[Liblas-commits] hg-main-tree: refactor to remove duplicated code
liblas-commits at liblas.org
Fri Mar 25 14:14:04 EDT 2011
details: http://hg.libpc.orghg-main-tree/rev/e0605abd4e2b
changeset: 459:e0605abd4e2b
user: Michael P. Gerlek <mpg at flaxen.com>
date: Fri Mar 25 11:00:54 2011 -0700
description:
Subject: hg-main-tree: updated comments
details: http://hg.libpc.orghg-main-tree/rev/9182d7217fa6
changeset: 460:9182d7217fa6
date: Fri Mar 25 11:05:00 2011 -0700
description:
updated comments
Subject: hg-main-tree: refactor to remove duplicated code
details: http://hg.libpc.orghg-main-tree/rev/f0e1e2cef160
changeset: 461:f0e1e2cef160
date: Fri Mar 25 11:05:10 2011 -0700
description:
Subject: hg-main-tree: allow for 64b writes
details: http://hg.libpc.orghg-main-tree/rev/b86cf9014e60
changeset: 462:b86cf9014e60
date: Fri Mar 25 11:10:15 2011 -0700
description:
diffstat:
include/libpc/Iterator.hpp | 5 +++
include/libpc/Writer.hpp | 6 ++--
include/libpc/filters/CacheFilter.hpp | 13 +++++---
src/Iterator.cpp | 47 ++++++++++++++++++++++++++++++++
src/Writer.cpp | 16 ++++++----
src/drivers/las/Iterator.cpp | 12 +-------
src/filters/CropFilterIterator.cpp | 18 +-----------
src/filters/DecimationFilterIterator.cpp | 17 +----------
8 files changed, 76 insertions(+), 58 deletions(-)
diffs (255 lines):
diff -r cc6156bfe890 -r b86cf9014e60 include/libpc/Iterator.hpp
--- a/include/libpc/Iterator.hpp Fri Mar 25 10:38:57 2011 -0700
+++ b/include/libpc/Iterator.hpp Fri Mar 25 11:10:15 2011 -0700
@@ -78,6 +78,11 @@
protected:
virtual boost::uint32_t readImpl(PointBuffer&) = 0;
+ // This is provided as a sample implementation that some stages could use
+ // to implement their own skip or seek functions. It uses the read() call
+ // to advance "count" points forward, so it is not at all optimal.
+ boost::uint64_t naiveSkipImpl(boost::uint64_t count);
boost::uint64_t m_index;
private:
diff -r cc6156bfe890 -r b86cf9014e60 include/libpc/Writer.hpp
--- a/include/libpc/Writer.hpp Fri Mar 25 10:38:57 2011 -0700
+++ b/include/libpc/Writer.hpp Fri Mar 25 11:10:15 2011 -0700
@@ -62,7 +62,7 @@
// Read the given number of points (or less, if the reader runs out first),
// and then write them out to wherever. Returns total number of points
// actually written.
- boost::uint64_t write(std::size_t targetNumPointsToWrite);
+ boost::uint64_t write(boost::uint64_t targetNumPointsToWrite);
protected:
// this is called once before the loop with the writeBuffer calls
@@ -77,8 +77,8 @@
Stage& getPrevStage();
// these two are valid for use after writeBegin has been called
- std::size_t m_actualNumPointsWritten;
- std::size_t m_targetNumPointsToWrite;
+ boost::uint64_t m_actualNumPointsWritten;
+ boost::uint64_t m_targetNumPointsToWrite;
private:
Stage& m_prevStage;
diff -r cc6156bfe890 -r b86cf9014e60 include/libpc/filters/CacheFilter.hpp
--- a/include/libpc/filters/CacheFilter.hpp Fri Mar 25 10:38:57 2011 -0700
+++ b/include/libpc/filters/CacheFilter.hpp Fri Mar 25 11:10:15 2011 -0700
@@ -47,11 +47,14 @@
namespace filters {
-// This is just a very simple MRU filter -- future versions will be smarter.
-// This cache has the following constraints:
-// - only one block is cached
-// - read chunk sizes are assumed to be just 1 point
-// If more than one point is read, the cache is skipped.
+// This is just a very simple MRU cache filter. It has the following constraints:
+// - up to 'numBlocks' will be cached
+// - we cache blocks of points, of size 'blockSize'
+// - we only cache full blocks
+// - we only cache on 'blockSize' boundaries
+// - we only look into the cache if 1 point is being requested
class LIBPC_DLL CacheFilter : public Filter
public:
diff -r cc6156bfe890 -r b86cf9014e60 src/Iterator.cpp
--- a/src/Iterator.cpp Fri Mar 25 10:38:57 2011 -0700
+++ b/src/Iterator.cpp Fri Mar 25 11:10:15 2011 -0700
@@ -34,11 +34,24 @@
#include <libpc/Iterator.hpp>
+#include <algorithm> // for std::min/max
+#include <libpc/Stage.hpp>
+#include <libpc/Header.hpp>
+#include <libpc/PointBuffer.hpp>
namespace libpc
static boost::uint32_t s_defaultChunkSize = 1024;
+// Iterator
Iterator::Iterator(const Stage& stage)
: m_index(0)
, m_stage(stage)
@@ -88,7 +101,36 @@
+boost::uint64_t Iterator::naiveSkipImpl(boost::uint64_t count)
+ boost::uint64_t totalNumRead = 0;
+ // read (and discard) all the next 'count' points
+ // in case count is really big, we do this in blocks of size 'chunk'
+ while (count > 0)
+ const boost::uint64_t thisCount64 = std::min<boost::uint64_t>(getChunkSize(), count);
+ // getChunkSize is a uint32, so this cast is safe
+ const boost::uint32_t thisCount = static_cast<boost::uint32_t>(thisCount64);
+ PointBuffer junk(getStage().getHeader().getSchema(), thisCount);
+ const boost::uint32_t numRead = read(junk);
+ if (numRead == 0) break; // end of file or something
+ count -= numRead;
+ totalNumRead += numRead;
+ return totalNumRead;
+// SequentialIterator
SequentialIterator::SequentialIterator(const Stage& stage)
: Iterator(stage)
@@ -119,6 +161,11 @@
+// RandomIterator
RandomIterator::RandomIterator(const Stage& stage)
: Iterator(stage)
diff -r cc6156bfe890 -r b86cf9014e60 src/Writer.cpp
--- a/src/Writer.cpp Fri Mar 25 10:38:57 2011 -0700
+++ b/src/Writer.cpp Fri Mar 25 11:10:15 2011 -0700
@@ -75,7 +75,7 @@
-boost::uint64_t Writer::write(std::size_t targetNumPointsToWrite)
+boost::uint64_t Writer::write(boost::uint64_t targetNumPointsToWrite)
m_targetNumPointsToWrite = targetNumPointsToWrite;
m_actualNumPointsWritten = 0;
@@ -84,18 +84,22 @@
writeBegin();
+ // in case targetNumPointsToWrite is really big, we will process just one chunk at a time
while (m_actualNumPointsWritten < m_targetNumPointsToWrite)
- boost::uint64_t numRemainingPointsToRead = m_targetNumPointsToWrite - m_actualNumPointsWritten;
- boost::uint32_t numPointsToReadThisChunk = static_cast<boost::uint32_t>(std::min<boost::uint64_t>(numRemainingPointsToRead, m_chunkSize));
+ const boost::uint64_t numRemainingPointsToRead = m_targetNumPointsToWrite - m_actualNumPointsWritten;
+ const boost::uint64_t numPointsToReadThisChunk64 = std::min<boost::uint64_t>(numRemainingPointsToRead, m_chunkSize);
+ // this case is safe because m_chunkSize is a uint32
+ const boost::uint32_t numPointsToReadThisChunk = static_cast<boost::uint32_t>(numPointsToReadThisChunk64);
PointBuffer buffer(m_prevStage.getHeader().getSchema(), numPointsToReadThisChunk);
- boost::uint32_t numPointsReadThisChunk = iter->read(buffer);
+ const boost::uint32_t numPointsReadThisChunk = iter->read(buffer);
assert(numPointsReadThisChunk <= numPointsToReadThisChunk);
- boost::uint32_t numPointsWrittenThisChunk = writeBuffer(buffer);
+ const boost::uint32_t numPointsWrittenThisChunk = writeBuffer(buffer);
assert(numPointsWrittenThisChunk == numPointsReadThisChunk);
m_actualNumPointsWritten += numPointsWrittenThisChunk;
diff -r cc6156bfe890 -r b86cf9014e60 src/drivers/las/Iterator.cpp
--- a/src/drivers/las/Iterator.cpp Fri Mar 25 10:38:57 2011 -0700
+++ b/src/drivers/las/Iterator.cpp Fri Mar 25 11:10:15 2011 -0700
@@ -62,17 +62,7 @@
boost::uint64_t SequentialIterator::skipImpl(boost::uint64_t count)
- const LasReader& reader = m_reader;
- const Header& header = reader.getHeader();
- boost::uint32_t chunk = (boost::uint32_t)count; // BUG: this needs to be done in blocks if pointNum is large
- // BUG: we can move the stream a constant amount
- PointBuffer PointBuffer(header.getSchema(), chunk);
- read(PointBuffer);
- // just drop the points on the floor and return
- return count;
+ return naiveSkipImpl(count);
diff -r cc6156bfe890 -r b86cf9014e60 src/filters/CropFilterIterator.cpp
--- a/src/filters/CropFilterIterator.cpp Fri Mar 25 10:38:57 2011 -0700
+++ b/src/filters/CropFilterIterator.cpp Fri Mar 25 11:10:15 2011 -0700
@@ -51,23 +51,7 @@
boost::uint64_t CropFilterSequentialIterator::skipImpl(boost::uint64_t count)
- boost::uint64_t totalNumRead = 0;
- while (count > 0)
- const boost::uint32_t thisCount = (boost::uint32_t)std::min<boost::uint64_t>(getChunkSize(), count);
- PointBuffer junk(getStage().getHeader().getSchema(), thisCount);
- const boost::uint32_t numRead = read(junk);
- if (numRead == 0) break; // end of file
- count -= numRead;
- totalNumRead += numRead;
- return totalNumRead;
diff -r cc6156bfe890 -r b86cf9014e60 src/filters/DecimationFilterIterator.cpp
--- a/src/filters/DecimationFilterIterator.cpp Fri Mar 25 10:38:57 2011 -0700
+++ b/src/filters/DecimationFilterIterator.cpp Fri Mar 25 11:10:15 2011 -0700
@@ -51,22 +51,7 @@
boost::uint64_t DecimationFilterSequentialIterator::skipImpl(boost::uint64_t count)
- while (count > 0)
- count -= numRead;
More information about the Liblas-commits
