[Liblas-commits] hg-main-tree: introducing build and source files for mrsid drive...
liblas-commits at liblas.org liblas-commits at liblas.org
Fri Mar 18 10:01:52 EDT 2011
details:   http://hg.libpc.orghg-main-tree/rev/c79a3bd0318d
changeset: 361:c79a3bd0318d
user:      Kirk McKelvey <kirkoman at lizardtech.com>
date:      Fri Mar 18 09:01:33 2011 -0500
description:
introducing build and source files for mrsid driver (driver not operational)
diffstat:
 CMakeLists.txt                         |   11 ++
 cmake/modules/FindMrSID.cmake          |   10 +-
 include/libpc/drivers/mrsid/Reader.hpp |   74 +++++++++++++
 src/CMakeLists.txt                     |   22 ++++
 src/drivers/mrsid/Reader.cpp           |  175 +++++++++++++++++++++++++++++++++
 5 files changed, 286 insertions(+), 6 deletions(-)
diffs (truncated from 342 to 300 lines):
diff -r a8af49df848a -r c79a3bd0318d CMakeLists.txt
--- a/CMakeLists.txt	Fri Mar 18 08:53:33 2011 -0500
+++ b/CMakeLists.txt	Fri Mar 18 09:01:33 2011 -0500
@@ -332,6 +332,17 @@
     "libPC currently requires a working libLAS installation 1.6.0 or greater")
 endif()
+# MrSID/LiDAR support - optiona, default=OFF
+set(WITH_MRSID FALSE CACHE BOOL "Choose if MrSID/LiDAR support should be built")
+if(WITH_MRSID)
+    find_package(MrSID)
+    if(MRSID_FOUND)
+        set(CMAKE_REQUIRED_LIBRARIES ${MRSID_LIBRARY})
+        include_directories(${MRSID_INCLUDE_DIR})
+    endif()
+endif()
 # installation path settings
diff -r a8af49df848a -r c79a3bd0318d cmake/modules/FindMrSID.cmake
--- a/cmake/modules/FindMrSID.cmake	Fri Mar 18 08:53:33 2011 -0500
+++ b/cmake/modules/FindMrSID.cmake	Fri Mar 18 09:01:33 2011 -0500
@@ -29,17 +29,15 @@
   message(STATUS "Searching for MrSID LiDAR library ${MrSID_FIND_VERSION}+")
 endif()
-if(NOT DEFINED ENV{MRSID_HOME})
-  message(FATAL_ERROR "Missing environment variable MRSID_HOME with location of MrSID LiDAR sdk")
+if(NOT MRSID_ROOT)
+  message(FATAL_ERROR "Missing variable MRSID_ROOT with location of MrSID LiDAR sdk")
 endif()
-set(MRSID_HOME $ENV{MRSID_HOME})
 find_path(MRSID_INCLUDE_DIR
           lidar/Base.h
           PATHS
-            ${MRSID_HOME}/include
-            ${MRSID_HOME}/Lidar_DSDK/include
+            ${MRSID_ROOT}/include
+            ${MRSID_ROOT}/Lidar_DSDK/include
           NO_DEFAULT_PATH)
 find_library(MRSID_LIBRARY
diff -r a8af49df848a -r c79a3bd0318d include/libpc/drivers/mrsid/Reader.hpp
--- /dev/null	Thu Jan 01 00:00:00 1970 +0000
+++ b/include/libpc/drivers/mrsid/Reader.hpp	Fri Mar 18 09:01:33 2011 -0500
@@ -0,0 +1,74 @@
+* Copyright (c) 2011, Kirk McKelvey <kirkoman at gmail.com>
+* All rights reserved.
+* Redistribution and use in source and binary forms, with or without
+* modification, are permitted provided that the following
+* conditions are met:
+*     * Redistributions of source code must retain the above copyright
+*       notice, this list of conditions and the following disclaimer.
+*     * Redistributions in binary form must reproduce the above copyright
+*       notice, this list of conditions and the following disclaimer in
+*       the documentation and/or other materials provided
+*       with the distribution.
+*     * Neither the name of Hobu, Inc. or Flaxen Geo Consulting nor the
+*       names of its contributors may be used to endorse or promote
+*       products derived from this software without specific prior
+*       written permission.
+* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
+* "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
+* LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS
+* FOR A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE
+* COPYRIGHT OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT,
+* INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING,
+* BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS
+* OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED
+* AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY,
+* OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT
+* OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY
+* OF SUCH DAMAGE.
+#ifndef INCLUDED_DRIVERS_MRSID_READER_HPP
+#define INCLUDED_DRIVERS_MRSID_READER_HPP
+#include <string>
+#include <libpc/Stage.hpp>
+#include "lidar/MG4PointReader.h"
+namespace LizardTech
+class MG4PointReader;
+namespace libpc
+namespace drivers
+namespace mrsid
+class LIBPC_DLL Reader : public libpc::Stage
+public:
+    Reader(const char *);
+    const std::string& getName() const;
+protected:
+    boost::uint32_t readBuffer(PointData&);
+private:
+    Reader& operator=(const Reader&); // not implemented
+    Reader(const Reader&); // not implemented
+    LizardTech::MG4PointReader *m_reader;
+} // end namespaces
+#endif // INCLUDED_DRIVERS_MRSID_READER_HPP
diff -r a8af49df848a -r c79a3bd0318d src/CMakeLists.txt
--- a/src/CMakeLists.txt	Fri Mar 18 08:53:33 2011 -0500
+++ b/src/CMakeLists.txt	Fri Mar 18 09:01:33 2011 -0500
@@ -191,6 +191,27 @@
 endif()
+# drivers/mrsid
+if (MRSID_FOUND)
+set(LIBPC_DRIVERS_MRSID_HPP
+  ${LIBPC_HEADERS_DIR}/drivers/mrsid/Reader.hpp
+set (LIBPC_DRIVERS_MRSID_CPP
+  ./drivers/mrsid/Reader.cpp
+FOREACH(file ${LIBPC_DRIVERS_MRSID_HPP})
+        SET(LIBPC_HPP "${LIBPC_HPP};${file}" CACHE INTERNAL "source files for drivers/mrsid")
+ENDFOREACH(file)
+FOREACH(file ${LIBPC_DRIVERS_MRSID_CPP})
+        SET(LIBPC_CPP "${LIBPC_CPP};${file}" CACHE INTERNAL "source files for drivers/mrsid")
+ENDFOREACH(file)
+endif()
 # filters
@@ -290,6 +311,7 @@
   ${LIBLAS_LIBRARY}
   ${TIFF_LIBRARY}
   ${ORACLE_LIBRARY}
+  ${MRSID_LIBRARY}
   ${GEOTIFF_LIBRARY}
   ${GDAL_LIBRARY}
   ${LASZIP_LIBRARY}
diff -r a8af49df848a -r c79a3bd0318d src/drivers/mrsid/Reader.cpp
+++ b/src/drivers/mrsid/Reader.cpp	Fri Mar 18 09:01:33 2011 -0500
@@ -0,0 +1,175 @@
+* OF SUCH DAMAGE.
+#include <libpc/drivers/mrsid/Reader.hpp>
+#include <libpc/exceptions.hpp>
+namespace libpc
+namespace drivers
+namespace mrsid
+LT_USE_LIDAR_NAMESPACE
+static libpc::Dimension::Field FieldEnumOf(const char *);
+static libpc::Dimension::DataType TypeEnumOf(LizardTech::DataType);
+Reader::Reader(const char * filepath)
+    : libpc::Stage(), m_reader(NULL)
+    try
+        // open a MG4 file
+        m_reader = MG4PointReader::create();
+        m_reader->init(filepath);
+    catch(...)
+        RELEASE(m_reader);
+        throw;
+    Header* header = new Header;
+    Schema& schema = header->getSchema();
+    header->setNumPoints(m_reader->getNumPoints());
+    Bounds<double> bounds(m_reader->getBounds().x.min, m_reader->getBounds().y.min, m_reader->getBounds().z.min,
+                          m_reader->getBounds().x.max, m_reader->getBounds().y.max, m_reader->getBounds().z.max);
+    header->setBounds(bounds);
+    size_t numChannels = m_reader->getNumChannels();
+    const PointInfo &pointInfo = m_reader->getPointInfo();
+    for(size_t i = 0; i < numChannels; i += 1)
+        schema.addDimension(Dimension(FieldEnumOf(pointInfo.getChannel(i).getName()), TypeEnumOf(pointInfo.getChannel(i).getDataType())));
+    setHeader(header);
+    return;
+libpc::Dimension::Field
+FieldEnumOf(const char * fieldname)
+    if (!strcmp(CHANNEL_NAME_X, fieldname))
+        return Dimension::Field_X;
+    if (!strcmp(CHANNEL_NAME_Y, fieldname))
+        return Dimension::Field_Y;
+        return Dimension::Field_Z;
+    if (!strcmp(CHANNEL_NAME_Intensity, fieldname))
+        return Dimension::Field_Intensity;
+    if (!strcmp(CHANNEL_NAME_ReturnNum, fieldname))
+        return Dimension::Field_ReturnNumber;
+    if (!strcmp(CHANNEL_NAME_NumReturns, fieldname))
+        return Dimension::Field_NumberOfReturns;
+    if (!strcmp(CHANNEL_NAME_ScanDir, fieldname))
+        return Dimension::Field_ScanDirectionFlag;
+    if (!strcmp(CHANNEL_NAME_EdgeFlightLine, fieldname))
+        return Dimension::Field_EdgeOfFlightLine;
+    if (!strcmp(CHANNEL_NAME_ClassId, fieldname))
+        return Dimension::Field_Classification;
+    if (!strcmp(CHANNEL_NAME_ScanAngle, fieldname))
+        return Dimension::Field_ScanAngleRank;
+    if (!strcmp(CHANNEL_NAME_UserData, fieldname))
+        return Dimension::Field_UserData;
+    if (!strcmp(CHANNEL_NAME_SourceId, fieldname))
+        return Dimension::Field_PointSourceId;
+    if (!strcmp(CHANNEL_NAME_GPSTime, fieldname))
+        return Dimension::Field_Time;
+    if (!strcmp(CHANNEL_NAME_Red, fieldname))
+        return Dimension::Field_Red;
+    if (!strcmp(CHANNEL_NAME_Green, fieldname))
+        return Dimension::Field_Green;
+    if (!strcmp(CHANNEL_NAME_Blue, fieldname))
+        return Dimension::Field_Blue;
+    // @todo
+    // Field_WavePacketDescriptorIndex
+    // Field_WaveformDataOffset
+    // Field_ReturnPointWaveformLocation
+    // Field_WaveformXt
+    // Field_WaveformYt
+    // Field_WaveformZt
+libpc::Dimension::DataType
+TypeEnumOf(LizardTech::DataType ldt)
+    switch (ldt)
More information about the Liblas-commits mailing list
