[Liblas-commits] laszip: fixed a memory little bug
liblas-commits at liblas.org
Tue May 10 10:33:03 EDT 2011
details: http://hg.liblas.orglaszip/rev/30637be5215b
changeset: 231:30637be5215b
user: isenburg
date: Tue May 10 07:34:02 2011 -0700
description:
Subject: laszip: added a test for seeking
details: http://hg.liblas.orglaszip/rev/8bd0e8d832dc
changeset: 232:8bd0e8d832dc
user: isenburg
date: Tue May 10 07:35:16 2011 -0700
description:
diffstat:
src/lasreadpoint.cpp | 2 +-
tools/laszippertest.cpp | 167 +++++++++++++++++++++++++++++++++++++++++++++--
2 files changed, 159 insertions(+), 10 deletions(-)
diffs (237 lines):
diff -r 4691ad3179a3 -r 8bd0e8d832dc src/lasreadpoint.cpp
--- a/src/lasreadpoint.cpp Tue May 10 05:01:55 2011 -0700
+++ b/src/lasreadpoint.cpp Tue May 10 07:35:16 2011 -0700
@@ -194,7 +194,7 @@
default:
return FALSE;
- if (i) seek_point[i] = seek_point[i-1]+items[i].size;
+ if (i) seek_point[i] = seek_point[i-1]+items[i-1].size;
if (laszip->compressor == LASZIP_COMPRESSOR_POINTWISE_CHUNKED)
diff -r 4691ad3179a3 -r 8bd0e8d832dc tools/laszippertest.cpp
--- a/tools/laszippertest.cpp Tue May 10 05:01:55 2011 -0700
+++ b/tools/laszippertest.cpp Tue May 10 07:35:16 2011 -0700
@@ -308,7 +308,7 @@
static void write_points(LASzipper* zipper, PointData& data)
- if (zipper==NULL) // range coder test
+ if (zipper==NULL)
return;
double start_time, end_time;
@@ -362,7 +362,7 @@
static void read_points(LASunzipper* unzipper, PointData& data)
- if (unzipper==NULL) // range coder test
+ if (unzipper==NULL)
return;
unsigned char c;
@@ -433,7 +433,148 @@
-static void run_test(const char* filename, PointData& data, unsigned short compressor, unsigned short requested_version=0, int chunk_size=-1)
+static void write_points_seek(LASzipper* zipper, PointData& data)
+ if (zipper==NULL)
+ return;
+ double start_time, end_time;
+ unsigned char c;
+ unsigned int i,j;
+ unsigned int num_bytes;
+ start_time = taketime();
+ // the two branches of this IF are the same, except for the use of a random number;
+ // we keep the random case separate, so that we can get fastest timing tests w/o random data
+ if (settings->use_random)
+ for (i = 0; i < settings->num_points; i++)
+ srand(i);
+ c = rand() % 256;
+ for (j = 0; j < data.point_size; j++)
+ data.point_data[j] = c;
+ c = rand() % 256;
+ zipper->write(data.point);
+ num_bytes = zipper->close();
+ else
+ c = (unsigned char)i;
+ c++;
+ end_time = taketime();
+ log("laszipper wrote %u bytes in %g seconds\n", num_bytes, end_time-start_time);
+ return;
+static void read_points_seek(LASunzipper* unzipper, PointData& data)
+ return;
+ unsigned char c;
+ unsigned int i,j;
+ unsigned int num_errors, num_bytes;
+ num_errors = 0;
+ if (i%1000 == 0)
+ int s = (rand()*rand())%settings->num_points;
+ fprintf(stderr, "at position %d seeking to %d\n", i, s);
+ unzipper->seek(s);
+ i = s;
+ unzipper->read(data.point);
+ srand(i);
+ c = rand() % 256;
+ if (data.point_data[j] != c)
+ log("%d %d %d != %d\n", i, j, data.point_data[j], c);
+ num_errors++;
+ if (num_errors > 20) break;
+ c = rand() % 256;
+ num_bytes = unzipper->close();
+ else
+ if (i%1000 == 0)
+ i = s;
+ num_errors++;
+ c++;
+ if (num_errors)
+ log("ERROR: with lasunzipper %d\n", num_errors);
+ getc(stdin);
+ else
+ log("SUCCESS: lasunzipper read %u bytes in %g seconds\n", num_bytes, end_time-start_time);
+ return;
+static void run_test(const char* filename, PointData& data, unsigned short compressor, unsigned short requested_version=0, int chunk_size=-1, bool random_seeks=false)
// COMPRESSION
@@ -460,7 +601,10 @@
data.setup(laszip.num_items, laszip.items);
// writing the points
- write_points(laszipper, data);
+ if (random_seeks)
+ write_points_seek(laszipper, data);
+ else
+ write_points(laszipper, data);
// cleaning up
delete laszipper;
@@ -484,7 +628,10 @@
data.setup(laszip_dec.num_items, laszip_dec.items);
// reading the points
- read_points(lasunzipper, data);
+ if (random_seeks)
+ read_points_seek(lasunzipper, data);
+ else
+ read_points(lasunzipper, data);
// cleaning up
delete lasunzipper;
@@ -492,10 +639,9 @@
return;
int main(int argc, char *argv[])
unsigned int num_points = 100000;
@@ -560,12 +706,15 @@
settings->seed = (unsigned int)time(NULL);
log("Seed: %u\n", settings->seed);
run_test("test1.lax", data, LASZIP_COMPRESSOR_NONE);
run_test("test2.lax", data, LASZIP_COMPRESSOR_DEFAULT);
run_test("test3.lax", data, LASZIP_COMPRESSOR_DEFAULT, 2);
run_test("test4.lax", data, LASZIP_COMPRESSOR_CHUNKED);
run_test("test5.lax", data, LASZIP_COMPRESSOR_CHUNKED, 2);
+ run_test("test0.lax", data, LASZIP_COMPRESSOR_CHUNKED, 1, -1, true);
log("Finished %u runs\n\n", run);
++run;
} while (run_forever);
More information about the Liblas-commits
