[Liblas-commits] hg-main-tree: make getCapacity const
liblas-commits at liblas.org
Fri Mar 18 09:53:43 EDT 2011
details: http://hg.libpc.orghg-main-tree/rev/2a7b213bc081
changeset: 355:2a7b213bc081
user: Howard Butler <hobu.inc at gmail.com>
date: Thu Mar 17 14:46:20 2011 -0500
description:
Subject: hg-main-tree: some (broken) chipper work
details: http://hg.libpc.orghg-main-tree/rev/155b08e88b32
changeset: 356:155b08e88b32
date: Thu Mar 17 14:46:41 2011 -0500
description:
Subject: hg-main-tree: merge
details: http://hg.libpc.orghg-main-tree/rev/990c53cc56c5
changeset: 357:990c53cc56c5
date: Thu Mar 17 14:46:55 2011 -0500
description:
merge
Subject: hg-main-tree: add copy and assignment constructors to PointData
details: http://hg.libpc.orghg-main-tree/rev/75e3b0f7c6d3
changeset: 358:75e3b0f7c6d3
date: Fri Mar 18 08:53:06 2011 -0500
description:
Subject: hg-main-tree: fix up chipper::Block constructor
details: http://hg.libpc.orghg-main-tree/rev/9617d8b88b30
changeset: 359:9617d8b88b30
date: Fri Mar 18 08:53:27 2011 -0500
description:
details: http://hg.libpc.orghg-main-tree/rev/a8af49df848a
changeset: 360:a8af49df848a
date: Fri Mar 18 08:53:33 2011 -0500
description:
merge
diffstat:
cmake/modules/FindOracle.cmake | 1 +
include/libpc/Chipper.hpp | 7 ++++++-
include/libpc/PointData.hpp | 7 ++++---
include/libpc/libpc_config.hpp | 5 +++++
src/Chipper.cpp | 12 +++++++++++-
src/PointData.cpp | 27 +++++++++++++++++++++++++++
6 files changed, 54 insertions(+), 5 deletions(-)
diffs (165 lines):
diff -r a04aceb325c4 -r a8af49df848a cmake/modules/FindOracle.cmake
--- a/cmake/modules/FindOracle.cmake Thu Mar 17 14:35:05 2011 -0500
+++ b/cmake/modules/FindOracle.cmake Fri Mar 18 08:53:33 2011 -0500
@@ -50,6 +50,7 @@
set(ORACLE_OCCI_NAMES libocci occi oraocci10 oraocci11)
set(ORACLE_LIB_DIR
+ ${ORACLE_HOME}
${ORACLE_HOME}/lib
${ORACLE_HOME}/OCI/lib/MSVC)
diff -r a04aceb325c4 -r a8af49df848a include/libpc/Chipper.hpp
--- a/include/libpc/Chipper.hpp Thu Mar 17 14:35:05 2011 -0500
+++ b/include/libpc/Chipper.hpp Fri Mar 18 08:53:33 2011 -0500
@@ -2,6 +2,7 @@
#define LIBLAS_CHIPPER_H
#include <libpc/Stage.hpp>
+#include <libpc/PointData.hpp>
#include <libpc/Bounds.hpp>
#include <libpc/export.hpp>
#include <libpc/Dimension.hpp>
@@ -11,6 +12,8 @@
namespace libpc
+class Schema;
namespace chipper
@@ -67,7 +70,7 @@
class LIBPC_DLL Chipper;
-class LIBPC_DLL Block
+class LIBPC_DLL Block : libpc::PointData
friend class Chipper;
@@ -82,6 +85,8 @@
// double m_ymax;
public:
+ Block(Schema const& schema, boost::uint32_t capacity);
+ Block(Block const& block);
std::vector<boost::uint32_t> GetIDs() const;
libpc::Bounds<double> const& GetBounds() const {return m_bounds;}
void SetBounds(libpc::Bounds<double> const& bounds) {m_bounds = bounds;}
diff -r a04aceb325c4 -r a8af49df848a include/libpc/PointData.hpp
--- a/include/libpc/PointData.hpp Thu Mar 17 14:35:05 2011 -0500
+++ b/include/libpc/PointData.hpp Fri Mar 18 08:53:33 2011 -0500
@@ -65,6 +65,9 @@
// represents the state within the owning object, which in this case is a completely
// empty buffer (similarly, all the points in the buffer are marked "invalid")
PointData(const SchemaLayout&, boost::uint32_t capacity);
+ PointData(const PointData&);
+ PointData& operator=(const PointData&);
~PointData();
const Bounds<double>& getSpatialBounds() const;
@@ -79,7 +82,7 @@
// number of points in this buffer that have legit data; initially will be zero,
// and after a read() call it will be in the range 0 to getNumPoints()-1
- inline boost::uint32_t getCapacity() { return m_capacity; }
+ inline boost::uint32_t getCapacity() const { return m_capacity; }
// schema (number and kinds of fields) for a point in this buffer
const SchemaLayout& getSchemaLayout() const
@@ -116,8 +119,6 @@
boost::uint32_t m_capacity;
Bounds<double> m_bounds;
- PointData(const PointData&); // not implemented
- PointData& operator=(const PointData&); // not implemented
diff -r a04aceb325c4 -r a8af49df848a include/libpc/libpc_config.hpp
--- a/include/libpc/libpc_config.hpp Thu Mar 17 14:35:05 2011 -0500
+++ b/include/libpc/libpc_config.hpp Fri Mar 18 08:53:33 2011 -0500
@@ -41,6 +41,9 @@
* OF SUCH DAMAGE.
+#ifndef INCLUDED_LIBPC_CONFIG_HPP
+#define INCLUDED_LIBPC_CONFIG_HPP
#include <string>
@@ -60,3 +63,5 @@
LIBPC_DLL int GetVersionPatch();
} // namespace libpc
+#endif
diff -r a04aceb325c4 -r a8af49df848a src/Chipper.cpp
--- a/src/Chipper.cpp Thu Mar 17 14:35:05 2011 -0500
+++ b/src/Chipper.cpp Fri Mar 18 08:53:33 2011 -0500
@@ -79,6 +79,16 @@
namespace libpc { namespace chipper {
+Block::Block(Schema const& schema, boost::uint32_t capacity)
+ : PointData(schema, capacity)
+Block::Block(Block const& block)
+ : PointData(block.getSchema(), block.getCapacity())
vector<boost::uint32_t> Block::GetIDs() const
vector<boost::uint32_t> ids;
@@ -360,7 +370,7 @@
void Chipper::Emit(RefList& wide, boost::uint32_t widemin, boost::uint32_t widemax,
RefList& narrow, boost::uint32_t narrowmin, boost::uint32_t narrowmax )
- Block b;
+ Block b(m_stage.getHeader().getSchema(), m_threshold);
b.m_list_p = &wide;
if (wide.m_dir == DIR_X) {
diff -r a04aceb325c4 -r a8af49df848a src/PointData.cpp
--- a/src/PointData.cpp Thu Mar 17 14:35:05 2011 -0500
+++ b/src/PointData.cpp Fri Mar 18 08:53:33 2011 -0500
@@ -57,6 +57,33 @@
return;
+PointData::PointData(PointData const& other)
+ : m_schemaLayout(other.getSchemaLayout())
+ , m_data(0)
+ , m_pointSize(m_schemaLayout.getByteSize())
+ , m_numPoints(other.m_numPoints)
+ , m_capacity(other.m_capacity)
+ , m_bounds(other.m_bounds)
+ m_data = new boost::uint8_t[m_pointSize * m_capacity];
+ memcpy(m_data, other.m_data, m_pointSize*m_capacity);
+PointData& PointData::operator=(PointData const& rhs)
+ if (&rhs != this)
+ m_schemaLayout = rhs.getSchemaLayout();
+ m_data = new boost::uint8_t[m_schemaLayout.getByteSize() * rhs.getCapacity()];
+ m_pointSize = m_schemaLayout.getByteSize();
+ m_numPoints = rhs.getNumPoints();
+ m_capacity = rhs.getCapacity();
+ m_bounds = rhs.getSpatialBounds();
+ return *this;
PointData::~PointData()
More information about the Liblas-commits
