[Liblas-commits] hg-main-tree: applyScaling should be a no-op in
the case where t...
liblas-commits at liblas.org
Fri May 6 16:42:34 EDT 2011
details: http://hg.libpc.orghg-main-tree/rev/232f34c0361b
changeset: 703:232f34c0361b
user: Howard Butler <hobu.inc at gmail.com>
date: Fri May 06 15:14:42 2011 -0500
description:
applyScaling should be a no-op in the case where the m_numericScale is 0.0
Subject: hg-main-tree: fix up copyright
details: http://hg.libpc.orghg-main-tree/rev/969559e617d4
changeset: 704:969559e617d4
date: Fri May 06 15:42:05 2011 -0500
description:
fix up copyright
Subject: hg-main-tree: add functional QFIT reader with some tests and example files
details: http://hg.libpc.orghg-main-tree/rev/07bb72893e39
changeset: 705:07bb72893e39
date: Fri May 06 15:42:22 2011 -0500
description:
diffstat:
include/libpc/Dimension.hpp | 7 +-
include/libpc/drivers/qfit/Iterator.hpp | 80 ++++++++++++
include/libpc/drivers/qfit/Reader.hpp | 42 ++++++-
src/CMakeLists.txt | 2 +
src/drivers/oci/Iterator.cpp | 2 +-
src/drivers/qfit/Iterator.cpp | 118 +++++++++++++++++++
src/drivers/qfit/Reader.cpp | 198 ++++++++++++++++++++++++++++++-
test/data/qfit/10-word.qi | 0
test/data/qfit/14-word.qi | 0
test/unit/QFITReaderTest.cpp | 96 ++++++++++++++-
10 files changed, 520 insertions(+), 25 deletions(-)
diffs (truncated from 739 to 300 lines):
diff -r 3114d8b05ac7 -r 07bb72893e39 include/libpc/Dimension.hpp
--- a/include/libpc/Dimension.hpp Fri May 06 10:59:44 2011 -0500
+++ b/include/libpc/Dimension.hpp Fri May 06 15:42:22 2011 -0500
@@ -239,7 +239,12 @@
template<class T>
double applyScaling(T v) const
- return (double)v * m_numericScale + m_numericOffset;
+ if ( !Utils::compare_approx(m_numericScale, 0.0, (std::numeric_limits<double>::min)()))
+ return (double)v * m_numericScale + m_numericOffset;
+ else
+ return v;
template<class T>
diff -r 3114d8b05ac7 -r 07bb72893e39 include/libpc/drivers/qfit/Iterator.hpp
--- /dev/null Thu Jan 01 00:00:00 1970 +0000
+++ b/include/libpc/drivers/qfit/Iterator.hpp Fri May 06 15:42:22 2011 -0500
@@ -0,0 +1,80 @@
+* Copyright (c) 2011, Howard Butler, hobu.inc at gmail.com
+* All rights reserved.
+* Redistribution and use in source and binary forms, with or without
+* modification, are permitted provided that the following
+* conditions are met:
+* * Redistributions of source code must retain the above copyright
+* notice, this list of conditions and the following disclaimer.
+* * Redistributions in binary form must reproduce the above copyright
+* notice, this list of conditions and the following disclaimer in
+* the documentation and/or other materials provided
+* with the distribution.
+* * Neither the name of Hobu, Inc. or Flaxen Geo Consulting nor the
+* names of its contributors may be used to endorse or promote
+* products derived from this software without specific prior
+* written permission.
+* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
+* "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
+* LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS
+* FOR A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE
+* COPYRIGHT OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT,
+* INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING,
+* BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS
+* OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED
+* AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY,
+* OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT
+* OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY
+* OF SUCH DAMAGE.
+#ifndef INCLUDED_DRIVERS_QFIT_ITERATOR_HPP
+#define INCLUDED_DRIVERS_QFIT_ITERATOR_HPP
+#include <libpc/libpc.hpp>
+#include <libpc/Iterator.hpp>
+#include <iosfwd>
+namespace libpc { namespace drivers { namespace qfit {
+class Reader;
+class SequentialIterator : public libpc::SequentialIterator
+public:
+ SequentialIterator(const Reader& reader);
+ ~SequentialIterator();
+private:
+ boost::uint64_t skipImpl(boost::uint64_t);
+ boost::uint32_t readImpl(PointBuffer&);
+ bool atEndImpl() const;
+ const Reader& m_reader;
+ std::istream* m_istream;
+class RandomIterator : public libpc::RandomIterator
+public:
+ RandomIterator(const Reader& reader);
+ ~RandomIterator();
+private:
+ boost::uint64_t seekImpl(boost::uint64_t);
+} } } // namespaces
+#endif
diff -r 3114d8b05ac7 -r 07bb72893e39 include/libpc/drivers/qfit/Reader.hpp
--- a/include/libpc/drivers/qfit/Reader.hpp Fri May 06 10:59:44 2011 -0500
+++ b/include/libpc/drivers/qfit/Reader.hpp Fri May 06 15:42:22 2011 -0500
@@ -38,14 +38,13 @@
#include <libpc/Stage.hpp>
+#include <libpc/Options.hpp>
#include <libpc/SchemaLayout.hpp>
#include <libpc/exceptions.hpp>
-#include <boost/scoped_ptr.hpp>
-#include <boost/scoped_array.hpp>
#include <vector>
@@ -93,6 +92,31 @@
+class PointIndexes
+public:
+ PointIndexes(const Schema& schema, QFIT_Format_Type format);
+ int Time;
+ int X;
+ int Y;
+ int Z;
+ int StartPulse;
+ int ReflectedPulse;
+ int ScanAngleRank;
+ int Pitch;
+ int Roll;
+ int PDOP;
+ int PulseWidth;
+ int GPSTime;
+ int PassiveSignal;
+ int PassiveX;
+ int PassiveY;
+ int PassiveZ;
class LIBPC_DLL Reader : public libpc::Stage
@@ -102,19 +126,31 @@
const std::string& getDescription() const;
const std::string& getName() const;
+ std::string getFileName() const;
bool supportsIterator (StageIteratorType t) const
if (t == StageIterator_Sequential ) return true;
+ if (t == StageIterator_Random ) return true;
return false;
boost::uint64_t getNumPoints() { return 0; }
libpc::SequentialIterator* createSequentialIterator() const;
+ libpc::RandomIterator* createRandomIterator() const;
Options& getOptions() const { return m_options; }
+ std::size_t getPointDataOffset() const { return m_offset; }
+ boost::uint32_t getPointDataSize() const { return m_size; }
+ // this is called by the stage's iterator
+ boost::uint32_t processBuffer(PointBuffer& PointBuffer, std::istream& stream, boost::uint64_t numPointsLeft) const;
protected:
inline QFIT_Format_Type getFormat() const { return m_format; }
@@ -125,6 +161,8 @@
Options& m_options;
QFIT_Format_Type m_format;
+ std::size_t m_offset;
+ boost::uint32_t m_size;
void registerFields();
diff -r 3114d8b05ac7 -r 07bb72893e39 src/CMakeLists.txt
--- a/src/CMakeLists.txt Fri May 06 10:59:44 2011 -0500
+++ b/src/CMakeLists.txt Fri May 06 15:42:22 2011 -0500
@@ -232,10 +232,12 @@
# drivers/qfit
set(LIBPC_DRIVERS_QFIT_HPP
+ ${LIBPC_HEADERS_DIR}/drivers/qfit/Iterator.hpp
${LIBPC_HEADERS_DIR}/drivers/qfit/Reader.hpp
set (LIBPC_DRIVERS_QFIT_CPP
+ ./drivers/qfit/Iterator.cpp
./drivers/qfit/Reader.cpp
diff -r 3114d8b05ac7 -r 07bb72893e39 src/drivers/oci/Iterator.cpp
--- a/src/drivers/oci/Iterator.cpp Fri May 06 10:59:44 2011 -0500
+++ b/src/drivers/oci/Iterator.cpp Fri May 06 15:42:22 2011 -0500
@@ -1,5 +1,5 @@
-* Copyright (c) 2011, Michael P. Gerlek (mpg at flaxen.com)
diff -r 3114d8b05ac7 -r 07bb72893e39 src/drivers/qfit/Iterator.cpp
+++ b/src/drivers/qfit/Iterator.cpp Fri May 06 15:42:22 2011 -0500
@@ -0,0 +1,118 @@
+* OF SUCH DAMAGE.
+#include <libpc/drivers/qfit/Iterator.hpp>
+#include <libpc/drivers/qfit/Reader.hpp>
+#include <libpc/exceptions.hpp>
+#include <libpc/Utils.hpp>
+#include <libpc/PointBuffer.hpp>
+#include <iostream>
+SequentialIterator::SequentialIterator(const qfit::Reader& reader)
+ : libpc::SequentialIterator(reader)
+ , m_reader(reader)
+ , m_istream(NULL)
+ m_istream = Utils::openFile(m_reader.getFileName());
+ m_istream->seekg(m_reader.getPointDataOffset());
+ return;
+SequentialIterator::~SequentialIterator()
+ Utils::closeFile(m_istream);
+ return;
+boost::uint64_t SequentialIterator::skipImpl(boost::uint64_t count)
+ m_istream->seekg( m_reader.getPointDataSize() * count, std::ios::cur);
+ return count;
+bool SequentialIterator::atEndImpl() const
+ return getIndex() >= getStage().getNumPoints();
More information about the Liblas-commits
