[Liblas-commits] hg-main-tree: move filters into a subdir
liblas-commits at liblas.org liblas-commits at liblas.org
Tue Mar 15 16:30:17 EDT 2011
details:   http://hg.libpc.orghg-main-tree/rev/a795fe09bff1
changeset: 247:a795fe09bff1
user:      Michael P. Gerlek <mpg at flaxen.com>
date:      Tue Mar 15 16:29:46 2011 -0400
description:
diffstat:
 apps/pc2pc.cpp                             |    2 +-
 include/libpc/CacheFilter.hpp              |   94 ---------------
 include/libpc/ColorFilter.hpp              |   66 -----------
 include/libpc/CropFilter.hpp               |   65 ----------
 include/libpc/DecimationFilter.hpp         |   64 ----------
 include/libpc/MosaicFilter.hpp             |   66 -----------
 include/libpc/filters/CacheFilter.hpp      |   94 +++++++++++++++
 include/libpc/filters/ColorFilter.hpp      |   66 +++++++++++
 include/libpc/filters/CropFilter.hpp       |   65 ++++++++++
 include/libpc/filters/DecimationFilter.hpp |   64 ++++++++++
 include/libpc/filters/MosaicFilter.hpp     |   66 +++++++++++
 src/CMakeLists.txt                         |   39 +++---
 src/CacheFilter.cpp                        |  172 -----------------------------
 src/ColorFilter.cpp                        |  114 -------------------
 src/CropFilter.cpp                         |   98 ----------------
 src/DecimationFilter.cpp                   |   79 -------------
 src/MosaicFilter.cpp                       |  149 -------------------------
 src/filters/CMakeLists.txt                 |   23 +++
 src/filters/CacheFilter.cpp                |  172 +++++++++++++++++++++++++++++
 src/filters/ColorFilter.cpp                |  114 +++++++++++++++++++
 src/filters/CropFilter.cpp                 |   98 ++++++++++++++++
 src/filters/DecimationFilter.cpp           |   79 +++++++++++++
 src/filters/MosaicFilter.cpp               |  149 +++++++++++++++++++++++++
 test/unit/CacheFilterTest.cpp              |    2 +-
 test/unit/CropFilterTest.cpp               |    2 +-
 test/unit/DecimationFilterTest.cpp         |    2 +-
 test/unit/MosaicFilterTest.cpp             |    2 +-
 27 files changed, 1015 insertions(+), 991 deletions(-)
diffs (truncated from 2199 to 300 lines):
diff -r e7436b47c718 -r a795fe09bff1 apps/pc2pc.cpp
--- a/apps/pc2pc.cpp	Tue Mar 15 16:13:45 2011 -0400
+++ b/apps/pc2pc.cpp	Tue Mar 15 16:29:46 2011 -0400
@@ -26,7 +26,7 @@
 #include <libpc/drivers/las/Reader.hpp>
 //#include <libpc/LasHeader.hpp>
 #include <libpc/drivers/las/Writer.hpp>
-#include <libpc/CacheFilter.hpp>
+#include <libpc/filters/CacheFilter.hpp>
 #include <libpc/drivers/liblas/writer.hpp>
 #include <libpc/drivers/liblas/reader.hpp>
diff -r e7436b47c718 -r a795fe09bff1 include/libpc/CacheFilter.hpp
--- a/include/libpc/CacheFilter.hpp	Tue Mar 15 16:13:45 2011 -0400
+++ /dev/null	Thu Jan 01 00:00:00 1970 +0000
@@ -1,94 +0,0 @@
-* Copyright (c) 2011, Michael P. Gerlek (mpg at flaxen.com)
-* All rights reserved.
-* Redistribution and use in source and binary forms, with or without
-* modification, are permitted provided that the following
-* conditions are met:
-*     * Redistributions of source code must retain the above copyright
-*       notice, this list of conditions and the following disclaimer.
-*     * Redistributions in binary form must reproduce the above copyright
-*       notice, this list of conditions and the following disclaimer in
-*       the documentation and/or other materials provided
-*       with the distribution.
-*     * Neither the name of Hobu, Inc. or Flaxen Geo Consulting nor the
-*       names of its contributors may be used to endorse or promote
-*       products derived from this software without specific prior
-*       written permission.
-* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
-* "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
-* LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS
-* FOR A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE
-* COPYRIGHT OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT,
-* INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING,
-* BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS
-* OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED
-* AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY,
-* OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT
-* OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY
-* OF SUCH DAMAGE.
-#ifndef INCLUDED_CACHEFILTER_HPP
-#define INCLUDED_CACHEFILTER_HPP
-#include <libpc/Filter.hpp>
-namespace libpc
-class PointDataCache;
-// This is just a very simple MRU filter -- future versions will be smarter.
-// This cache has the following constraints:
-//   - only one block is cached
-//   - read chunk sizes are assumed to be just 1 point
-// If more than one point is read, the cache is skipped.
-class LIBPC_DLL CacheFilter : public Filter
-public:
-    CacheFilter(Stage& prevStage, boost::uint32_t numBlocks, boost::uint32_t blockSize);
-    ~CacheFilter();
-    const std::string& getName() const;
-    // override
-    void seekToPoint(boost::uint64_t index);
-    // clear cache (but leave cache params unchanged)
-    void resetCache();
-    // clear cache, and change cache params too
-    void resetCache(boost::uint32_t numBlocks, boost::uint32_t blockSize);
-    // number of points requested from this filter via read()
-    boost::uint64_t getNumPointsRequested() const;
-    // num points this filter read from the previous stage
-    boost::uint64_t getNumPointsRead() const;
-    void getCacheStats(boost::uint64_t& numCacheLookupMisses,
-                       boost::uint64_t& numCacheLookupHits,
-                       boost::uint64_t& numCacheInsertMisses,
-                       boost::uint64_t& numCacheInsertHits) const;
-private:
-    boost::uint32_t readBuffer(PointData&);
-    boost::uint64_t m_numPointsRequested;
-    boost::uint64_t m_numPointsRead;
-    PointDataCache* m_cache;
-    boost::uint32_t m_maxCacheBlocks;
-    boost::uint32_t m_cacheBlockSize;
-    CacheFilter& operator=(const CacheFilter&); // not implemented
-    CacheFilter(const CacheFilter&); // not implemented
-} // namespace libpc
-#endif
diff -r e7436b47c718 -r a795fe09bff1 include/libpc/ColorFilter.hpp
--- a/include/libpc/ColorFilter.hpp	Tue Mar 15 16:13:45 2011 -0400
@@ -1,66 +0,0 @@
-* OF SUCH DAMAGE.
-#ifndef INCLUDED_COLORFILTER_HPP
-#define INCLUDED_COLORFILTER_HPP
-#include <boost/cstdint.hpp>
-#include <libpc/export.hpp>
-namespace libpc
-// adds three new u8 fields (R,G,B) for the colourization of the Z axis
-// the color is done as a ramp from the declared Z min/max values in the header
-class LIBPC_DLL ColorFilter : public Filter
-public:
-    ColorFilter(Stage& prevStage);
-private:
-    void getColor(float value, boost::uint8_t& red, boost::uint8_t& green, boost::uint8_t& blue);
-    ColorFilter& operator=(const ColorFilter&); // not implemented
-    ColorFilter(const ColorFilter&); // not implemented
-#endif
diff -r e7436b47c718 -r a795fe09bff1 include/libpc/CropFilter.hpp
--- a/include/libpc/CropFilter.hpp	Tue Mar 15 16:13:45 2011 -0400
@@ -1,65 +0,0 @@
-* OF SUCH DAMAGE.
-#ifndef INCLUDED_CROPFILTER_HPP
-#define INCLUDED_CROPFILTER_HPP
-#include <libpc/Bounds.hpp>
-namespace libpc
-// removes any points outside of the given range
-// updates the header accordingly
-class LIBPC_DLL CropFilter : public Filter
-public:
-    CropFilter(Stage& prevStage, Bounds<double> const& bounds);
-private:
-    Bounds<double> m_bounds;
-    CropFilter& operator=(const CropFilter&); // not implemented
-    CropFilter(const CropFilter&); // not implemented
-#endif
diff -r e7436b47c718 -r a795fe09bff1 include/libpc/DecimationFilter.hpp
--- a/include/libpc/DecimationFilter.hpp	Tue Mar 15 16:13:45 2011 -0400
@@ -1,64 +0,0 @@
-* OF SUCH DAMAGE.
-#ifndef INCLUDED_DECIMATIONFILTER_HPP
-#define INCLUDED_DECIMATIONFILTER_HPP
-namespace libpc
-// we keep only 1 out of every step points; if step=100, we get 1% of the file
-class LIBPC_DLL DecimationFilter : public Filter
More information about the Liblas-commits mailing list
