES AUTHORS COPYING INSTALL LICENSE.txt README.txt
+install(FILES AUTHORS.txt LICENSE.txt
DESTINATION ${LIBPC_DATA_DIR}/doc)
diff -r ca3ff449d03a -r 298237820520 apps/Application.cpp
--- a/apps/Application.cpp Wed Mar 09 14:04:43 2011 -0600
+++ b/apps/Application.cpp Tue Mar 15 13:44:03 2011 -0400
@@ -90,21 +90,21 @@
// call derived function
int status = 0;
- try
+ // try
status = execute();
- catch (std::exception e)
- const std::string s(e.what());
- runtimeError("Caught exception: " + s);
- status = 1;
- catch (...)
- runtimeError("Caught unknown exception");
- status = 1;
+ // catch (std::exception e)
+ // const std::string s(e.what());
+ // runtimeError("Caught exception: " + s);
+ // status = 1;
+ // catch (...)
+ // runtimeError("Caught unknown exception");
+ // status = 1;
if (status == 0 && hasOption("timer"))
@@ -144,10 +144,17 @@
void Application::addOptionSet(po::options_description* options)
+ if (!options) return;
m_options.push_back(options);
+void Application::addPositionalOption(const char* name, int max_count)
+ m_positionalOptions.add(name, max_count);
void Application::outputHelp()
outputVersion();
@@ -200,19 +207,16 @@
po::options_description options;
- std::vector<po::options_description*>::iterator iter;
- for (iter = m_options.begin(); iter != m_options.end(); ++iter)
+ std::vector<po::options_description*>::iterator iter1;
+ for (iter1 = m_options.begin(); iter1 != m_options.end(); ++iter1)
- po::options_description* sub_options = *iter;
+ po::options_description* sub_options = *iter1;
options.add(*sub_options);
- //po::positional_options_description p;
- //p.add("input", 1);
- //p.add("output", 1);
po::store(po::command_line_parser(m_argc, m_argv).
- options(options)/*.positional(p)*/.run(), m_variablesMap);
+ options(options).positional(m_positionalOptions).run(),
+ m_variablesMap);
po::notify(m_variablesMap);
diff -r ca3ff449d03a -r 298237820520 apps/Application.hpp
--- a/apps/Application.hpp Wed Mar 09 14:04:43 2011 -0600
+++ b/apps/Application.hpp Tue Mar 15 13:44:03 2011 -0400
@@ -75,6 +75,7 @@
protected:
Application(int argc, char* argv[], const std::string& appName);
void addOptionSet(boost::program_options::options_description* options);
+ void addPositionalOption(const char* name, int max_count);
bool isVerbose() const;
bool hasOption(const std::string& name);
void usageError(const std::string&);
@@ -92,6 +93,7 @@
const std::string m_appName;
std::vector<boost::program_options::options_description*> m_options;
+ boost::program_options::positional_options_description m_positionalOptions;
boost::program_options::variables_map m_variablesMap;
Application& operator=(const Application&); // not implemented
diff -r ca3ff449d03a -r 298237820520 apps/pc2pc.cpp
--- a/apps/pc2pc.cpp Wed Mar 09 14:04:43 2011 -0600
+++ b/apps/pc2pc.cpp Tue Mar 15 13:44:03 2011 -0400
@@ -12,7 +12,7 @@
#include <iostream>
-//#include "libpc/exceptions.hpp"
+#include "libpc/exceptions.hpp"
//#include "libpc/libpc_config.hpp"
//#include "libpc/Bounds.hpp"
//#include "libpc/Color.hpp"
@@ -26,10 +26,14 @@
#include "libpc/LasReader.hpp"
//#include "libpc/LasHeader.hpp"
#include "libpc/LasWriter.hpp"
+#include "libpc/CacheFilter.hpp"
#include "libpc/../../src/drivers/liblas/writer.hpp"
#include "libpc/../../src/drivers/liblas/reader.hpp"
+#ifdef HAVE_ORACLE
+#include "libpc/../../src/drivers/oci/writer.hpp"
+#endif
#include "Application.hpp"
@@ -84,6 +88,7 @@
("input,i", po::value<std::string>(&m_inputFile), "input file name")
("output,o", po::value<std::string>(&m_outputFile), "output file name")
("native", "use native LAS classes (not liblas)")
+ ("oracle", "oracle test")
addOptionSet(file_options);
@@ -116,6 +121,41 @@
assert(numPoints == np); // BUG
writer.write(np);
+#ifdef HAVE_ORACLE
+ else if (hasOption("oracle"))
+#ifdef HAVE_ORACLE
+ LiblasReader reader(*ifs);
+ const boost::uint64_t numPoints = reader.getHeader().getNumPoints();
+ libpc::driver::oci::Options options;
+ boost::property_tree::ptree& tree = options.GetPTree();
+ tree.put("capacity", 15);
+ tree.put("connection", "lidar/lidar at oracle.hobu.biz/crrel");
+ tree.put("debug", true);
+ tree.put("verbose", true);
+ CacheFilter cache(reader, 1, 1024);
+ libpc::driver::oci::Writer writer(cache, options);
+ //BUG: handle laz writer.setCompressed(false);
+ //writer.setPointFormat( reader.getPointFormatNumber() );
+ size_t np = (size_t)numPoints;
+ assert(numPoints == np); // BUG
+ writer.write(np);
+#else
+ throw configuration_error("libPC not compiled with Oracle support");
+#endif
+#endif
else
diff -r ca3ff449d03a -r 298237820520 apps/pcinfo.cpp
--- a/apps/pcinfo.cpp Wed Mar 09 14:04:43 2011 -0600
+++ b/apps/pcinfo.cpp Tue Mar 15 13:44:03 2011 -0400
@@ -10,10 +10,15 @@
+#include "libpc/LasReader.hpp"
+#include "libpc/../../src/drivers/liblas/reader.hpp"
#include <iostream>
+using namespace libpc;
+namespace po = boost::program_options;
class Application_pcinfo : public Application
@@ -22,6 +27,9 @@
int execute();
private:
void addOptions();
+ bool validateOptions();
+ std::string m_inputFile;
@@ -31,12 +39,63 @@
+bool Application_pcinfo::validateOptions()
+ if (!hasOption("input"))
+ usageError("input file name required");
+ return false;
+ return true;
void Application_pcinfo::addOptions()
+ po::options_description* file_options = new po::options_description("file options");
+ file_options->add_options()
+ ("input,i", po::value<std::string>(&m_inputFile), "input file name")
+ ("native", "use native LAS classes (not liblas)")
+ addOptionSet(file_options);
+ addPositionalOption("input", 1);
+ return;
int Application_pcinfo::execute()
+ if (!Utils::fileExists(m_inputFile))
+ runtimeError("file not found: " + m_inputFile);
More information about the Liblas-commits
