[Liblas-commits] hg-main-tree: #1: now using consistent LIBPC_*
macros, fixed som...
liblas-commits at liblas.org
Fri Mar 25 13:39:06 EDT 2011
details: http://hg.libpc.orghg-main-tree/rev/76e24ad4bfde
changeset: 457:76e24ad4bfde
user: Michael P. Gerlek <mpg at flaxen.com>
date: Fri Mar 25 10:38:47 2011 -0700
description:
#1: now using consistent LIBPC_* macros, fixed some old ones
Subject: hg-main-tree: merge
details: http://hg.libpc.orghg-main-tree/rev/cc6156bfe890
changeset: 458:cc6156bfe890
date: Fri Mar 25 10:38:57 2011 -0700
description:
merge
diffstat:
CMakeLists.txt | 18 +++++++++++++++++-
apps/Application.hpp | 4 ++--
apps/pc2pc.cpp | 4 ++--
apps/pcinfo.cpp | 4 ++--
include/libpc/Bounds.hpp | 2 +-
include/libpc/PointBufferCache.hpp | 4 ++--
include/libpc/Stage.hpp | 4 +---
include/libpc/drivers/faux/Reader.hpp | 14 ++++++--------
include/libpc/drivers/las/Reader.hpp | 12 +++++-------
include/libpc/drivers/liblas/Reader.hpp | 12 +++++-------
include/libpc/drivers/mrsid/Reader.hpp | 14 ++++++--------
include/libpc/drivers/oci/Common.hpp | 2 +-
include/libpc/drivers/oci/Reader.hpp | 14 +++++---------
include/libpc/export.hpp | 8 +++++---
include/libpc/filters/CacheFilter.hpp | 12 +++++-------
include/libpc/filters/ColorFilter.hpp | 10 ++++------
include/libpc/filters/CropFilter.hpp | 11 ++++-------
include/libpc/filters/DecimationFilter.hpp | 10 ++++------
include/libpc/filters/MosaicFilter.hpp | 10 ++++------
libpc_defines.h.in | 24 ++++++++++++++++++++++--
src/CMakeLists.txt | 26 +++++++++++++++++++-------
src/Utils.cpp | 6 +++---
src/drivers/faux/Reader.cpp | 9 ---------
src/drivers/las/LasHeaderReader.cpp | 2 +-
src/drivers/las/Reader.cpp | 8 --------
src/drivers/liblas/Reader.cpp | 8 --------
src/drivers/mrsid/Reader.cpp | 5 -----
src/filters/CacheFilter.cpp | 9 ---------
src/filters/ColorFilter.cpp | 8 --------
src/filters/CropFilter.cpp | 8 --------
src/filters/DecimationFilter.cpp | 10 ----------
src/filters/MosaicFilter.cpp | 9 ---------
test/unit/FauxReaderTest.cpp | 5 ++---
test/unit/LiblasReaderTest.cpp | 6 ++----
34 files changed, 130 insertions(+), 182 deletions(-)
diffs (truncated from 776 to 300 lines):
diff -r 689ad51ea693 -r cc6156bfe890 CMakeLists.txt
--- a/CMakeLists.txt Fri Mar 25 09:56:02 2011 -0700
+++ b/CMakeLists.txt Fri Mar 25 10:38:57 2011 -0700
@@ -118,6 +118,15 @@
add_definitions(-D_CRT_SECURE_NO_WARNINGS)
add_definitions(-D_CRT_NONSTDC_NO_WARNING)
add_definitions(-D_SCL_SECURE_NO_WARNINGS)
+ set(LIBPC_COMPILER_MSVC 1)
+ if (MSVC10)
+ set(LIBPC_COMPILER_VC10 1)
+ elseif (MSVC9)
+ set(LIBPC_COMPILER_VC9 1)
+ elseif (MSVC8)
+ set(LIBPC_COMPILER_VC8 1)
+ endif()
endif()
if(CMAKE_CXX_FLAGS MATCHES "/W[0-4]")
@@ -131,6 +140,8 @@
set(CMAKE_INCLUDE_PATH c:/osgeo4w/include;$ENV{CMAKE_INCLUDE_PATH})
set(CMAKE_LIBRARY_PATH c:/osgeo4w/lib;$ENV{CMAKE_LIBRARY_PATH})
+ set(LIBPC_OS_WIN32 1)
else()
# not WIN32
@@ -145,9 +156,12 @@
if (CMAKE_COMPILER_IS_GNUCXX)
set(CMAKE_CXX_FLAGS "${CMAKE_CXX_FLAGS} -std=c++98")
endif()
+ set(LIBPC_COMPILER_GCC 1)
elseif("${CMAKE_CXX_COMPILER_ID}" MATCHES "Clang" OR "${CMAKE_CXX_COMPILER}" MATCHES "clang")
set(CMAKE_CXX_FLAGS "${CMAKE_CXX_FLAGS} ${LIBPC_COMMON_CXX_FLAGS}")
+ set(LIBPC_COMPILER_CLANG 1)
endif()
endif(WIN32)
@@ -292,6 +306,7 @@
if(ORACLE_FOUND)
include_directories(${ORACLE_INCLUDE_DIR})
add_definitions(-DHAVE_ORACLE=1)
+ set(LIBPC_HAVE_ORACLE 1)
endif()
endif()
@@ -343,6 +358,7 @@
set(CMAKE_REQUIRED_LIBRARIES ${MRSID_LIBRARY})
include_directories(${MRSID_INCLUDE_DIR})
add_definitions(-DHAVE_MRSID=1)
+ set(LIBPC_HAVE_MRSID 1)
endif()
endif()
diff -r 689ad51ea693 -r cc6156bfe890 apps/Application.hpp
--- a/apps/Application.hpp Fri Mar 25 09:56:02 2011 -0700
+++ b/apps/Application.hpp Fri Mar 25 10:38:57 2011 -0700
@@ -38,12 +38,12 @@
#include <iosfwd>
-#ifdef _MSC_VER
+#ifdef LIBPC_COMPILER_MSVC
# pragma warning(push)
# pragma warning(disable: 4512) // assignment operator could not be generated
#endif
#include <boost/program_options.hpp>
-#ifdef _MSC_VER
# pragma warning(pop)
#endif
diff -r 689ad51ea693 -r cc6156bfe890 apps/pc2pc.cpp
--- a/apps/pc2pc.cpp Fri Mar 25 09:56:02 2011 -0700
+++ b/apps/pc2pc.cpp Fri Mar 25 10:38:57 2011 -0700
@@ -31,7 +31,7 @@
#include <libpc/drivers/liblas/writer.hpp>
#include <libpc/drivers/liblas/reader.hpp>
-#ifdef HAVE_ORACLE
+#ifdef LIBPC_HAVE_ORACLE
#include <libpc/drivers/oci/writer.hpp>
#endif
@@ -123,7 +123,7 @@
else if (hasOption("oracle"))
-#ifdef HAVE_ORACLE
libpc::drivers::liblas::LiblasReader reader(m_inputFile);
const boost::uint64_t numPoints = reader.getHeader().getNumPoints();
diff -r 689ad51ea693 -r cc6156bfe890 apps/pcinfo.cpp
--- a/apps/pcinfo.cpp Fri Mar 25 09:56:02 2011 -0700
+++ b/apps/pcinfo.cpp Fri Mar 25 10:38:57 2011 -0700
@@ -13,7 +13,7 @@
#include <libpc/drivers/las/Reader.hpp>
#include <libpc/drivers/liblas/Reader.hpp>
#include <libpc/Utils.hpp>
-#ifdef HAVE_MRSID
+#ifdef LIBPC_HAVE_MRSID
#include <libpc/drivers/mrsid/Reader.hpp>
#endif
@@ -97,7 +97,7 @@
reader = new libpc::drivers::liblas::LiblasReader(m_inputFile);
-#ifdef HAVE_MRSID
else if (!m_inputFile.substr(ext).compare("sid"))
reader = new libpc::drivers::mrsid::Reader(m_inputFile.c_str());
diff -r 689ad51ea693 -r cc6156bfe890 include/libpc/Bounds.hpp
--- a/include/libpc/Bounds.hpp Fri Mar 25 09:56:02 2011 -0700
+++ b/include/libpc/Bounds.hpp Fri Mar 25 10:38:57 2011 -0700
@@ -443,7 +443,7 @@
} // namespace libpc
// Needed for C++ DLL exports
-#ifdef _MSC_VER
template class LIBPC_DLL libpc::Range<double>;
template class LIBPC_DLL libpc::Bounds<double>;
#endif
diff -r 689ad51ea693 -r cc6156bfe890 include/libpc/PointBufferCache.hpp
--- a/include/libpc/PointBufferCache.hpp Fri Mar 25 09:56:02 2011 -0700
+++ b/include/libpc/PointBufferCache.hpp Fri Mar 25 10:38:57 2011 -0700
@@ -25,7 +25,7 @@
#include <libpc/libpc.hpp>
-#ifdef _MSC_VER
#endif
@@ -33,7 +33,7 @@
#include <boost/bimap/list_of.hpp>
//#include <boost/bimap/set_of.hpp>
//#include <boost/function.hpp>
-#ifdef _MSC_VER
#endif
diff -r 689ad51ea693 -r cc6156bfe890 include/libpc/Stage.hpp
--- a/include/libpc/Stage.hpp Fri Mar 25 09:56:02 2011 -0700
+++ b/include/libpc/Stage.hpp Fri Mar 25 10:38:57 2011 -0700
@@ -67,9 +67,7 @@
const Header& getHeader() const;
Header& getHeader();
- virtual boost::uint8_t getIteratorSupport () const { return 0; }
- virtual libpc::Iterator* createIterator(StageIteratorType) const { return NULL; }
+ virtual bool supportsIterator (StageIteratorType) const { return false; }
virtual bool supportsSequentialIterator() const { return false; }
virtual bool supportsRandomIterator() const { return false; }
diff -r 689ad51ea693 -r cc6156bfe890 include/libpc/drivers/faux/Reader.hpp
--- a/include/libpc/drivers/faux/Reader.hpp Fri Mar 25 09:56:02 2011 -0700
+++ b/include/libpc/drivers/faux/Reader.hpp Fri Mar 25 10:38:57 2011 -0700
@@ -81,16 +81,14 @@
Mode getMode() const;
- boost::uint8_t getIteratorSupport ()
+ bool supportsIterator (StageIteratorType t)
- boost::uint8_t mask(0);
- mask |= StageIterator_Sequential;
- mask |= StageIterator_Random;
- return mask;
+ if (t == StageIterator_Sequential ) return true;
+ if (t == StageIterator_Random ) return true;
+ return false;
- libpc::Iterator* createIterator(StageIteratorType t) const;
bool supportsSequentialIterator() const { return true; }
bool supportsRandomIterator() const { return true; }
libpc::SequentialIterator* createSequentialIterator() const;
diff -r 689ad51ea693 -r cc6156bfe890 include/libpc/drivers/las/Reader.hpp
--- a/include/libpc/drivers/las/Reader.hpp Fri Mar 25 09:56:02 2011 -0700
+++ b/include/libpc/drivers/las/Reader.hpp Fri Mar 25 10:38:57 2011 -0700
@@ -60,16 +60,14 @@
const LasHeader& getLasHeader() const;
- boost::uint8_t getIteratorSupport () const
- return mask;
+ return false;
diff -r 689ad51ea693 -r cc6156bfe890 include/libpc/drivers/liblas/Reader.hpp
--- a/include/libpc/drivers/liblas/Reader.hpp Fri Mar 25 09:56:02 2011 -0700
+++ b/include/libpc/drivers/liblas/Reader.hpp Fri Mar 25 10:38:57 2011 -0700
@@ -72,16 +72,14 @@
bool hasColorData() const;
bool hasWaveData() const;
- return mask;
+ return false;
diff -r 689ad51ea693 -r cc6156bfe890 include/libpc/drivers/mrsid/Reader.hpp
--- a/include/libpc/drivers/mrsid/Reader.hpp Fri Mar 25 09:56:02 2011 -0700
+++ b/include/libpc/drivers/mrsid/Reader.hpp Fri Mar 25 10:38:57 2011 -0700
@@ -59,17 +59,15 @@
const std::string& getName() const;
void seekToPoint(boost::uint64_t pointNum);
- Iterator* createIterator(const Bounds<double>& bounds);
- // FIXME: make this represent what this reader actually supports!
- mask |= StageIterator_Block;
- return mask;
+ if (t == StageIterator_Block ) return true;
+ return false;
protected:
boost::uint32_t readBuffer(PointBuffer&);
diff -r 689ad51ea693 -r cc6156bfe890 include/libpc/drivers/oci/Common.hpp
--- a/include/libpc/drivers/oci/Common.hpp Fri Mar 25 09:56:02 2011 -0700
+++ b/include/libpc/drivers/oci/Common.hpp Fri Mar 25 10:38:57 2011 -0700
@@ -57,7 +57,7 @@
-#ifdef _WIN32
#define compare_no_case(a,b,n) _strnicmp( (a), (b), (n) )
#else
#define compare_no_case(a,b,n) strncasecmp( (a), (b), (n) )
diff -r 689ad51ea693 -r cc6156bfe890 include/libpc/drivers/oci/Reader.hpp
--- a/include/libpc/drivers/oci/Reader.hpp Fri Mar 25 09:56:02 2011 -0700
+++ b/include/libpc/drivers/oci/Reader.hpp Fri Mar 25 10:38:57 2011 -0700
@@ -60,17 +60,13 @@
- return mask;
+ return false;
More information about the Liblas-commits
