[Liblas-commits] hg-main-tree: add Field_Alpha. Calls to
setNumericScale that are...
liblas-commits at liblas.org
Wed May 11 11:50:09 EDT 2011
details: http://hg.libpc.orghg-main-tree/rev/973ca0f83b2e
changeset: 706:973ca0f83b2e
user: Howard Butler <hobu.inc at gmail.com>
date: Wed May 11 10:49:20 2011 -0500
description:
add Field_Alpha. Calls to setNumericScale that are not 0.0 imply the dimension is fixed precision
Subject: hg-main-tree: add Field_Alpha name
details: http://hg.libpc.orghg-main-tree/rev/79e38c1ca368
changeset: 707:79e38c1ca368
date: Wed May 11 10:49:38 2011 -0500
description:
Subject: hg-main-tree: add a (not yet working) TerraSolid reader
details: http://hg.libpc.orghg-main-tree/rev/e8f2efe44b86
changeset: 708:e8f2efe44b86
date: Wed May 11 10:49:55 2011 -0500
description:
diffstat:
include/libpc/Dimension.hpp | 8 +
include/libpc/drivers/terrasolid/Iterator.hpp | 80 ++++
include/libpc/drivers/terrasolid/Reader.hpp | 187 ++++++++++
src/CMakeLists.txt | 20 +
src/Dimension.cpp | 1 +
src/drivers/terrasolid/Iterator.cpp | 118 ++++++
src/drivers/terrasolid/Reader.cpp | 471 ++++++++++++++++++++++++++
test/unit/CMakeLists.txt | 1 +
test/unit/TerraSolidTest.cpp | 159 ++++++++
9 files changed, 1045 insertions(+), 0 deletions(-)
diffs (truncated from 1112 to 300 lines):
diff -r 07bb72893e39 -r e8f2efe44b86 include/libpc/Dimension.hpp
--- a/include/libpc/Dimension.hpp Fri May 06 15:42:22 2011 -0500
+++ b/include/libpc/Dimension.hpp Wed May 11 10:49:55 2011 -0500
@@ -85,6 +85,7 @@
Field_WaveformXt,
Field_WaveformYt,
Field_WaveformZt,
+ Field_Alpha,
// add more here
@@ -219,6 +220,13 @@
inline void setNumericScale(double v)
+ // If you set a scale that isn't 0, you just made the dimension
+ // finite precision by default.
+ if ( !Utils::compare_approx(v, 0.0, (std::numeric_limits<double>::min)()))
+ m_precise = true;
m_numericScale = v;
diff -r 07bb72893e39 -r e8f2efe44b86 include/libpc/drivers/terrasolid/Iterator.hpp
--- /dev/null Thu Jan 01 00:00:00 1970 +0000
+++ b/include/libpc/drivers/terrasolid/Iterator.hpp Wed May 11 10:49:55 2011 -0500
@@ -0,0 +1,80 @@
+* Copyright (c) 2011, Howard Butler, hobu.inc at gmail.com
+* All rights reserved.
+* Redistribution and use in source and binary forms, with or without
+* modification, are permitted provided that the following
+* conditions are met:
+* * Redistributions of source code must retain the above copyright
+* notice, this list of conditions and the following disclaimer.
+* * Redistributions in binary form must reproduce the above copyright
+* notice, this list of conditions and the following disclaimer in
+* the documentation and/or other materials provided
+* with the distribution.
+* * Neither the name of Hobu, Inc. or Flaxen Geo Consulting nor the
+* names of its contributors may be used to endorse or promote
+* products derived from this software without specific prior
+* written permission.
+* THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
+* "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
+* LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS
+* FOR A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE
+* COPYRIGHT OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT,
+* INCIDENTAL, SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING,
+* BUT NOT LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS
+* OF USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED
+* AND ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY,
+* OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT
+* OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY
+* OF SUCH DAMAGE.
+#ifndef INCLUDED_DRIVERS_QFIT_ITERATOR_HPP
+#define INCLUDED_DRIVERS_QFIT_ITERATOR_HPP
+#include <libpc/libpc.hpp>
+#include <libpc/Iterator.hpp>
+#include <iosfwd>
+namespace libpc { namespace drivers { namespace terrasolid {
+class Reader;
+class SequentialIterator : public libpc::SequentialIterator
+public:
+ SequentialIterator(const Reader& reader);
+ ~SequentialIterator();
+private:
+ boost::uint64_t skipImpl(boost::uint64_t);
+ boost::uint32_t readImpl(PointBuffer&);
+ bool atEndImpl() const;
+ const Reader& m_reader;
+ std::istream* m_istream;
+class RandomIterator : public libpc::RandomIterator
+public:
+ RandomIterator(const Reader& reader);
+ ~RandomIterator();
+private:
+ boost::uint64_t seekImpl(boost::uint64_t);
+} } } // namespaces
+#endif
diff -r 07bb72893e39 -r e8f2efe44b86 include/libpc/drivers/terrasolid/Reader.hpp
+++ b/include/libpc/drivers/terrasolid/Reader.hpp Wed May 11 10:49:55 2011 -0500
@@ -0,0 +1,187 @@
+* OF SUCH DAMAGE.
+#ifndef INCLUDED_LIBPC_DRIVER_TERRASOLID_READER_HPP
+#define INCLUDED_LIBPC_DRIVER_TERRASOLID_READER_HPP
+#include <libpc/Stage.hpp>
+#include <libpc/Options.hpp>
+#include <libpc/SchemaLayout.hpp>
+#include <libpc/exceptions.hpp>
+#include <vector>
+#include <boost/detail/endian.hpp>
+#include <boost/scoped_ptr.hpp>
+enum TERRASOLID_Format_Type
+TERRASOLID_Format_1 = 20010712,
+TERRASOLID_Format_2 = 20020715,
+TERRASOLID_Format_Unknown = 999999999
+struct TerraSolidHeader
+ TerraSolidHeader() :
+ HdrSize(0),
+ HdrVersion(0),
+ RecogVal(0),
+ PntCnt(0),
+ Units(0),
+ OrgX(0),
+ OrgY(0),
+ OrgZ(0),
+ Time(0),
+ Color(0)
+ boost::int32_t HdrSize;
+ boost::int32_t HdrVersion;
+ boost::int32_t RecogVal;
+ char RecogStr[4];
+ boost::int32_t PntCnt;
+ boost::int32_t Units;
+ double OrgX;
+ double OrgY;
+ double OrgZ;
+ boost::int32_t Time;
+ boost::int32_t Color;
+typedef boost::scoped_ptr<TerraSolidHeader> TerraSolidHeaderPtr ;
+class terrasolid_error : public libpc_error
+public:
+ terrasolid_error(std::string const& msg)
+ : libpc_error(msg)
+class PointIndexes
+public:
+ PointIndexes(const Schema& schema, TERRASOLID_Format_Type format);
+ int Time;
+ int X;
+ int Y;
+ int Z;
+ int Classification;
+ int PointSourceId;
+ int EchoInt;
+ int ReturnNumber;
+ int Intensity;
+ int Mark;
+ int Flag;
+ int Red;
+ int Green;
+ int Blue;
+ int Alpha;
+class LIBPC_DLL Reader : public libpc::Stage
+public:
+ Reader(Options& options);
+ ~Reader();
+ const std::string& getDescription() const;
+ const std::string& getName() const;
+ std::string getFileName() const;
+ bool supportsIterator (StageIteratorType t) const
+ if (t == StageIterator_Sequential ) return true;
+ if (t == StageIterator_Random ) return true;
+ return false;
+ boost::uint64_t getNumPoints() { return 0; }
+ libpc::SequentialIterator* createSequentialIterator() const;
+ libpc::RandomIterator* createRandomIterator() const;
+ Options& getOptions() const { return m_options; }
+ std::size_t getPointDataOffset() const { return m_offset; }
+ boost::uint32_t getPointDataSize() const { return m_size; }
+ // this is called by the stage's iterator
+ boost::uint32_t processBuffer(PointBuffer& PointBuffer, std::istream& stream, boost::uint64_t numPointsLeft) const;
+protected:
+ inline TERRASOLID_Format_Type getFormat() const { return m_format; }
+private:
+ Reader& operator=(const Reader&); // not implemented
+ Reader(const Reader&); // not implemented
+ Options& m_options;
+ TerraSolidHeaderPtr m_header;
+ TERRASOLID_Format_Type m_format;
+ std::size_t m_offset;
+ boost::uint32_t m_size;
+ bool m_haveColor;
+ bool m_haveTime;
+ void registerFields();
+}}} // namespace libpc::driver::oci
+#endif // INCLUDED_LIBPC_DRIVER_OCI_READER_HPP
More information about the Liblas-commits
