[Liblas-commits] laszip: allows variable-sized chunking with
explicit zipper.chun...
liblas-commits at liblas.org
Mon May 9 16:02:10 EDT 2011
details: http://hg.liblas.orglaszip/rev/89966fbc7885
changeset: 224:89966fbc7885
user: isenburg
date: Mon May 09 13:03:25 2011 -0700
description:
allows variable-sized chunking with explicit zipper.chunk() call when chunk_size == 0
Subject: laszip: allows variable-sized chunking with explicit zipper.chunk() call when chunk_size == 0
details: http://hg.liblas.orglaszip/rev/18dca0c2b4cc
changeset: 225:18dca0c2b4cc
user: isenburg
date: Mon May 09 13:04:25 2011 -0700
description:
diffstat:
include/laszip/laszip.hpp | 6 ++-
include/laszip/laszipper.hpp | 4 ++-
src/lasreadpoint.cpp | 61 ++++++++++++++++++++++++++++++++++++++-----
src/lasreadpoint.hpp | 4 ++
src/laswritepoint.cpp | 31 ++++++++++++++++++++-
src/laswritepoint.hpp | 3 ++
src/laszipper.cpp | 5 +++
7 files changed, 101 insertions(+), 13 deletions(-)
diffs (truncated from 341 to 300 lines):
diff -r 3fc5cbb8490e -r 18dca0c2b4cc include/laszip/laszip.hpp
--- a/include/laszip/laszip.hpp Fri May 06 05:53:12 2011 -0700
+++ b/include/laszip/laszip.hpp Mon May 09 13:04:25 2011 -0700
@@ -14,7 +14,7 @@
COPYRIGHT:
- (c) 2010-2011, Martin Isenburg, LASSO - tools to catch reality
+ (c) 2007-2011, Martin Isenburg, LASSO - tools to catch reality
This is free software; you can redistribute and/or modify it under the
terms of the GNU Lesser General Licence as published by the Free Software
@@ -25,7 +25,9 @@
CHANGE HISTORY:
- 20 March 2011 -- incrementing LASZIP_VERSION to 2.0 for improved compression
+ 8 May 2011 -- added an option for variable chunking via chunk()
+ 23 April 2011 -- changed interface for simplicity and chunking support
+ 20 March 2011 -- incrementing LASZIP_VERSION to 1.2 for improved compression
10 January 2011 -- licensing change for LGPL release and liblas integration
12 December 2010 -- refactored from lasdefinitions after movies with silke
diff -r 3fc5cbb8490e -r 18dca0c2b4cc include/laszip/laszipper.hpp
--- a/include/laszip/laszipper.hpp Fri May 06 05:53:12 2011 -0700
+++ b/include/laszip/laszipper.hpp Mon May 09 13:04:25 2011 -0700
@@ -24,7 +24,8 @@
CHANGE HISTORY:
- 23 April 2011 -- changed interface for easier future compressor support
12 December 2010 -- created from LASwriter/LASreader after Howard got pushy (-;
@@ -55,6 +56,7 @@
unsigned int open(FILE* outfile);
unsigned int open(ostream& outstream);
bool write(const unsigned char* const * point);
+ bool chunk();
unsigned int close();
LASzipper();
diff -r 3fc5cbb8490e -r 18dca0c2b4cc src/lasreadpoint.cpp
--- a/src/lasreadpoint.cpp Fri May 06 05:53:12 2011 -0700
+++ b/src/lasreadpoint.cpp Mon May 09 13:04:25 2011 -0700
@@ -50,7 +50,9 @@
// used for chunking
chunk_size = U32_MAX;
chunk_count = 0;
+ current_chunk = 0;
number_chunks = 0;
+ chunk_totals = 0;
chunk_starts = 0;
// used for seeking
seek_point = 0;
@@ -85,6 +87,9 @@
readers = 0;
num_readers = num_items;
+ // disable chunking
+ chunk_size = U32_MAX;
// always create the raw readers
readers_raw = new LASreadItem*[num_readers];
for (i = 0; i < num_readers; i++)
@@ -186,7 +191,7 @@
if (laszip->compressor == LASZIP_COMPRESSOR_POINTWISE_CHUNKED)
- chunk_size = laszip->chunk_size;
+ if (laszip->chunk_size) chunk_size = laszip->chunk_size;
number_chunks = U32_MAX;
@@ -198,12 +203,14 @@
if (!instream) return FALSE;
this->instream = instream;
+ // if chunking is enabled
if (number_chunks == U32_MAX)
if (!read_chunk_table())
return FALSE;
point_start = instream->position();
@@ -232,17 +239,27 @@
U32 delta = 0;
if (dec)
- if (number_chunks)
+ if (chunk_starts)
- U32 current_chunk = current/chunk_size;
- U32 target_chunk = target/chunk_size;
+ U32 target_chunk;
+ if (chunk_totals)
+ target_chunk = search_chunk_table(target, 0, number_chunks);
+ chunk_size = chunk_totals[target_chunk+1]-chunk_totals[target_chunk];
+ delta = target - chunk_totals[target_chunk];
+ else
+ target_chunk = target/chunk_size;
+ delta = target%chunk_size;
if (current_chunk != target_chunk || current > target)
dec->done();
- instream->seek(chunk_starts[target_chunk]);
+ current_chunk = target_chunk;
+ instream->seek(chunk_starts[current_chunk]);
init(instream);
chunk_count = 0;
- delta = target%chunk_size;
else
@@ -282,6 +299,11 @@
if (chunk_count == chunk_size)
+ current_chunk++;
+ if (chunk_totals)
+ chunk_size = chunk_totals[current_chunk+1]-chunk_totals[current_chunk];
dec->done();
init(instream);
chunk_count = 0;
@@ -353,12 +375,25 @@
return FALSE;
+ if (chunk_totals) delete [] chunk_totals;
+ chunk_totals = 0;
if (chunk_starts) delete [] chunk_starts;
- chunk_starts = new long[number_chunks];
+ chunk_starts = 0;
+ if (chunk_size == U32_MAX) chunk_totals = new U32[number_chunks+1];
+ chunk_starts = new long[number_chunks+1];
+ if (chunk_size == U32_MAX) chunk_totals[0] = 0;
chunk_starts[0] = chunks_start;
U32 i;
- for (i = 1; i < number_chunks; i++)
+ for (i = 1; i <= number_chunks; i++)
+ if (!instream->get32bitsLE((U8*)&chunk_totals[i]))
+ return FALSE;
+ chunk_totals[i] += chunk_totals[i-1];
if (!instream->get32bitsLE((U8*)&chunk_starts[i]))
return FALSE;
@@ -369,6 +404,16 @@
return TRUE;
+U32 LASreadPoint::search_chunk_table(const U32 index, const U32 lower, const U32 upper)
+ if (lower + 1 == upper) return lower;
+ U32 mid = (lower+upper)/2;
+ if (index >= chunk_totals[mid])
+ return search_chunk_table(index, mid, upper);
+ else
+ return search_chunk_table(index, lower, mid);
LASreadPoint::~LASreadPoint()
U32 i;
diff -r 3fc5cbb8490e -r 18dca0c2b4cc src/lasreadpoint.hpp
--- a/src/lasreadpoint.hpp Fri May 06 05:53:12 2011 -0700
+++ b/src/lasreadpoint.hpp Mon May 09 13:04:25 2011 -0700
@@ -24,6 +24,7 @@
CHANGE HISTORY:
+ 25 April 2011 -- added chunked laszip for random access decompression
7 December 2010 -- adapted from LASpointReader for better code modularity
3 December 2010 -- updated to (somewhat) support LAS format 1.3
@@ -66,9 +67,12 @@
U32 chunk_size;
U32 chunk_count;
+ U32 current_chunk;
U32 number_chunks;
long* chunk_starts;
+ U32* chunk_totals;
BOOL read_chunk_table();
+ U32 search_chunk_table(const U32 index, const U32 lower, const U32 upper);
// used for seeking
U32 point_start;
U32 point_size;
diff -r 3fc5cbb8490e -r 18dca0c2b4cc src/laswritepoint.cpp
--- a/src/laswritepoint.cpp Fri May 06 05:53:12 2011 -0700
+++ b/src/laswritepoint.cpp Mon May 09 13:04:25 2011 -0700
@@ -52,8 +52,10 @@
chunk_count = 0;
number_chunks = 0;
alloced_chunks = 0;
+ chunk_sizes = 0;
chunk_bytes = 0;
chunk_table_start_position = 0;
+ chunk_start_position = 0;
BOOL LASwritePoint::setup(const U32 num_items, const LASitem* items, LASzip* laszip)
@@ -195,7 +197,7 @@
chunk_count = 0;
@@ -208,6 +210,7 @@
if (!outstream) return FALSE;
this->outstream = outstream;
number_chunks = 0;
@@ -273,13 +276,26 @@
return TRUE;
+BOOL LASwritePoint::chunk()
+ if (chunk_start_position == 0 || chunk_size != U32_MAX)
+ return FALSE;
+ enc->done();
+ add_chunk_to_table();
+ init(outstream);
+ chunk_count = 0;
+ return TRUE;
BOOL LASwritePoint::done()
if (writers == writers_compressed)
enc->done();
- if (chunk_size != U32_MAX)
+ if (chunk_start_position)
if (chunk_count) add_chunk_to_table();
return write_chunk_table();
@@ -295,16 +311,20 @@
if (chunk_bytes == 0)
alloced_chunks = 1024;
+ if (chunk_size == U32_MAX) chunk_sizes = (U32*)malloc(sizeof(U32)*alloced_chunks);
chunk_bytes = (U32*)malloc(sizeof(U32)*alloced_chunks);
else
alloced_chunks *= 2;
+ if (chunk_size == U32_MAX) chunk_sizes = (U32*)realloc(chunk_sizes, sizeof(U32)*alloced_chunks);
chunk_bytes = (U32*)realloc(chunk_bytes, sizeof(U32)*alloced_chunks);
+ if (chunk_size == U32_MAX && chunk_sizes == 0) return FALSE;
if (chunk_bytes == 0) return FALSE;
I64 position = outstream->position();
+ if (chunk_size == U32_MAX) chunk_sizes[number_chunks] = chunk_count;
chunk_bytes[number_chunks] = (U32)(position - chunk_start_position);
chunk_start_position = position;
number_chunks++;
@@ -336,6 +356,13 @@
for (i = 0; i < number_chunks; i++)
+ if (!outstream->put32bitsLE((U8*)&chunk_sizes[i]))
+ return FALSE;
if (!outstream->put32bitsLE((U8*)&chunk_bytes[i]))
return FALSE;
diff -r 3fc5cbb8490e -r 18dca0c2b4cc src/laswritepoint.hpp
More information about the Liblas-commits
