[Liblas-commits] hg-main-tree: add Sphinx build setup
liblas-commits at liblas.org liblas-commits at liblas.org
Tue Mar 15 16:33:27 EDT 2011
details:   http://hg.libpc.orghg-main-tree/rev/d6454814cc00
changeset: 248:d6454814cc00
user:      Howard Butler <hobu.inc at gmail.com>
date:      Tue Mar 15 15:32:41 2011 -0500
description:
Subject: hg-main-tree: merge
details:   http://hg.libpc.orghg-main-tree/rev/86d3959da0f3
changeset: 249:86d3959da0f3
date:      Tue Mar 15 15:33:04 2011 -0500
description:
merge
diffstat:
 .hgignore                                  |    1 +
 apps/Application.cpp                       |    2 +-
 apps/pc2pc.cpp                             |   36 ++--
 apps/pcinfo.cpp                            |    4 +-
 doc/Makefile                               |  130 ++++++++++++++
 doc/conf.py                                |  256 +++++++++++++++++++++++++++++
 doc/index.txt                              |   37 ++++
 doc/make.bat                               |  170 +++++++++++++++++++
 doc/notes/apps.txt                         |    2 +
 doc/notes/bindings.txt                     |    2 +
 doc/notes/c-api.txt                        |    2 +
 doc/notes/coding-conventions.txt           |    2 +
 doc/notes/core-classes.txt                 |    2 +
 doc/notes/docs.txt                         |    2 +
 doc/notes/future.txt                       |    2 +
 doc/notes/goals.txt                        |    2 +
 doc/notes/intro.txt                        |    2 +
 doc/notes/io.txt                           |    2 +
 doc/notes/misc.txt                         |    2 +
 doc/notes/pipeline.txt                     |    2 +
 doc/notes/stages.txt                       |    2 +
 doc/notes/testing.txt                      |    2 +
 doc/notes/use-cases.txt                    |    2 +
 doc/sprint/notes.txt                       |    6 +
 include/libpc/CacheFilter.hpp              |   94 ----------
 include/libpc/ColorFilter.hpp              |   66 -------
 include/libpc/CropFilter.hpp               |   65 -------
 include/libpc/DecimationFilter.hpp         |   64 -------
 include/libpc/MosaicFilter.hpp             |   66 -------
 include/libpc/SpatialReference.hpp         |    2 +-
 include/libpc/filters/CacheFilter.hpp      |   94 ++++++++++
 include/libpc/filters/ColorFilter.hpp      |   66 +++++++
 include/libpc/filters/CropFilter.hpp       |   65 +++++++
 include/libpc/filters/DecimationFilter.hpp |   64 +++++++
 include/libpc/filters/MosaicFilter.hpp     |   66 +++++++
 src/CMakeLists.txt                         |   39 ++--
 src/CacheFilter.cpp                        |  172 -------------------
 src/ColorFilter.cpp                        |  114 ------------
 src/CropFilter.cpp                         |   98 -----------
 src/DecimationFilter.cpp                   |   79 --------
 src/MosaicFilter.cpp                       |  149 ----------------
 src/SpatialReference.cpp                   |    2 +-
 src/drivers/las/LasHeaderWriter.cpp        |    2 +-
 src/filters/CMakeLists.txt                 |   23 ++
 src/filters/CacheFilter.cpp                |  172 +++++++++++++++++++
 src/filters/ColorFilter.cpp                |  114 ++++++++++++
 src/filters/CropFilter.cpp                 |   98 +++++++++++
 src/filters/DecimationFilter.cpp           |   79 ++++++++
 src/filters/MosaicFilter.cpp               |  149 ++++++++++++++++
 test/unit/CacheFilterTest.cpp              |    4 +-
 test/unit/CropFilterTest.cpp               |    6 +-
 test/unit/DecimationFilterTest.cpp         |    6 +-
 test/unit/FauxReaderTest.cpp               |    2 +-
 test/unit/FauxWriterTest.cpp               |    4 +-
 test/unit/LiblasReaderTest.cpp             |    2 +-
 test/unit/LiblasWriterTest.cpp             |    6 +-
 test/unit/MosaicFilterTest.cpp             |    4 +-
 test/unit/PointDataCacheTest.cpp           |    4 +-
 test/unit/PointDataTest.cpp                |    2 +-
 test/unit/RangeTest.cpp                    |    2 +-
 test/unit/SchemaLayoutTest.cpp             |    2 +-
 test/unit/SchemaTest.cpp                   |    2 +-
 test/unit/SignallerTest.cpp                |    2 +-
 test/unit/UtilsTest.cpp                    |    2 +-
 test/unit/VectorTest.cpp                   |    2 +-
 65 files changed, 1690 insertions(+), 1036 deletions(-)
diffs (truncated from 3227 to 300 lines):
diff -r 40be85a9bd1d -r 86d3959da0f3 .hgignore
--- a/.hgignore	Tue Mar 15 14:35:30 2011 -0500
+++ b/.hgignore	Tue Mar 15 15:33:04 2011 -0500
@@ -34,3 +34,4 @@
 csharp/libpc_swig_cpp/libpc_wrap.cpp
 Makefile
+doc/build
diff -r 40be85a9bd1d -r 86d3959da0f3 apps/Application.cpp
--- a/apps/Application.cpp	Tue Mar 15 14:35:30 2011 -0500
+++ b/apps/Application.cpp	Tue Mar 15 15:33:04 2011 -0500
@@ -36,7 +36,7 @@
 #include <boost/timer.hpp>
-#include "libpc/libpc_config.hpp"
+#include <libpc/libpc_config.hpp>
 #include "Application.hpp"
diff -r 40be85a9bd1d -r 86d3959da0f3 apps/pc2pc.cpp
--- a/apps/pc2pc.cpp	Tue Mar 15 14:35:30 2011 -0500
+++ b/apps/pc2pc.cpp	Tue Mar 15 15:33:04 2011 -0500
@@ -12,27 +12,27 @@
 #include <iostream>
-#include "libpc/exceptions.hpp"
-//#include "libpc/libpc_config.hpp"
-//#include "libpc/Bounds.hpp"
-//#include "libpc/Color.hpp"
-//#include "libpc/Dimension.hpp"
-//#include "libpc/Schema.hpp"
-//#include "libpc/CropFilter.hpp"
-//#include "libpc/ColorFilter.hpp"
-//#include "libpc/MosaicFilter.hpp"
-//#include "libpc/FauxReader.hpp"
-//#include "libpc/FauxWriter.hpp"
-#include "libpc/drivers/las/Reader.hpp"
-//#include "libpc/LasHeader.hpp"
-#include "libpc/drivers/las/Writer.hpp"
-#include "libpc/CacheFilter.hpp"
+#include <libpc/exceptions.hpp>
+//#include <libpc/libpc_config.hpp>
+//#include <libpc/Bounds.hpp>
+//#include <libpc/Color.hpp>
+//#include <libpc/Dimension.hpp>
+//#include <libpc/Schema.hpp>
+//#include <libpc/CropFilter.hpp>
+//#include <libpc/ColorFilter.hpp>
+//#include <libpc/MosaicFilter.hpp>
+//#include <libpc/FauxReader.hpp>
+//#include <libpc/FauxWriter.hpp>
+#include <libpc/drivers/las/Reader.hpp>
+//#include <libpc/LasHeader.hpp>
+#include <libpc/drivers/las/Writer.hpp>
+#include <libpc/filters/CacheFilter.hpp>
-#include "libpc/drivers/liblas/writer.hpp"
-#include "libpc/drivers/liblas/reader.hpp"
+#include <libpc/drivers/liblas/writer.hpp>
+#include <libpc/drivers/liblas/reader.hpp>
 #ifdef HAVE_ORACLE
-#include "libpc/drivers/oci/writer.hpp"
+#include <libpc/drivers/oci/writer.hpp>
 #endif
diff -r 40be85a9bd1d -r 86d3959da0f3 apps/pcinfo.cpp
--- a/apps/pcinfo.cpp	Tue Mar 15 14:35:30 2011 -0500
+++ b/apps/pcinfo.cpp	Tue Mar 15 15:33:04 2011 -0500
@@ -10,8 +10,8 @@
 #include <iostream>
diff -r 40be85a9bd1d -r 86d3959da0f3 doc/Makefile
--- /dev/null	Thu Jan 01 00:00:00 1970 +0000
+++ b/doc/Makefile	Tue Mar 15 15:33:04 2011 -0500
@@ -0,0 +1,130 @@
+# Makefile for Sphinx documentation
+# You can set these variables from the command line.
+SPHINXOPTS    =
+SPHINXBUILD   = sphinx-build
+PAPER         =
+BUILDDIR      = build
+# Internal variables.
+PAPEROPT_a4     = -D latex_paper_size=a4
+PAPEROPT_letter = -D latex_paper_size=letter
+ALLSPHINXOPTS   = -d $(BUILDDIR)/doctrees $(PAPEROPT_$(PAPER)) $(SPHINXOPTS) .
+.PHONY: help clean html dirhtml singlehtml pickle json htmlhelp qthelp devhelp epub latex latexpdf text man changes linkcheck doctest
+help:
+	@echo "Please use \`make <target>' where <target> is one of"
+	@echo "  html       to make standalone HTML files"
+	@echo "  dirhtml    to make HTML files named index.html in directories"
+	@echo "  singlehtml to make a single large HTML file"
+	@echo "  pickle     to make pickle files"
+	@echo "  json       to make JSON files"
+	@echo "  htmlhelp   to make HTML files and a HTML help project"
+	@echo "  qthelp     to make HTML files and a qthelp project"
+	@echo "  devhelp    to make HTML files and a Devhelp project"
+	@echo "  epub       to make an epub"
+	@echo "  latex      to make LaTeX files, you can set PAPER=a4 or PAPER=letter"
+	@echo "  latexpdf   to make LaTeX files and run them through pdflatex"
+	@echo "  text       to make text files"
+	@echo "  man        to make manual pages"
+	@echo "  changes    to make an overview of all changed/added/deprecated items"
+	@echo "  linkcheck  to check all external links for integrity"
+	@echo "  doctest    to run all doctests embedded in the documentation (if enabled)"
+clean:
+	-rm -rf $(BUILDDIR)/*
+html:
+	$(SPHINXBUILD) -b html $(ALLSPHINXOPTS) $(BUILDDIR)/html
+	@echo
+	@echo "Build finished. The HTML pages are in $(BUILDDIR)/html."
+dirhtml:
+	$(SPHINXBUILD) -b dirhtml $(ALLSPHINXOPTS) $(BUILDDIR)/dirhtml
+	@echo
+	@echo "Build finished. The HTML pages are in $(BUILDDIR)/dirhtml."
+singlehtml:
+	$(SPHINXBUILD) -b singlehtml $(ALLSPHINXOPTS) $(BUILDDIR)/singlehtml
+	@echo
+	@echo "Build finished. The HTML page is in $(BUILDDIR)/singlehtml."
+pickle:
+	$(SPHINXBUILD) -b pickle $(ALLSPHINXOPTS) $(BUILDDIR)/pickle
+	@echo
+	@echo "Build finished; now you can process the pickle files."
+json:
+	$(SPHINXBUILD) -b json $(ALLSPHINXOPTS) $(BUILDDIR)/json
+	@echo
+	@echo "Build finished; now you can process the JSON files."
+htmlhelp:
+	$(SPHINXBUILD) -b htmlhelp $(ALLSPHINXOPTS) $(BUILDDIR)/htmlhelp
+	@echo
+	@echo "Build finished; now you can run HTML Help Workshop with the" \
+	      ".hhp project file in $(BUILDDIR)/htmlhelp."
+qthelp:
+	$(SPHINXBUILD) -b qthelp $(ALLSPHINXOPTS) $(BUILDDIR)/qthelp
+	@echo
+	@echo "Build finished; now you can run "qcollectiongenerator" with the" \
+	      ".qhcp project file in $(BUILDDIR)/qthelp, like this:"
+	@echo "# qcollectiongenerator $(BUILDDIR)/qthelp/libPC.qhcp"
+	@echo "To view the help file:"
+	@echo "# assistant -collectionFile $(BUILDDIR)/qthelp/libPC.qhc"
+devhelp:
+	$(SPHINXBUILD) -b devhelp $(ALLSPHINXOPTS) $(BUILDDIR)/devhelp
+	@echo
+	@echo "Build finished."
+	@echo "# mkdir -p $$HOME/.local/share/devhelp/libPC"
+	@echo "# ln -s $(BUILDDIR)/devhelp $$HOME/.local/share/devhelp/libPC"
+	@echo "# devhelp"
+epub:
+	$(SPHINXBUILD) -b epub $(ALLSPHINXOPTS) $(BUILDDIR)/epub
+	@echo
+	@echo "Build finished. The epub file is in $(BUILDDIR)/epub."
+latex:
+	$(SPHINXBUILD) -b latex $(ALLSPHINXOPTS) $(BUILDDIR)/latex
+	@echo
+	@echo "Build finished; the LaTeX files are in $(BUILDDIR)/latex."
+	@echo "Run \`make' in that directory to run these through (pdf)latex" \
+	      "(use \`make latexpdf' here to do that automatically)."
+latexpdf:
+	@echo "Running LaTeX files through pdflatex..."
+	make -C $(BUILDDIR)/latex all-pdf
+	@echo "pdflatex finished; the PDF files are in $(BUILDDIR)/latex."
+text:
+	$(SPHINXBUILD) -b text $(ALLSPHINXOPTS) $(BUILDDIR)/text
+	@echo
+	@echo "Build finished. The text files are in $(BUILDDIR)/text."
+man:
+	$(SPHINXBUILD) -b man $(ALLSPHINXOPTS) $(BUILDDIR)/man
+	@echo
+	@echo "Build finished. The manual pages are in $(BUILDDIR)/man."
+changes:
+	$(SPHINXBUILD) -b changes $(ALLSPHINXOPTS) $(BUILDDIR)/changes
+	@echo
+	@echo "The overview file is in $(BUILDDIR)/changes."
+linkcheck:
+	$(SPHINXBUILD) -b linkcheck $(ALLSPHINXOPTS) $(BUILDDIR)/linkcheck
+	@echo
+	@echo "Link check complete; look for any errors in the above output " \
+	      "or in $(BUILDDIR)/linkcheck/output.txt."
+doctest:
+	$(SPHINXBUILD) -b doctest $(ALLSPHINXOPTS) $(BUILDDIR)/doctest
+	@echo "Testing of doctests in the sources finished, look at the " \
+	      "results in $(BUILDDIR)/doctest/output.txt."
diff -r 40be85a9bd1d -r 86d3959da0f3 doc/conf.py
+++ b/doc/conf.py	Tue Mar 15 15:33:04 2011 -0500
@@ -0,0 +1,256 @@
+# -*- coding: utf-8 -*-
+# libPC documentation build configuration file, created by
+# sphinx-quickstart on Tue Mar 15 15:22:19 2011.
+# This file is execfile()d with the current directory set to its containing dir.
+# Note that not all possible configuration values are present in this
+# autogenerated file.
+# All configuration values have a default; values that are commented out
+# serve to show the default.
+import sys, os
+# If extensions (or modules to document with autodoc) are in another directory,
+# add these directories to sys.path here. If the directory is relative to the
+# documentation root, use os.path.abspath to make it absolute, like shown here.
+#sys.path.insert(0, os.path.abspath('.'))
+# -- General configuration -----------------------------------------------------
+# If your documentation needs a minimal Sphinx version, state it here.
+#needs_sphinx = '1.0'
+# Add any Sphinx extension module names here, as strings. They can be extensions
+# coming with Sphinx (named 'sphinx.ext.*') or your custom ones.
+extensions = []
+# Add any paths that contain templates here, relative to this directory.
+templates_path = ['_templates']
+# The suffix of source filenames.
+source_suffix = '.txt'
+# The encoding of source files.
+#source_encoding = 'utf-8-sig'
+# The master toctree document.
+master_doc = 'index'
+# General information about the project.
+project = u'libPC'
+copyright = u'2011, Howard Butler'
+# The version info for the project you're documenting, acts as replacement for
+# |version| and |release|, also used in various other places throughout the
+# built documents.
+# The short X.Y version.
+version = '0.0.1'
+# The full version, including alpha/beta/rc tags.
+release = '0.0.1'
+# The language for content autogenerated by Sphinx. Refer to documentation
+# for a list of supported languages.
+#language = None
+# There are two options for replacing |today|: either, you set today to some
+# non-false value, then it is used:
+#today = ''
+# Else, today_fmt is used as the format for a strftime call.
+#today_fmt = '%B %d, %Y'
+# List of patterns, relative to source directory, that match files and
+# directories to ignore when looking for source files.
+exclude_patterns = []
+# The reST default role (used for this markup: `text`) to use for all documents.
+#default_role = None
+# If true, '()' will be appended to :func: etc. cross-reference text.
+#add_function_parentheses = True
+# If true, the current module name will be prepended to all description
+# unit titles (such as .. function::).
+#add_module_names = True
+# If true, sectionauthor and moduleauthor directives will be shown in the
More information about the Liblas-commits mailing list
